18th January 2017, 16:44 | #81 | Link |
Built with VC10_64, ICL didn't yield any advantage. I only tested it very briefly but it should be working fine.
Groucho's Avisynth Stuff |
18th January 2017, 20:01 | #82 | Link |
Thanx g2k4, no probs with that here. No surprise that ICL gives no advantage,, all work done before frame serving starts.
Mobile.
23rd October 2017, 18:43 | #83 | Link |
By the way, I eventually found out why I was having probs installing SDK 7.1 for VS 2008 (with 64bit), seems the SDK ISO I had was corrupt, with much of it missing but still occupying blank space, it failed on accessing some html file (whose name existed), but the file contents did not exist in the ISO (so install failed and uninstalled again).
Guess I really should check MD5's
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 23rd October 2017 at 22:34. |
7th January 2019, 06:43 | #84 | Link | |
RoboCrop v1.11, new version see 1st post.
For v1.11 Docs, see post #37:- https://forum.doom9.org/showthread.p...03#post1696703 Code:
v1.09, Added reticule when Show=true.. v1.10, Added Exact line marker when show. v1.11, 07 Jan 2019. Added Version Resource, Move to VS2008, Added x64, Changed default Align=True. Code:
Align: Default True. If true, then aligns frames in memory when cropping, for eg SSE2 16-byte alignment required by some filters, particularly smoothing filters (filters following RoboCrop). See Docs for Crop(). Only Applies if Cropping, ie Blank==false AND Show==false. v1.11, changed Default to True, avoid Avs+ problems which can put up an error if False. Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 7th January 2019 at 06:47. |
30th January 2019, 01:06 | #85 | Link | ||||
Dear StainlessS, first of all, thanks for all your scripts!
Back to topic: DynaCrop (https://forum.doom9.org/showthread.p...85#post1633485) I have a video with variable vertical borders; they are pixel perfect (no "smearing" like in analog captures). I want to get fixed borders for the whole video, so it seems your DynaCrop is the right script. Some questions: Quote:
Now, let's say that I want the video to be resized at 1920x816, where should I set these figures? Last thing: Quote:
Thanks a lot in advance, hope to not abuse (well, not too much!) of your infinite patience! |
30th January 2019, 01:57 | #86 | Link | |
Sorry, but I aint gonna go back to look at that, was long Superceded by DBSC:- https://forum.doom9.org/showthread.p...highlight=DBSC
I dont know of anything else that can do what DBSC can do, but it aint automatic. The current version is somewhat diferent to posted, but is not really suitable for posting yet. EDIT: You defo need DebugView, and need to use it.
24th April 2019, 16:45 | #87 | Link |
Why is it not working or even can not detect borders? I use potplayer
PPcheck=1#WIDTH PPcheck==1? eval (""" SetFilterMTMode("ffdshow_source",3) ffdshow_source() ConvertToYV12() global threads=2 #for regular player """) : eval (""" global threads=round(1.83 * #CPUS) #valid only for PotPlayer. You can calculate and input numbers of CPU Cores*2 manually SetFilterMTMode("potplayer_source",3) potplayer_source() """) LoadPlugin("avisynth\RoboCrop_x86.dll") LoadPlugin("autocrop.dll") #autocrop(mode=1) RoboCrop(Samples=10,show=true) #RoboCrop(potplayer_source/ffdshow_source,show=true) If I just use crop, it works, but still can not get why robocrop/autocrop can not even recognize black borders (i've used pc level too) LoadPlugin("avisynth\RoboCrop_x86.dll") crop(100,100,400,376) RoboCrop(show=true) Last edited by Dreamject; 24th April 2019 at 17:02. |
25th April 2019, 13:12 | #88 | Link |
What does the debug output tell you, post it. [ RoboCrop(show=true,debug=true) # you need DebugView, google]
Try in something other than Potplayer, I've never even heard of PotPlayer_Source, Suggest Vdub2. Does your clip have sections without any border, if so then it is doing exactly what its supposed to do. Absolutely no idea what is happening with your 2nd image, I would say that result is impossible. (dont have any idea what the blue stuff says either). Also, suggest that you do not change Samples, default 40 samples would probably take less than a second to scan. EDIT: What is the clip length ? RoboCrop deliberately alters thresh for short clips (when using Default autothresh, Thresh = -32.0 or thresh = -40). [to avoid overcrop on short dark clips] If your clips are dark (and they look like they are), and also short, then set a non DEFAULT_AUTOTHRESH. Code:
