2nd February 2014, 18:06 | #19081 | Link | |
Mr
2nd February 2014, 18:40 | #19082 | Link | |
Mr
It would seem that it recognizes the presence of Intel Media encoder/decoder hardware and tries to use it regardless. Don't know if others with Ivy or Sandy Bridge processors have tried to use this feature. It always fails immediately following the completion of the extraction phase. Last edited by dfsooner; 2nd February 2014 at 18:49. |
2nd February 2014, 18:43 | #19083 | Link | |
Someone further back in the thread reported using a supported processor without issues... |
2nd February 2014, 18:53 | #19085 | Link | |
This only happens on movie-only backups, right? Last edited by jdobbs; 2nd February 2014 at 19:00. |
2nd February 2014, 19:21 | #19087 | Link | |
It might be a day or two, but I'll find it and fix it. |
2nd February 2014, 19:33 | #19089 | Link | ||
2nd February 2014, 20:05 | #19090 | Link | |
I cannot test it on my other player, as it's from 2012 and adheres to Cinavia. If I may suggest you leave it playing, and come back to it past the half way point. Thanks. |
2nd February 2014, 20:12 | #19091 | Link | |
2nd February 2014, 20:35 | #19092 | Link | |
Mr
It fails on the two with Intel hardware encode capabilities (Ivy Bridge & Sandy Bridge) and works on the one without. Therefore, I must remain skeptical that it is set up to work properly with Quicksync-enabled processors. Update: I may owe you an apology. On a hunch, I cleared my BDRB folder completely, copied all the new stuff into it, set the FRIM_SW_DECODE and FRIM_SW_ENCODE parameters to 1 and tried again. It seems to be working! It would seem that something in the install folder, maybe old BDREBUILDER.INI parameters or an old project file, was the culprit. I will also check to see if it works with hardware decode. Update 2: Still fails with hardware decode. In addition, I see just enough pixilation in the right eye of the finished product to make it annoying to watch. That is the case on three different titles processed on three different computers. Last edited by dfsooner; 3rd February 2014 at 16:31. |
3rd February 2014, 18:07 | #19093 | Link | |
I thought "Raw Video" must be set to "all YUV". I'm not doing 3D Bluray's, only 2D to MKV. Last edited by Glarioo; 3rd February 2014 at 18:10. |
3rd February 2014, 21:55 | #19094 | Link |
[QUOTE=dfsooner;1665745]
It fails on the two with Intel hardware encode capabilities (Ivy Bridge & Sandy Bridge) and works on the one without. Therefore, I must remain skeptical that it is set up to work properly with Quicksync-enabled processors. --I too am having problems converting SBS 3D videos. I have never had problems previously using BD Rebuilder, even when creating 3D SBS MKV's. Is it something on just my Intel i7 system or is there is a setting I am missing that enables the 3D output ISO. I have done a fresh install of BD Rebuilder (and all helper apps) on two different OS's (WIN-7 64k & WIN-8.1 64k w/ Nvidia GTX-550 Ti GPU) and am puzzled why it will not complete, even using the hidden commands FRIM_SW_DECODE=1 & FRIM_SW_ENCODE=1. Included Files: BD Rebuider.log Code:
---------------------- [02/03/14] BD Rebuilder v0.46.07 (beta) [15:38:20] Source: PJSOFMNSTERS3D_(SBS)_00000 - Input BD size: 3.88 GB - Approximate total content: [01:46:09.029] - Target BD size: 23.68 GB - Windows Version: 6.2 [9200] - MOVIE-ONLY mode enabled - Converting SBS source to 3D-BD format - Quality: High Quality (Default), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:38:21] PHASE ONE, Encoding - [15:38:21] Processing: VID_00000 (1 of 1) - [15:38:21] Extracting A/V streams [VID_00000] - [15:40:04] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 152,704 frames - Bitrate: 28,997 Kbs - Using FRIMEncoder for MVC reencoding - [15:40:04] Reencoding: VID_00000, Pass 1 of 1 [15:40:05] - Failed video encode, aborted BD Rebuilder INF [ Code:
Status] LABEL=PJSOFMNSTERS3D_(SBS) VERSION=v0.46.07 (beta) SOURCE_SIZE=4166344704 SOURCE_VIDEO_SIZE=4166344704 TARGET_SIZE=25427968000 REDUCTION=6.10318391936876 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng;spa; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng;spa; BACKUP_MODE=1 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 SSIF_MODE=0 QUICK=0 ENCODE_STEP=1.5 [00000] AUDIO=1 PGS= APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=25427968000 RATE=28997 Thanks jdobbs, Let me know if you need any more info. |
4th February 2014, 00:16 | #19096 | Link | |
It might be a good idea on the next release for me to set SW encoding/decoding as the default, and make automatic the alternative. Last edited by jdobbs; 4th February 2014 at 00:53. |
4th February 2014, 00:54 | #19097 | Link |
BD Rebuilder v0.46.10 (beta)
I have updated the first post of this thread with links to the latest version of BD-RB (v0.46.10). Changes for this release:
- Fixed an issue in which incorrect setting of the decoder for FFDSHOW VFW Raw video could cause 3D backups from SBS to fail at encode time. BD-RB now sets the VFW/rawv correctly before encode, and then resets it to it's previous state at completion. - Added warnings when attempting to backup SBS 3D sources and the backup mode is not correct for BD-3D using MVC. - Corrected a problem in which forced sub- title text in movie-only mode could, under certain circumstances, remain on until the next subtitle period begins. - Changed the default for FRIM decoding and encoding from "Automatic" to "software". It seems this will provide a greater level of compatibility, even on Intel processors. - Added code to prevent "Keep original video" from occurring when processing a SBS source into BD-3D. - Removed INSPECT.EXE from the build. The same functionality is now available from the BD-RB HELP menu. - Added FFDSHOW release 4515 to the list of tested/recommended versions. - Other minor corrections and cosmetic fixes. |
4th February 2014, 02:24 | #19099 | Link | |
Mr
4th February 2014, 02:50 | #19100 | Link | |
I'm not saying you can't create a presentable BD-5/9 -- but I wouldn't expect quality comparible to the original. I personally do all my 3D backups to BD-25 (except possibly imported half-SBS sources that have already lost a significant portion of their true resolution before the conversion). |
