Old 4th April 2020, 16:36   #6961  |  Link
Zetti
MKVToolNix v45.0.0 is released.
Old 7th April 2020, 15:28   #6962  |  Link
Barough
Barough's Avatar
Originally Posted by Morku View Post
"The file you requested has been blocked for a violation of our Terms of Service."
Yeah, MediaFire hates files named "Xvid"-something, automatically assumes illegal moviez in it.
The archive have been cleared by Mediafire now.
Old 11th April 2020, 13:30   #6963  |  Link
Zetti
x264 r3000 is released.
Old 13th April 2020, 20:39   #6964  |  Link
magnetite
I've noticed that although you can select a folder to encode, MeGUI doesn't support recursive folder selection.
magnetite is offline   Reply With Quote
Old 13th April 2020, 21:28   #6965  |  Link
stax76
Does it maybe support drag & drop? In that case you can use the search feature of Windows File Explorer.
Old 14th April 2020, 17:57   #6966  |  Link
magnetite
An error pops up which says these files or folders cannot be used in OneClick mode when dragging and dropping.
Using Explorer's search function does work, but for some reason it's unbearably slow. Maybe that's due to the files being stored on my NAS?
Old 18th April 2020, 12:33   #6967  |  Link
kalehrl
Can somebody update Xvid?
kalehrl is offline   Reply With Quote
Old 26th April 2020, 11:49   #6968  |  Link
Devilman1
Bug in audio encoding,
when you choose VBR and aac MeGUI put a "," instead of a "." in the value for example 1,6 instead of 1.6 and so it stops with an error.
Devilman1 is offline   Reply With Quote
Old 27th April 2020, 07:39   #6969  |  Link
That looks like a locale dependent number conversion...
Old 15th May 2020, 09:52   #6970  |  Link
wthreex
Dont know if its a feature request or not but,
Add ability to get path of current file in the queue (One Click Encoder)
Usage is for avisynth, My script need a file path as string but there is no way to get current file path in megui when we doing a batch processing
Related topics :
https://forum.videohelp.com/threads/...ue-dynamically
https://forum.doom9.org/showthread.php?p=1911775
https://forum.doom9.org/showthread.php?p=1911779
Also i recorded my issue: https://streamable.com/cdkk1d
wthreex is offline   Reply With Quote
Old 15th May 2020, 12:39   #6971  |  Link
StainlessS
StainlessS's Avatar
I added this post to thread in Avisynth Usage forum: (maybe clarifies above posted Wthreex requirement)
Hi wthreex,
The thing with the '<input>' stuff is an Avisynth script template, it just allows you to add some avisynth scripting.
It might be possible to convert the source file name into a subtitle file eg "D:\myfile.avi' to 'D:\myfile.srt' if you had access to the
sourcefile name from within avisynth called via MeGUI, however I am not aware that the source filename is available to avisynth script.
Additionally, even if you did have access to the source filename, and hence a similar subtitle filename, all you could do from within
avisynth would be to add a 'Hard Coded' subtitle to the video, ie always there and could not switch off subtitle as it is part of the video.
I'm guessing that what you want is to be able to auto add eg myfile.srt to the files to be multiplexed together at the final encode stage.
I dont think that this is possible, (and the avisynth script template has nothing to do with that type of functionality).
I can only suggest that you ask in MeGUI forum if it is possible to auto add an associated subtitle file (eg myfile.srt) to the files to be
multiplexed together and the end of encode. [I doubt that this is currently possible, I wish it were otherwise as I would also like to be able
auto do that, and for more than a single subtitle file].
EDIT:
When I use AutoEncode and want to add multiple subtitle [single subs file can be added quite easily by ticking the 'Add additional content' box],
I have to encode normal, and then use the Tools/Muxer/MP4 Muxer tool to mux the separate video, audio and subtitle streams together.
I sometimes post sober.
Old 21st May 2020, 05:00   #6972  |  Link
magnetite
Avisynth+ 3.6.0 is out. MeGUI crashes when it's installed.
Old 21st May 2020, 10:06   #6973  |  Link
tebasuna51
tebasuna51's Avatar
MeGUI is a Windows soft and don't need the Avs+ 3.6.0 new version. Also there are plugins than don't work with this new version.
Use the Options -> Main -> Always use the included AviSynth
Old 22nd May 2020, 00:32   #6974  |  Link
magnetite
The included version of Avisynth+ is really outdated. Version 2272, file date 2/17/2019.
Old 22nd May 2020, 11:32   #6975  |  Link
Zetti
MeGUI AviSynth Wrapper test by pinterf.
https://forum.doom9.org/showthread.p...54#post1913054
Old 22nd May 2020, 15:06   #6976  |  Link
Zathor
I think I have not mentioned that before, but neither the project nor I am dead - I would say luckily
I only do have even lesser available time for this here than I had before . Which is the reason why I do not show up here anymore.
So if there is anything which is not working or needs fixing, please post it on sourceforge. I do not have the time to browse the forums atm. Please be also aware that if you e.g. paste a link to an updated version of an included application I will simply put it on the development update server so that the community can test it and report problems (again on SF) if needed. I am not able to make any time consuming tests or checks.
However there are some minor changes incoming e.g. I am playing currently with the "new" lsmash, the avisynth+ 3.6 thing (still not sure if I should or can support that officially - reasons above), ...
Beside that everyone for keeping the community up & running.
Old 22nd May 2020, 17:24   #6977  |  Link
tebasuna51
tebasuna51's Avatar
You are wrong, is the Avs+ 3.5.1 r3106 from 3 Apr 2020, please:
Options -> Extended -> Use development update server
Old 24th May 2020, 14:38   #6978  |  Link
Zathor
2919 [Main]                 improved error handling when copying the redist files
2918 [Profile Selector]     fixed new profile not available immediately. Bug #953
2917 [L-SMASH Indexer]      always show source and cachefile (if available)
2916 [FFmpeg AAC Encoder]   fixed quality mode using the wrong number format (regression of 2904)
2915 [L-SMASH Indexer]      added support for recent versions
                            enabled VC-1 decoding support
                            enabled custom index file locations
2914 [Audio Encoder]        improved error handling
Old 25th May 2020, 00:00   #6979  |  Link
tebasuna51
tebasuna51's Avatar
Thanks Zathor
Old 25th May 2020, 00:54   #6980  |  Link
jlw_4049
MP4Box does not work on latest developmental build of MeGui
Pasting msvcr100.dll into the MP4Box folder will fix it. I pulled this from the previous version of MP4Box.
This isn't an issue with MeGui but an issue with MP4Box. However, it doesn't work at all without this fix.
