Old 7th March 2020, 13:28   #7241  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by koupa View Post
Is there a possibility to add multi site support for subs like mpc-hc?
Sent from my MI MAX 3 using Tapatalk
Not planned.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 7th March 2020, 13:49   #7242  |  Link
koupa
Oh OK. I use BE for everything since it's got support for most filetypes. But I'm from Greece and subs are not always available or correct. So I have also installed HC for that reason.
koupa is offline   Reply With Quote
Old 7th March 2020, 14:20   #7243  |  Link
v0lt
You can specify any URL to the subtitle database.
Please do not write this anymore.
Old 7th March 2020, 14:27   #7244  |  Link
stax76
It's a very popular mobile app that writes this, probably cannot be disabled. Please note that this old forum software doesn't have mobile support except using Tapatalk.
stax76 is online now   Reply With Quote
Old 7th March 2020, 16:17   #7245  |  Link
koupa
It's not only a single site but a bunch of them. It's not a big deal but it would be nice. Both mpc players gave the easiest way to find subs. You press D and it's done. In every other player you must do alchemy.
OH an something else. I use the nightly version which is updated almost daily. Can we have an update information because yandex has blocked me and I have to save the file in my account and then download it. It's a little bit complicated.
Old 7th March 2020, 21:14   #7246  |  Link
It can be disabled. It's set by default for advertising and people generally wouldn't know about it.
Old 8th March 2020, 16:37   #7247  |  Link
M.Scott
M.Scott's Avatar
Just wanted to say thank you to the devs and contributors who do a great job on MPC-BE, it has essentially become my daily driver... in only a few situations do I still need VLC.
If I could ask a simple first question... the links in v0lt's sig to the main and alternate 1 downloads for v5113 show (x64.7z) 11.9 MB (main) & 11.8 MB (alt 1) - are these files the same? If I could ever catch the main and alternate 1 both available with the same version I would download both and do a hash comparison, extract both a have a look but I usually can only get the file offered from alt 1.
Just wonderin'
M.Scott is offline   Reply With Quote
Old 8th March 2020, 18:26   #7248  |  Link
v0lt
These are files compiled from the same source code. The files may differ.
Old 8th March 2020, 18:54   #7249  |  Link
Klaus1189
What situations are these?
Old 10th March 2020, 01:31   #7250  |  Link
JarrettH
Originally Posted by Aleksoid1978 View Post
All look's good. Without such device i can't test and say what's wrong.
P.S. Try another app with WASAPI Exclusive Output(need use WASAPI Exclusive Event mode) - foobar, AIMP.
The problem has been solved after I updated to the latest Topping driver (4.82). I guess it's for the XMOS XU208.
Old 11th March 2020, 03:17   #7251  |  Link
yonta
mpc-be+LAVVideo can't hardware-decode this video.
d3d11, dxva2n, dxva2copyback nothing works.
mpc-hc plays it in dxva mode just fine with the same setup.
it is a plain youtube video downloaded some time in last septermber(youtube-dl+ffmpeg).
source URL: https://www.youtube.com/watch?v=AkBQDBwuQT4
i re-downloaded the video using the latest version of ffmpeg for muxing and mpc-be can play it in dxva mode just fine?
one more thing, potplayer shows the same behavior as mpc-be.
yonta is offline   Reply With Quote
Old 11th March 2020, 05:12   #7252  |  Link
Aleksoid1978
It’s normal DXVA decode with internal decoder ?
Old 11th March 2020, 05:19   #7253  |  Link
yonta
yes, mpc internal decoder's dxva2 mode works just fine on this video.
Old 11th March 2020, 05:59   #7254  |  Link
Aleksoid1978
LAVVideo detect incompatible profile and fallback to software. When use LAVSource - it's read stream's data from file and extract profile and then LAVVideo can handle it's value
Old 11th March 2020, 06:21   #7255  |  Link
yonta
yes, using LAVSplitter Source solves the problem.
LAVSplitter+LAVVideo+MPC VR = sweet D3D11, thanks!
Old 19th March 2020, 13:28   #7256  |  Link
tormento
Acid fr0g
tormento's Avatar
I tried to feed MPCBE some really old AVI with external subs made from .idx and .rar (compressed sub) and it doesn't recognize the subs.
Any idea?
@turment on Telegram
Old 19th March 2020, 14:07   #7257  |  Link
Aleksoid1978
Any idea?
Upload sample files.
Old 19th March 2020, 14:47   #7258  |  Link
tormento
Acid fr0g
tormento's Avatar
Here.
Old 19th March 2020, 18:40   #7259  |  Link
v0lt
@tormento
You need UnRAR.dll or UnRAR64.dll.
https://www.rarlab.com/rar_add.htm
Old 19th March 2020, 22:02   #7260  |  Link
tormento
Acid fr0g
tormento's Avatar
@tormentoYou need UnRAR.dll or UnRAR64.dll.
In the MPCBE directory, I suppose.
Does it work with 7-Zip too?
