29th May 2020, 06:13 | #1922 | Link |
@Stax76 wanted to post an update on the FFMPEG demux to core. It does not work correctly, it results in an error dropping from 7.1 to 5.1 core.
Here is a logfile. https://pastebin.com/C9rXVgzP https://i.imgur.com/W7HywQ1.png These are the settings that I used. The source was a 7.1, that FFMPEG command will automatically reduce a DTS 7.1 (of any variant) and a DTS 5.1 (of any variant) to DTS 5.1. If the source is a DTS 2.0 of any kind, it will reduce to core but keep the same channels. I don't know but the channel/sample rate selection should be greyed out if it's effecting the command. I don't know if it is, however, I tried the command by setting the channel to original and 5.1 and both threw an error. This is running the command manually https://pastebin.com/XShARNGX I think it's due to the fact that StaxRip is outputting to a .wav file. I don't know if that's required at all what so ever. Either way, let me know if you need any more information. Thanks as usual! Last edited by jlw_4049; 29th May 2020 at 06:30. |
29th May 2020, 07:49 | #1924 | Link |
Yes i can make my own with the command line in and outside of StaxRip that works.
However stax added this feature to the GUI. Just wanted to update and let him know its not working as intended. Sent from my SM-G986U1 using Tapatalk Last edited by jlw_4049; 29th May 2020 at 07:52. |
29th May 2020, 12:19 | #1927 | Link | ||
29th May 2020, 20:17 | #1929 | Link |
I noticed not always an audio track name is passed to staxrip, is this normal? Some times it is passed and some times it is not. For example this is not passed
Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1 h 28 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 951 MiB (12%) Title : English Feature Mix Language : English Default : Yes Forced : No |
29th May 2020, 23:13 | #1930 | Link | |
Also I took your advice and started learning Python |
31st May 2020, 01:13 | #1931 | Link |
App Digger
I set up an Event Command to play a sound after a job or jobs are finished as follows:
It works well on the first run of a job or jobs on the Jobs list. But when I modify settings of the same project and re-run it without saving, the sound does not play. Is it something that can be fixed by choosing some other event, or is there any underlying logic that prevents the sound from playing? |
31st May 2020, 14:11 | #1932 | Link | |
SMPTE 2084? Since there's no SMPTE ST 2094 option |
31st May 2020, 15:06 | #1934 | Link |
App Digger
SMPTE ST 2094 is NOT a transfer function, but the dynamic metadata you put as a json file. Among the 4 popular HDR standards, 3(HDR10, HDR10+, Dolby Vision) use PQ(=SMPTE 2084) as the transfer function and only SL-HDR1 uses HLG(Hybrid Log Gamma, ARIB-STD-B67 in x265).
See this Wiki document about HDR. Last edited by JKyle; 31st May 2020 at 15:13. |
1st June 2020, 06:59 | #1935 | Link | ||
2nd June 2020, 05:08 | #1937 | Link |
Hello, I have a question that I would like some clarification on as I am not the most technical minded. When trimming using the preview menu, when I select the start and end frames for trimming it will shift my end frame selection back a frame instead of using the frame I selected for eg:
Trim(2163, 31171) + Trim(33331, 33688) Trim(2163, 31170) + Trim(33331, 33687) Thanks Last edited by Disturbance; 2nd June 2020 at 23:55. |
2nd June 2020, 15:57 | #1938 | Link |
Not including the last frame looks like a bug.
3rd June 2020, 01:15 | #1940 | Link | |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