Thresh: Default= -40.0 (==DEFAULT AUTOTHRESH, any -ve (or 0.0) Thresh is AUTOTHRESH where Thresh adjustments are automatic). v1.06, Changed DEFAULT AUTOTHRESH from -32.0 to -40.0. v1.07, Changed to recognise a Thresh of either -32.0 or -40.0 as DEFAULT_AUTOTHRESH (fully automatic). Thresh > 0: (Explicit Threshold) A user supplied +ve Thresh should be at correct TV/PC levels for the the clip being worked on ie 16->235 for TV levels and 0->255 for PC Levels (RGB, as appropriate for matrix being used). Thresh <= 0: (AUTOTHRESH) When Thresh <= 0, the clip will be sampled over Samples frames to find the minimum YPlaneMin (using Matrix if RGB) which we will call MINLUMA and an Explicit Threshold calculated by adding MINLUMA to abs(Thresh), after that it is processed as for Thresh > 0: (Explicit Threshold) as noted above, but, before adding MINLUMA, some AUTOTHRESH massaging and scaling occurs. Here AUTOTHRESH Thresh massaging and scaling occurs in sequence:- 1 ) if (Thresh == DEFAULT AUTOTHRESH && ATM < abs(thresh)) (DEFAULT AUTOTHRESH = exactly -40.0, defaulted OR user supplied, v1.07 also recognises -32.0 as DEFAULT_AUTOTHRESH): Let sampstart and sampend, be starting and ending frames numbers after any Auto Credits skipping and/or user set Start or End. Let Samples be limited to sampend-sampstart+1. Let SampRange (Sample Range) = SampEnd-SampStart+1. samples_massage =(Samples>=20) ? 1.0 : (Samples-1) * (1.0/(20-1)) # No massaging if Samples >= 20 range_massage =(SampRange >= (250*20)) ? 1.0 : (SampRange-1) * (1.0/((250*20)-1)) # No massaging if SampRange >= 5000 Both samples_massage and range_massage will be in range 0.0 to 1.0. Thresh = -(((samples_massage * range_massage) * (abs(Thresh) - ATM)) + ATM) This adjustment to Auto Thresh is to reduce the possibility of overcropping on eg a dark low 'Samples' clip, or where source SampRange (ie temporal frame set) is too small to take a reliable sample from. Resulting massaged Thresh will range between -ATM and DEFAULT_AUTOTHRESH. Although massaging is intended to reduce overcropping, it could result in not cropping enough border (less disastrous), its a bit of a balancing act really. See also ATM. 2 ) If RGB AND PC matrix(default) AND ScaleAutoThreshRGB==True(default) then Thresh= Thresh*(255.0/(235-16)) 3 ) If YUV AND ScaleAutoThreshYUV==True(default=false) then Thresh= Thresh*(255.0/(235-16)) Steps 2) and 3) above, by default treat a -ve AUTOTHRESH as being @ TV Levels and so Scale RGB Thresh to PC levels but not YUV. If you want to supply a PC levels AUTOTHRESH Thresh for RGB, then simply set ScaleAutoThreshRGB=false to inhibit scaling. Note, if a TV levels Matrix is supplied for RGB, then scaling will always be inhibited. If your clip is YUV at PC levels and you want to use eg DEFAULT AUTOTHRESH (-40.0, which is considered to be @ TV levels), then set ScaleAutoThreshYUV=True to enable Thresh scaling. If your clip is YUV at PC levels and you want to use a PC levels AUTOTHRESH (-ve) then leave ScaleAutoThreshYUV at default false which does not scale Thresh. After any scaling, MINLUMA is then added to abs(Thresh) and processed as for +ve Explicit Threshold as noted above. NOTE, Above RoboCrop step 1) 'massages' DEFAULT_AUTOTHRESH (exactly -40.0 or v1.07 exactly -32.0) if low samples count or if short clip. Reason being to avoid overcropping when insufficient data available for reliable cropping. It is considered better to not crop enough or at all, than to overcrop. You can override by simply setting an explicit threshold (+ve) of eg 40.0, or setting a NON-DEFAULT auto thresh (-ve) eg -16.0 or -40.1, where YPlaneMin is established for the sampled frames and then abs(thresh) is added to that value which is then used as an explicit thresh. NOTE, v1.07 recognises a Thresh of either -40.0 OR -32.0 as DEFAULT_AUTOTHRESH, so user can provide either value and DEFAULT_AUTOTHRESH massaging will be applied for low samples count and/or low frame ranges.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 25th April 2019 at 14:15. |
6th February 2020, 19:02 | #89 | Link |
RoboCrop v1.12, update, see first post.
