15th June 2016, 00:39 | #61 | Link | ||
EDIT: oh, and I noticed that your scripts don't say anything about converting to RGB. That might be necessary if the edges are being cropped by an odd number of pixels. Or maybe the script just assumes that the colorspace is already RGB. I seriously have no idea.
I ask unusual questions but always give proper thanks to those who give correct and useful answers. Last edited by Katie Boundary; 15th June 2016 at 00:47. |
15th June 2016, 00:59 | #62 | Link | |
Script updated. (You would not want to use it though, too unstable). EDIT: Script will handle any Progressive colorspace.
15th June 2016, 01:15 | #63 | Link | |
GSCript(""" Function Katie_Lo(clip c,int n,Int WKill,Int HKill,Bool Subs) { c XMod = RT_ColorSpaceXMod # Left and Right scan Width : eg 1 for RGB, 2 for YV12 & YUY2 WKill = (WKill + XMod-1) / XMod * XMod # Round UP Will return WRONG SIZE and Error Alert of WKill not multiple of XMod. Lft=0 Rgt=0 While(Lft+Rgt<WKill) { LAve=RT_AverageLuma(n=n,x=Lft,y=0,w=XMod,H=0) RAve=RT_AverageLuma(n=n,x=Width-XMod-Rgt,y=0,w=XMod,H=0) if(LAve<RAve) {Lft = Lft + XMod} # Lft is darker than Rgt else if(RAve<LAve) {Rgt = Rgt + XMod} # Rgt is darker than Lft else if(Lft<Rgt) {Lft = Lft + XMod} # Lft and Rgt same AveLuma AND Lft < Rgt else {Rgt = Rgt + XMod} # Lft and Rgt same AveLuma AND Rgt <= Lft } YMod = RT_ColorSpaceYMod(Laced=False) # Top and Bot Scan Height : eg 1 for RGB and YUY2, 2 for YV12 HKill = (HKill + YMod-1) / YMod * YMod # Round UP Will return WRONG SIZE and Error Alert of HKill not multiple of YMod. Top=0 Bot=0 While(Top+bot<HKill) { TAve=RT_AverageLuma(n=n,x=0,y=Top,w=0,H=YMod) BAve=RT_AverageLuma(n=n,x=0,y=Height-YMod-Bot,w=0,H=YMod) if(TAve<BAve) {Top = Top + YMod} # Top is darker than Bot else if(BAve<TAve) {Bot = Bot + YMod} # Bot is darker than Top else if(Top<Bot) {Top = Top + YMod} # Top and Bot same AveLuma AND Top < Bot else {Bot = Bot + YMod} # Top and Bot same AveLuma AND Bot <= Top } Crop(Lft,Top,-Rgt,-Bot) (Subs)?RT_Subtitle("Lft=%d Rgt=%d : Top=%d Bot=%d",Lft,Rgt,Top,Bot,Align=5):NOP Return Last } Function Katie(clip c,Int "WKill",Int "HKill",Bool "Subs") { WKill=Default(WKill,0) HKill=Default(HKill,0) Subs=Default(Subs,False) Dummy=c.Crop(WKILL,HKILL,0,0) # Scriptclip can ONLY return same size clip as arg, so we create dummy clip SCRIPT = "return Katie_Lo(c,current_frame,WKill,HKill,Subs)" # We use c clip and simply discard the dummy clip Return Dummy.ScriptClip(SCRIPT,Args="c,WKILL,HKILL,Subs") # Import c (full uncropped) clip into Scriptclip (req Grunt) } """) ##################################### #Avisource("CabaretUncropped.avi") # My Test clip ### Katie's Config Below mpeg2source("001.d2v") bob(b=0,c=1) selecteven() # WKILL = 16 HKILL = 0 SUBS = True # Katie(wkill=WKILL,hkill=HKILL,subs=SUBS) simpleresize(352,240) ### Return Last EDIT: Even if encoded in CPP, would be slowish (and unstable), a simple Crop() is considered a 'zero cost' filter, especially if not aligning in memory (just adjusts offset within the frame descriptor), but this function would not only have to scan each and every frame, would also need to vary the coords to copy into a new frame (no great overhead I guess). I would not waste my time converting this to CPP but is interesting exercise in script. RoboCrop prescans 40(default) frames in constructor (less than 1.0 second usually) before frame serving starts, after that is little different to a zero cost crop() filter (when align=false[default]). EDIT: Is real slow when cropping all four sides of my Cabaret test clip (Liza Minnelli) with borders about 28,90,-24,-92. EDIT: I wonder if there is a better (hier rez) version of Cabaret, mine came as freebie on cover of tabloid newspaper.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2016 at 05:40. |
15th June 2016, 02:08 | #64 | Link |
You... you'd have me bob, selecteven, bob again, selecteven again, resize, and then resize again?
