27th November 2024, 21:08 | #20961 | Link |
Seeing how there is very little difference between the 3900x and 5900x, I doubt there would be much of a difference between the 3700x and 5700x in encoding performance. Remember encoding is based a lot on core and thread count, maybe a 5900x or a 5950x from the 3700x to get more cores. You will have to account for additional cooling though, either an aoi or a noctua d15, but that also brings into play the case on if it can handle an aio or the 165mm cooler height of the Noctua.
27th November 2024, 21:22 | #20962 | Link |
Since we have been talking power usage lately, i found this that is interesting. Instead of changing the max cpu state in the power plan to 99%, leave that at 100%. then regedit here:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings\54533251-82be-4824-96c1-47b60b740d00\be337238-0d82-4146-a960-4f3749d470c7 and change "Attributes" (DWORD) and set to "2" Now, there is a new setting on advanced power settings: (in the legacy control panel power options) "Processor performance boost mode". Set it to "Disabled" and cpu power drops considerably. This works for both AMD and Intel CPU's and forces everything to run at the base clock speed (setting to 99% didn't do anything for me on my Intel systems) Have found on my AMD boxes, there is little performance difference with a considerable power decrease. On the Intel systems, since they have a much lower base clock (larger spread from base to boost speed) it does hamper performance a bit more. On my i7-14700, disabling boost, dropped p-cores to 2gz and E-cores to 1500 mhz. but cpu power dropped from 175 watts to 35 watts. lost about 30-40% performance Just something else to consider if looking at lowering power usage quickly without messing with BIOS settings. If I get some time this weekend, I'll run some numbers comparing the same video/chunk for each machine both boost enabled/disabled and come up with a fps versus watts used and see where things shake out. Last edited by rlev11; 27th November 2024 at 21:59. |
29th November 2024, 16:24 | #20963 | Link | |
And as someone else said, their machines won't sound like a jet turbine just to gain another 5% performance at double the power usage and most likely killing the processor sooner then later. Last edited by Ryushin; 30th November 2024 at 14:09. |
2nd December 2024, 13:22 | #20964 | Link | |
5th December 2024, 12:59 | #20965 | Link |
Is there a way to force files shorter than 60 seconds to still be encoded distributively?
The problem I'm having is that my main RipBot controlling computer, which I don't usually encode with but like using as the central server, uses a iGPU (UHD 770). Any video with KNLMeansCL used gets extra blurry/halos around the edges of things when encoding with the UHD 770, but with KNLMeansCL off or when I use any of my other computers with discrete GPUs I don't have that issue. Example of the issue: https://imgur.com/a/X09dQrh Last edited by hardkhora; 5th December 2024 at 13:14. |
5th December 2024, 14:39 | #20966 | Link | |
do you really need nlmeans noise reduction on this footage? Looks fine to me.... I usually use CPU degrain on anime, rarely nlmeans does a better job. |
5th December 2024, 18:18 | #20967 | Link | |
I was trying to understand if there a way to force files shorter than 60 seconds to still be encoded distributively? I also tried updating the iGPU driver and that didn't make a difference. |
5th December 2024, 19:28 | #20968 | Link | |
if you donīt run a encoding server on the master PC - shouldnīt it pass one chunk onto one of the network encoders? Have you tried that ? |
5th December 2024, 20:49 | #20969 | Link | |
I tried setting the chunk size to 0 but it still won't pass it to encoding servers as I'd expect. |
7th December 2024, 08:31 | #20971 | Link | |
Doesn't have to work as hard to achieve sitting at the speed limit which puts less strain on engine overall. |
7th December 2024, 19:58 | #20972 | Link |
So I got a chance to do a full test for FPS and wattage on my entire encoding farm with cpu boost enabled and disabled. I did a separate run with a 4k source (3840x1600 light degraining) and a 1920x1080 source with heavy degraining just to see how they compare. The below link is for the spreadsheet with the results. Ran each run and got the fps from the distributed encoding window and for each cpu it was the same chunk number so that matches up. I also timed each run and saw about a 10-12% increase in total encoding time without boost, which is close to what the fps difference is. Saw about a 48% total drop in combined power usage.
So my math may be fuzzy on the end result, but it looks like it is much more cost efficient to run at least AMD processors with boost disabled since their spread is minimal. Just using my raw numbers, If an encode runs for 1 hour at full power, I would use appx 106380 total watts. If running with boost off and it takes 15% longer (69 minutes) I get 63135 total watts used for the same encode. I am not advocating anything with this, just was curious of the difference and how it all fits together. And plus, as others have mentioned, your computers don't sound like a turboprop taking off. https://docs.google.com/spreadsheets...#gid=983798900 Last edited by rlev11; 7th December 2024 at 20:03. |
8th December 2024, 00:44 | #20973 | Link |
I'm running RB 1.27.4 and for some reason every time I try to encode a movie from Netflix it encodes like normal but when played back on computer or portable hard drive the movie keeps skipping and looping which makes watching impossible. Only happens with Rb for some strange reason. Same file I encode with other software works fine.
9th December 2024, 11:11 | #20975 | Link |
Hello Atak Snajpera
I see from the logs shown in mediainfo that RipBot has different default settings than the x265. Code:
x265 default : --ctu 64 --max-tu-size 32 --qg-size 32 --merange 57 --aq-mode 3 RipBot default : --ctu 16 --max-tu-size 16 --qg-size 16 --merange 9 --aq-mode 2 Cheers, D |
10th December 2024, 03:34 | #20977 | Link | |
10th December 2024, 19:35 | #20978 | Link |
Pig on the wing
I did a little power consumption test on a 5950X just for fun, using my chunked encoder to run an analysis step.
With PBO enabled and Curve Optimizer tweaked cores, the process took 1h 45min 47sec. With stock multiplier and PBO disabled (i.e. all cores constantly at 3600 MHz), the process took 1h 50min 22sec. The average power consumption of the whole PC with PBO enabled was 416,7 Watts and with stock clocks 361,8 Watts. These were measured using a Shelly smart plug with 5-second resolution stored to an SQL database. So with about 5% loss in performance, a gain of close to 15% in energy efficiency which is quite nice if you for example don't have any excessive solar power to utilize here.