Added ScanPerc, allows detect when image is wholly one or other side of clip center. Code:
Function RoboCrop(clip c,int "Samples"=40,Float "Thresh"=-40.0,bool "Laced"=true,int "WMod",int "HMod",int "RLBT"=15,bool "Debug"=false, \ float "Ignore"=0.4,int "Matrix"=(c.Width>1100||c.Height>600?3:2), int "Baffle"=4, bool "ScaleAutoThreshRGB"=true, bool "ScaleAutoThreshYUV"=false, int "CropMode"=2,bool "Blank"=false,bool "BlankPC"=false,bool "Align"=True,bool "Show"=false, \ String "LogFn"="",bool "LogAppend"=false, Float "ATM"=4.0,int "Start"=Undefined,Int "End"=Undefined, \ Int "LeftAdd"=0,Int "TopAdd"=0,Int "RightAdd"=0,Int "BotAdd"=0, \ Int "LeftSkip"=0,Int "TopSkip"=0,Int "RightSkip"=0,Int "BotSkip"=0 \ Float "ScanPerc=49.0 ) Code:
Float ScanPerc, Default 49.0, Range 1.0->99.0. Precentage of clip dimensions to scan for border edges. Default 49.0%, Starts scan from nearly the middle of frame to outer edge of frame looking for borders. Specialist use, might use eg 99.0% when image wholly to one of other side of the middle of frame. eg, when 99.0, starts scan for TOP edge at nearly bottom of frame, scanning upwards. starts scan for BOT edge at nearly top of frame, scanning downwards. starts scan for LFT edge at nearly RHS of frame, scanning leftwards. starts scan for RGT edge at nearly LHS of frame, scanning rightwards. Code:
BlankClip(width=1024,height=768,Pixel_type="YV12").trim(0,-1) W=Last.BlankClip(width=320,height=240,color=$FF00FF) OverLay(W,x=680,y=416) RoboCrop(Samples=1,debug=true,ScanPerc=99,show=true) Return Last#.info Show=true [from old version 1.06] Show=true [from old version 1.10] Bottom image above: Left edge, single dots line, other edges a bit wiggly ie cropping moved inwards [CROPMORE] to adhere to X/Y/W/H Mod requirements. EDIT: AutoCrop() fails badly [with defaults] on a 10 mins clip surrounding above frame from Cabaret. [chops off half of frame, not much image left]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th February 2020 at 22:56. |
6th February 2020, 23:42 | #91 | Link |
StainlessS,
Does RoboCrop only support 8 bit video? If that's the case do you have any plans? Being all new and shiny I assumed it would support high bitdepths, so I was going to replace AutoCrop with RoboCrop in my script, but I appear to have assumed incorrectly. I also have a feature request if it's not hard to do. For a future version would it be possible to display the cropping in human-speak in addition to the current method? ie Crop(8,52,-16,-52) and Crop(8,52,1256,616) The dimensions in human-speak would be great too. Something like: Source Dimensions 1280x720 Cropped Dimensions 1256x616 I realise the information is already there. It's just a habit thing, or maybe I'm an idiot, but I don't see it displayed in other ways regularly, so I invariably need to down-tools for a bit while I think about it. Cheers. Last edited by hello_hello; 6th February 2020 at 23:49. |