Or did you not read my post carefully enough? When I have no idea how your script actually works, I can't distinguish between what you're trying to say and what you're actually saying, which makes it absolutely critical that the rest of our communication be specific and 100% accurate. When I ask you what to replace one line of my script with, and you respond with a complete script, that's a sign that we're not communicating clearly. I was able to catch this communication error, but what errors have escaped my attention? And what the hell is "CabaretUncropped.avi"? Why is it in the script?
I ask unusual questions but always give proper thanks to those who give correct and useful answers. |
15th June 2016, 02:20 | #65 | Link | |
The last script spoon feeds you with everything. EDIT: The first ever program on UK ITV Television on 22 Sept 1955 was a childrens TV program called "Muffin the Mule". I always thought it sounded like something you would get jail for [Except in certain US states] EDIT: Seems I'm wrong about Muffin the Mule, not even on ITV:- http://home.bt.com/news/world-news/s...11364005683860 https://en.wikipedia.org/wiki/Muffin_the_Mule https://www.youtube.com/watch?v=spQY2FbCUtM Dont know where I got that from
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2016 at 06:14. |
17th June 2016, 05:20 | #66 | Link |
BTW Stainless I'm sorry that this is taking so long. I've been sidetracked by several different things in the past few days. However, my WoW subscription expired earlier today so I should have some results to report tomorrow.
18th June 2016, 04:31 | #67 | Link |
Well now, THIS is neat. Not only is the script clipping the borders pretty closely to where it should, but it's giving me some white text telling me exactly what it's clipping from each frame, thus saving me a whole LOT of trouble that I thought I'd have to go through with copying source frames to clipboards and seeing exactly what parts of the original image they corresponded to... the bad news is, it's only cropping in increments of two.
I'll do more thorough stress-testing in the next few days. For now, StainlessS, I am quite impressed with your black magic. I must learn what all this arcane jibberish means... EDIT: adding converttorgb and replacing simpleresize with bilinear fixed the even-numbered pickiness. It's now cropping exactly where it's supposed to: 11 off the left and 5 off the right, occasionally veering into 12/4 or 10/6 when it's supposed to. If I still had a Paypal account, I would send you five bucks. EDIT 2: The first experiment used Exo Squad episode 4, "Blitzkreig". The second run, using episode 2, "Seeds of Deception", proved far more... interesting. The black bars were somewhere in the neighborhood of 4,-7, so the results should have ranged from 7,-9 to 6,-10. Actual results were quite a bit more erratic... It definitely seemed like the filter wasn't very good at handling thinner-than-expected black bars, especially when one edge of the screen was a lot darker than the other. This is exactly what I expected from the first-draft version of the filter, before I figured out that this is exactly what would happen. The good news is that I've had the time to figure out how the second-draft version might work. It requires setting an arbitrary threshold parameter and involves a much more complicated decision tree, though...
I ask unusual questions but always give proper thanks to those who give correct and useful answers. Last edited by Katie Boundary; 18th June 2016 at 15:51. |
18th June 2016, 17:42 | #68 | Link |
Yep, YV12 [from mpeg2source("001.d2v")] can only be cropped mod2 [both horiz & vert, you cannot crop a chroma sample in half],
convertToRGB24/32 as RGB can be cropped mod1. [might be faster to, convertToYV24, Katie(...), ConvertToRGB for display <cannot normally view YV24>]. EDIT: Below inquires current colorspace min cropping increment. Code:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th June 2016 at 17:44. |
21st June 2016, 04:46 | #69 | Link |
RoboCrop v1.08, new version. See 1st post.
V1.08 Docs overflow 16kb limit, so left first post docs at v1.0. See post #37 for v1.08 Docs over two posts. Here: http://forum.doom9.org/showthread.ph...03#post1696703 Code:
v1.06, Changed Default WMod to 4, avoid possible problems in Avisynth v2.58, some media players and VDubMod. Changed Default AutoThresh to -40.0, been wanting to do this for some time. Changed default Samples to 40, paranoia. v1.07, Changed to recognise AutoThresh of both -32.0 and -40.0 as DEFAULT AUTOTHRESH (both old and new version args). v1.08, wmod,hmod limited max 16. Fixed crop centering. EDIT: Code:
AvisourcE("CabaretUncropped.avi") A=RoboCrop(WMod=16,HMod=16,Laced=false, show=true,CropMode=1).Trim(13858,-1) # 1 frame CropLess B=A.BlankClip(height=4,color=$FFFFFF) # white separator C=RoboCrop(WMod=16,HMod=16,Laced=false, show=true,CropMode=2).Trim(13858,-1) # 1 frame CropMore StackVertical(A,B,C)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 16th July 2017 at 00:25. |
24th August 2016, 15:07 | #70 | Link |
RoboCrop v1.09, new version.
