Old 23rd February 2020, 21:31   #1361  |  Link
imhh11
thanks but the GCC builds don't work on my end. it says it's missing libgcc_s_seh-1.dll
imhh11 is offline
Old 23rd February 2020, 22:27   #1362  |  Link
imhh11
same error
imhh11 is offline
Old 24th February 2020, 12:51   #1363  |  Link
Mzvasturbo
Hi is it possible to rip with 2computers at the same time. I have a pc with i7 and other pc with i5 cpu both conected in my home network i rip 4k hdr movies using x265 cpu only. Now my i7 struggles even at medium preset so if there is a way my i5 pc could help it would be great. O and i found some nice settings for 4k hdr compression i get very nice rezults and small files if anyone is interested write me in private.
Mzvasturbo is offline
Old 24th February 2020, 15:38   #1364  |  Link
stax76
stax76's Avatar
Not with StaxRip but with RipBot264.
stax76 is offline
Old 24th February 2020, 16:23   #1365  |  Link
Mzvasturbo
And finally i figure out x265 settings i like. Staxrip with encoding server is the future
Old 25th February 2020, 02:19   #1366  |  Link
chipxtreme
What were your settings?
chipxtreme is offline
Old 26th February 2020, 09:30   #1367  |  Link
Natty
Noob
Originally Posted by Patman View Post
Short explanation to my builds:
x265-3.3+2 - Default Branch / Master Branch
x265M-3.3+2 - Default Branch / Master Branch with customization to display estimated file size
Natty is offline
Old 26th February 2020, 20:39   #1368  |  Link
mikraphne
I've been doing 4K encodes perfectly fine for awhile, and was wondering about HDR10+. I know how to use the HDR10plus parser tool to generate a JSON from a raw HEVC file, but how do I insert this file into Staxrip to have it embedded within the .mkv?
mikraphne is offline
Old 26th February 2020, 22:43   #1369  |  Link
MrBrownCow
I added a stable version of x265 (3.3+1) that was compiled with GCC 9.2.0 and MSVC 1924 (VS2019). Short explanation to my builds:
x265-3.3+1 - Stable Build
Pls test and give feedback...
the GCC version was consistently about 4% faster vs the MSVC on my ryzen 3900X testing with a few short files.
Thank you!
MrBrownCow is offline
Old 26th February 2020, 23:21   #1370  |  Link
imhh11
here:
you will want to add --dhdr10-opt too
imhh11 is offline
Old 27th February 2020, 08:01   #1371  |  Link
stax76
stax76's Avatar
--chromaloc --vpp-sub --vpp-sub-charset --vpp-sub-shaping --videoformat --colormatrix --colorprim --transfer --fullrange
Were all these switches removed from qsvenc or is the documentation incomplete?
stax76 is offline
Old 27th February 2020, 20:48   #1372  |  Link
Patman
Patman's Avatar
Only vpp-sub (--vpp-sub --vpp-sub-charset --vpp-sub-shaping) switches were removed. All other switchen can be found here
Tools for StaxRip | x264 - x265
Patman is offline
Old 27th February 2020, 20:49   #1373  |  Link
Patman
Patman's Avatar
Thank you!
Thanks for your feedback!
Patman is offline
Old 27th February 2020, 22:37   #1374  |  Link
Mzvasturbo
Try it on average 4k hdr bluray source.
preset medium
--crf 17 --level-idc 5.1 --output-depth 10 --rdoq-level 2 --aq-mode 4 --aq-motion --max-merge 3 --ref 4 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(x,x)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --max-cll "x,x" --hdr --hdr-opt --repeat-headers --hrd --aud --deblock -1:-1 --no-sao
If you can go slow preset it is like this.
--crf 17 --preset slow --level-idc 5.1 --output-depth 10 --aq-mode 4 --aq-motion --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(x,x)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --max-cll "x,x" --hdr --hdr-opt --repeat-headers --hrd --aud --deblock -1:-1 --no-sao
It gives me very good rezults and small files.
