19th July 2016, 09:23 | #21 | Link |
The speed of stupid
Doing some adjustment bullshit in Photoshop (primarily curves with a little Color Balance cheating) certainly reveals that you can do much more. But it's good to see people making interesting things, even if I have no use for them myself being the young'un I am. |
19th July 2016, 11:49 | #22 | Link | |
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
19th July 2016, 15:17 | #24 | Link | |
and results were not terribly encouraging. Looking at AutoLevels source, I find that it converts R,G & B to Luma Y to get min, max and mean (together with the ignore args). So, AutoLevels currently uses neither RGB min,max method mentioned. Dont know whether this change was done since the previous IanB quote or whether always as is. Anyway, we really dont need to be re-inventing that wheel and I am now happy to completely abandon any idea to do same in purely RGB. Fred can you verify that you did not use any of the gamma args in AutoLevels in your tests [they are unused by default and I did not pass on gamma related args in the AutoLevelsGamMac() stub]. EDIT: better still can you post the script for eg the Lollipop Lady [GamMac000001.jpg]. EDIT: @ Bloax, you could have gotten LockChan 2 Lenna without the metrics setting Show=false, and perhaps better results in PhotoShop due to missing white text. (guess you just downloaded the pic and not GamMac).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 19th July 2016 at 15:48. |
19th July 2016, 18:43 | #25 | Link |
Fred, I cocked up previous trials at the RGB prelevel thing (such is the lot of a nincompoop),
I had another go and this time a bit better. Here v1.03Beta for you to have a play with, because I'm going t' pub. LINK REMOVED and the puppy pic args added Code:
Th, Default 0.0(off) 0.0 -> 10.0(perhaps limited to ~2.0 in non Beta). Default for MinTh and MaxTh. Suggest about 0.2(percent). MinTh, Default Th. 0.0 -> ??? as for Ignore_low in AutoLevels, or threshold in YPlaneMin. MaxTh, Default Th. 0.0 -> ??? as for Ignore_high in AutoLevels, or threshold in YPlaneMax. MinMaxLock, Default True. If true, input_low and input_high set identical eg min(rmin,gmin,bmin) for R,G,B. Else set individually. EDIT: If you (or anyone) would like to knock up a little documentation, that would be glorious [me hates dat]
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2018 at 14:28. |
20th July 2016, 00:04 | #26 | Link | |
Fred.
20th July 2016, 00:07 | #27 | Link | ||
Will test it asap... Quote:
Fred.
20th July 2016, 00:31 | #28 | Link | |
Need full docs, way more sensible than wot I wud wryt. Take your time, be careful, and good. May the lord be with you, and also with you. (no idea wot that means). EDIT: Pick, suggest whatever arg names you want, I pretty much guarantee your suggestions are acceptable and concrete. EDIT: Lost my other Vape stick again, today is a very sad day, again. Sick 0' losin my Vape sticks, the world is such a dangerous place. Stella, beer, pretty damn good. Also your Trappist, brewed by drunken clerics (very well recommended). Belgians are the most prolific of Beer makers (high up there on drinkers too) in the world.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 20th July 2016 at 10:56. |
20th July 2016, 14:21 | #29 | Link | |
my suggestion was about to match a reference channel range coz other tools yet did increase global contrast using something like min(minR,minG,minB)/max(maxR,maxG,maxB), also autolevels roughly do the same but it stretch all of them to 0/255 - 16/235 not maintaining the source frame's dynamic range also IanB was talking about don't change RGB ratios as AutoLevels is to increase global contrast without change colors or dominances. GamMac will change those ratios anyway. ps as gamma function is more effective on the lower part of the range than on the upper one, maybe will be better to use a different, more balanced, curve?