7th February 2020, 00:31 | #92 | Link | |
You are welcome Hotte
Hello_Hello, Quote:
Crop(28,90,668,394) [CROPMORE] From prev posted script for lob-sided borders (Debug=True) Code:
00000146 23:22:07.597 RoboCrop: v1.12 - 06 Feb 2020 - By StainlessS 00000147 23:22:07.597 Input: Width=1024 Height=768 FrameCount=1 00000149 23:22:07.597 Thresh defaulting to DEFAULT AUTOTHRESH -40.00 00000150 23:22:07.597 Thresh -40.00 recognised as DEFAULT AUTOTHRESH 00000151 23:22:07.597 Potential Auto Credits Skip Start@5%=0 End @90%=0 : Range=1 00000152 23:22:07.597 No Skip Start(0), No Skip End(0) : Range=1 [Skip range < 250] 00000153 23:22:07.597 Low Samples count(1), Massaging Auto Thresh(samples scaler=0.000000) 00000154 23:22:07.597 Low Frames Range(1), Massaging Auto Thresh(range scaler=0.000000) 00000155 23:22:07.597 Combined Thresh Massage Scaler=0.000000 00000156 23:22:07.597 Auto Thresh reduced from DEFAULT -40.000000 to -4.000000 00000158 23:22:07.597 Samples=1 Thresh=-4.000 Laced=True Matrix=3 00000159 23:22:07.597 WMod=4 HMod=4 {Colorspace/Laced Restricted XMod=2 YMod=4} 00000160 23:22:07.597 RLBT=15 Ignore=0.400 Baffle=4 00000161 23:22:07.597 ScaleAutoThreshRGB=Yes ScaleAutoThreshYUV=No 00000162 23:22:07.597 CropMode=2(CropMore) Blank=No Align=Yes Show=Yes Log=No 00000163 23:22:07.597 Atm=4.000 SampStart=0 SampEnd=0 SampRange=1 00000164 23:22:07.597 LeftAdd=0 TopAdd=0 RightAdd=0 BotAdd=0 00000165 23:22:07.597 LeftSkip=0 TopSkip=0 RightSkip=0 BotSkip=0 00000166 23:22:07.597 ScanPerc=99.000000 00000168 23:22:07.597 AutoThresh 1) [ 0] YPlaneMin = 16 (16) 00000170 23:22:07.597 YPlaneMin=16 : Automatic set Thresh=20.000 00000172 23:22:07.597 Top 1) [ 0] AveY= 44.13 Y1=416 00000173 23:22:07.597 Bot 1) [ 0] AveY= 44.13 Y2=655 00000174 23:22:07.597 Lft 1) [ 0] AveY=106.00 X1=680 00000175 23:22:07.597 Rgt 1) [ 0] AveY=106.00 X2=999 00000177 23:22:07.597 Active Frames (where image coords first found) = 1 00000178 23:22:07.597 Sampled ImageEdge: X1=680 Y1=416 X2=999(W=320,-24) Y2=655(H=240,-112) 00000180 23:22:07.597 Crop(ModW/H): X =680 Y =416 W =320(-24) H =240(-112) 00000181 23:22:07.597 Constructor Scan Total Time=0.000 secs I aint had enough play as yet to do a plug, and first one would have to be DDigit text renderer, which I would need in a lot of my plugs. [Info.h Metrics text renderer from Avs+ source does not support HBD either, leastwise last time I looked.] Maybe one day, but not today, sorry.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 7th February 2020 at 02:37. |
7th February 2020, 02:27 | #93 | Link | |
I rarely work with HBD video anyway, but while I was playing with RoboCrop I thought I'd ask. Cheers. |
7th February 2020, 06:14 | #94 | Link |
RoboCrop v1.13, update, see first post.