For heavy grainy movies like midway 2019 filesize with above settings is very big almost the same as tune grain. So in movies like that it is better to use tune grain if you want quality. Or some other settings mybe some grain remove filter to get better compression and smaller file.
Old 27th February 2020, 23:13   #1375  |  Link
stax76
stax76's Avatar
Thanks, I'll update it later. Which GCC version did you use to build x265?
@all
I was working on this VFW interface replacement, it worked out well I think and I've tested all I could think of, I hope the new build is fine as well as the updated tools. In the next weeks I don't plan to work on anything larger, so I should have time for staxrip and mpv.net maintenance. Sorry for things not addressed yet, I have to catch up. I hope there are some useful improvements, have fun.
### 2.0.7.1 Beta
- new: icons added in encoder dialog menus
- new: option dialog is shown in case a tool has multiple help
       resources, x265 for instance has a local help file containing
       the console help and it has a comprehensive online help.
       L-Smash-Works for instance has separate help pages
       for AviSynth and for VapourSynth
- new: medium quality for x264 was changed from crf 20 to 22
- new: medium quality for x265 was changed from crf 20 to 18
- new: %dpi% macro added, returnes the DPI value of the main dialog screen
- new: High DPI aware Info() AviSynth filter profile added to misc section
- new: the VFW interface used to access AviSynth and VapourSynth
       was replaced with a new library
- new: a dozen new x265 switches
- new: nvenc switches --colorrange, --psnr, --ssim
- new: search matches in the video encoder config dialog
       stay now permanently highlighted with bold font
- new: the search feature in the video encoder config dialog now
       also searches in option values, for instance searching
       for 'medium' will find and highlight the 'preset' switch
- new: in the video encoder config dialogs the context menu of the
       command line preview has a new menu item to search
       for the switch or string at the caret or cursor
- new: Opus format enabled for MP4Box muxer, this was requested
       but did not work in my test
- new: bmp format for cover art can be used in muxer dialog
- update: nvenc 4.65
- update: qsvenc 3.31
- update: vceenc 5.02
- update: x265 3.3+2-gbe2d82093 GCC Patman
- update: ffmpeg N-96788 GCC 9.2.0 Patman
- update: mkvtoolnix 43
- update: MP4Box 0.8.0-rev178-g44c48d630 Patman
- fix: x265 three pass encoding (untested)
- fix: zoom in/out was flipped in preview dialog
https://www.dropbox.com/sh/4ctl2y928...dd3yqcAHa?dl=0
https://1drv.ms/u/s!ArwKS_ZUR01g0kH4...3GaKe?e=qbOfGS
stax76 is offline
Old 28th February 2020, 07:35   #1376  |  Link
Patman
Patman's Avatar
I use GCC 9.2.0 to build x265.
Patman is offline
Old 28th February 2020, 08:49   #1377  |  Link
JKyle
App Digger
JKyle's Avatar
@stax76:
Thanks for the update.
But even with 2.0.7.1 Beta, the following things related to x265 options don't seem to have been fixed.
1) refine-ctu-distortion is named incorrectly
2) High Tier doesn't work
3) Options with the 'no-' switch do not show up the help file when right-clicked
JKyle is offline
Old 28th February 2020, 12:52   #1378  |  Link
Patman
Patman's Avatar
Originally Posted by JKyle View Post
@stax76:
This switch only had an effect when a level is set. I can't see in the commandline, that you set a level.
Patman is offline
Old 28th February 2020, 14:47   #1379  |  Link
JKyle
App Digger
JKyle's Avatar
Oops, my bad!
Yes, you’re right, as it’s obviously explained in the help.
JKyle is offline
Old 28th February 2020, 21:42   #1380  |  Link
shodan5000
When trying to open a source file with the newest beta I only get a message stating:
System.DllNotFoundException: Unable to load DLL 'FrameServer': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Any ideas on how to fix this issue?
shodan5000 is offline