powered by Google Translator Last edited by Motenai Yoda; 20th July 2016 at 14:31. |
20th July 2016, 15:51 | #30 | Link | ||
Yoda, discuss what is required with Fred, so far as I'm concerned it is his baby and he's the gaffer. Source is included in the zip below (I shall not try to convert the original script to be similar to current version). Code:
GamMac(), [Gamma Machine] An extraordinary Idea by VideoFred (the gent from Gent). Coded by StainlessS. Home Thread:- http://forum.doom9.org/showthread.php?p=1774281#post1774281 Idea:- http://forum.doom9.org/showthread.php?t=173683 RGB Only. Useful to correct color cast on old 8mm films. Alters channel pixel average to match LockChan using Gamma correction. (By default alters Red and Blue channels to match Green). Additional tweaking via RedMul, GrnMul and BluMul. GamMac(clip c,int "LockChan"=1,Float "LockVal"=128, \ Float "RedMul"=1.0,Float "GrnMul"=1.0, Float "BluMul"=1.0, \ Float "MinLim"=32.0,Float "MaxLim"=255.0-32.0,float "GamLo"=0.25,Float "GamHi"=4.0, \ Bool "Show"=false,int "Verbosity"=1 \ Float "Th"= -1.0,Float "loTh"=Th,Float "hiTh"=Th,Bool "loHiLock"=True \ ) LockChan Default 1. Chan for lock to Ave. (0)LockVal=RedAve, (1)LockVal=GreenAve, (2)LockVal=BlueAve -1 = Use explicit LockVal below. -2 = LockVal=(RedAve+GrnAve+BluAve)/3.0. -3 = LockVal=Median(RedAve,GrnAve,BluAve) LockVal, default 128.0. Ignored if LockChan != -1.0. 0.0 < LockVal < 255.0 RedMul, default 1.0. 0.1 <= RedMul <= 10.0. Red channel adjustment. GrnMul, default 1.0. 0.1 <= GrnMul <= 10.0. Green channel adjustment. BluMul, default 1.0. 0.1 <= BluMul <= 10.0. Blue channel adjustment. Above Multipliers only shown in metrics when at least one is != 1.0. MinLim, default 32.0. 0.0 < MinLim < 255.0 If any channel average smaller than this, then no effect on channel. MaxLim, default 255.0-32.0. MinLim < MaxLim < 255.0 If any channel average greater than this, then no effect on channel. GamLo, default 0.25. 0.1 <= GamLo <= 10.0. Lower value for guess gamma (starting guess range and limit) GamHi, default 4.0. GamLo < GamHi <= 10.0. Upper value for guess gamma (starting guess range and limit) Show, default false. True, show info. Verbosity, default 1. 0=Only Upper metrics, 1(default)=Upper + important ones. 2=Full metrics. Th, Default -1.0(off) -1.0, or 0.0 -> 2.0. Sets Default for loTh and hiTh. Suggest about 0.0, or 0.1(percent). loTh, Default Th. -1.0, or 0.0 -> 2.0. as for Ignore_low in AutoLevels, or Threshold in YPlaneMin. hiTh, Default Th. -1.0, or 0.0 -> 2.0. as for Ignore_high in AutoLevels, or Threshold in YPlaneMax. Percent, amount of extreme pixels (eg noise) to ignore when finding minimum and maximum R, G or B channel values. -1.0 is OFF, input channel minimum is set to 0 and maximum set to 255.0, as in levels(0,gamma,255, ... ). If loTh set to eg 0.0, then will scan frame looking for minimum accumulated channel values that have more than 0.0% of pixels, and set input_min for that channel to that value. (Accumulated:- including values that were lower but not of great enough number to break the threshold). If hiTh set to eg 0.0, then will scan frame looking for maximum accumulated channel values that have more than 0.0% of pixels, and set input_max for that channel to that value. loTh and hiTh, only shown in metrics if greater or equal to 0.0 ie switched ON. loHiLock, Default True. If (loHiLock==true) then input_lowR = min(rmin,gmin,bmin) ELSE input_lowR = rmin If (loHiLock==true) then input_highR = max(rmax,gmax,bmax) ELSE input_highR = rmax Where for Red, sort of equivalent to outR=LevelsR(input_lowR,gamma,input_highR, 0,255) Same for other channels. Code:
Imagesource("GreenChurch.png",end=0) #Imagesource("Puppy.png",end=0) #Imagesource("lennaRed.png",end=0) #Avisource("1937 Lund Utah 16mm Film [Low, 360p].mp4.avi") #Avisource("1941 Flint Michigan Parade [Low, 360p].mp4.AVI") ConvertToRGB24 ORG=Last LockChan = 1 # Chan for lock to Ave, 0=R, 1=G, 2=B # -1 = Use LockVal below. # -2 = LockVal=(RedAve+GrnAve+BluAve)/3.0 for LockVal. # -3 = LockVal=Median(RedAve,GrnAve,BluAve) LockVal = 128 # Only valid if LockChan == -1 RedMul = 1.0 # Required Ave multiplier for Red Channel, applied when requesting GuessGamma(reqAve*RedMul), Even applied when LockChan=-1. GrnMul = 1.0 # Same for Green channel. GrnMul even applies when LockChan is Green Channel, etc for chans. BluMul = 1.0 # Same for Blue channel. Allows tinkering/fine tuning. Show = true # Subtitles A=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=0) thB = 0.0 BluMulB = 0.95 B=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMulB,Show=Show,Verbosity=1,th=thB) thC = 0.0 BluMulC = 0.95 LoHiLockC=False C=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMulC,Show=Show,Verbosity=2,th=thC,LoHiLock=LoHiLockC) TOP=StackHorizontal(ORG,A) BOT=StackHorizontal(B,C) StackVertical(TOP,BOT) return Last Here v1.04, incl GreenChurch, Puppy, and red Lenna pings(990KB):- LINK REMOVED Fred, I'm leaving totally up to you to say what your orders are, including any arg name changes or whatever, awaiting instruction. I can do what Yoda suggests if required (or make optional via arg if required).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2018 at 14:29. |
20th July 2016, 21:03 | #31 | Link |
OK, have tried to implement what Yoda was talking about.
update to DOC Code:
GamMac(clip c,int "LockChan"=1,Float "LockVal"=128, \ Float "RedMul"=1.0,Float "GrnMul"=1.0, Float "BluMul"=1.0, \ Float "MinLim"=32.0,Float "MaxLim"=255.0-32.0,float "GamLo"=0.25,Float "GamHi"=4.0, \ Bool "Show"=false,int "Verbosity"=1 \ Float "Th"= -1.0,Float "loTh"=Th,Float "hiTh"=Th,Bool "loHiLock"=True \ bool "Scale"=true \ ) ... Scale, default False. if Scale (and loTh and/or hiTh >= 0.0) then scales input channel averages eg, in_scale = (Scale) ? 255.0 / (in_max - in_min) : 1.0; where in_min = min(minR,minG,minB) and in_max = max(maxR,maxG,maxB) Code:
#Imagesource("GreenChurch.png",end=0) Imagesource("Puppy.png",end=0) #Imagesource("lennaRed.png",end=0) #Avisource("1937 Lund Utah 16mm Film [Low, 360p].mp4.avi") #Avisource("1941 Flint Michigan Parade [Low, 360p].mp4.AVI") ConvertToRGB24 ORG=Last LockChan = 1 # Chan for lock to Ave, 0=R, 1=G, 2=B # -1 = Use LockVal below. # -2 = LockVal=(RedAve+GrnAve+BluAve)/3.0 for LockVal. # -3 = LockVal=Median(RedAve,GrnAve,BluAve) LockVal = 128 # Only valid if LockChan == -1 RedMul = 1.0 # Required Ave multiplier for Red Channel, applied when requesting GuessGamma(reqAve*RedMul), Even applied when LockChan=-1. GrnMul = 1.0 # Same for Green channel. GrnMul even applies when LockChan is Green Channel, etc