16th June 2013, 16:52 | #17461 | Link | |
17th June 2013, 10:43 | #17462 | Link |
@ omegaman7
As much as I Love BD-RB, you should try MKVToolNix. Building a Pseudo file structure isn't always needed from an already created MKV/MP4(V). Unless you need MPX.... ;-)
17th June 2013, 18:48 | #17464 | Link |
If an MKV has trouble playing, most of the time it is because it was created with an incompatible track compression. You can fix that by using MKVMERGE:
mkvmerge.exe -o x:\destpath\outfile.mkv --compression -1:none x:\srcpath\infile.mkv even better: mkvmerge.exe --engage no_cue_duration --engage no_cue_relative_position -o x:\destpath\outfile.mkv --compression -1:none x:\srcpath\infile.mkv mkvmerge.exe is included in the BD-RB tools folder. Last edited by jdobbs; 17th June 2013 at 18:52. |
18th June 2013, 02:58 | #17466 | Link |
mismatch audio error
Received the attached error when BDRB starts extracting the main movie streams. This particular disc has TrueHD tracks. The error doesn't specify which track is in error but the error comes up 3 times, so I'm assuming it's referencing the TrueHD tracks. My questions is, should I answer Yes or No from the options given? Or is this a bug and the warning is in error? Thanks for your help...
18th June 2013, 13:21 | #17467 | Link |
@spotswood
That error message isn't coming from BD-RB. It is from DGIndexNV. Generally I think the PAT/PMT is correct -- but Neuron2 would be a better source of information. Note that you can open DGIndexNV.exe and set an automatic answer so that message doesn't appear. See this link for a discussion. Note: As I mention above the newest versions of DGIndexNV allows you to automatically answer "Yes", "No", or "Ignore Stream" and suppress that message. You set it from the DGIndexNV GUI. I just tested this on my system. Getting that message with TrueHD isn't happening, even if I enable the prompt. So I don't think it is "normal" to get it. Last edited by jdobbs; 18th June 2013 at 13:38. |
19th June 2013, 08:28 | #17468 | Link | |
Shutdown does not seem to work.
In the event log there is no sign that the computer even tried to shutdown. Windows 7 Ultimate - 64 bit |
19th June 2013, 13:38 | #17471 | Link |
shutdown /s works.
I think that you use that command? I have no idea what happened. I will try to verify it again. Edit: Now it worked also with BD_Rebuilder. Something happened (or not happened) last night. Edit2: Is there a way to perform a "shutdown /h"? (hibernate instead of shutting down) Last edited by dt5; 19th June 2013 at 13:52. |
19th June 2013, 14:39 | #17472 | Link | |
Currently you can either shutdown completely, or put the system to sleep when "Shutdown" is selected. To put the system to sleep instead of performing a complete shutdown, see SHUTDOWN_SLEEP as documented in HIDDENOPTS.TXT. Last edited by jdobbs; 19th June 2013 at 14:46. |
19th June 2013, 21:19 | #17473 | Link | ||
20th June 2013, 00:28 | #17474 | Link | |
20th June 2013, 01:13 | #17475 | Link | |
I'd recommend just setting DGIndexNV to answer "Yes" automatically -- and don't worry about it. |
20th June 2013, 02:48 | #17476 | Link | ||
21st June 2013, 12:15 | #17479 | Link |
Paths
@jdobbs
I've recently had some trouble to have BDRebuilder work because it always gave me an ExtractAudioSubs() 00058 1605 error (file already exists). My system is a MacPro with Paralles installed running Windows8. Of course, I am working with network volumes as working directories, they are hfs formatted disk drives being accessed via IP network. The error mentioned above occurs solely in movie only mode! When creating the working directory in the Parallels disk C: everything runs smoothly. I guess the problem is the path name: string length, delimiter or something like this. Although my problem is solved now, it might be easy for you to check on behavior with these network paths and eventually change it. Thanks! |
23rd June 2013, 00:35 | #17480 | Link |
malware in tools?
Comodo just found this:
TrojWare.Win32.Injector.ABQS@299622063 C:\Users\Matt\Desktop\BLU RAY + VIDEO PROCESSING\BD-RBV04306\BD_Rebuilder\Tools\split.exe TrojWare.Win32.Injector.ABQS@299622063 C:\Users\Matt\Desktop\BLU RAY + VIDEO PROCESSING\BD_Rebuilder\Tools\split.exe TrojWare.Win32.Injector.ABQS@299622063 C:\ALL PROG SETUP STUFF\Necessary Setup and Driver Files\VIDEO APPS\BluRay Burning\New Versions of\BD_Rebuilder\Tools\split.exe What do you think? False positive? Matt |
