7th January 2015, 09:08 | #21 | Link |
That test clip correctly resizes to 1184x720 for me using SB62 when I ran the command "mplayer mkv-ar-test.mkv".
MPlayer SB62 (C) 2000-2015 MPlayer Team ... Starting playback... Movie-Aspect is 1.64:1 - prescaling to correct movie aspect. VO: [directx] 960x720 => 1184x720 Planar YV12 |
7th January 2015, 12:34 | #23 | Link |
SuperVirus
OMG, it seems the problem is actually much more complicated than I thought
http://www.mediafire.com/download/cp...ratio-test.mkv MKVinfo says: Code:
mkvinfo Akiha_mkv-aspectratio-test.mkv + EBML head |+ EBML version: 1 |+ EBML read version: 1 |+ EBML maximum ID length: 4 |+ EBML maximum size length: 8 |+ Doc type: matroska |+ Doc type version: 2 |+ Doc type read version: 2 + Segment, size 172488 |+ Seek head (subentries will be skipped) |+ EbmlVoid (size: 4045) |+ Segment information | + Timecode scale: 1000000 | + Muxing application: libebml v1.3.0 + libmatroska v1.4.1 | + Writing application: mkvmerge v7.4.0 ('Circles') 32bit built on Dec 12 2014 12:10:09 | + Duration: 5.000s (00:00:05.000) | + Date: Wed Jan 07 11:05:56 2015 UTC | + Segment UID: 0x81 0xc0 0xfb 0x15 0x93 0x58 0x1a 0xc7 0xac 0x33 0x7c 0x1f 0x85 0xf0 0xe5 0x85 |+ Segment tracks | + A track | + Track number: 1 (track ID for mkvmerge & mkvextract: 0) | + Track UID: 10633627220123197336 | + Track type: video | + Lacing flag: 0 | + MinCache: 1 | + Codec ID: V_MS/VFW/FOURCC | + CodecPrivate, length 40 (FourCC: DX50, 0x30355844) | + Default duration: 41.667ms (24.000 frames/fields per second for a video track) | + Language: und | + Video track | + Pixel width: 704 | + Pixel height: 480 | + Display width: 512 | + Display height: 512 |+ EbmlVoid (size: 1058) |+ Cluster Code:
mplayer Akiha_mkv-aspectratio-test.mkv MPlayer Redxii-SVN-r37278-4.8.3 (i686) (C) 2000-2014 MPlayer Team Compiled against FFmpeg version N-66276-g04b0dda Build date: Sun Sep 14 18:15:13 EDT 2014 duplicated FourCC at line 28 Playing Akiha_mkv-aspectratio-test.mkv. libavformat version 56.4.101 (internal) libavformat file format detected. [lavf] stream 0: video (mpeg4), -vid 0 VIDEO: [MP4V] 704x480 24bpp 24.000 fps 0.0 kbps ( 0.0 kbyte/s) Clip info: encoder: libebml v1.3.0 + libmatroska v1.4.1 creation_time: 2015-01-07 11:05:56 Load subtitles in ./ Load subtitles in F:/C0MM0NAPPS/M000/MPLAYER/mplayer/sub/ ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 56.1.100 (internal) Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4) ========================================================================== Audio: no sound Starting playback... Movie-Aspect is 1.47:1 - prescaling to correct movie aspect. VO: [directx] 704x480 => 704x480 Planar YV12 [VD_FFMPEG] DRI failure. Exiting... (Quit) Code:
mplayer Akiha_mkv-aspectratio-test.mkv MPlayer SB62 (C) 2000-2015 MPlayer Team Custom build by SubJunk, http://www.spirton.com duplicated FourCC at line 28 Scanning dir F:/C0MM0NAPPS/M000/MPLAYER/fonts/files Playing Akiha_mkv-aspectratio-test.mkv. libavformat version 56.16.102 (internal) libavformat file format detected. [lavf] stream 0: video (mpeg4), -vid 0 VIDEO: [MP4V] 704x480 24bpp 24.000 fps 0.0 kbps ( 0.0 kbyte/s) Clip info: encoder: libebml v1.3.0 + libmatroska v1.4.1 creation_time: 2015-01-07 11:05:56 Load subtitles in ./ ========================================================================== Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family libavcodec version 56.19.100 (internal) Selected video codec: [ffodivx] vfm: ffmpeg (FFmpeg MPEG-4) ========================================================================== Audio: no sound Starting playback... Movie-Aspect is 1.00:1 - prescaling to correct movie aspect. VO: [directx] 704x480 => 704x704 Planar YV12 [VD_FFMPEG] DRI failure. Exiting... (Quit) Last edited by filler56789; 7th January 2015 at 12:41. |
7th January 2015, 23:27 | #24 | Link |
SB62 has made a correct choice in that case, while Redxii's is wrong.
Different players handle MKV video resizing differently. I tested that video in VLC Media Player which also did 704x704, and MPC-HC did 480x480, which is still a valid choice. So the logic of the players is this: SB62 and VLC: Use the correct aspect ratio while not downscaling any pixels. MPC-HC: Use the correct aspect ratio while not upscaling any pixels. Redxii's MPlayer: Ignore the correct aspect ratio and display the unadjusted pixels. The first two choices are good in my opinion especially since the user will typically make the video fullscreen or resize it how they want, so the ratio is all that matters. |
mencoder, mplayer, subjunk |
