Old 19th June 2019, 16:11   #241  |  Link
Groucho2004
Originally Posted by ChaosKing View Post
The profile/config for smdegrain needs to be updated in avsp mod. This is a manual task and can't be detected automatically as far as I know.
This can easily be done in a text editor ("filterdb.dat", search for smdegrain and change "int "prefilter"=0 (0 / 1 / 2 / 3)," to "int "prefilter"=0 (0 / 1 / 2 / 3 / 4),".
Groucho's Avisynth Stuff
Old 19th June 2019, 17:23   #242  |  Link
Zetti
Thank You, Working Fine.
Old 25th June 2019, 22:41   #243  |  Link
Natty
Noob
thanks for your collection i have been playing with it recently and have some questions
https://pastebin.com/CcMxX3xG - your FineDehalo. is it optimized for 16bit? because when i run ConvertBits(16).FineDehalo() it runs atleast 50% slower is it normal? same for your other filters. results are impressive when using whole script in native HBD but its so slow that its not usable.
will u update f3kdb for native high bit depth?
and i need your help in selective debanding.
for example. i use this for full clip.
f3kdb(range=30, y=50, Cb=50, Cr=50, grainY=50, grainC=50, keep_tv_range=true)
but i want to put more grain in some complex large flat and dark scenes only. how can i do that?
hoping for faster HBD filters in future. thanks for all your collection. i use most of them.
Natty is offline   Reply With Quote
Old 26th June 2019, 00:05   #244  |  Link
real.finder
yes many filters updated to work with HBD, and it will be slower than 8bit ofc
f3kdb is not a script so I can't, you should ask someone else for it but anyway you can use Double-Width hack for it
that can be done with masktools, there are already many examples around, you can search in https://forum.doom9.org/showthread.php?t=98985
See My Avisynth Stuff
Old 26th June 2019, 00:24   #245  |  Link
ChaosKing
You could try LumaDB http://avisynth.nl/index.php/External_filters#Debanding
Click also on the discussion link.
Old 26th June 2019, 20:15   #246  |  Link
Natty
Noob
thank you r.f and chaos, i will test and read about it.
Old 1st July 2019, 10:00   #247  |  Link
Natty
Noob
this this the latest version ?
https://pastebin.com/pzACBAX1
Old 2nd July 2019, 07:52   #248  |  Link
real.finder
yes it is
Old 17th July 2019, 22:00   #249  |  Link
DarkNite
Almost Silent Member
DarkNite's Avatar
Getting script error: Invalid arguments to function 'mt_convolution' for lines 18, 59, and 71 of the 2019.07.12 mod of DDComb. Typo in sbrV?
Rethinking the "Why?" chromosome.
DarkNite is offline   Reply With Quote
Old 17th July 2019, 22:08   #250  |  Link
real.finder
work fine here, what is your full script?
Old 20th July 2019, 18:33   #251  |  Link
real.finder
scripts state for float (32bit) chroma for now:-
aside from smaskmerge, in SMDegrain, Dither_Luma_Rebuild and SMDegrain_prefilters mode 3 both will give wrong output in chroma
but since mode 3 use Dfttest not work with float (32bit) yet this is not a big problem, Dither_Luma_Rebuild can be used in many scripts so it's problem for now, avoid use float (32bit) with it if you processes chroma
qtgmc in other hand has no problem but since there are a bug
will see the other scripts soon and then report back
edit: the same bug in qtgmc float (32bit) can be in other scripts
Old 21st July 2019, 03:42   #252  |  Link
real.finder
updates for FineDehalo, BalanceBorders, LSFmod, FastLineDarkenMOD, Masked_DHA, BlindDeHalo3 and DeHalo_alpha
all update are some changes in LUT things, mainly for speed up float (32bit)
Old 21st July 2019, 07:08   #253  |  Link
dREV
dREV's Avatar
I need to double post as the character limit is preventing me to place the script within one post.