for chans. BluMul = 1.0 # Same for Blue channel. Allows tinkering/fine tuning. Show = true # Subtitles th = 0.0 A=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,Th=Th) B=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,th=Th,SCALE=True) LoHiLockC=False C=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,th=th,LoHiLock=LoHiLockC,SCALE=True) TOP=StackHorizontal(ORG,A) BOT=StackHorizontal(B,C) StackVertical(TOP,BOT) return Last Here:- LINK REMOVED Can both Fred and Yoda check it out [not sure if its worth the bother]. here main changes Code:
PVideoFrame __stdcall GamMac::GetFrame(int n, IScriptEnvironment* env) { n = (n<0) ? 0 : (n>= vi.num_frames) ? vi.num_frames - 1 : n; CountRGB(n,cntR,cntG,cntB,env); int in_minR = (loTh>=0.0) ? ChanMin(cntR,loTh) : 0; int in_minG = (loTh>=0.0) ? ChanMin(cntG,loTh) : 0; int in_minB = (loTh>=0.0) ? ChanMin(cntB,loTh) : 0; int in_maxR = (hiTh>=0.0) ? ChanMax(cntR,hiTh) : 255; int in_maxG = (hiTh>=0.0) ? ChanMax(cntG,hiTh) : 255; int in_maxB = (hiTh>=0.0) ? ChanMax(cntB,hiTh) : 255; int in_min = (loTh>=0.0) ? min(min(in_minR,in_minG),in_minB) : 0; int in_max = (hiTh>=0.0) ? max(max(in_maxR,in_maxG),in_maxB) : 255; if(loTh>=0.0 && loHiLock) in_minR=in_minG=in_minB=in_min; if(hiTh>=0.0 && loHiLock) in_maxR=in_maxG=in_maxB=in_max; double inR=ChanAve(cntR); double inG=ChanAve(cntG); double inB=ChanAve(cntB); double in_scale = (Scale) ? 255.0 / (in_max - in_min) : 1.0; double scaleR = inR * in_scale; double scaleG = inG * in_scale; double scaleB = inB * in_scale; double lockval; if(LockChan==0) {lockval=scaleR;} else if(LockChan==1) {lockval=scaleG;} else if(LockChan==2) {lockval=scaleB;} else if(LockChan==-2) {lockval=((scaleR+scaleG+scaleB)/3.0);} else if(LockChan==-3) { double mx=max(max(scaleR,scaleG),scaleB); double mn=min(min(scaleR,scaleG),scaleB); lockval=scaleR+scaleG+scaleB-mx-mn; } else { lockval =LockVal; } bool skipR=(inR<MinLim || inR>MaxLim); bool skipG=(inG<MinLim || inG>MaxLim); bool skipB=(inB<MinLim || inB>MaxLim); bool guessR=(in_minR!=0 || in_maxR!=255 || fabs(scaleR-lockval*RedMul)>=0.00001); bool guessG=(in_minG!=0 || in_maxG!=255 || fabs(scaleG-lockval*GrnMul)>=0.00001); bool guessB=(in_minB!=0 || in_maxB!=255 || fabs(scaleB-lockval*BluMul)>=0.00001); double gammaR=(skipR || !guessR)?1.0:GuessGamma(in_minR,in_maxR,cntR,lockval*RedMul); double gammaG=(skipG || !guessG)?1.0:GuessGamma(in_minG,in_maxG,cntG,lockval*GrnMul); double gammaB=(skipB || !guessB)?1.0:GuessGamma(in_minB,in_maxB,cntB,lockval*BluMul); SetGammaLut(in_minR,in_maxR, gammaR,lutR); SetGammaLut(in_minG,in_maxG, gammaG,lutG); SetGammaLut(in_minB,in_maxB, gammaB,lutB); ... Code:
double in_scale = (Scale) ? 255.0 / (in_max - in_min) : 1.0; double scaleR = inR * in_scale; double scaleG = inG * in_scale; double scaleB = inB * in_scale; Code:
double in_scale = (Scale) ? 255.0 / (in_max - in_min) : 1.0; double scaleR = (inR - in_min) * in_scale; double scaleG = (inG - in_min) * in_scale; double scaleB = (inB - in_min) * in_scale; Without metrics Think that last mod was correct, updating soon. EDIT: Damn that bottom RHS one is good (Nice one Yoda ).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2018 at 14:31. |
20th July 2016, 22:27 | #32 | Link |
Nice Job, S, beautiful work! Makes faded images look brand new.
