10th September 2011, 14:02 | #801 | Link | |
Subtitles are so small that they virtually no impact on the output quality -- why even bother worrying about it? Just keep all subtitles all the time (that's what I do). Of course, now that I think about it, sometimes European titles can have a huge number of subs... I guess just having to select from that list during playback might be a factor. I'll take a look at it. Unfortuantely it would mean I have to scan the entire set of subtitle streams to see if any are "forced". Last edited by jdobbs; 10th September 2011 at 14:05. |
10th September 2011, 14:11 | #802 | Link |
The "problem" is that when i select the subtitles in Elgato Turbo.264 then all subtitles (Extracted from BD Rebuilder) are visible all the time in the Video.
When BD Rebuilder extracts only the forced (Option), then only the forced would be visible. |
10th September 2011, 14:16 | #803 | Link | |
Also i don't know how Pavtube Blu-Ray Ripper is doing it. I select the stream and then there is no visible scan for forced subs, encoding starts from the beginning (to e.g. AppleTV Format). |
14th September 2011, 17:13 | #804 | Link |
Here's my workflow for forced subs:
Rip to HD with AnyDVDHD. BDRB Movie Only with 1 English Soundrack and all English Subs. Use BDSub2Sup to examine the subs in the BDRB workfiles folder. It will report if there are forced subs in each sub track. If there are none, that just makes it easier. (You can skip the rest and just use the built in function in BDRB to output for a different device. Since there aren't any forced subs you don't need to mess with them.) Use RipBot264 and load the single .mt2s file created by BDRB. I adjust settings to 2 pass encoding with 1024 bitrate, no cropping, and resize to whatever I need. (Usually this is for my iPad so I do 1024xwhatever is needed for the aspect ratio of the movie. RipBot264 will Demux the mt2s and then let you pick which sub/audio streams to put back in your movie. (If you didn't check the subs out in the BDRB/Workfiles folder you can do that now with BDsub2sup. They are in the Temp/Work/YourMovie folder that RipBot created) In the subtitle selection in Ripbot I just pick the stream that has the forced subs and then make sure it is only going to display the forced ones. You can also use the preview function and see the subtitles as they will end up. If all looks good, I add it to the queue and then start the reencode. RipBot is definitely slower than BDRB, but you will eventually end up with a good looking/sounding movie that displays the forced subs and plays on your device. It's worked for me so far on all the movies I've tried (Avatar extended collectors, Taken, Tourist, Da Vinci Code, Angels and Demons to mention a few). Jeff Last edited by jwjohnson; 14th September 2011 at 17:17. |
14th September 2011, 17:35 | #806 | Link | |
If then i would convert it with pavtube blu ray ripper (option only forced subtitles checked), maybe before extract main movie with BDRebuilder (didn't have enough time if Pavtube markes the Main movie exactly) , finished. If not, extract main movie with BDRebuilder, convert with Elgato H.264, finished. |
15th September 2011, 00:07 | #807 | Link |
Identify Selected or Default Playlist from Menu
The latest "game" studios are playing with released BDs is to have disguised, bogus and multiple playlists in order to confound backing up a title in movie only mode. It can be tricky to identify which playlist is the correct one. Sometimes these multiple playlists are legitimate (dynamic branching of different language titles, etc. in films - Disney does this a bit). At other times, it is just intended to convince a program or person to process an incorrect playlist. As an example . . the animated feature "Anastasia" has 4 playlists that look alike (same length, # of chapters, etc.). BDRB defaults to the lowest numbered one. How can we be certain that is the one we want? Is there a way to reliably determine which playlist is being run by the main menu on the disc, so we can be sure to pick the right one when backing it up or converting it? Is there a player program that will handle the menus and show which playlist has been selected and is running?
15th September 2011, 00:23 | #808 | Link | |
Some of them (like "Source Code") have a ridiculous number of choices -- and most are goofy (with repeated scenes). There's no easy way to tell which is the "real" feature. |
15th September 2011, 18:40 | #812 | Link | |
I was actually playing around with the animated title "Anastasia" which indicates 4 full feature playlists - all valid, the same length and all the same number of chapters. I expect they are related to language selections where dynamic branching is used to change the language being displayed in credits, titles, etc. within the movie itself. Disney uses this approach also. That's why I was inquiring about a method to indicate or tell which playlist the BD disc menu process has selected and is using/playing as a way to select the desired playlist to be processed within BD-RB. |
16th September 2011, 02:04 | #815 | Link |
I believe the newest versions of these decrypting programs (Slysoft & Fengtao) are requiring internet connections to handle newer titles. I wonder if the programs need access to file servers to access data telling the program which playlist, etc. to default to. If AnyDVD knows which playlist to default to in a title such as "Source Code", is that because the program can figure it out? Or because someone figured it out and made the info available to the program via the Slysoft program server. Just some thoughts . . .
16th September 2011, 04:48 | #816 | Link | |
http://forum.slysoft.com/showthread.php?t=49011 |
16th September 2011, 14:04 | #817 | Link | |
16th September 2011, 21:34 | #818 | Link |
@rick86: you're wrong about anydvd "requiring" internet to handle newer protections. The online database speeds up decryption but is not a requirement. If you disable the database in settings it will still decrypt just might take a bit longer. And if it fails to decrypt you can then try the online BD.
17th September 2011, 05:01 | #819 | Link | |
17th September 2011, 12:29 | #820 | Link |
server updates are applied yes and that results in the increased decryption but it's not mandatory. hell i've had it use the local database on newer discs. If it would NEED the online database then there wouldn't be a local one anymore + there would be no need for Peer to create special BDPHash.bin's (for blu-rays) to get a local decryption. Even with the online database if they're really new or have a new protection there's no guarantee that the online database will be able to decrypt. Thats why a local DB will always be usefull, that and the fact that not every computer is hooked up to the internet. If they were making it mandatory to have online access (like that crappy passkey or DVDFab itself), then a bucketload of users would get screwed over that don't hook their computer up to the net. They'd be unable to decrypt the discs. That's not a slysoft way, thats the fengtao "screw you" way.