Thanks for the updates. I am having issues with DebilinearM still. I'm guessing it maybe due to not being able to get the latest ResizeX_v1.0.1 mod 9 as it's still pending for approval so I only got mod 7. Would it be possible to provide a pastebin?
I'm receiving the following in avspmod: ResizeX does not have a named argument "dither_mode" (C: path\plugins64+\DebilinearM_v1.3.1_mod1.25.avsi, line 78) (New File, line 95).
Another subject. As mentioned on the ResampleMT thread, https://forum.doom9.org/showthread.p...89#post1879189 I came about this script just a few days ago but it's been available since 2016. Haven't seen it on any Doom9 thread for Avisynt just VaporSynth. It uses DebilinearM and Debilinear.dll for both versions of AviSynth x86 not sure for 64 bit.
This script, Gradfun3mod (https://forum.doom9.org/showthread.p...65#post1879765) I've been implementing it like so:
dither_convert_8_to_16()
ly = GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearM", lsb_in=true, lsb=true)
lc = nnedi3_resize16(1280*2, 720*2,lsb_in=true,lsb=true,kernel_d="Spline64",kernel_u="Spline64",src_top=0.0,src_left=0.50) #
lu = lc.UtoY()
lv = lc.VtoY()
YtoUV(lu,lv,ly)
Dither_out()
The issue thus far I've found is that for resolutions 1920x1080 > 1280x720 like say a old show in 4:3 with black borders it'll create a 1 pixel artifact on all 4 sides that even ContinuityFixer / EdgeFixer http://avisynth.nl/index.php/EdgeFixer won't be able to fix. I had to get around this by adding nnedi3_resize16(960, 720,lsb_in=true,lsb=true,kernel_d="Spline64",kernel_u="Spline64") below YtoUV(lu,lv,ly).
I'm not asking for anything but this if you may be interested in modifying this to work with your updated DebilinearM script using the ResampleMT plugin for Avisynth+.
Also, about this n16 matter. Is there a documentation about this? I like to know more as if I understood correctly this n16 is true 16 bit and not the somewhat fake 16 bit of lsb and how would I turn it off going 8 bit. Is there an new method of going:
DitherPost(mode=6)
& to end Dither_out()
Thanks for your time.
