Old 15th September 2018, 23:31   #961  |  Link
Nice ... another alternative to aomenc, similar to rav1e (by team Xiph), here by team VideoLAN.
_
Oops: decoder.
Old 16th September 2018, 00:10   #962  |  Link
mandarinka
mandarinka's Avatar
Originally Posted by TD-Linux View Post
I plan to add debugging options exactly for the purpose of getting feedback from users - the first obvious thing to add is the internal cdef-dist parameters to tune them. That said, they will remain debug options - for example, we may change how cdef-dist works internally when we find a better way to do it, and that will break the options. If you find a combination of debug options that looks better, I'd rather you report it as a bug and we use that information to change the defaults.
I don't think that's going to be viable. The point of tweakability is that the changes taht improve one source don't improve all sources. I would be surprised if one set of magic numbers were ideal for all content. And likewise, even beyond that objective factor, people have different ideas about how should the video look and that requires ability to change settings too and again precludes one specific setting from being ideal for everything.
Hmmm, makes me think... Doom9 has this in its forum rules: "There is no best".
It's not a straightforward "video truth" (heh), but the reason behind it most likely has a connection exactly with this case. In video processing/compression, you usually don't have an absolute correct and final answer that is true always, regardless of context. Personally I agree with it that there is not one best aq-strength, psy-rdo, crf and so on. IMHO it's going to happen with Rav1e options too.
Old 16th September 2018, 07:17   #963  |  Link
Selur
Selur's Avatar
Since when feeding 10bit yv12 with profile I get:
Profile 2 bit-depth < 10 requires 4:2:2 color format
I got a small question:
What color sampling and bit depth combinations are supported in which profile when using aomenc?
Cu Selur
Old 16th September 2018, 07:39   #964  |  Link
You should be using Profile 0 (Main) for 10-bit 4:2:0 for maximum compatibility.
The general AV1 rules are pretty simple:
Main Profile (0) is 8/10-bit 4:2:0 or Monochrome (4:0:0)
High Profile (1) is 8/10-bit 4:2:0, 4:4:4, Monochrome
Professional Profile (2) is 8/10/12-bit, 4:2:0, 4:2:2, 4:4:4, Monochrome
I would assume that the encoder follows the same rules - and judging by that message it even enforces the "use the lowest profile possible" suggestion?
I don't know right off the top of my head if the profiles actually influence anything else beyond the bitdepth/chroma, but I don't think so, which gives you little to no reason to use a higher profile when you don't need its chroma/bitdepth extensions.
Old 16th September 2018, 08:54   #965  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Originally Posted by marcomsousa View Post
I like more the second round testing at lower data rates and this comment:
You should focus your tests on the data rates at which your video will most likely be deployed. At this point, H.264 and any newer codec should produce near perfect quality at 6 Mbps, making that data rate irrelevant for forward-looking testing. HEVC and VP9 take the near perfect quality level down to between 3.5Mbps to 4Mbps, and AV1 and future codecs should bring this down into the 2Mbps to 3.5Mbps range.
The bias of this comment is obvious: This is targeting the little-to-no-grain FHD segment. Grain is basically an uncompressible random number generator, the only only way out is tons of bitrate or FGM. People are going to hate on AV1 the same way they hate on HEVC because it won't store film grain efficiently, since neither codec is even remotely targeting that.
Old 16th September 2018, 09:07   #966  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Originally Posted by mzso View Post
@benwaggoner
Well, I for one don't care at all about <100kbps crappines whatever the codec may be.
It has nothing to do with only being good at crap bitrates, and everything to do with having one codec that can go from 8kbps to 500kbps without compromise, the one codec to replace them all. That is the siren call of Opus, and that is the promise of xHE-AAC, although it hasn't exactly been realized yet. IMHO it's still better to have two heavyweights that are better than everything else out there, because it keeps the pressure on to keep improving.
Originally Posted by IgorC View Post
xHE-AAC, Opus, HEVC and VP9 were all standarized at the same time.
VP9, HEVC and Opus were adopted in many applications.
xHE-AAC? Name me one functional encoder. 6 years and counting.
No market for its licensing (Opus did it), awfully late and too little.
xHE-AAC is dead.
Spotify has been using it all year at the 24kbps point, and they're working on moving it up the stack. Android 9 has made it mandatory. (Android 5 made Opus mandatory.)
Old 16th September 2018, 14:32   #967  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
Originally Posted by lvqcl View Post
Dav1d: a fast new AV1 decoder
Ronald Bultje is making the decoder?!!
So we will have the worlds fastest AV1 decoder soon
https://blogs.gnome.org/rbultje/2014...decoder-ffvp9/
Mr_Khyron is offline   Reply With Quote
Old 16th September 2018, 15:23   #968  |  Link
IgorC
Spotify uses HE-AAC for lowest bitrate mode, not xHE-AAC.
As for the rest of bitrates they use Vorbis and LC-AAC. There is no quality benefit from xHE/HE-AAC codec at higher rates. Add to it that Vorbis is free and LC-AAC patents will expire in 2 years.
https://support.spotify.com/us/using...ity-streaming/
That's a decoder. There is still no any encoder (and it won't be)
Remember MPEG surround format? It's 11 years old ... with zero adoption. xHE-AAC goes a same road with its 6 years of 'unadoption'. After MP3 and (HE)AAC none of a new mpeg audio format has seen any meaningful adoption.
