6th August 2014, 09:51 | #621 | Link | ||
Broadband Junkie
If someone else comes up for a fix for VSFilter itself, we could certainly merge it. I'm not very familiar with how the whole Windows topmost and z-order behavior is supposed to work in this case, expecially when both MPC-HC (setting) and madVR (FSE) themselves enforce such behavior on their own windows, and cause this issue with vsfilter child windows which function nominally otherwise. This being some kind of Windows bug or unintended behavior in the DWM also seems within the realm of possibility. There was even a hotfix a few years ago off the LDR service branch for ontop behavior being broken on Windows 7 SP1 (RTM/GDR) out-of-box. I've always had this hotfix applied myself though, and I still run into buggy and strange on-top behavior with other applications, so who knows what it actually fixed or if it made something else worse. Last edited by cyberbeing; 6th August 2014 at 10:55. |
6th August 2014, 18:59 | #622 | Link | |
7th August 2014, 18:19 | #623 | Link | |
/人 ◕ ‿‿ ◕ 人\
For example, video Code:
BlankClip (500, 1920, 1080, color=$222222) Code:
PlayResX: 1920 PlayResY: 1080 Code:
PlayResX: 640 PlayResY: 360 |
7th August 2014, 23:06 | #624 | Link |
Broadband Junkie
Yes, this is pretty much expected for ASS scripts since that size behavior is the basis of all existing typesetting. I actually looked into overriding PlayRes before I posted that other build, but I couldn't figure out a trivial way to do so in the part of the code I was modifying. When the xy-dev originally tried to implement this as well, he was scaling fontsize/border/shadow/spacing/margins directly within the script styles without touching PlayRes, and actually why I suspect this method was utterly broken on ASS scripts. I mentioned this to him before, but he never got around to fixing it before the release of Beta2, so it was reverted. I'll still keep this in mind for the future.
22nd August 2014, 10:35 | #627 | Link | |
Broadband Junkie
MPC-HC accidentally broke the XySubFilter interface to EVR-CP while they were doing updates to the ISR backend. madVR should still be fine, but I'd recommend just sticking with an older MPC-HC build until they get around to fixing it. Last edited by cyberbeing; 22nd August 2014 at 10:44. |
29th August 2014, 18:43 | #629 | Link |
Broadband Junkie
Faster with heavy subtitle typesetting (i.e. anime fansubs), improved subtitle interface, matrix correction for BT.601->BT.709 subtitles (legacy VSFilter.dll limitation) required for correct video color matching, subtitle queue (madVR only), and gamma/gamut correction (madVR only), and various other compatibility improvements for .ass subtitles.
29th August 2014, 23:08 | #631 | Link | |
of cause the main benefits of this render is for styled subtitles and normal BD/dvd subs work totally fine with the ISR. |
30th August 2014, 01:59 | #632 | Link |
If you have any files that do not render correctly with the ISR, then please submit them to the bug tracker.
https://trac.mpc-hc.org/report/9 The performance of the ISR has improved a lot in the past months. Next nightly/stable is going to have several more performance improvements. madshi could easily apply 3dluts and color corrections to the ISR ouput as well in a future version of madVR. Plus 3dluts isn't something that many people use. MPC-HC also already has some code for the new interface, so that might get used in the future if it provides any benefits.
MPC-HC 2.2.1 |
30th August 2014, 02:02 | #633 | Link | |
Broadband Junkie
Is is relevant, since SubRenderInf allows functionality and improved integration which is not otherwise possible with the limitations of the ISubRender used by the MPC-HC ISR. I'm sure madshi could explain the specifics of this better than I can though. The new subtitle interface came into existence since he was dissatisfied with the capabilities of ISubRender. So at least as far as madVR support is concerned, native support of the new SubRenderIntf interface will always be considered an advantage.
I look forward to testing the upcoming round of improvements, since despite what you've said, there really hasn't been any significant improvements with heavy typesetting in the ISR since the initial round of xy inspired cache commits around a year or so ago. Either way, it's encouraging to see Underground78 continuing to work on closing the remaining gaps in performance. I hope he continues to push forward implementing the remaining low-hanging fruit / feature gaps from xy, and ultimately moves on to eventually tackling some of the performance issues vs recent Libass which we've yet to touch ourselves. The status of the xy-VSFilter developer has been rather unknown for months now, so if or when our project will continue is rather uncertain at the moment. Last edited by cyberbeing; 30th August 2014 at 02:50. |
30th August 2014, 02:51 | #634 | Link |
I would be really helpful if you could use your knowledge about the changes in xy*filter to compile a (short) list of the most important/beneficial fixes and improvements in the xy project. Preferably with sample files and links to the relevant commits. That could help speed up and streamline development on the MPC-HC side.
MPC-HC 2.2.1 |
30th August 2014, 03:04 | #635 | Link |
Broadband Junkie
Once the latest round of subtitle improvement commits from Underground78's personal branch are merged to MPC-HC master, I'd consider doing so once I have a chance to reassess performance. Judging from some of the commit names, he may have already discovered a couple of the most obvious ones. We'll have to wait and see what comes of it.
30th August 2014, 06:14 | #636 | Link |
I see absolutely no difference between MPC-HT built-in and XY, the font style box looks the same,
the CPU usage is non existent, the rendering looks smooth with internal/external subs with both. I'll stick with the built-in because for all I care it's exactly the same.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. |
30th August 2014, 18:04 | #638 | Link |
Broadband Junkie
For general use like you describe, that's pretty much to be expected. The only users who really require XySubFilter over MPC-HC ISR & Libass, are those who likely were already prior users or at the very least aware of xy-VSFilter prior to me creating this topic on Doom9 in 2013. For everyone else, there are some benefits especially for users of madVR, as well as some feature/functionality differences, but each user will need to decide for themselves if they are worthwhile it or not.
I'd hope this eventually occurs as well, but at this point it seems rather doubtful. Even if MPC-HC ISR never supports it, there is a logical successor (not from us) supporting the madVR interface on the horizon in the next couple years, which will likely deem both MPC-HC ISR and XySubFilter obsolete unless a major modernization effort occurs. Such future talk is rather off-topic for this thread though. |
31st August 2014, 23:24 | #639 | Link |
MPC-HC Developer
Little announcement: Latest MPC-HC nightly include recent performance changes. @cyberbeing: If you could provide samples that works "a lot" better with XySubFilter than with ISR. You can send them directly to me or open tickets on trac, thanks in advance.
