Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > IFO/VOB Editors
Old 26th April 2018, 13:10   #21  |  Link
Matt Kirby
I work often with TSDoctor and I cut ts-files with that, too. There are no freezes or stuttering. But TSDoc cuts the movies only at I-Frames. The cutting is not frame exact.
Yes an export without menu is possible. BUT the most DVBTV-transport-streams are not compatible to the BluRay standard. In this case TAW will reencode the movie.
For your case try: VideoReDo, TSDoctor or TMPGEnc MPEG Smart Renderer 5
http://tmpgenc.pegasys-inc.com/en/product/tmsr5.html
Matt Kirby is offline   Reply With Quote
Old 26th April 2018, 13:49   #22  |  Link
Music Fan
Thanks, I had found TMPGEnc MPEG Smart Renderer but it's quite expensive for the use I have.
Even with interlaced h264 ?
And can it append segments ?
I could do this with Tsmuxer but it's not that precise ; you can't cut on the i-frame you want, only on the timing. And there is no preview.
Music Fan is offline   Reply With Quote
Old 26th April 2018, 13:59   #23  |  Link
Matt Kirby
Yes, I think so.
No, I don't know how. There is a filemerge tool, when your TV-receiver splits one recording.
You can download a trial of TSDoc and try for yourself.
Old 27th April 2018, 09:17   #24  |  Link
Music Fan
Ok thanks.
Old 30th April 2018, 15:43   #25  |  Link
Ghitulescu
Ghitulescu's Avatar
If there are some frames that aren't accepted then only this few frames will be encoded. And that will be displayed.
Laymaen usually have a simplisitic opinion upon professional things.
Some think that by buying eg a professional screwdriver or hammer they are automatically professional themselves, even if they have no idea how a nail is hammered down.
Others think professional is just another word to describe expensive things.
I would like to find out how this software managed to insert a new cell in a commercial videostream, which had to be strictly compatible with the standard, without recoding at least partially the video? And what reason had TAW discovered to consider a perfect legit video as "smart rendering"-able?
Reading about is not the same as FC /B (for binary). I bet you'll have a surprise.
Born in the USB (not USA)