p.s. Lena is here https://www.cs.cmu.edu/~chuck/lennapg/lenna.shtml There is a full scan of the original, yes it was reddish and the scarf looks to be blue. Last edited by jmac698; 20th July 2016 at 22:33. |
20th July 2016, 23:02 | #33 | Link |
Thanx very much JMac, but, me gots dem all 12/53 (Marilyn) up till bout 08.
GamMac() v1.04Beta3:- LINK REMOVED Check it out. EDIT: Non of the above have had any of the xxxMul settings applied. All setting same as in first image metrics. Waiting for orders Fred, change anything ? (then beta lifted)
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2018 at 14:32. |
21st July 2016, 01:38 | #34 | Link |
GamMac() v1.04Beta4:- LINK REMOVED
Scale changed from Bool to Int. Code:
GamMac(), [Gamma Machine] An extraordinary Idea by VideoFred (the gent from Gent). Coded by StainlessS. Home Thread:- http://forum.doom9.org/showthread.php?p=1774281#post1774281 Idea:- http://forum.doom9.org/showthread.php?t=173683 RGB Only. Useful to correct color cast on old 8mm films. Alters channel pixel average to match LockChan using Gamma correction. (By default alters Red and Blue channels to match Green). Additional tweaking via RedMul, GrnMul and BluMul. GamMac(clip c,int "LockChan"=1,Float "LockVal"=128, \ Float "RedMul"=1.0,Float "GrnMul"=1.0, Float "BluMul"=1.0, \ Float "MinLim"=32.0,Float "MaxLim"=255.0-32.0,float "GamLo"=0.25,Float "GamHi"=4.0, \ Bool "Show"=false,int "Verbosity"=1 \ Float "Th"= -1.0,Float "loTh"=Th,Float "hiTh"=Th,Bool "loHiLock"=True, \ int "Scale"=0 \ ) LockChan Default 1. Chan for lock to Ave. (0)LockVal=RedAve, (1)LockVal=GreenAve, (2)LockVal=BlueAve -1 = Use explicit LockVal below. -2 = LockVal=(RedAve+GrnAve+BluAve)/3.0. -3 = LockVal=Median(RedAve,GrnAve,BluAve) LockVal, default 128.0. Ignored if LockChan != -1.0. 0.0 < LockVal < 255.0 RedMul, default 1.0. 0.1 <= RedMul <= 10.0. Red channel adjustment. GrnMul, default 1.0. 0.1 <= GrnMul <= 10.0. Green channel adjustment. BluMul, default 1.0. 0.1 <= BluMul <= 10.0. Blue channel adjustment. Above Multipliers only shown in metrics when at least one is != 1.0. MinLim, default 32.0. 0.0 < MinLim < 255.0 If any channel average smaller than this, then no effect on channel. MaxLim, default 255.0-32.0. MinLim < MaxLim < 255.0 If any channel average greater than this, then no effect on channel. GamLo, default 0.25. 0.1 <= GamLo <= 10.0. Lower value for guess gamma (starting guess range and limit) GamHi, default 4.0. GamLo < GamHi <= 10.0. Upper value for guess gamma (starting guess range and limit) Show, default false. True, show info. Verbosity, default 1. 0=Only Upper metrics, 1(default)=Upper + important ones. 2=Full metrics. Th, Default -1.0(off) -1.0, or 0.0 -> 2.0. Sets Default for loTh and hiTh. Suggest about 0.0, or 0.1(percent). loTh, Default Th. -1.0, or 0.0 -> 2.0. as for Ignore_low in AutoLevels, or Threshold in YPlaneMin. hiTh, Default Th. -1.0, or 0.0 -> 2.0. as for Ignore_high in AutoLevels, or Threshold in YPlaneMax. Percent, amount of extreme pixels (eg noise) to ignore when finding minimum and maximum R, G or B channel values. -1.0 is OFF, input channel minimum is set to 0 and maximum set to 255.0, as in levels(0,gamma,255, ... ). If loTh set to eg 0.0, then will scan