Old 8th November 2013, 00:10   #101  |  Link
videofan3d
Originally Posted by tymoxa View Post
Exactly.
I want do something like this:
I will thing about it
Probably you want to get pure_L.h264 (as AVC) and also pure_R.h264 (also as AVC), right?
videofan3d is offline   Reply With Quote
Old 8th November 2013, 00:11   #102  |  Link
videofan3d
v1.11 named pipe still does not work here. Now I get the error:
Error: Unknown codec
Unknown codec - you have likely wrong command line, some hyphen "-" is missing, or you have there extra space.
Old 8th November 2013, 00:12   #103  |  Link
tymoxa
Originally Posted by HWK View Post
Good news we already have decoder which can do it for you and yes you can use X.264 encoder with it.
You are referencing to DirectShow MVC Source.dll? It's not an option to me.
tymoxa is offline   Reply With Quote
Old 8th November 2013, 00:14   #104  |  Link
tymoxa
We already have pure_L.h264. I want pure_R.h264.
Old 8th November 2013, 00:21   #105  |  Link
HWK
HWK's Avatar
May I know why, if that is ok with you?
Old 8th November 2013, 00:43   #106  |  Link
Eseninzhiv
videofan3d
Thank you for your work, just super!
long looking for a decoder MVC 3D (interest only output YUV)
if use this method, everything is fine
Decoding H.264 MVC combined elementary stream into two yuv‐files (3D)
output_L.yuv 1822500kb
output_R.yuv 1822500kb
if use this method
Decoding H.264 MVC separate main and dependent views into two yuv‐files (3D)
output_R.yuv 1819463kb then the last frame is then removed
is it possible to add the conversion directly from the file SSIF?
Eseninzhiv is offline   Reply With Quote
Old 8th November 2013, 00:46   #107  |  Link
Sharc
@videofan3d
I confirm that separate input files and named pipe now work perfectly with v1.11:
FRIMDecode.exe mvc -i base.264 -i dependent.mvc -o \\.\pipe\TMP.yuv | FRIMencode.exe mvc -i \\.\pipe\TMP_L.yuv -i \\.\pipe\TMP_R.yuv -viewoutput -o output_L.avc -o output_R.mvc -w 1920 -h 1080 -dstw 1280 -dsth 720 -f 23.976 -l 4 -cpbsize 3750 -vbr 6000 15000 -u 4 -profile high -level 4.0 -gop 24 4 0 O
Old 8th November 2013, 01:09   #108  |  Link
tymoxa
Originally Posted by Eseninzhiv View Post
if use this method
That's odd. In my tests both methods give me the same size of .yuv's.
Old 8th November 2013, 09:03   #109  |  Link
Sharc
Originally Posted by colinhunt View Post
Does this mean I can feed it demuxed h264 files directly from a 3DBD?
Workflow:
1. Rip the 3DBD to .iso
2. Mount the .iso
3. Start tsMuxeR and open the *.ssif (usually the largest for the movie)
4. Select the wanted tracks and demux with tsMuxeR
=> You will get the elementary files for the base view *.264, dependent view *.mvc, and the selected audio and sup files.
5. Now encode the video files with FRIMTools, like:
FRIMDecode.exe mvc -i 00049.track_4113.264 -i 00050.track_4114.mvc -o \\.\pipe\TMP.yuv | FRIMencode.exe mvc -i \\.\pipe\TMP_L.yuv -i \\.\pipe\TMP_R.yuv -viewoutput -o output_L.avc -o output_R.mvc -w 1920 -h 1080 -dstw 1280 -dsth 720 -f 23.976 -l 4 -cpbsize 3750 -vbr 8000 15000 -u 4 -profile high -level 4.0 -gop 24 4 0 O
(I included resizing to 1280x720 in the example)
=> You will get re-encoded base *.avc and dependent *.mvc streams.
6. Start tsMuxeR, open the video files from 5., add the audio and sup files from 4., select as output Blu-ray ISO, and start muxing ...
7. Burn the .iso
Old 8th November 2013, 15:22   #110  |  Link
videofan3d
videofan3d
if use this method
This is strange - for investigation I need to simulate it.
How did get the original combined file and related separated files? Please describe me process in order to reproduce it.
