15th January 2020, 09:48 | #561 | Link | |
Do you happen to know how to use CRU in making customize refresh rates for the ff: 2160p@23hz 1080p@119hz The timings are way off. I think LG doesn't even support it
15th January 2020, 11:01 | #562 | Link |
I would personally not recommend to switch resolution. Players/Windows can get confused by that and trip a high-DPI mode, resulting in double-scaling.
15th January 2020, 11:52 | #563 | Link | |
Anymore tips for using madvr and LAV in LG OLED?
15th January 2020, 18:54 | #564 | Link |
Some of us are now using 2160p@60Hz exclusively along with madvr's smooth motion. This results in, well, smoother motion on the OLED
And, as most of you know by now, I've been advocating YCbCr 4:2:2 10-bit for virtually no banding at all. No regrets so far.
15th January 2020, 23:14 | #565 | Link |
For sure smooth motion at 60hz is much smoother than 23p and Real Cinema. The extra blurring does bother me a bit though. Actually I've gone back to 23p and trying Trumotion. LG must have improved this at some point because last time I tried it there were too many artifacts, but dejudder on 2 and i have yet to see any artifacts and the motion is smooth with minimal soap opera effect.
Ycbcr 422 10 bit looks good to me, too. Thanks for testing it! I did a few tests of my own and it does look good. |
15th January 2020, 23:44 | #566 | Link |
I haven't looked at test patterns but with RGB 8 bit output on the GPU, I never see banding where there shouldn't be on my C8.
Nor do I notice anything wrong with motion with 2160p23 Maybe I'm just not as picky.. Last edited by quietvoid; 15th January 2020 at 23:46. |
16th January 2020, 00:56 | #569 | Link |
Thanks SamuriHL.
VBB you are right! Image looks better at YCbCr 4:2:2 10-bit. Shadow details are more conspicuous
16th January 2020, 01:18 | #570 | Link |
Is it also the same to you guys? I can't get fullscreen exclusive. Only 8bit window
Maybe I missed something?
16th January 2020, 01:49 | #571 | Link |
If you're on windows 10, use window mode as full screen exclusive doesn't work on later windows 10 builds. I've not had any issues with window mode.
16th January 2020, 04:40 | #572 | Link |
@Magik Mark - Yes to FS windowed, madVR 10-bit 0-255, OLED Black Level Low. There is a bug in madVR, where it sometimes switches back to 8-bit playback, even though everything is set to 10-bit. When that happens, only a reboot fixes it for me.
16th January 2020, 13:56 | #574 | Link |
I have also observed that indicating your actual number of CPU threads in "Threads for MultiThreading" found in LAV Video Decoder gives smoother playback especially when running your CPU in almost full load, just liken when encoding videos.
All along I thought NGU AA very high was the culprit in dropping frames. I was mistaken.
16th January 2020, 18:42 | #578 | Link |
That's good news, do you have a link? But since the SoC is not much different compared to last year (alpha 9 gen 2 vs gen 3), I can't imagine where the improvemnt comes from, firmware?
16th January 2020, 23:05 | #580 | Link |
With video card limited, madVR full, and TV low, everything would be fine. Another option would be video card full, madVR full, TV high. Any reason why you're doing what you're doing?
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex Last edited by VBB; 16th January 2020 at 23:09. |