dREV is offline   Reply With Quote
Old 21st July 2019, 07:09   #254  |  Link
dREV
dREV's Avatar
The script is called Gradfun3mod. https://pastebin.com/0mkhsimh
#	High bitdepth tools for Avisynth - GradFun3mod r6
#       based on Dither v1.27.1
#	Author: Firesledge, slightly modified by Gebbi
#  What?
#       - This is a slightly modified version of the original GradFun3.
#       - It combines the usual color banding removal stuff with resizers during the process
#         for sexier results (less detail loss, especially for downscales of cartoons).
#       - This is a starter script, not everything is covered through parameters. Modify it to your needs.
#	Requirements (in addition to the Dither requirements):
#       - AviSynth 2.6.x
#       - Debilinear, Debicubic, DebilinearM
#       - NNEDI3 + nnedi3_resize16
#  Changes from the original GradFun3:
#       - yuv444 = true
#         (4:2:0 -> 4:4:4 colorspace conversion, needs 1920x1080 input)
#       - resizer = [ "none", "Debilinear", "DebilinearM", "Debicubic", "DebicubicM", "Spline16",
#         "Spline36", "Spline64", "lineart_rpow2", "lineart_rpow2_bicubic" ]
#         (use it only for downscales)
#           NOTE: As of r2 Debicubic doesn't have 16-bit precision, so a Y (luma) plane fix by torch is used here,
#                 more info: https://mechaweaponsvidya.wordpress.com/2015/07/07/a-precise-debicubic/
#                 Without yuv444=true Dither_resize16 is used with an inverse bicubic kernel.
#       - w = 1280, h = 720
#         (output width & height for the resizers; or production resolution for resizer="lineart_rpow2")
#       - smode = 4
#         (the old GradFun3mod behaviour for legacy reasons; based on smode = 1 (dfttest);
#         not useful anymore in most cases, use smode = 2 instead (less detail loss))
#       - deb = true
#         (legacy parameter; same as resizer = "DebilinearM")
#  Usage examples:
#       - Source is bilinear 720p->1080p upscale (BD) with 1080p credits overlayed,
#         revert the upscale without fucking up the credits:
#               lwlibavvideosource("lol.m2ts")
#               GradFun3mod(smode=1, yuv444=true, resizer="DebilinearM")
#       - You just want to get rid off the banding without changing the resolution:
#               GradFun3(smode=2)
#       - Source is 1080p production (BD), downscale to 720p:
#               GradFun3mod(smode=2, yuv444=true, resizer="Spline36")
#       - Source is a HDTV transportstream (or CR or whatever), downscale to 720p:
#               GradFun3mod(smode=2, resizer="Spline36")
#       - Source is anime, 720p->1080p upscale, keep the resolution
#         but with smoother lineart instead of bilinear upscaled shit:
#               GradFun3mod(smode=2, resizer="lineart_rpow2")
#         This won't actually resize the video but instead mask the lineart and re-upscale it using
#         nnedi3_rpow2 which often results in much better looking lineart (script mostly by Daiz).
#       Note: Those examples don't include parameters like thr, radius, elast, mode, ampo, ampn, staticnoise.
#             You probably don't want to use the default values.
#             For 16-bit output use:
#              GradFun3mod(lsb=true).Dither_out()
#  What's the production resolution of my korean cartoon?
#       - Use your eyes combined with Debilinear(1280,720) - if it looks like oversharped shit,
#         it was probably produced in a higher resolution.
#       - Use Debilinear(1280,720).BilinearResize(1920,1080) for detail loss search.
#       - Alternatively you can lookup the (estimated) production resolution at
#         http://anibin.blogspot.com  (but don't blindly trust those results)
#	This program is free software. It comes without any warranty, to
#	the extent permitted by applicable law. You can redistribute it
#	and/or modify it under the terms of the Do What The Fuck You Want
#	To Public License, Version 2, as published by Sam Hocevar. See
#	http://sam.zoy.org/wtfpl/COPYING for more details.
Function GradFun3mod (clip src, float "thr", int "radius", float "elast",
\	int "mask", int "mode", float "ampo", float "ampn", int "pat",
\	bool "dyn", float "dthr", int "smode", float "wmin", float "thr_det",
\	float "thr_edg", int "debug", int "subspl", bool "lsb", bool "lsb_in",
\	bool "staticnoise", float "thrc", int "radiusc", float "elastc",
\	int "y", int "u", int "v", clip "ref", bool "slice", bool "yuv444", int "w", int "h", string "resizer", bool "deb")
	thr     = Default (thr,       0.35)
	thrc    = Default (thrc,       thr)
	radius  = Default (radius,      12)
	radiusc = Default (radiusc, radius)
	elast   = Default (elast,      3.0)
	elastc  = Default (elastc,   elast)
	mask    = Default (mask,         2)
	smode   = Default (smode,        2)
	wmin    = Default (wmin,       1.0)
	thr_det = Default (thr_det, 2 + Round (Dither_max (thr - 0.35, 0) / 0.3))
	debug   = Default (debug,        0)
	subspl  = Default (subspl,       0)
	lsb     = Default (lsb,      false)
	lsb_in  = Default (lsb_in,   false)
	ref     = Default (ref,        src)
	yuv444 = Default (yuv444, false)
	w = Default (w, 1280)
	h = Default (h, 720)
	resizer = Default (resizer, "none")
	deb = Default (deb, false)
	# Do lineart smoothing first for sharper results
	ow = src.Width()
	oh = src.Height()
	src = (resizer == "lineart_rpow2") ? lineart_rpow2(src, w, h, ow, oh, false)
\           : (resizer == "lineart_rpow2_bicubic") ? lineart_rpow2(src, w, h, ow, oh, true)
\           : src
	# Input range check. The other parameters are checked by the plugins.
	Assert (radius  > 0, "GradFun3: "+chr(34)+"radius" +chr(34)+" must be strictly positive.")