frame looking for minimum accumulated channel values that have more than 0.0% of pixels, and set input_min for that channel to that value. (Accumulated:- including values that were lower but not of great enough number to break the threshold). If hiTh set to eg 0.0, then will scan frame looking for maximum accumulated channel values that have more than 0.0% of pixels, and set input_max for that channel to that value. loTh and hiTh, only shown in metrics if greater or equal to 0.0 ie switched ON. loHiLock, Default True. If (loHiLock==true) then input_lowR = min(rmin,gmin,bmin) ELSE input_lowR = rmin If (loHiLock==true) then input_highR = max(rmax,gmax,bmax) ELSE input_highR = rmax Where for Red, sort of equivalent to outR=LevelsR(input_lowR,gamma,input_highR, 0,255) Same for other channels. Scale, default 0. Range 0 -> 2. No Effect unless Scale > 0 and loTh and/or hiTh >= 0.0. 0) No Effect. 1) Scales input channel average maximum dynamic range of R,G,B, 0.0 -> 255.0 where, in_min = min(minR,minG,minB) and in_max = max(maxR,maxG,maxB) inR = R channel Average, inG = G channel Average, inB = B channel Average. in_scale = 255.0 / (in_max - in_min) scaleR = min(max((inR - in_min) * in_scale,0.0),255.0) scaleG = min(max((inG - in_min) * in_scale,0.0),255.0) scaleB = min(max((inB - in_min) * in_scale,0.0),255.0) 2) Scales input channel average dynamic range of R and G and B, Individually, 0.0 -> 255.0 in_scaleR = 255.0 / (in_maxR - in_minR) in_scaleG = 255.0 / (in_maxG - in_minG) in_scaleB = 255.0 / (in_maxB - in_minB) scaleR = min(max((inR - in_minR) * in_scaleR,0.0),255.0) scaleG = min(max((inG - in_minG) * in_scaleG,0.0),255.0) scaleB = min(max((inB - in_minB) * in_scaleB,0.0),255.0) Code:
#Imagesource("GreenChurch.png",end=0) Imagesource("Puppy.png",end=0) #Imagesource("lennaRed.png",end=0) #Imagesource("G1.BMP",end=0) crop(0,0,0,-48) Spline36Resize(480,360) ConvertToRGB24 ORG=Last LockChan = 1 # Chan for lock to Ave, 0=R, 1=G, 2=B # -1 = Use LockVal below. # -2 = LockVal=(RedAve+GrnAve+BluAve)/3.0 for LockVal. # -3 = LockVal=Median(RedAve,GrnAve,BluAve) LockVal = 128 # Only valid if LockChan == -1 RedMul = 1.0 # Required Ave multiplier for Red Channel, applied when requesting GuessGamma(reqAve*RedMul), Even applied when LockChan=-1. GrnMul = 1.0 # Same for Green channel. GrnMul even applies when LockChan is Green Channel, etc for chans. BluMul = 1.0 # Same for Blue channel. Allows tinkering/fine tuning. Show = true # Subtitles th = 0.0 LoHiLockC=True Scale=0 A=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,Th=Th,SCALE=SCALE) LoHiLockC=False Scale=1 B=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,th=th,LoHiLock=LoHiLockC,SCALE=Scale) LoHiLockC=False Scale=2 C=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,th=th,LoHiLock=LoHiLockC,SCALE=Scale) TOP=StackHorizontal(ORG,A) BOT=StackHorizontal(B,C) StackVertical(TOP,BOT) return Last Show=False Bot RHS is new Scale=2 (prev Bot RHS puppy now on BOT LHS). EDIT: I can probably move LoHiLock functionality into Scale, once I figure out how they 'interfere/interact' with each other.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2018 at 14:34. |
21st July 2016, 13:53 | #36 | Link |
Not being magic, I do not know.