Small change only. Code:
Show: Default false. If true, then does no cropping, just shows a little info on frame. Overrides both Blank and Align. v1.09, Added cross hair reticule when show=True. Larger markings are 10 pixels apart, dots are 5 pixels apart. Perhaps of use where borders not of fixed position. See 1st post. EDIT: Code:
Int LeftAdd, TopAdd, RightAdd, BotAdd, All default 0. Valid range depends upon clip dimensions, Skip and Baffle settings. User adjustments to Skip + Autocrop exact found coords. CropMode applied after user Add adjustments.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 7th January 2019 at 07:16. |
25th August 2016, 18:23 | #71 | Link |
v1.10, new version. See 1st post or docs here:- http://forum.doom9.org/showthread.ph...03#post1696703
Show: Default false. If true, then does no cropping, just shows a little info on frame. Overrides both Blank and Align. Final image edge positions shown as dotted lines every fifth pixel set white, always shown. Final image edge markers show edge after any User adjustment via Add args (LeftAdd, TopAdd, RightAdd, BotAdd), and also after Modn rounding applied (CropMore/CropLess). Exact image edges are shown if not exactly coinciding with Final Image Edge markers, Exact image edge markers shown as every 3rd pixel plotted in white. Where the Skip args (LeftSkip, TopSkip, RighSkip, BotSkip) are non zero, will show skip positions as dotted lines with dots every other pixel, not plotted if exact same position at final Modn (CropMore/CropLess) position or detected exact edge position. The Skip args preset the 'already cropped area', ie auto cropping starts with edges already considered border. Added cross hair reticule when show=True. Larger markings are 10 pixels apart, dots are 5 pixels apart. Perhaps of use where borders not of fixed position. script used. Code:
AviSource("D:\V\CabaretUnCropped.avi") RoboCrop(laced=False,Show=True,Debug=true,LeftSkip=5,TopSkip=5,RightSkip=5,BotSkip=5,LeftAdd=4,TopAdd=4,RightAdd=4,BotAdd=4) Return last Exact top edge y1, at 89, User adjustment to 93, and then rounded YMod=2 to 94 (CropMore). EDIT: Debug output Code:
00000004 18:25:58.937 RoboCrop: RoboCrop: v1.10 - 25 Aug2016 - By StainlessS 00000005 18:25:58.937 RoboCrop: Input: Width=720 Height=576 FrameCount=15285 00000006 18:25:58.937 RoboCrop: 00000007 18:25:58.937 RoboCrop: Thresh defaulting to DEFAULT AUTOTHRESH -40.00 00000008 18:25:58.937 RoboCrop: Thresh -40.00 recognised as DEFAULT AUTOTHRESH 00000009 18:25:58.937 RoboCrop: Potential Auto Credits Skip Start@5%=764 End @90%=13756 : Range=12993 00000010 18:25:58.937 RoboCrop: Skip Start(764) and End(13756) : Range=12993 00000011 18:25:58.937 RoboCrop: 00000012 18:25:58.937 RoboCrop: Samples=40 Thresh=-40.000 Laced=False Matrix=2 00000013 18:25:58.937 RoboCrop: WMod=4 HMod=2 {Colorspace/Laced Restricted XMod=2 YMod=2} 00000014 18:25:58.937 RoboCrop: RLBT=15 Ignore=0.400 Baffle=4 00000015 18:25:58.937 RoboCrop: ScaleAutoThreshRGB=Yes ScaleAutoThreshYUV=No 00000016 18:25:58.937 RoboCrop: CropMode=2(CropMore) Blank=No Align=No Show=Yes Log=No 00000017 18:25:58.937 RoboCrop: Atm=4.000 SampStart=764 SampEnd=13756 SampRange=12993 00000018 18:25:58.937 RoboCrop: LeftAdd=4 TopAdd=4 RightAdd=4 BotAdd=4 00000019 18:25:58.937 RoboCrop: LeftSkip=5 TopSkip=5 