	Assert (radiusc > 0, "GradFun3: "+chr(34)+"radiusc"+chr(34)+" must be strictly positive.")
	Assert (thr     > 0, "GradFun3: "+chr(34)+"thr"    +chr(34)+" must be strictly positive.")
	Assert (thrc    > 0, "GradFun3: "+chr(34)+"thrc"   +chr(34)+" must be strictly positive.")
	Assert (thr_det > 0, "GradFun3: "+chr(34)+"thr_det"+chr(34)+" must be strictly positive.")
	Assert (elast  >= 1, "GradFun3: "+chr(34)+"elast"  +chr(34)+" must be greater or equal to 1.")
	Assert (elastc >= 1, "GradFun3: "+chr(34)+"elastc" +chr(34)+" must be greater or equal to 1.")
	(yuv444 && resizer != "lineart_rpow2" && resizer != "lineart_rpow2_bicubic") ? Assert (w == 1280, "GradFun3mod: Output resolution must be 1280x720 when using 4:4:4 colorspace.") : true
	(yuv444 && resizer != "lineart_rpow2" && resizer != "lineart_rpow2_bicubic") ? Assert (h == 720, "GradFun3mod: Output resolution must be 1280x720 when using 4:4:4 colorspace.") : true
	src_8  = (lsb_in) ? src.DitherPost (mode=-1) : src
	src_16 = (lsb_in) ? src : src.Dither_convert_8_to_16 ()
	ref_16 = (lsb_in) ? ref : ref.Dither_convert_8_to_16 ()
	yv411_flag = src.Dither_isyv411 ()
	# Main debanding
	yp     = (! Defined (y) || (y == 3)) ? 3 : 1
	up     = (! Defined (u) || (u == 3)) ? 3 : 1
	vp     = (! Defined (v) || (v == 3)) ? 3 : 1
	chroma_flag = (  (thrc != thr || radiusc != radius || elastc != elast)
\	               && yp == 3 && (up == 3 || vp == 3))
	up2    = (chroma_flag) ? 1 : up
	vp2    = (chroma_flag) ? 1 : vp
	src_16
	flt_y  =                 Dither_gf3_smooth_mod (last, src_8, ref_16, smode, radius,  thr,  elast,  lsb_in, wmin, subspl, yp, up2, vp2)
	flt_c  = (chroma_flag) ? Dither_gf3_smooth_mod (last, src_8, ref_16, smode, radiusc, thrc, elastc, lsb_in, wmin, subspl, 1,  up,  vp) : flt_y
	flt    = (chroma_flag) ? flt_y.MergeChroma (flt_c) : flt_y
	# Edge/detail mask
	td_lo  = Dither_max (thr_det * 0.75, 1)
	td_hi  = Dither_max (thr_det,        1)
	mexpr  = Dither_make_expr_gate (td_lo, td_hi)
	dmask  = (mask > 0 && yv411_flag) ? src_8.ConvertToY8 ()       : src_8
	dmask  = (mask > 0) ? dmask.Dither_build_gf3_range_mask (mask) : dmask
	dmask  = (mask > 0) ? dmask.mt_lut (expr=mexpr)                : dmask
	dmask  = (mask > 0) ? dmask.Dither_removegrain_emul (22, -1)   : dmask
	dmask  = (mask > 1) ? dmask.Dither_removegrain_emul (11, -1)   : dmask
	dmask  = (mask > 2) ? dmask.Dither_removegrain_emul (20, -1)   : dmask
	dmask  = (mask > 0 && yv411_flag) ? dmask.ConvertToYV411 ()    : dmask
	res_16 = (mask > 0) ? Dither_merge16_8 (flt, src_16, dmask, luma=true, y=yp, u=up, v=vp) : flt
	# Resizing / colorspace conversion (GradFun3mod)
	resizer = (deb) ? "DebilinearM" : resizer
	resizer = (yuv444 && resizer == "none") ? "Spline36" : resizer
	rkernel = (resizer == "Debilinear" && yuv444) ? res_16.DebilinearY(w,h,lsb_inout=true)
\           : (resizer == "Debilinear") ? res_16.Debilinear(w,h,lsb_inout=true)
\           : (resizer == "DebilinearM" && yuv444) ? res_16.DebilinearM(w,h,lsb_inout=true,chroma=false)
