Old 3rd December 2017, 21:26   #41  |  Link
kolak
And there are quite a few software which did use of it and have direct integration.
Hopefully someone will take this task
Old 9th December 2017, 02:42   #42  |  Link
WorBry
Originally Posted by shekh View Post
VDFM is also in the list. I think the FFMpeg statement was right there: "patch welcome"
Hey shekh, great to see that VDFM does now have native Cineform support also. Ran a quick test comparing Cineform (YUV 422 10-bit) avi encode bitrates at the different quality levels and they tally with those obtained with the vfw Cineform codec (v 9.2.1) from GoPro Studio (Quik).
But where did "Filmscan 3" come from ? Not that I'm complaining, but I was under the impression that "Filmscan 2" was the max quality level. I haven't done any quality metric tests (yet), but with the same source clip the bitrate of the 'Filmscan 3" encode was about 5% higher than that of the 'Filmscan 2" encode.
Edit:
Originally Posted by WorBry View Post
I haven't done any quality metric tests (yet)....
With this one test clip (HD-AVC 1080/30p mp4) as source:
               Bitrate (Mb/s)               SSIM score (%)
Filmscan 3      346                          98.28
Filmscan 2      327                          98.09
Filmscan 1      239                          96.43
And that's after converting the Cineform encodes back to YV12 for the AVISynth SSIM test.
Nostalgia's not what it used to be
WorBry is offline   Reply With Quote
Old 9th December 2017, 08:39   #43  |  Link
shekh
From the sdk:
CFHD_ENCODING_QUALITY_FILMSCAN3, // overkill but useful for get higher data-rates from animation or extremely clean sources
Old 9th December 2017, 21:23   #44  |  Link
WorBry
Thanks shekh.
Old 10th December 2017, 00:56   #45  |  Link
kolak
FilmsScan3 is a "special" mode made for Disney for very clean sources. For typical or noisy source it may rise bitrate a lot for not much quality gain.
Cineform was made with idea of high-end RAW (or film scan) sources, not already pre-compressed ones. When you test it with h264 etc (or even already compressed ProRes) source it will tend to use relatively low bitrates even for FS2 mode. If you take some RAW source (RED, Arri) etc then it's a different story. It will nicely preserve quality over whole source.
Here is an example:
http://s32.postimg.org/u54dzr079/test.png
Great to see native Cinefrom in Vdub!
Old 10th December 2017, 03:45   #46  |  Link
WorBry
Interesting. I knew 'Film Scan' per se was developed to accurately reproduce the grain characteristics in high grade film scans but had seen no mention of 'Film Scan 3' before:
https://cineform.zendesk.com/hc/en-u...ality-Settings
Old 11th December 2017, 12:51   #47  |  Link
kolak
FilmScan3 or mode 6 in old cmd tools was rather a "secret" mode for typical users. You could turn it on with registry "hack" on PC.
Old 12th December 2017, 16:57   #48  |  Link
poisondeathray
I'm not getting bit for bit identical the same result.... Very slightly different bitrate and differences on a 10bit422 source . Anyone else ?
Old 12th December 2017, 17:59   #49  |  Link
shekh
I am not sure it is possible to compare results bit-to-bit from current sdk vs vfw 9.2.1 implementation. Probably something was changed.
Old 12th December 2017, 18:50   #50  |  Link
poisondeathray
There seem to be decoder differences as well , between ffmpeg and VFW (regardless if file was encoded with 9.2.1 or native vdfm sdk implementation)
Or how do you test "proper" 10-bit VFW decoding ? Maybe some testing methodology errors ? I'm testing in vapoursynth, with avisource and pixel_type="v210" . The differences don't look like a simple 10bit vs 8bit issue . And the difference pattern is quite different when testing v9.2.1 vs SDK
import vapoursynth as vs
core = vs.get_core()
c0 = core.ffms2.Source(source=r'F:\_Video Tests\QT Prores\cineform_filmscan2_native.avi')
a0 = core.avisource.AVISource(r'F:\_Video Tests\QT Prores\cineform_filmscan2_native.avi', pixel_type="v210")
#c0 = core.ffms2.Source(source=r'F:\_Video Tests\QT Prores\cineform_filmscan2_v9.2.1.avi')
#a0 = core.avisource.AVISource(r'F:\_Video Tests\QT Prores\cineform_filmscan2_v9.2.1.avi', pixel_type="v210")
d = core.std.MakeDiff(c0,a0)
da = core.std.Levels(d, min_in=511, max_in=513, gamma=1, min_out=0, max_out=1023, planes=[0,1,2])
da.set_output()
Old 12th December 2017, 19:16   #51  |  Link
shekh
Can you post pictures with your results? And the source file.