RightSkip=5 BotSkip=5 00000020 18:25:58.937 RoboCrop: 00000021 18:25:58.953 RoboCrop: AutoThresh 1) [ 764] YPlaneMin = 14 (14) 00000022 18:25:58.968 RoboCrop: AutoThresh 2) [ 1097] YPlaneMin = 14 (14) 00000023 18:25:58.984 RoboCrop: AutoThresh 3) [ 1430] YPlaneMin = 14 (14) 00000024 18:25:59.000 RoboCrop: AutoThresh 4) [ 1763] YPlaneMin = 14 (14) 00000025 18:25:59.015 RoboCrop: AutoThresh 5) [ 2097] YPlaneMin = 14 (14) 00000026 18:25:59.031 RoboCrop: AutoThresh 6) [ 2430] YPlaneMin = 15 (14) 00000027 18:25:59.062 RoboCrop: AutoThresh 7) [ 2763] YPlaneMin = 14 (14) 00000028 18:25:59.093 RoboCrop: AutoThresh 8) [ 3096] YPlaneMin = 14 (14) 00000029 18:25:59.125 RoboCrop: AutoThresh 9) [ 3429] YPlaneMin = 14 (14) 00000030 18:25:59.140 RoboCrop: AutoThresh 10) [ 3762] YPlaneMin = 14 (14) 00000031 18:25:59.156 RoboCrop: AutoThresh 11) [ 4095] YPlaneMin = 14 (14) 00000032 18:25:59.187 RoboCrop: AutoThresh 12) [ 4428] YPlaneMin = 14 (14) 00000033 18:25:59.203 RoboCrop: AutoThresh 13) [ 4762] YPlaneMin = 14 (14) 00000034 18:25:59.234 RoboCrop: AutoThresh 14) [ 5095] YPlaneMin = 14 (14) 00000035 18:25:59.250 RoboCrop: AutoThresh 15) [ 5428] YPlaneMin = 14 (14) 00000036 18:25:59.265 RoboCrop: AutoThresh 16) [ 5761] YPlaneMin = 14 (14) 00000037 18:25:59.281 RoboCrop: AutoThresh 17) [ 6094] YPlaneMin = 14 (14) 00000038 18:25:59.296 RoboCrop: AutoThresh 18) [ 6427] YPlaneMin = 14 (14) 00000039 18:25:59.328 RoboCrop: AutoThresh 19) [ 6760] YPlaneMin = 14 (14) 00000040 18:25:59.343 RoboCrop: AutoThresh 20) [ 7093] YPlaneMin = 14 (14) 00000041 18:25:59.359 RoboCrop: AutoThresh 21) [ 7427] YPlaneMin = 15 (14) 00000042 18:25:59.375 RoboCrop: AutoThresh 22) [ 7760] YPlaneMin = 14 (14) 00000043 18:25:59.390 RoboCrop: AutoThresh 23) [ 8093] YPlaneMin = 14 (14) 00000044 18:25:59.406 RoboCrop: AutoThresh 24) [ 8426] YPlaneMin = 14 (14) 00000045 18:25:59.421 RoboCrop: AutoThresh 25) [ 8759] YPlaneMin = 14 (14) 00000046 18:25:59.437 RoboCrop: AutoThresh 26) [ 9092] YPlaneMin = 14 (14) 00000047 18:25:59.453 RoboCrop: AutoThresh 27) [ 9425] YPlaneMin = 14 (14) 00000048 18:25:59.468 RoboCrop: AutoThresh 28) [ 9758] YPlaneMin = 14 (14) 00000049 18:25:59.484 RoboCrop: AutoThresh 29) [ 10092] YPlaneMin = 14 (14) 00000050 18:25:59.500 RoboCrop: AutoThresh 30) [ 10425] YPlaneMin = 14 (14) 00000051 18:25:59.515 RoboCrop: AutoThresh 31) [ 10758] YPlaneMin = 14 (14) 00000052 18:25:59.531 RoboCrop: AutoThresh 32) [ 11091] YPlaneMin = 14 (14) 00000053 18:25:59.546 RoboCrop: AutoThresh 33) [ 11424] YPlaneMin = 14 (14) 00000054 18:25:59.562 RoboCrop: AutoThresh 34) [ 11757] YPlaneMin = 14 (14) 00000055 18:25:59.578 RoboCrop: AutoThresh 35) [ 12090] YPlaneMin = 14 (14) 00000056 18:25:59.593 RoboCrop: AutoThresh 36) [ 12423] YPlaneMin = 14 (14) 00000057 18:25:59.609 RoboCrop: AutoThresh 37) [ 12757] YPlaneMin = 14 (14) 00000058 18:25:59.625 RoboCrop: AutoThresh 38) [ 13090] YPlaneMin = 14 (14) 00000059 18:25:59.640 RoboCrop: AutoThresh 39) [ 13423] YPlaneMin = 14 (14) 00000060 18:25:59.656 RoboCrop: AutoThresh 40) [ 13756] YPlaneMin = 14 (14) 00000061 18:25:59.656 RoboCrop: 00000062 18:25:59.656 RoboCrop: YPlaneMin=14 : Automatic set Thresh=54.000 00000063 18:25:59.656 RoboCrop: 00000064 18:25:59.656 RoboCrop: Top 1) [ 764] AveY= 54.30 Y1=178 00000065 18:25:59.656 RoboCrop: Bot 1) [ 764] AveY= 