Old 8th November 2013, 15:56   #111  |  Link
Eseninzhiv
demux SSIF via tsMuxeR 2.1.6
1. MVC combined, use the utility http://forum.doom9.org/showthread.ph...58#post1628058 files are the same
2. MVC separate, demux SSIF via tsMuxeR 2.1.6 http://i.imgur.com/haAbf6b.png
if demux with eac3to playlist, all right, files are the same
eac3to probably adds at the end of an empty frame
eac3to v3.24
command line: "F:\3D\H.264 MVC 3D Decoder\eac3to v3.24\eac3to.exe" "J:\BDMV\PLAYLIST\00250.mpls" 01: l.h264 02: r.h264
M2TS, 2 video tracks, 3 audio tracks, 3 subtitle tracks, 0:01:41, 24p /1.001
1: h264/AVC (left eye), 1080p24 /1.001 (16:9)
2: h264/AVC (right eye), 1080p24 /1.001 (16:9)
3: AC3, English, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB
4: AC3, French, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB
5: AC3, Russian, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB
6: Subtitle (PGS), French
7: Subtitle (PGS), Dutch
8: Subtitle (PGS), Russian
[v02] Extracting video track number 2...
[v01] Extracting video track number 1...
[v02] Creating file "r.h264"...
[v01] Creating file "l.h264"...
Video track 1 contains 2419 frames.
Video track 2 contains 2420 frames.
eac3to processing took 4 seconds.
Done.
Old 8th November 2013, 17:47   #112  |  Link
videofan3d
Post was geared towards videofan3d
@HWK
@frencher
Guys,
I copied HWK's package into directory C:\Stereoplayer,
then I used you ENCODE_3D_MOVIE.avs:
LoadPlugin("C:\Stereoplayer\DirectShowMVCSource.dll")
DirectShowMVCSource("c:\Stereoplayer\00000.ssif", seek=false, seekzero=true, stf=14) # 14 = SBS
AssumeFPS("ntsc_film")
File 00000.ssif was about 1 minute, but it doesn't change a principle.
Then I ran command
FRIMEncode.exe mvc -avi -sbs 2 -i ENCODE_3D_MOVIE.avs -viewoutput -o TEST_L.h264 -o TEST_R.h264 -cbr 40000
And two files TEST_L.h264, TEST_R.h264 were correctly created.
So, I don't see any problem here...
Old 8th November 2013, 17:52   #113  |  Link
HWK
HWK's Avatar
@HWK
@frencher
Guys,
Then I ran command
Ok I will try again and see what happens.
Apparently it still doesn't work for me. Thanks for trying I think I will use previous mvc encoder I have.
Old 8th November 2013, 20:40   #114  |  Link
Cedvano
Works fine for me.
Thank you very much videofan3D.
Cedvano is offline   Reply With Quote
Old 8th November 2013, 21:25   #115  |  Link
Sharc
Don't give up! DirectShowMVCSource works here as well. I'll post details later today ....
Edit:
Oooops! It runs for some time (few thousand frames), then FRIMencode crashes with the error
M_Alloc; error allocing 4552128
Doing more tests .....
Edit2:
Encoding a 2 hours movie with named pipes worked flawlessly and was reasonably fast.
Interesting that the original had a file size ratio dependent/base = 0.304 (which is exceptionally low, more typical ratios seem to be around 0.5), while after encoding with FRIMenocde this ratio became 0.83.
Old 8th November 2013, 21:36   #116  |  Link
HWK
HWK's Avatar
That would be helpful, Although I own mainconcept mvc encoder but I want to help improve this as well.
In the mean time I would also try using ssif file decoder as well which doesn't rely on directshowmvcsource to decode file.
Old 8th November 2013, 21:51   #117  |  Link
colinhunt
Workflow:
2. Mount the .iso
7. Burn the .iso
Awesome answer, thank you Sharc!
Old 8th November 2013, 22:24   #118  |  Link
Cedvano
It's strange, I have 1 additional frame in the MVC file when I encode.
Edit: Work if Demuxing with eac3to.
Workflow:
2. Mount the .iso
4. Select the wanted tracks and demux with eac3to
7. Burn the .iso
Old 8th November 2013, 22:54   #119  |  Link
frencher
French Love
@HWK
@frencher
Guys,
Then I ran command
@videofan3d
1 minute is too short for view from AVS problem
I have upload full video demo and log report with 266804 total frames (AVC/MVC from "MVCcombined.264")
Download:
FRIMDecode YUV FRIMEncode - VS - From AVS Script.rar
Watch FRIMDecode YUV FRIMEncode - VS - From AVS Script.mkv (include into package) before explore folder and report
Low CPU Usage for recode, it's possible to add CPU optimisation ? x264x64 use 100% of my CPU (i7 3930k)
Thanks for your bigest works
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 8th November 2013, 23:16   #120  |  Link
Sharc
Strange; should perhaps be reported to physic.
What is the consequence of the 1 frame difference? Does the encoding fail?
encoders, mvc