Old 12th December 2017, 19:27   #52  |  Link
poisondeathray
The original file is prores , then I used vdfm to encode either with native cfhd, or gopro v9.2.1 implementation
http://www.mediafire.com/file/fzxi5p...v210.part1.rar
http://www.mediafire.com/file/pqrydi...v210.part2.rar
I'm still investigating, but it looks like ffms2 issue (I'll try a few others later) ; but it also looks like recent ffmpeg.exe (zeranoe) decoding it incorrectly too when outputing v210 and checking the uncompressed stream. Looks almost like interlace issue
EDIT:
1) It seems like only the 9.2.1 streams are affected . The native implmentation encoded streams are decoded correctly by everything. ffmpeg, ffms2 derivatives all decode it incorrectly. Yet vdfm decodes it correctly. I had video format "automatic" for the 9.2.1 settings. I'll try with progressive
Yes that's it for that "interlace" issue. You have to explicity set progressive encoding settings for 9.2.1, otherwise ffmpeg, ffms2 exhibit the issue
2) Does the SDK expose progressive / interlaced settings ? I didn't see the option in the vdfm native implementation
3) But there are still differences between decoders. e.g when I test a native stream such as in post #50 . The ffms2 result is consistent with ffmpeg result (decoding to v210) as expected , but the VFW result is still different
Old 12th December 2017, 20:24   #53  |  Link
shekh
This is what I see: https://s8.postimg.org/hpxoe38id/alexa.png
(Levels min_in=512-20, max_in=512+20)
The lower edge is maybe this problem: http://trac.ffmpeg.org/ticket/6675
Other parts look good to me.
Btw in VDFM there are 3 ways to decode CineForm, this way I saw some defects with different behavior across implementations.
1) Native: through caching input driver and default options
2) FFMpeg: through caching input driver and uncheck "Use native decoder" in open dialog options
3) VFW: through AVI driver
Old 12th December 2017, 20:39   #54  |  Link
poisondeathray
Yes, some differences similar to that when testing VFW vs. FFMS2 in vapoursynth . I would expect on the decode side things would be identical for the same input stream . Not just the lower edge issue, but decoder should output bit identical, so the other parts don't look good to me in terms of testing (they look fine to naked eye when not testing differences)
I know it's work in progress, but it's supposed to be standardized STMPE VC5 , so results so be more consistent IMO . I don't know a thing about writing code. I can't even spel properly . I can only help by making observations and test
I'll look in the QT/MOV and Adobe implementation next . Do you know if it's based on the same SDK or did they do some tweaks ?
Is there a "reference" decoder ? Similar to JVT JM bitstream reference decoder for AVC streams ? I would assume it's the go pro implementation
Old 12th December 2017, 21:11   #55  |  Link
shekh
But this is hacked ffmpeg decoder that makes this test look bad.
I just compared:
vfw decode of vfw.avi, vfw decode of native.avi, native decode of native.avi, native decode of vfw.avi: all appear bit-identical. I am lazy to run it through md5, just seeing perfectly gray difference.
So returning to your observation, how you see that?
Bitrate may be slightly different due to embedded metadata (things like encoding date etc).
Previously the sdk included compiled dlls, I doubt any at Adobe had source code. But I have no idea.
Old 12th December 2017, 21:22   #56  |  Link
poisondeathray
Yes, the problem is the ffmpeg decoder (or derivatives , ffms2 etc...)
The not bit for bit identical results are from different decoder output. The ENcode side is ok
The ffmpeg decoder also requires 9.2.1 steams to select "progressive". When "automatic" is used for the encoding, they are decoded even more incorrectly. So something is written into the header that causes additional problems on top
Old 12th December 2017, 21:45   #57  |  Link
poisondeathray
Actually there are differences between vfw decode of 9.2.1 encoded vs. vfw decode of vdfm native encoded . 1st frame is identical , as are a few others. But other frames are not.
But you said : "I am not sure it is possible to compare results bit-to-bit from current sdk vs vfw 9.2.1 implementation. Probably something was changed. "
ap = core.avisource.AVISource(r'F:\_Video Tests\QT Prores\cineform_filmscan2_v9.2.1_prog.avi', pixel_type="v210")
d = core.std.MakeDiff(a0,ap)
da.set_output()
Old 12th December 2017, 21:57   #58  |  Link
shekh
It is probably possible to upgrade vfw codec to current state by replacing CFHDDecoder.dll etc. Not curious enough to try this right now
Which frame was most different?
Old 12th December 2017, 22:03   #59  |  Link
poisondeathray
I don't know about "most" different, but
frame zero (1st frame) was the same
frame one (2nd frame) was different
Some frames later on were identical, some were different. Again this is on amplified differences. On plain difference you can barely see any differences
Old 13th December 2017, 01:47   #60  |  Link
WorBry
The actual results obtained with that one 1080/30p HD-AVC.mp4 (8-bit 4:2:0) source clip (795 frames)
Bitrate of Cineform avi encode (Mb/s) - no audio
                   Native           VFW
Filmscan 2          327             326
Filmscan 1          239             239
High                169             168
Medium              133             133
Low                 122             122
Same frame count in all cases. I didn't record the actual file sizes (in bytes).
Edit: And just for reference, same source clip transcoded to Cineform.avi with DaVinci Resolve 14.1 (at Full 'Data' levels), which uses a different terminology for the quality levels, just to confuse matters:
Bitrate Mb/s
Best (= Film Scan 2)          332
High (= Film Scan 1)          242
Medium (= High)               172
Low (= Medium)                135
Least (= Low)                 124
Same frame count (795)
