15th July 2019, 22:49 | #56841 | Link |
i can only tell a couple out of my head and they depend on the windows version.
FSE is simulated/faked on win 10. this is planned by microsoft and can result in all kinds of issues. they added a new great WFS 10 bit flip presentation but they can't leave there finger of FSE. WFS 10 bit was broken a couple of times now this is not planned. 1903 just added a new level of banding thanks to yet another WDDM version this is month old. windows 10 brought back the desktop composition mismatch issue from win 7. this is an extremely old bug and finally acknowledge by nvidia. |
15th July 2019, 23:02 | #56842 | Link | |
gamma 2.2 relative w 100% black offset is pretty good at hiding black noise (setting recommended by Florian from dispcal for HDR)
Ghetto | 2500k 5Ghz Last edited by tp4tissue; 15th July 2019 at 23:08. |
15th July 2019, 23:09 | #56843 | Link |
You wanna watch the Open Matte release of Alita, not sure if it'll ever be released officially.
16th July 2019, 01:31 | #56844 | Link | |
Use this auto select rule: if (HDR) "BT.2020" else "BT.709" One profile name is BT.2020, the other is BT.709 for the calibration portion. I ticked report BT.2020 to display (nVidia only) for BT.2020 although I can't remember why. Maybe someone knows exactly what that switch is for and can elaborate.
HOW TO-Kodi 2D-3D-UHD (4k) HDR Guide Internal & External Players W11 Pro 23H2 GTX960-4GB RGB 4:4:4 @Matched Refresh Rates 8,10,12bit KODI 21 MPC-HC/BE 82" Q90R Denon S720W |
16th July 2019, 01:56 | #56845 | Link | |
Ghetto | 2500k 5Ghz |
16th July 2019, 02:19 | #56846 | Link | |
16th July 2019, 06:54 | #56847 | Link | |
Thanks. My projector is the Epson ls10500. So think setting to DCI-P3 is correct. What would happen if you select disable calibration controls to this device? |
16th July 2019, 08:21 | #56848 | Link | |
16th July 2019, 08:58 | #56849 | Link | |
Does this also apply if I wish to use two 3DLUT files? |
16th July 2019, 10:33 | #56850 | Link | |
E.g. why should a nvidia GPU user care about AMD GPU problems or vice versa? In Windows 10 certain problems can show up which canīt show up in Windows 8. Ok, so itīs good to recommend Windows 8 in a general way. On the other side many Windows 10 users donīt have problems. Letīs say 5% of the Windows 10 users have problems, which they wouldnīt have if using Windows 8. Then Iīd say: This 5% should downgrade to Windows 8, but the remaining 95% should still use Windows 10. In my post I simply wanted to point at a personal problem with Windows 10 1903, a hint to maybe delay upgrading for others and the implicit question if someone else experiences similar problems. Implicit answer: "Your fault, Windows 8 is the better/recommended/right OS for HTPC usage". Thatīs the point. |
16th July 2019, 10:54 | #56851 | Link |
every 1903 user with new GPU driver get's banding everyone so you going to tell me that 5% and this is not the first time and this will not be the last time.
there is not a single know major problem with win 8 for years. because you are willing to spend hours to fix win 10 don't except other user to waste there time. windows 10 is a nightmare because it simply get's updated to often. do we really need a new WDDM version every 6 months... |
16th July 2019, 10:57 | #56852 | Link |
This has been confusing me as well... what is Microsoft doing?
madVR options explained |
16th July 2019, 12:23 | #56853 | Link |
I think people are totally overrating the impact of the new WDDM versions, as if that will always break the drivers and cause all issues. And its not like they are just doing it out of boredom, there is actually new and useful stuff being included.
Short recap of recent WDDM additions: WDDM 2.0 (Windows 10): D3D12 WDDM 2.1 (1607): Shader Model 6.0 (improved parallelism for much better performance), HDR10, Variable Refresh Rate WDDM 2.2 (1703): VR WDDM 2.3 (1709): Backend technology improvements for better hardware control WDDM 2.4 (1803): More primarily backend improvements, support for choosing your rendering device on a per-application basis WDDM 2.5 (1809): Ray Tracing WDDM 2.6 (1903): Shader Model 6.4 (ML stuff), Variable Rate Shading Now you might not be interested in all of those, most are gaming-only afterall, but I would rather have the graphics stack being brought forward then it stagnating just because some people don't like change.
16th July 2019, 13:04 | #56854 | Link |
the added feature are not the problem it is the to short time frame. the major issues aren't stopping game mode, deleting personal files, reboot loops and now banding for everyone.
heck i have to buy a new studio mic soon because because 1903 decided that the driver isn't a windows driver anymore for an USB device. shader model 6.4 will not be used in huge quantities any time soon. using insider builds to provide these new features every 3-6 months is great so developer can create content with these features a proper implementation takes a long time anyway. there is a fine difference between stagnation and forcing it down your throat. windows update have a terrible track record and forcing it out every 6 month clearly doesn't help. how may normal user would be negatively effected by delaying WDDM versions from 1607, 1709, 1803, 1903 for 6 months? 2 and a half month until we get a new WDDM version which will come first the banding fix or this new version your bets are on. |
16th July 2019, 13:17 | #56855 | Link |
Maybe the display can't do BT.2020 in SDR mode? Or maybe it has something to do with how the 3D LUT was profiled.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 16th July 2019 at 13:23. |
16th July 2019, 13:18 | #56856 | Link | |
If you disable the controls, it defaults to BT.709 and pure power gamma 2.20.
16th July 2019, 13:22 | #56858 | Link |
If your 3D LUTs are for SDR and HDR content, that would work.
16th July 2019, 14:12 | #56860 | Link |
NVIDIA uses proprietary API to enable HDR on Windows 8.1, only with WDDM 2.1 is there an official OS-driven way to do it, which for application developers means they don't need to build that stuff 3 times (once for AMD, NVIDIA, Intel each).
