Old 2nd May 2017, 14:54   #4281  |  Link
IanD
Originally Posted by Aleksoid1978 View Post
Also - for 3D decoding don't need LAV Video Decoder. Internal video decoder can do it.
Not much point if it's going to scale to 1920x1080 regardless, just like MadVR.
I don't understand why Over/Under works correctly in MPC-BE/MadVR and Line Interleaved doesn't: they are effectively the same frame size before scaling to desktop, but they don't appear as the same frame size in a window on the desktop.
IanD is offline   Reply With Quote
Old 2nd May 2017, 14:54   #4282  |  Link
madshi
All "free" MVC decoders do, and even further, they even all use my wrapper code to do it, its fascinating how these features magically appeared everywhere last year
Seems ffmpeg/libav have given up on MVC decoder development?
Originally Posted by IanD View Post
I don't understand why Over/Under works correctly in MPC-BE/MadVR and Line Interleaved doesn't: they are effectively the same frame size before scaling to desktop.
madVR doesn't do Over/Under. It does do top-and-bottom, but that's also half-resolution.
Old 2nd May 2017, 14:56   #4283  |  Link
It comes up occasionally, but its not really moving much. With 3D TVs slowly dying out in newer generations, I wouldn't be surprised if its never finished.
Old 4th May 2017, 12:57   #4284  |  Link
Aleksoid1978
Aleksoid1978's Avatar
But - in MPC-BE it's support Hardware Acceleration on Intel GPU
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 8th May 2017, 14:57   #4285  |  Link
v0lt
beta release
MPC-BE 1.5.1 (build 2548) beta (SourceForge.net).
Old 9th May 2017, 13:19   #4286  |  Link
Magik Mark
Guys,
Where can I get the "mpc audio render" .ax files for both x86 & x64?
Aora Master - Intel i9 - RTX 2060 - DDR4 24GB Predator - LG OLED C9 - Yamaha A3030 - Windows 10 x64 - Kodi with DSplayer - Lav - MadVR
Old 9th May 2017, 13:39   #4287  |  Link
In the very link V0lt posted right above you...
standalone_filters-mpc-be...
Old 9th May 2017, 14:29   #4288  |  Link
Magik Mark
Sent from my iPhone using Tapatalk
Old 10th May 2017, 03:23   #4289  |  Link
thrawnrulz68
I am experiencing a very odd issue when playing FILM (.cpk or .cak) files. The video renders but the audio (PCM according to MPC-BE) is played highly distorted and very quickly. This occurs with either MPC-BE built-in filters or with LAV Filters and occurs with both the built-in audio renderer and with the default DirectSound device.
MPC-HC does not have this issue.
A bunch of samples can be found here: http://samples.ffmpeg.org/game-formats/film-cpk/
Does anyone have any suggestions?
Thanks!!
thrawnrulz68 is offline   Reply With Quote
Old 10th May 2017, 03:51   #4290  |  Link
Aleksoid1978
Thanks!!
Bug in LAV Source - it's output wrong/incorrect MediaType for audio stream. In MPC-HC - connect LAV Audio for "private" MediaType.
Old 10th May 2017, 05:37   #4291  |  Link
thrawnrulz68
Hi Aleksoid, I am having difficulty locating the "private" MediaType. Is this done in "External Filters" of MPC? Can it be done in LAV Audio Configuration?
Old 10th May 2017, 06:20   #4292  |  Link
Aleksoid1978
You can't do anything - until LAV not fix. LAV output mediatype MEDIASUBTYPE_PCM, but it's wrong.
Old 10th May 2017, 07:59   #4293  |  Link
nsnhd
Why Option\Video\Color Correction sometime doesn't work for EVR CP ?
nsnhd is offline   Reply With Quote
Old 10th May 2017, 08:37   #4294  |  Link
Aleksoid1978
It's all question to your video-driver.
Old 10th May 2017, 09:02   #4295  |  Link
nsnhd
Do you mean that the video-driver handles video files (eg. 8-bit, 10-bit, hevc, vp9, hdr etc. ) differently ?
Old 10th May 2017, 09:04   #4296  |  Link
Aleksoid1978
No - color correction do video-driver.
Old 10th May 2017, 10:08   #4297  |  Link
I'm not aware of any media type for planar PCM audio, as those files contain.
Old 10th May 2017, 11:50   #4298  |  Link
Aleksoid1978
Maybe you just delete MEDIASUBTYPE_PCM from output, as it's wrong ??
Or add new subtype, i use custom for ADX ADPCM in MPEGSplitter & Audio Decoder:
{78646153-0000-0010-8000-00AA00389B71} for ffmpeg codec AV_CODEC_ID_ADPCM_ADX.
Old 11th May 2017, 22:26   #4299  |  Link
P.J
Anyway to stop MPC-BE/HC from overwriting screenshots with the same filename?
P.J is offline   Reply With Quote
Old 12th May 2017, 00:03   #4300  |  Link
beter
This mov-file is no longer played normally in recent versions.
Is it a bug, or support for this old format is simply dropped?
https://www.sendspace.com/file/k5z8gt
beter is offline   Reply With Quote