\           : (resizer == "DebilinearM") ? res_16.DebilinearM(w,h,lsb_inout=true)
\           : (resizer == "Debicubic" && yuv444) ? res_16.debicubicy_precise(w,h)
\           : (resizer == "Debicubic") ? res_16.Dither_resize16(w,h,kernel="bicubic",invksh=true,fh=1.3,fv=1.3,invkstaps=7)
\           : (resizer == "DebicubicM" && yuv444) ? res_16.DebicubicM_precise16(w,h,chroma=false)
\           : (resizer == "DebicubicM") ? res_16.DebicubicM_precise16(w,h)
\           : (resizer == "Spline16" && yuv444) ? res_16.Dither_resize16(w,h,kernel="spline16",fh=1.2,fv=1.2).ConvertToY8()
\           : (resizer == "Spline16") ? res_16.Dither_resize16(w,h,kernel="spline16",fh=1.2,fv=1.2)
\           : (resizer == "Spline36" && yuv444) ? res_16.Dither_resize16(w,h,kernel="spline36",fh=1.2,fv=1.2).ConvertToY8()
\           : (resizer == "Spline36") ? res_16.Dither_resize16(w,h,kernel="spline36",fh=1.2,fv=1.2)
\           : (resizer == "Spline64" && yuv444) ? res_16.Dither_resize16(w,h,kernel="spline64",fh=1.2,fv=1.2).ConvertToY8()
\           : (resizer == "Spline64") ? res_16.Dither_resize16(w,h,kernel="spline64",fh=1.2,fv=1.2)
\           : ((resizer == "lineart_rpow2" || resizer == "lineart_rpow2_bicubic") && yuv444) ? res_16.Dither_resize16(1280,720,kernel="spline36",fh=1.2,fv=1.2).ConvertToY8()
\           : (resizer == "lineart_rpow2" || resizer == "lineart_rpow2_bicubic") ? res_16
\           : (resizer == "none") ? res_16
\	         : Assert (false, "GradFun3mod: wrong resizer value.")
    ly = rkernel
    lu = res_16.utoy8().Dither_resize16(1280, 720, src_left=0.25, kernel="blackman")
    lv = res_16.vtoy8().Dither_resize16(1280, 720, src_left=0.25, kernel="blackman")
    (yuv444) ? ytouv(lu,lv,ly) : rkernel
	# Dithering
	result = (lsb) ? last : last.DitherPost (
\		mode=mode, ampo=ampo, ampn=ampn, pat=pat, dyn=dyn,
\		prot=false, thr=dthr, staticnoise=staticnoise,
\		y=yp, u=up, v=vp, slice=slice
	result = (lsb)
\		? Dither_switch_planes16 (src_16, result, y=y, u=u, v=v)
\		: Dither_switch_planes8  (src_8,  result, y=y, u=u, v=v)
	(debug == 1       ) ? dmask.GreyScale ()        : result
	(debug == 1 && lsb) ? Dither_convert_8_to_16 () : last
Function Dither_gf3_smooth_mod (clip src_16, clip src_8, clip ref_16, int smode, int radius, float thr, float elast, bool lsb_in, float wmin, int subspl, int yp, int up, int vp)
	src_16
	  (smode == 0) ? Dither_gf3_smoothgrad_multistage (ref_16, radius, thr, elast, yp, up, vp)
\	: (smode == 1) ? Dither_gf3_dfttest (src_8, ref_16, radius, thr, elast, lsb_in, yp, up, vp)
\	: (smode == 2) ? Dither_gf3_bilateral_multistage (ref_16, radius, thr, elast, wmin, subspl, yp, up, vp)
\	: (smode == 3) ? Dither_gf3_smoothgrad_multistage_3 (radius, thr, elast, yp, up, vp)
\  : (smode == 4) ? Dither_gf3_dfttest_mod (src_8, ref_16, radius, thr, elast, lsb_in, yp, up, vp)
\	:                Assert (false, "GradFun3mod: wrong smode value.")