58.04 Y2=484 00000066 18:25:59.656 RoboCrop: Lft 1) [ 764] AveY= 54.79 X1=154 00000067 18:25:59.656 RoboCrop: Rgt 1) [ 764] AveY= 54.75 X2=695 00000068 18:25:59.656 RoboCrop: Lft 3) [ 1430] AveY= 54.43 X1= 28 00000069 18:25:59.671 RoboCrop: Top 9) [ 3429] AveY= 54.11 Y1=177 00000070 18:25:59.671 RoboCrop: Rgt 10) [ 3762] AveY= 69.26 X2=696 00000071 18:25:59.671 RoboCrop: Top 14) [ 5095] AveY= 54.04 Y1= 89 00000072 18:25:59.734 RoboCrop: 00000073 18:25:59.734 RoboCrop: Active Frames (where image coords first found) = 5 00000074 18:25:59.734 RoboCrop: Sampled ImageEdge: X1=28 Y1=89 X2=696(W=669,-23) Y2=484(H=396,-91) 00000075 18:25:59.734 RoboCrop: 00000076 18:25:59.734 RoboCrop: User Adjust: X1=32 Y1=93 X2=692(W=661,-27) Y2=480(H=388,-95) 00000077 18:25:59.734 RoboCrop: 00000078 18:25:59.734 RoboCrop: Crop(ModW/H): X = 32 Y = 94 W =660(-28) H =386(-96) 00000079 18:25:59.734 RoboCrop: Constructor Scan Total Time=0.812 secs right and bottom (adjacent dotted lines). Left edge did not need rounding. Code:
RoboCrop(laced=False,Show=True)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 7th January 2019 at 07:17. |
18th January 2017, 00:36 | #73 | Link |
The is no 64 bit version of RoboCrop (leastwise not by me). what MediaFire link are you talking about that returns as 'invalid' ?
EDIT: I did try to do some filter in 64 bit (I'm on XP32) some time ago, but it did not work, cant remember what it was.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th January 2017 at 00:48. |
18th January 2017, 01:07 | #74 | Link | |
http://avisynth.nl/index.php/Externa...64-bit_filters It's under "Borders and Cropping". It points to MediaFire. |
18th January 2017, 02:47 | #75 | Link |
You were looking in the wrong place, should have taken this link at page you linked (link marked in Blue)
64-bit filters A comprehensive list of 64-bit filters is available in the AviSynth+ page RoboCrop is not in the list, however AutoCrop is (but it was not that good unless improved since I last tried).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th January 2017 at 05:10. |
18th January 2017, 03:48 | #76 | Link |
I can see how you would have thought that but I had looked at the page you suggested too. I was looking for and found other 64 bit filters like Colormatrix which is not on that list. I dug a little deeper and was just wondering if anyone had a copy. Yes, AutoCrop is on the list and I am using it, but I prefer to use yours over that one as I have found cases where AutoCrop fails.
Thanks. |
18th January 2017, 05:00 | #77 | Link | ||
and the 64 bit section was simply a link to the Avs+ 64 bit page, no other plugins on the original page are 64 bit. (although they may have counterparts on the 64 bit page). Quote:
EDIT: By the way, the 32 bit RoboCrop MediaFire link should not really have been put up on the Wiki, old dll zips are deleted when a new version is uploaded, so direct links on MediaFire will be invalid, Wiki should really point links at the StainlessS folder on MediaFire or the plugin thread on D9, which will in turn point to MediaFire/StainlessS folder.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 18th January 2017 at 06:49. |
18th January 2017, 11:45 | #78 | Link | |
18th January 2017, 12:50 | #79 | Link | |
Groucho's Avisynth Stuff |
autocrop, crop |