Full docs here:- https://forum.doom9.org/showthread.p...03#post1696703 Added Prefix Arg. Code:
Function RoboCrop(clip c,int "Samples"=40,Float "Thresh"=-40.0,bool "Laced"=true,int "WMod",int "HMod",int "RLBT"=15,bool "Debug"=false, \ float "Ignore"=0.4,int "Matrix"=(c.Width>1100||c.Height>600?3:2), int "Baffle"=4, bool "ScaleAutoThreshRGB"=true, bool "ScaleAutoThreshYUV"=false, int "CropMode"=2,bool "Blank"=false,bool "BlankPC"=false,bool "Align"=True,bool "Show"=false, \ String "LogFn"="",bool "LogAppend"=false, Float "ATM"=4.0,int "Start"=Undefined,Int "End"=Undefined, \ Int "LeftAdd"=0,Int "TopAdd"=0,Int "RightAdd"=0,Int "BotAdd"=0, \ Int "LeftSkip"=0,Int "TopSkip"=0,Int "RightSkip"=0,Int "BotSkip"=0 \ Float "ScanPerc=49.0,String "Prefix"="ROBOCROP_" ) Code:
String Prefix, Default "ROBOCROP_". Prefix for Local vars set by the filter, crop coordinates. Setting to "" disables Local vars. With Prefix="ROBOCROP_" (Default) ROBOCROP_X = X coord ROBOCROP_Y = Y coord ROBOCROP_W = +ve Width ROBOCROP_H = +ve Height ROBOCROP_W2 = -ve Width relative crop coord ROBOCROP_H2 = -ve Height relative crop coord Example use: <<<<<<<<< CODE START <<<<<<< BlankClip(Length=1,width=1024,height=768,Pixel_type="YV12") Wid=Width Hit=Height BLK=Last.BlankClip(width=320,height=240,color=$FF00FF) OverLay(BLK,x=680,y=416) RoboCrop(ScanPerc=99,show=true,debug=true,Prefix="ROBOCROP_") X=ROBOCROP_X # Get Local Vars as set by RoboCrop (Using Prefix, above using Prefix same as Default Prefix) Y=ROBOCROP_Y W=ROBOCROP_W H=ROBOCROP_H W2=ROBOCROP_W2 H2=ROBOCROP_H2 Subtitle("Source: Width="+String(Wid)+",Height="+String(Hit),Y=4) Subtitle("Crop("+String(X)+","+String(Y)+","+String(W)+","+String(H)+")",Y=24) Subtitle("Crop("+String(X)+","+String(Y)+","+String(W2)+","+String(H2)+")",Y=44) Return Last >>>>>>>>>> CODE END >>>>>>> Code:
BlankClip(Length=1,width=1024,height=768,Pixel_type="YV12") Wid=Width Hit=Height BLK=Last.BlankClip(width=320,height=240,color=$FF00FF) OverLay(BLK,x=680,y=416) RoboCrop(ScanPerc=99,show=true,debug=true,Prefix="ROBOCROP_") X=ROBOCROP_X # Get Local Vars as set by RoboCrop (Using Prefix, above using Prefix same as Default Prefix) Y=ROBOCROP_Y W=ROBOCROP_W H=ROBOCROP_H W2=ROBOCROP_W2 H2=ROBOCROP_H2 Subtitle("Source: Width="+String(Wid)+",Height="+String(Hit),Y=4) Subtitle("Crop("+String(X)+","+String(Y)+","+String(W)+","+String(H)+")",Y=24) Subtitle("Crop("+String(X)+","+String(Y)+","+String(W2)+","+String(H2)+")",Y=44) Return Last debug output Code:
00000123 04:58:04.155 RoboCrop: v1.13 - 07 Feb 2020 - By StainlessS 00000124 04:58:04.155 Input: Width=1024 Height=768 FrameCount=1 00000126 04:58:04.155 Samples (40) limited to FrameCount(1) 00000127 04:58:04.155 Thresh defaulting to DEFAULT AUTOTHRESH -40.00 00000128 04:58:04.155 Thresh -40.00 recognised as DEFAULT AUTOTHRESH 00000129 04:58:04.155 Potential Auto Credits Skip Start@5%=0 End @90%=0 : Range=1 00000130 04:58:04.155 No Skip Start(0), No Skip End(0) : Range=1 [Skip range < 250] 00000131 04:58:04.155 Low Samples count(1), Massaging Auto Thresh(samples scaler=0.000000) 00000132 04:58:04.155 Low Frames Range(1), Massaging Auto Thresh(range scaler=0.000000) 00000133 04:58:04.155 Combined Thresh Massage Scaler=0.000000 00000134 04:58:04.155 Auto Thresh reduced from DEFAULT -40.000000 to -4.000000 00000136 04:58:04.155 Samples=1 Thresh=-4.000 Laced=True Matrix=3 00000137 04:58:04.155 WMod=4 HMod=4 {Colorspace/Laced Restricted XMod=2 YMod=4} 00000138 04:58:04.155 RLBT=15 Ignore=0.400 Baffle=4 00000139 04:58:04.155 ScaleAutoThreshRGB=Yes ScaleAutoThreshYUV=No 00000140 04:58:04.155 CropMode=2(CropMore) Blank=No Align=Yes Show=Yes Log=No 