# Valid values for y, u and v: 1 and 3
Function Dither_gf3_dfttest_mod (clip src, clip src_8, clip ref,
\	int radius, float thr, float elast, bool lsb_in,
\	int y, int u, int v)
	Assert (radius <= 128, "GradFun3: max "+chr(34)+"radius" +chr(34)+" value is 128 when smode = 1.")
	hrad = Dither_max (radius * 3 / 4, 1)
	(lsb_in) ? src : src_8
	dfttest (
\		sigma=thr*12, tbsize=1,
\		sbsize=hrad*4, sosize=hrad*3,
\		lsb=true, lsb_in=lsb_in,
\		Y=(y==3), U=(u==3), V=(v==3)
	Dither_limit_dif16 (last, ref, thr=thr, elast=elast, y=y, u=u, v=v)
Function lineart_rpow2 (clip src, int w, int h, int ow, int oh, bool bicubic)
    w = default(w, 1280)
    h = default(h, 720)
    ow = default(ow, 1920)
    oh = default(oh, 1080)
    bicubic = default(bicubic, false)
    orig = src
    (bicubic) ? DebicubicM(src, w, h) : DebilinearM(src, w, h)
    nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=ow, fheight=oh)
    edges = last.mt_edge("prewitt", 4, 24, 4, 24, chroma="true").removegrain(20, 1)
    sharp = last
    mt_merge(orig, sharp, edges)
Function debicubicy_precise(clip src, int dst_width, int dst_height, float "src_left", float "src_top", float "src_width", float "src_height")
    # script by torch
	sw = src.width()
	sh = src.height()/2
	src_left = default(src_left,   0.0)
	src_top = default(src_top,    0.0)
	src_width = default(src_width,  sw)
	src_height = default(src_height, sh)
	inv_left = -src_left * dst_width/src_width
	inv_top = -src_top * dst_height/src_height
	inv_width = (sw-src_left) * dst_width/src_width
	inv_height = (sh-src_top) * dst_height/src_height
	seed = debicubicy(src, dst_width, dst_height, src_left, src_top, src_width+src_left, src_height+src_top, lsb_inout=true)
	up = seed.dither_resize16(sw, sh, inv_left, inv_top, inv_width, inv_height, kernel="bicubic", fh=-1.0, fv=-1.0)
	diff = dither_sub16(src, up, dif=true).dither_lut16("x 32768 - 99 * 32768 +")
	down = diff.debicubicy(dst_width, dst_height, src_left, src_top, src_width+src_left, src_height+src_top, lsb_inout=true)
	down = down.dither_lut16("x 32768 - 99 / 32768 + round")
	return seed.dither_add16(down, dif=true)
Function DebicubicM_precise16(clip input, int target_width, int target_height, bool "chroma")
    # based on DebilinearM v1.3.1
    Assert(target_width  > 0, "GradFun3mod: target width must be greater than 0")
    Assert(target_height > 0, "GradFun3mod: target height must be greater than 0")
    thr = 10
    expand = 1
    inflate = 2
    kernel = "Spline36"
    chroma = Default(chroma, true)
    w = input.Width()
    h = input.Height()/2
    uvint = chroma ? 3 : 1
    # Resizing
    input_8bit = input.DitherPost(mode=-1)
        dbi = chroma ? input.Dither_resize16(target_width,target_height,kernel="bicubic",invksh=true,fh=1.3,fv=1.3,invkstaps=7)
         \                 : input.debicubicy_precise(target_width,target_height)
    dbi_8bit = chroma ? input_8bit.Debicubic(target_width,target_height)
         \                 : input_8bit.DebicubicY(target_width,target_height)
    dbi2     = dbi_8bit.ResizeX(w,h, kernel="Bicubic", chroma=chroma)
    rs = input.ResizeX(target_width,target_height, kernel=kernel, chroma=chroma, lsb_in=true, lsb=true)
    # Masking