IgorC is offline   Reply With Quote
Old 17th September 2018, 09:48   #969  |  Link
marcomsousa
ffmpeg 2018-09-13 zeranoe build
ffmpeg -threads 4 -i 1080.mp4  -benchmark -f null -
ffmpeg version N-91943-g1b98bfb932
[libaom-av1 @ 000001e19c898940] 1.0.0-507-g5d963cb57
frame= 1736 fps= 19 q=-0.0 Lsize=N/A time=00:00:57.92 bitrate=N/A speed=0.637x
bench: utime=88.703s stime=0.938s rtime=90.919s
bench: maxrss=233580kB
ffmpeg 2018-09-16 zeranoe build
ffmpeg version N-91961-g5109c38162
[libaom-av1 @ 000001b015cfd8c0] 1.0.0-590-g6fa400604
frame= 1736 fps= 34 q=-0.0 Lsize=N/A time=00:00:57.92 bitrate=N/A speed=1.15x
bench: utime=100.594s stime=2.812s rtime=50.395s
bench: maxrss=274472kB
The new ffmpeg builds with a newer libaom-av1 improves performance a lot (like SmilingWolf said)
marcomsousa is offline   Reply With Quote
Old 17th September 2018, 14:24   #970  |  Link
iwod
Any links? The only thing I got was from Wikimedia
https://phabricator.wikimedia.org/T166025
Which state LC-AAC to be patents free in 2018! This is big news.
iwod is offline   Reply With Quote
Old 17th September 2018, 19:37   #971  |  Link
mzso
Why? Because around no-one cares about it by now?
Old 17th September 2018, 19:51   #972  |  Link
In general, generalizations are wrong... "no-one" is a strong assumption without proof over the whole population of earth using technology compatible to LC-AAC already (e.g. iTunes).
If you don't care about AAC, it's your choice. But don't assume about anyone else.
Old 18th September 2018, 08:23   #973  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Let's try to keep discussion focused on AV1, guys
Old 18th September 2018, 08:53   #974  |  Link
marcomsousa
Can doom9 promote AV1 and give an sub-forum like for HEVC?
So we can have more specialized threads:
AV1
  • Software adoptions
  • HW compatible
  • libaom
  • Rav1e
  • Dav1d
  • Tune with parametres
  • 10bit and 12bit
  • Quality compare
  • Performance compare
  • Custom Builds
  • Containers
  • Etc...
Old 18th September 2018, 08:57   #975  |  Link
hajj_3
xHE-AAC is dead.
xHE-AAC was added to the DRM+ digital radio standard which india is rolling out. It may still become popular in the future if DRM+ becomes popular.
I can't see it becoming popular online due to the patent costs especially as Opus 1.3 has improved lower bitrates recently and will continue to improve.
Old 18th September 2018, 11:14   #976  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
So we can have more specialized posts:
  • News
  • HW decode compatible
  • HW encode compatible
  • Tune with parametres (libaom-av1)
  • Tune with parametres (ffmpeg)
  • Tune with parametres (others)
  • 10bit and 12bit
  • Quality compare
  • Custom Builds
  • Containers
  • Etc...
As much as I'm hoping AV1 sets the world on fire, especially once it's released from Google's "performance? who needs optimization when you have the world's largest server farm?" attitude, Doom9 is about interest more than promotion. So far there just aren't that many posts about AV1; compare the HEVC forum. Some of those threads are obvious duplicates or way too niche, but if you want to go ahead and found a dedicated AV1 tuning or comparison thread, go ahead.
News goes in the news forum, naturally.
Old 18th September 2018, 13:59   #977  |  Link
hydra3333
OK. Possibly only for now, though ? A novice like me and perhaps most punters may have reasonably inferred that with google and so many (almost all ?) large industry players signed up and behind it that it is likely to receive growing attention. Just a thought.
hydra3333 is offline   Reply With Quote
Old 18th September 2018, 18:09   #978  |  Link
IgorC
Sorry for offtopic. Last one and probably will get it somewhere else.
It's difficult to say. I'm not a lawyer. I just saw some patent related estimations here http://www.ecodis.de/audio.htm
Especially when laws change per country. Also there are decoding and encoding related patents. MP3 decoding related patents have expried in 2015 but encoder patents in 2017. https://www.cs.helsinki.fi/group/pak...docs/legal.pdf
It might be the case that patents of LC-AAC have already expired.
Will investigate.
Old 18th September 2018, 23:49   #979  |  Link
Nintendo Maniac 64
Nintendo Maniac 64's Avatar
MPC-HC v1.8.2 also got released - could you perhaps confirm/deny whether its built-in LAVfilters also contain these performance improvements?
Thing is, I saw no performance gains when using 1.8.2 vs 1.8.1, so I need to confirm/deny whether my performance issue is persisting or whatnot.
I did however notice that, out of the three cores being utilized on my Xeon x3470, one of them is pretty much fully pegged and the other two are about half utilization - this would then equal the ~25% utilization I'm seeing.
Now normally I would let this all go as simply a case of "not having fast enough single-threaded performance" and be done with it, but the fact that you and others were seeing over 60% utilization on your own 4c/8t CPUs (which implies it was balancing the load across more than 4 threads) makes me thing something still isn't quite right here - I mean, weaker single-threaded performance shouldn't result in fewer threads being utilized, and if anything you'd want it to be the opposite, no?
Nintendo Maniac 64 is offline   Reply With Quote
Old 19th September 2018, 11:58   #980  |  Link
lvqcl
I downloaded aom-master.tar.gz (that is, the latest sources), recompiled libaom amd ffmpeg libs myself, and I cannot see speed increase over vanilla LAVFilters-0.72.0-13.
Also: according to LAVFilters sources, it uses AV1 library v1.0.0-552-gbb82e05fb which does have that "row-based multi-thread decoding" patch.
