Old 9th January 2021, 19:55   #30301  |  Link
videoh
Useful n00b
Send me a PM. Happy to help.
Old 9th January 2021, 22:05   #30302  |  Link
gonca
You guys should try DGDemux for UHD and BD movies.
Fast and handles thd + atmos well
Old 9th January 2021, 23:00   #30303  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by videoh View Post
Subscribe to the Binaries Notification thread and you'll get an email whenever a new slipstream is released.
There is no link at the bottom of the page in which to subscribe to the thread.
Old 9th January 2021, 23:04   #30304  |  Link
MrVideo
MrVideo's Avatar
Originally Posted by ggtop View Post
Simply redo what you've done on 4/26/2019
ggtop
Done. Files downloaded.
Old 9th January 2021, 23:05   #30305  |  Link
videoh
Useful n00b
If you are logged in and on the thread page, pull down on the wrench drop-down (at top or bottom of page) and select 'Subscribe topic'.
Old 10th January 2021, 01:11   #30306  |  Link
MrVideo
MrVideo's Avatar
I wasn't logged in. I used the wrong link in the activation e-mail. I used to have an account, but I suspect that I hadn't used it in so long that I got removed.
Old 11th January 2021, 02:17   #30307  |  Link
videoh
Useful n00b
Currently in progress: DGIndex.
Happy to report that the current changes produce a 350% performance increase. Will regression test and then release.
Old 11th January 2021, 04:28   #30308  |  Link
lithiumus
@jdobbs any chance you could update the blanking for 4k releases to use 4k blank clips vs the 1080 blank clips? It will help reduce the resolution switching on the displays.
or if you can point me to a set of 4k clip files and if simply swapping them into the tools\blankclip directory will work, I can do that too. LMK!
lithiumus is offline   Reply With Quote
Old 12th January 2021, 18:14   #30309  |  Link
I'll look at it.
Old 12th January 2021, 18:50   #30310  |  Link
lithiumus
I'll look at it.
As always... you rock!
Sent from my iPhone using Tapatalk
Old 13th January 2021, 04:46   #30311  |  Link
MrVideo
MrVideo's Avatar
OK, I'm looking at getting the RTX-3060Ti. Will that be a good fit with BDRB, UHD Blu-ray recoding with use of B-frames?
Nvidia points to Best Buy for purchase and they want $400. But they are sold out. E-bay has them for a lot more. No idea why.
EDIT: Or, is there a recent older model(s) that will also work?
Old 13th January 2021, 13:51   #30312  |  Link
Mike-uk
a while back Jdobbs got a 1660 i think and i had a 2070 super and encode fps was the same, not sure about the 30XXX series, but you pro defo want a card that does b frames which is anything 1660 upwards i think
Mike-uk is offline   Reply With Quote
Old 13th January 2021, 21:36   #30313  |  Link
cartman0208
If you don't do 3D (gaming and such) you should be fine with a GTX1660 at half the price from a RTX3060.
Ampere has essentially the same NVENC generation engine as Turing
Old 13th January 2021, 22:03   #30314  |  Link
MrVideo
MrVideo's Avatar
Yep, no gaming. Thanks guys for the input.
Ordered, from ebay: MSI GTX 1660 Ventus XS - 6GB DDR5
Also ordered a DisplayPort to VGA adapter.
Old 14th January 2021, 12:43   #30315  |  Link
cartman0208
Your Display Device is that old?
If there is a DVI Port, I'd go for that adapter
Old 14th January 2021, 13:15   #30316  |  Link
MrVideo
MrVideo's Avatar
The display is an HDMI/DVI/VGA monitor. The HDMI is fed from the AVR. The DVI is fed from the OTA STB and the VGA is fed from the KVM.
Old 14th January 2021, 15:07   #30317  |  Link
Same for me. If you're using a KVM (or at least one like mine) you have to use an HDMI-->VGA adapter.
One warning... on my system I had to initially configure the card with it connected directly via HDMI (before using the adapter). Another issue is that I don't get video to my monitor (via the adapter) until Windows is booted (so if I want to go the the BIOS screen, for example, I have to connect the card directly to the monitor via HDMI).
It isn't a big deal -- but it can sometimes be a PIA.
Old 14th January 2021, 19:32   #30318  |  Link
MrVideo
MrVideo's Avatar
Yep, it is an 8-port VGA KVM, with USB or old keyboard/mouse cables. I don't use all of the ports anymore, as some systems have been retired.
Thanks for the warnings. I would have been bitching at the card for not working. Sounds like you have to get up and running and then go and configure the output for a different port. At least on my current cards, even though there might be an HDMI port, the VGA output is the default.
Why doesn't it work with the HDMI->VGA adapter from the get-go? If the HDMI output is the default, you'd think that it would work right away.
Old 15th January 2021, 12:44   #30319  |  Link
Glarioo
According to Mediainfo, the maximum bitrate with v0.61.19. is limited 30.0 to Mb/s
With v0.61.18 it was 40.0 Mb/s.
I 'm using alternate movie-only output, MKV container 1920x1080 640kbs DD5.1.
Using NVEnc encoder One Pass CQM, Constant Quality Mode (CQM): 19.
Old 16th January 2021, 01:35   #30320  |  Link
Not sure why. I guess it's possible it could be something specific about my HDMI-->VGA adapter. Don't know for sure.
