6th October 2020, 18:00 | #18702 | Link |
I have stumbled upon an hevc stream ripbot seems to have massive problems with, two notable problems:
- It seems to have problems decoding it in the first way: Auto cropping does not work with the message :" 'INF' is not a valid floating point value ", setting cropp left and right to 1000 and it can not generate a preview, no matter how often I press new frame. I've seen that before, and worked around it by analyzing it in a different software and then just punching in the numbers manually. -Additionally, and this is first for me: When trying to encode, not matter the settings, distributed or single machine encoding and the target codec, at exactly the time it fails. The fps goes up, the bitrate goes way way down, and the cpu consumptino goes down to, on all machines that are participating. When done in in DE mode, the later chunks are just very small and are only black, and if mixed together the video just stalls at the last good frame. The Original Video play back fine on all sorts of players and machines. Can someone give me any tipps? |
11th October 2020, 18:43 | #18703 | Link |
I am having a problem with Output Speed option (under Avisynth) which is giving intermittent problems. Originally noticed this in August, went away and has now re-appeared
It appears to be a problem for some encodes and not others - where it does occur then If I use any setting other than default The FPS on the main screen does not change The Duration on the main screen does not change Once encoding is started a 'info.txt does not exist' error is generated After which the script goes directly to the final re-encode and shows 'Error: The file 'H:\Temp\RipBot264temp\job2\video.265' could not be opened for reading: open file error.' Re-setting Output Speed to default allows the program to run. I use this option where I have used MkvCutter to edit and re-encode the start of a video. As it re-encodes at 24 fps regardless of the speed of original, I need to use the Output Speed to prevent the audio and video being out of sync. I have tested on the same videos, with or without using MkvCutter, in each case RipBot264 runs normally if Output Speed is default and fails for any other setting. Any suggestions on what I can do to track down why this setting (Output speed) is not taking properly. Thanks Archiel Last edited by archiel; 11th October 2020 at 18:58. |
12th October 2020, 01:08 | #18704 | Link | |
Grumpy Old Man.
12th October 2020, 11:21 | #18705 | Link | |
As such I would prefer to understand how to see why change output speed is not working as expected. |
13th October 2020, 00:57 | #18706 | Link | |
Grumpy Old Man.
Anyway, I think you've sussed out why Ripbot encodes the whole clip at the wrong fps...but of course there is ONLY one person who can do anything to rectify that. So good luck, you should still keep looking for other ways to edit...that doesn't change the fps !!
15th October 2020, 12:41 | #18707 | Link |
Looks like MakeMKV has added support for Dolby Vision. Not sure if the other tools have been updated yet that Atak can add this support in RipBot.
https://www.makemkv.com/forum/viewto...p?f=12&t=23306 https://www.reddit.com/r/PleX/commen..._android_beta/ |
15th October 2020, 23:45 | #18708 | Link | |
Grumpy Old Man.
No use to me
16th October 2020, 13:40 | #18709 | Link | |
After checking I noticed that the same problem exists if I used the unedited file as the input. In each case the file info.txt is lost from the job folder after selecting a non-default output speed - resetting to default recreates the file. After looking at bunch of other files, the issue only seems to arise if any of the audio is encoded with FLAC, it does not happen with AAC or DTS audio. For now the workaround is simple, do not include any FLAC audio in the file I am working on, then add it back from the job folder or the source file after RipBot64 has finished encoding the video. On a separate note, is there a way to retain track names or to add them back with a post-processing script. For example, a file may have a secondary audio "Commentary by .." |
16th October 2020, 22:08 | #18710 | Link | |
17th October 2020, 13:00 | #18712 | Link | |
Grumpy Old Man.
https://www.mediafire.com/
17th October 2020, 17:59 | #18714 | Link |
you can't.
19th October 2020, 14:31 | #18715 | Link | |
http://www.mediafire.com/folder/yobt...1ycae2e/shared In both cases changing the Output Speed fails if a flac audio track is included and any track names (audio and subtitles) are lost during the editing/conversion process. n.b. first time using mediafire, so my apologies if I have not done this correctly. |
19th October 2020, 16:27 | #18716 | Link | |
Track names I will try to add this weekend. Currently I'm too tired mentally after my real day job...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 19th October 2020 at 16:29. |
22nd October 2020, 21:14 | #18718 | Link |
cdial
Hi Atak,
Been a long time fan of RipBot. I use an automated script on linux with Nvenc for a lot of stuff but nothing better for x265 than RipBot with distributed encoding. I just setup some servers and I'm trying to get watchfolders setup. I've been looking through the thread and not sure how the txt file is supposed to be formatted. Also will you be adding any Nvenc Support? The newer cards are supporting 10 bit and B frames so hopefully quality will just get better like the old days of xvid to x264. Just curious because I would love to be able to use RipBot for everything. Thanks |
23rd October 2020, 15:07 | #18719 | Link | |
C:\MyWatchFolder1 D:\MyWatchFolder2
25th October 2020, 12:22 | #18720 | Link |
Grumpy Old Man.
Update hiccup
Atak, something's wrong
2020-10-25 22:15:47 : Update for [mkvtoolnix] detected 2020-10-25 22:15:47 : Downloading file http://atak-snajpera.5v.pl/ripbot264...mkvtoolnix.zip to D:\RipBot264v1.26.0\updates\mkvtoolnix.zip 2020-10-25 22:15:50 : [ERROR] File http://atak-snajpera.5v.pl/ripbot264...mkvtoolnix.zip could not be downloaded! However, if you click on the link, it will download successfully, and when placed in the Update folder, it DOES install without error.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 25th October 2020 at 12:29. Reason: more info |