Have you tried it ? EDIT: Dont know much about the underwater thing, but think much of the red part of spectrum is absorbed by the water, and weird things happen due to distance, the further away things would be further affected by red absorption of the water between observer and the viewed object. There probably is no magic bullet due to the distance from viewer thing, I guess all you can really do is try to correct for the object of main concern. Here, just a quick knock up Code:
Imagesource("Fish.BMP",end=0) Spline36Resize(480,360) ConvertToRGB24 ORG=Last LockChan = 1 # Chan for lock to Ave, 0=R, 1=G, 2=B # -1 = Use LockVal below. # -2 = LockVal=(RedAve+GrnAve+BluAve)/3.0 for LockVal. # -3 = LockVal=Median(RedAve,GrnAve,BluAve) LockVal = 128 # Only valid if LockChan == -1 RedMul = 1.0 # Required Ave multiplier for Red Channel, applied when requesting GuessGamma(reqAve*RedMul), Even applied when LockChan=-1. GrnMul = 1.0 # Same for Green channel. GrnMul even applies when LockChan is Green Channel, etc for chans. BluMul = 1.0 # Same for Blue channel. Allows tinkering/fine tuning. Show = false # Subtitles th = 0.0 LoHiLock=True Scale=0 A=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,Th=Th,LoHiLock=LoHiLock,SCALE=SCALE) RedMul = 0.87 LoHiLock=false Scale=1 B=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,th=th,LoHiLock=LoHiLock,SCALE=Scale) Scale=2 C=GamMac(LockChan=LockChan,LockVal=LockVal,RedMul=RedMul,GrnMul=GrnMul,BluMul=BluMul,Show=Show,Verbosity=1,th=th,LoHiLock=LoHiLock,SCALE=Scale) TOP=StackHorizontal(ORG,A) BOT=StackHorizontal(B,C) StackVertical(TOP,BOT) return Last Also does not help if you got no idea what something is supposed to look like. Here, same pic modded via something else:- http://forum.doom9.org/showthread.ph...98#post1726798 EDIT: Some more stuff here:- http://forum.doom9.org/showthread.php?t=156774 EDIT: On above pic, LoHiLock would have no effect dues to all min being 0, and all max being 255. Also, scale 2 and 3 should produce same I think (for same reason, bottom two pics are therefore probably identical, maybe try adjust eg bluMul a little for one of them).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 15th June 2018 at 14:35. |
21st July 2016, 15:55 | #37 | Link |
I made "6-axis color" for underwater thing. Not sure if it is useful with avisynth environment.
https://gfycat.com/PaleShorttermBelugawhale
VirtualDub2 |
21st July 2016, 23:00 | #38 | Link |
Shekh, that dont look anything like any beluga whale to me (dont they normally look like a dolphin wearing a crash helmet ?)
https://www.google.com/search?q=belu...QiR4IiAE&dpr=1
21st July 2016, 23:52 | #39 | Link |
tormento,
It is possible that MinLim, or MaxLim is preventing any changes on a channel. Try something like Code:
MinLim=0.01 MaxLim=254.99 I'll see if I can implement some kind of indicator when channel mods are disabled due to MinLim/MaxLim. If channel mods are disabled, then will probably see Gamma=1.0 for that channel.
22nd July 2016, 09:20 | #40 | Link | |
Fred.
color cast, correction, fade, gamma |
