Old 23rd March 2018, 09:48   #681  |  Link
varekai
Originally Posted by raymondjpg View Post
It appears that there is something of Subtitle Edit's settings remaining in the system after a complete uninstall. If anyone knows what it is, could they please point me to it.
TIA
Uninstall then delete this Subtitle Edit folder:
C:\Users\***(user name)***\AppData\Roaming\Subtitle Edit
Old 23rd March 2018, 12:08   #682  |  Link
raymondjpg
Thanks for the response, but yes, I have removed that folder after uninstalling SE. The reinstalled SE still remembers the last opened directory.
raymondjpg is offline   Reply With Quote
Old 25th March 2018, 12:24   #683  |  Link
varekai
Have you tried to locate and delete Subtitle Edit in regisrty?
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SubtitleEdit_is1
Old 26th March 2018, 06:08   #684  |  Link
raymondjpg
Thanks, but that entry does not appear to be in the registry after an uninstall. It reappears after SE is reinstalled.
Old 26th March 2018, 08:18   #685  |  Link
mkver
Have you just searched your registry for "SubtitleEdit"? This seems to be a Windows feature and not something that SE controls.
I remember that Windows keeps MRU (most recently used) lists in the registry.
mkver is offline   Reply With Quote
Old 26th March 2018, 09:38   #686  |  Link
raymondjpg
That may be it, although I could not find such an entry in the registry specifically for SubtitleEdit after I had completely uninstalled the program.
Old 28th March 2018, 22:31   #687  |  Link
sfatula
Noise/names list not Retaining
When using Tesseract on SE 3.5.6 under Wine on Mac OSX, I can add to user dictionary, it retains changes, etc. However, adding to names/noise list does not seem to update the file so this info is lost for future uses. Is it supposed to update the file thats lists names/noise words?
sfatula is offline   Reply With Quote
Old 31st March 2018, 12:20   #688  |  Link
Nikse555
@raymondjpg: mkver is most likely correct - SE (except installer) does not save anything in the registry (all settings are saved in the Settings.xml file).
@sfatula: thx, that's a bug. "Add to names list" in OCR spell check did not work - should be fixed in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip
Old 22nd July 2018, 03:37   #689  |  Link
x265
How do i convert .srt file to dvd .sup in subtitle edit? I want to add subtitles to a DVD. I tried exporting as bd sup but that does not load correctly in muxman.
x265 is offline   Reply With Quote
Old 22nd July 2018, 12:44   #690  |  Link
varekai
Have you tried export to VobSub (sub/idx)?
Old 22nd July 2018, 14:32   #691  |  Link
x265
Yeah i tried that but it won't open in muxman. It only accepts dvd .sup.
Old 22nd July 2018, 18:45   #692  |  Link
Music Fan
Try export in Blu-ray sup, but I don't know if it's the same format than dvd sup.
Music Fan is offline   Reply With Quote
Old 22nd July 2018, 20:33   #693  |  Link
x265
Error message: subpicture type not supported.
Old 22nd July 2018, 23:19   #694  |  Link
Music Fan
Then try an export in VobSub or Blu-ray sup and convert to Dvd sup with another tool (BDSup2Sub for example).
Old 26th July 2018, 09:15   #695  |  Link
Ghitulescu
Ghitulescu's Avatar
It's not.
Just why one would try to export in BD format when the target is DVD? What kind of logic in thinking is this?
Born in the USB (not USA)
Old 26th July 2018, 10:25   #696  |  Link
Music Fan
I said : "I don't know if it's the same format", could I be more cautious ?
There are some common points between Dvd and BD, and I was hoping for him that a BD sup in 720x576 (or 720x480) could be dvd compliant.
Also, I made this suggestion thinking that Nikse555 couldn't have forgotten one of the most common formats (dvd sup doesn't appear in the list), thus I tought he had maybe given the same name to both formats and that only higher resolutions wouldn't be dvd compliant.
That's a very logical reasoning actually.
Old 3rd August 2018, 15:37   #697  |  Link
tormento
Acid fr0g
tormento's Avatar
@Nikse555
Found another srt that can crash Subtitle. Tried latest beta:
h**ps://openload.co/f/twwBdcwStS0/crash.zip
Just try to remove hearing impaired text
@turment on Telegram
Old 4th August 2018, 10:20   #698  |  Link
varekai
Originally Posted by tormento View Post
@Nikse555
No problem for me using SE version 3.5.6
You really should use another cloud service!
That openload site is a piece of s***!
Sorry for being a bit harsh...
You could get a free account on https://www.mediafire.com/upgrade/
There are some ads but not so pesky as on openload.
http://www.mediafire.com/file/fnxfia...no%20crash.zip
Best regards
Old 7th August 2018, 20:34   #699  |  Link
Nikse555
@tormento: thx for the info (crashed with some combination of options in 'remove text before colon').
Should be fixed in latest beta: https://github.com/SubtitleEdit/subt...leEditBeta.zip
Old 9th August 2018, 13:53   #700  |  Link
tormento
Acid fr0g
tormento's Avatar
OT: uBlock Origin is the cure.
