9th July 2012, 23:26 | #61 | Link |
In the function "static PcsData ParsePicture(byte[] buffer, SupSegment segment)" in BluRaySupParser.cs you can see where I loop through compositionObjectCount x PcsObjects. The original code assumed there was only 1 PcsObject per subtitle frame a.k.a. a single region.
Once you have multiple PcsObjects per PcsData describing the regions, you need multiple BitmapObjects in the Pcs as well with the actual data (attached when the Pcs is being completed). So PcsData goes from being a simple class to containing several collections which must be dealt with separately. Last edited by Tappen; 9th July 2012 at 23:32. |
22nd August 2012, 04:22 | #63 | Link |
Dear slartibardfast,
I don't know what happens but I can never use the output of PunkGraphicStream directly. Now, I see there is no more "cropping" issues, but instead the timing is seriously messed up. Several subtitles are displayed too long while the next subtitle doesn't show up. It happens to ALL the outputs. BUT, if I feed those outputs into bdsup2sub and save them, everything is now fine. One more step, but I still appreciate the speed PunkGraphicStream and use it instead of avs2bdnxml (EasySub). I uploaded the ass and the two generated sups for your review: https://dl.dropbox.com/u/19135597/testPGS.rar ========== PS: I used tsMuxer to create sample bluray, and TotalMedia Theater 5 to play it. But the good thing is XBMC plays it without problem, while it has problem (flashing subtitle) with the outputs of bdSup2SuB. . I will run a test on my Media Tank Player and report the compatibility issue, if any. ============== Edit: HD Player can't display properly PunkGraphicStream, but, again supports well output of bdSup2SuB So, the situation is like this Code:
PunkGraphicStrem bdSup2SuB HD Player x ok TotalMedia Theater (5) x ok XBMC (12) ok x Last edited by qknet; 22nd August 2012 at 14:30. |
5th January 2016, 00:16 | #66 | Link | |
7th December 2018, 17:39 | #71 | Link |
I love this application! Exactly what I needed.
However I had this bug with the fps as well. @LowDead Which version did you use? In my case both (23.976 and 24) options will give me a .sup with 24 fps. At least that's what Blu-Disc Sudio says (Decoding PGS stream (track 5): Resolution: 1920:1080 Frame rate: 24 Change FPS from 24 to 23.976 for PGS stream #5), when I'm exporting something (via tsMuxeR) with the converted subtitles. And in the finished product, the subtitles are a little bit to slow. Any idea what I'm doing wrong? Or what I could do alternatively to compensate this? I'm no sure, how the "24fps"-information is contained in the .sup, but maybe it's possible to change it? Or to somehow compensate it by changing the .ass before converting? I'm still not entirely sure, how all the subtitles stuff works, I thought it's about absolute timestamps anyway. I'd appreciate, if someone could help me there. Also, I just realized that suddenly I'm getting the mentioned error. (Encode failed - java.lang.UnsatisfiedLinkError etc.) I have installed 32-bit java and didn't change anything since the last time. It runs without problems on my notebook. Any idea, whta this could be about? |
7th December 2018, 21:10 | #73 | Link |
Is it able to do the same thing? Because I have some effects like blur, fade, positions etc as well as different styles and if i remember correct, easySup was only generating the images in it's own style from the text.
Correct me if I'm wrong, if this would work I'd be happy to use it. |
8th December 2018, 17:29 | #75 | Link |
I did, and it almost worked perfectly after trying a few things. I guess I will pn you about the one last thing, I don't want to spam this thread with my specific kinda offtopic questions. I hope that's ok.
Anyway, thanks for the help! |
