Old 5th July 2020, 20:09   #7561  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by nussman View Post
LAV output: NV12 (16-235 Range)
So, is there any decoder able to output full PC range? Because x264 is in YUV space and YUV can be converted to RGB both with LAV and with MPC decoders.
@turment on Telegram
Old 5th July 2020, 20:17   #7562  |  Link
there is no difference for decoder between full range and limited range both are the same the only difference is a flag send to the renderer that a file is full range or limited range.everything is working as it should be the option in lavfilter doesn't change the range it only changes the range for forced RGB output else the better untouched image is given the renderer which is in 99.9% limited range because that's how files are encoded.
this output option in lavfilter is not needed with good video renderer and can be ignored.
Old 5th July 2020, 20:18   #7563  |  Link
nussman
LAV can do that i.e. if you disable all other output formats, but as I said dont do that.
LAV is choosing the „best“ format for you with default settings.
The Renderer are converting to RGB anyway, why LAV should do that if not necessary?
nussman is offline   Reply With Quote
Old 7th July 2020, 07:37   #7564  |  Link
tormento
Acid fr0g
tormento's Avatar
So, is the 16-235 report "fake"?
If not, how can I get the full range?
Old 7th July 2020, 09:40   #7565  |  Link
v0lt
This has already been voiced. Do not use a hardware decoder. And turn off all formats except RGB in the decoder settings. After that, the setting in the decoder will work for regular video.
Can you explain why you need the full range at the decoder output?
Old 7th July 2020, 10:53   #7566  |  Link
chros
chros's Avatar
What others tried to tell you is this:
No, it belongs to the INPUT (!) format!
Take a look at the Output section of the above image, it says something like: B8R8G8A (= RGB 8bit).
The playback chain is: splitter (lav) -> decoder (lav) -> renderer (madvr)
This is how it works with video: it has 16-235 (!) level in the container!
The decoder (lav) output the video as it is, meaning at 16-235 levels, and the responsibility of the renderer (madvr) is to convert it to RGB if it's needed!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 7th July 2020, 11:26   #7567  |  Link
chros
chros's Avatar
Originally Posted by v0lt View Post
@cmhrkyMPC VideoRenderer 0.4.8.1407. Added support for exclusive full screen for DX11 mode.
I just tried out this (and the prev release as well), but I got massive tearing on the Secondary monitor (LG TV) at 23p/24p with 23p content. (see my details in my signature)
Old 7th July 2020, 11:40   #7568  |  Link
v0lt
@chros
Yes. Exclusive full screen has problems in DX11 mode. The reasons are not clear to us. I advise you to use the DX9 mode.
Old 7th July 2020, 14:46   #7569  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Show fullscreen screenshot with statistics.
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 8th July 2020, 08:42   #7570  |  Link
s0meone_new
If uninstall the program, it remains in the registry:
...\HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Media\MPC-BE
Windows 10 64 bit
s0meone_new is offline   Reply With Quote
Old 8th July 2020, 09:07   #7571  |  Link
Aleksoid1978
Windows 10 64 bit
So ??
Old 8th July 2020, 09:14   #7572  |  Link
s0meone_new
If someone uninstall the program, removes it as well. "So" it will be correct. No? Yes?
Old 8th July 2020, 13:48   #7573  |  Link
kerry7
As far as I know, keeping the register is pretty common in many Windows-based programs.
In concrete, for the key HKEY_LOCAL_MACHINE\SOFTWARE, it is not stored on the disk, but in memory. And those values are loaded on booting time. My guessing it would be to try to investigate a little bit more, on config boot, or check if by starting it in safe mode, that key is still there.
Techy lover addicted to Raspberry Pi
kerry7 is offline   Reply With Quote
Old 8th July 2020, 21:55   #7574  |  Link
P.J
Originally Posted by Aleksoid1978 View Post
Thx - fixed.
Big thanks
P.J is offline   Reply With Quote
Old 9th July 2020, 02:23   #7575  |  Link
Aleksoid1978
Windows 10 64 bit
Fixed.
Old 9th July 2020, 05:45   #7576  |  Link
s0meone_new
That's cool.
Old 10th July 2020, 16:50   #7577  |  Link
chros
chros's Avatar
Here it is along with settings.
Old 11th July 2020, 09:57   #7578  |  Link
v0lt
@chros
Are you sure that you have screen tearing? I have not watched the tearing in the video for several years. Maybe you turned off vertical synchronization in the driver settings?
PS: MPC VideoRenderer 0.4.8.1420 is available.
Old 12th July 2020, 06:49   #7579  |  Link
Aleksoid1978
Just checked on my config - perfect playback on DX11 FSE on 23.976 on secondary TV. Win10 2004 latest Nvidia driver.
Maybe you using very old 1607 windows.
Old 13th July 2020, 15:11   #7580  |  Link
SirMaster
I am interested in using the YouTube support, but I noticed that the built in YouTube page parsing method only selects H264 1080p at most automatically, even if I select 2160p in the preferred quality. I think I understand that YouTube page parsing doesn't support more than 1080p H264 anymore or something like that.
I see that I can put youtube-dl in the mpc-be folder and use that to parse the YouTube links, and then I can get 2160p webm to work automatically which is great. However I wish there was a way to prevent youtube-dl method from loading the HDR version when the video has HDR.
I wish there was an HDR checkbox for youtube-dl method like there is for the built in page parser method (though the built in method preferred quality selector doesn't work anyways).
Yes I know that I can manually select the quality from a menu button on the bottom of mpc-be after opening a youtube video, but I am trying to automate this process and I want to basically select the max quality up to 4K60, but not HDR. Right now it's very close, it selects the max up to 4K60, but will pick the HDR when that exists.
I am sending links to open in mpc-be remotely and having the video play, but I don't have a mouse/kb connected to the playback machine, so I cannot and don't want to have to manually un-select the HDR version when that exists and gets selected automatically.
Any tip or tricks for me on this?
SirMaster is offline   Reply With Quote