00000141 04:58:04.155 Atm=4.000 SampStart=0 SampEnd=0 SampRange=1 00000142 04:58:04.155 LeftAdd=0 TopAdd=0 RightAdd=0 BotAdd=0 00000143 04:58:04.155 LeftSkip=0 TopSkip=0 RightSkip=0 BotSkip=0 00000144 04:58:04.155 ScanPerc=99.000000 00000145 04:58:04.155 Prefix='ROBOCROP_' 00000147 04:58:04.155 AutoThresh 1) [ 0] YPlaneMin = 16 (16) 00000149 04:58:04.155 YPlaneMin=16 : Automatic set Thresh=20.000 00000151 04:58:04.155 Top 1) [ 0] AveY= 44.13 Y1=416 00000152 04:58:04.155 Bot 1) [ 0] AveY= 44.13 Y2=655 00000153 04:58:04.155 Lft 1) [ 0] AveY=106.00 X1=680 00000154 04:58:04.155 Rgt 1) [ 0] AveY=106.00 X2=999 00000156 04:58:04.155 Active Frames (where image coords first found) = 1 00000157 04:58:04.155 Sampled ImageEdge: X1=680 Y1=416 X2=999(W=320,-24) Y2=655(H=240,-112) 00000159 04:58:04.155 Crop(ModW/H): X =680 Y =416 W =320(-24) H =240(-112) 00000160 04:58:04.155 Input: Width=1024 Height=768 00000161 04:58:04.155 Crop(680,416,320,240) 00000162 04:58:04.155 Crop(680,416,-24,-112) 00000163 04:58:04.155 Constructor Scan Total Time=0.000 secs
8th February 2020, 05:32 | #95 | Link |
That was speedy service. Thanks.
Is it always possible to get plugin variables that way, or is it something you've specifically had to configure? "Usage" looked a bit hard, so I made a wrapper function and sexed it up a bit, although I'm not sure what font you're using normally. I couldn't think of a better name, so it's called RoboCropped. It just calls RoboCrop with the options at their default values, but you can specify them as you can for RoboCrop, so to show the cropping preview it's Show=true as usual. The subtitles should sit in the bottom left corner. There's a link below. Have you used RoboCrop with much h264 video? It's really, really slow to open for me with the default settings. Your example avs and mpeg2 are okay, but the 720p sources I've been playing around with take between 30 seconds to 1 minute to open. If I reduce Samples to 1 it's okay, so I guess there's a lot of decoding that needs to be done when checking lots of frames. Cheers. RoboCropped.avsi (function edited 2020-02-29 to change scaling of subtitle text) Last edited by hello_hello; 28th February 2020 at 20:18. |
8th February 2020, 06:37 | #96 | Link | ||
if(debug) { dprintf("Crop(ModW/H): X =%3d Y =%3d W =%3d(%d) H =%3d(%d)", crop_x,crop_y,crop_w,crop_x+crop_w-w,crop_h,crop_y+crop_h-h); dprintf("Input: Width=%d Height=%d",w,h); dprintf("Crop(%d,%d,%d,%d)",crop_x,crop_y,crop_w,crop_h); dprintf("Crop(%d,%d,%d,%d)",crop_x,crop_y,crop_x+crop_w-w,crop_y+crop_h-h); // debug output if(isplanar && crop_w % 4) dprintf("*** WARNING *** Some players and VDubMod may require WMod=4"); double duration = (double(clock()) / double(CLOCKS_PER_SEC)) - start_time; dprintf("Constructor Scan Total Time=%.3f secs",duration); } if(prefix !="") { const char *p; int pfixlen=int(strlen(prefix)); if(pfixlen>128) pfixlen=128; char bf[128+32]; memcpy(bf,prefix,pfixlen); char *d; AVSValue var; d=bf+pfixlen; for(p="X";*d++=*p++;); // strcat variable name part var = GetVar(env,bf); env->SetVar(var.Defined()?bf:env->SaveString(bf),crop_x); d=bf+pfixlen; for(p="Y";*d++=*p++;); // strcat variable name part var = GetVar(env,bf); env->SetVar(var.Defined()?bf:env->SaveString(bf),crop_y); d=bf+pfixlen; for(p="W";*d++=*p++;); // strcat variable name part var = GetVar(env,bf); env->SetVar(var.Defined()?bf:env->SaveString(bf),crop_w); d=bf+pfixlen; for(p="H";*d++=*p++;); // strcat variable name part var = GetVar(env,bf); env->SetVar(var.Defined()?bf:env->SaveString(bf),crop_h); d=bf+pfixlen; for(p="W2";*d++=*p++;); // strcat variable name part var = GetVar(env,bf); env->SetVar(var.Defined()?bf:env->SaveString(bf),crop_x+crop_w-w); d=bf+pfixlen; for(p="H2";*d++=*p++;); // strcat variable name part var = GetVar(env,bf); env->SetVar(var.Defined()?bf:env->SaveString(bf),crop_y+crop_h-h); } Dont think I've ever seen anybody else check valid var name, I did it in one plug but forgot which one. RoboCrop scans from start to end of video clip, Samples number of frames [default 40], spread evenly throughout the clip. Is your source filter Indexing the thing, if so then that is where the pause is. [I usually use it with Ut_Video AVI, where it takes maybe less than 1.0 sec for 2 hr Movie]. LSMashVideoSource source does not index, although I dont know how well it does where seeking in big jumps through the video clip. RoboCrop tries to get the OutMost borders, so if borders change will try to find the least crop borders. "Usage" looked a bit hard" I usually just call as RoboCrop(), is intended to be mostly autonomous. [might want to set WMod, HMod, and Laced]. Quote:
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th February 2020 at 06:48. |
8th February 2020, 08:39 | #97 | Link | |
Thanks for the info.
I don't use auto cropping a lot, but I think the main reason AutoCrop's default settings might be more likely to fail isn't because it only takes 5 samples, but because the default for the first sample is the first frame, and the last sample is the second last frame. I'm not sure what the point of starting more than a few hundred frames from the beginning would be, especially for a movie and to avoid the end credits you'd probably want to finish a fair bit before the end too, but you'd no doubt know better than me. |
8th February 2020, 12:34 | #98 | Link |
Yes it normally starts at 5% and ends at 90% [below clip is only single frame so that is not gonna happen there, I said starts at beginning and ends at end, I was being economical with words.]
12th February 2020, 15:56 | #99 | Link |
HH,
Something just occurred to me, when you say RoboCrop is slow, maybe you are calling it last, after some heavy duty scripting, eg MCDegrain/QTGMC. This would cause it to sample eg McDegrain/QTGMC'ed frames, and so slow. I always use RoboCrop pre [nearly] everything else, just be sure to set Laced [ie interlaced, is default True] arg for interlaced sources. Cropping first, would take borders out prior to any eg Auto Gain/Levelling, may produce less frame to process. Deblocking might require a bit more thought, would need pad to mod 8 [usually], and done before cropping. [then remove padding] prior to autocrop] Prev post not quite correct, finds Potential Auto Credits skip frames at 5% and 90% Framecount [where at least 250 frames], thereafter spreads out samples frames like so Code:
00100100 # OR 00100100100 # OR 000010000 Also, where default SAMPLES = 40, will actually scan 80 frames, 40 sampled for YPlaneMin [to decide what Auto threshold should be], and then same 40 frames again to detect borders usng the auto set threshold. EDIT: I have occasionally come across clips where border color is quite a bit lighter than darkest luma in image part [maybe YPlaneMin=0, border=32], this tends to mess up the auto thresholding somewhat, and will may cause failure where no border is cropped. EDIT: You could also crop in YV24 for YMOD, HMod of 2.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 13th February 2020 at 18:31. |
21st October 2020, 18:12 | #100 | Link |
Hi StainlessS
is it possible to use RoboCrop to generate a mask instead of cropping? so the mask will be used in ExInpaint or AvsInpaint and the mask changes every frame of course
See My Avisynth Stuff |
autocrop, crop |