    diffmask = mt_lutxy(input_8bit,dbi2, "x y - abs", U=uvint, V=uvint).mt_binarize(threshold=thr, U=uvint, V=uvint)
    diffmask = diffmask.ResizeX(target_width,target_height, kernel="Bilinear", chroma=chroma)
    \                                  .mt_binarize(threshold=3, U=uvint, V=uvint)
    \                                  .DebilinearM_expand(expand=expand, U=uvint, V=uvint)
    \                                  .DebilinearM_inflate(inflate=inflate, U=uvint, V=uvint)
    merged = Dither_merge16_8(dbi,rs,diffmask, u=uvint, v=uvint)
    return merged
Old 21st July 2019, 07:34   #255  |  Link
real.finder
it's already has the pastebin https://pastebin.com/LP7kDbe6 but seems you didn't note it
about n16 yes it's like lsb but true 16bit, we did talk about that here in the past (and even in other Threads like https://forum.doom9.org/showthread.p...47#post1875147)
will see the other things you asked for later (maybe in few Hours or some days)
and since you bring deband filter, can you or other members provides some video samples (I remember there also some code in avs to generate moving banding in some post here in doom9 few years ago)
Old 21st July 2019, 11:41   #256  |  Link
Natty
Noob
thanks. will this speed up native HBD (16) too?
Old 21st July 2019, 16:19   #257  |  Link
real.finder
in very few scripts
Old 21st July 2019, 16:25   #258  |  Link
StainlessS
StainlessS's Avatar
Very sneaky Real.Finder, that squiggle in your last [EDIT: but one] post had me investigating how you did it, (to save anybody else the trouble of finding out, its repeated below [png]).
I sometimes post sober.
Old 21st July 2019, 17:42   #259  |  Link
StainlessS
StainlessS's Avatar
I had a good look for the banding generator, but could not find.
What is the cause of "Moving Banding", just moving images ?
EDIT: This works but need low OUTLEVELS for real obvious banding
Function BandingGenny(clip c,int "nLevels",Bool "PcLevels") { # https://forum.doom9.org/showthread.php?p=1879799#post1879799
    c
    nLevels  = Default(NLevels,36)
    PcLevels = Default(PcLevels,False)
    Foot = (PcLevels) ?   0 : 16
    Head = (PcLevels) ? 255 : 235
    Levels(Foot          , 1.0, Head, Head-nLevels+1, Head,coring=false)    # Squish   range to nLevels number of levels
    Levels(Head-nLevels+1, 1.0, Head, Foot          , Head,coring=false)    # UnSquish range, still nLevels number of levels
    return Last
AviSource("D:\AutoLevels\OZ.avi")
ConvertToYV12
ORG=Last
### CONFIG ###
PCLEVELS  = False
OUTLEVELS = 36
SHOW      = false
BandingGenny(OutLevels,PcLevels)
(Show) ? Subtract(ORG) : Last
return last
EDIT: Above banding definitely moves plenty good.
Old 21st July 2019, 23:21   #260  |  Link
StvG
... The issue thus far I've found is that for resolutions 1920x1080 > 1280x720 like say a old show in 4:3 with black borders it'll create a 1 pixel artifact on all 4 sides that even ContinuityFixer / EdgeFixer http://avisynth.nl/index.php/EdgeFixer won't be able to fix. I had to get around this by adding nnedi3_resize16(960, 720,lsb_in=true,lsb=true,kernel_d="Spline64",kernel_u="Spline64") below YtoUV(lu,lv,ly)...
Did you try different radius values? radius 2-5 should be ok.
StvG is offline   Reply With Quote
avisynth, avs script, avs+, banding, generator, hbd, mod
