31st May 2023, 18:21 | #1421 | Link |
Broadcast Encoder
Chelsea is blue and Gispos is a dude, we don't do that here. :P
eheheheh not this time. This time it works for real. Last edited by FranceBB; 31st May 2023 at 18:36. |
31st May 2023, 22:45 | #1422 | Link |
Big Bit Savings Now !
2.7.4.7_(Windows_x86-32)_audio_XP: So geil !
2.7.4.7_(Windows_x86-32)_2_audio_XP: the same. Everything works, scrub, audio, prefetch, normal speed, max.speed. We are getting closer to Vegas, I feel ;-)) The odd .mp4 clip max unprefetched 260fps. The proper DV-PAL avi prefetched (2,2) max 110fps, Prefetch 4,10 works too now ! the same 110fps @ 85% CPU playing from 7200rpm SSD. Now Nominal speed fps (25fps). Reported fps starting with 23,xyz, approaching and crossing 25fps after some 10 frames, nothing to worry about. QTGMC with Prefetch (4,10): 6,4fps @ 88..98% CPU. A dream, not a single stall. Deep respect, gispos !
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 5th June 2023 at 10:53. |
3rd June 2023, 21:47 | #1424 | Link |
Sorry, the 2.7.4.7 contained a bug that affected the menu bar. see Bugfix 2.7.4.8
AvsPmod 2.7.4.8 Code:
* Audio playback is now WinXP 32bit compatible * Fast VUV > RGB conversion (DecodeYUVtoRGB.dll, DTL Doom9) now also for 32 bit available. * Added: Options > Font & Colors > Mis 2 > 'Video controls frame text field bold', use bold font style or not. * Added: avisynth 'DelayAudio' as a slider to filterdb.dat * Minor bugfix audio: In the playback, an attempt was always made to create the audio, even if the video did not contain any audio. * Bugfix 2.7.4.8: When clicking in the "Video" menu bar, an error is displayed if the video (clip) is not initialized. Sorry. What I noticed about the audio playback with LWLibavAudioSource: You should always set av_sync to true, otherwise asynchronous playback can occur with some videos. AvsPmod and VirtualDub2 for example plays them sometimes synchronous and sometimes not synchronous if av_sync is not set.
Live and let live Last edited by gispos; 3rd June 2023 at 21:54. |
8th June 2023, 19:22 | #1425 | Link |
AvsPmod 2.7.4.9 Pre-Release
Playback thread revised again: Replacing old proven routines has increased speed and response, I hope this is not at the expense of robustness. Instead of an entry into the main thread a lock is used to avoid a collision between main and playthread. On my system for 1920 x 1080 video without filter: without 'Prefetch display conversion' from 80 fps to 100 fps with 'Prefetch display conversion' from 102 fps to 148 fps with 'Fast YUV420 display conversion' from 100 to 130 fps With light filtering only 1 to 3 fps increase is left. But this can make the difference to a clean or not clean audio playback. I am curious if it works with WinXP 32bit. https://drive.google.com/drive/folde...usp=drive_link
Live and let live |
9th June 2023, 14:12 | #1426 | Link |
Broadcast Encoder
Source clip is an MPEG-2 SD in yv12 50p, playback speed set to "Normal Speed".
Playback results on Windows XP x86: - Legacy legacy settings (video, no audio) 50fps - Legacy settings (video, audio) 50fps - Prefetch RGB Display Conversion (video, audio) 50fps - Prefetch RGB Display Conversion, fast YUV420 auto reset (video, audio) 50fps - Prefetch RGB Display Conversion, fast YUV420 display conversion using DecodeYUVtoRGB() (video, audio) - error This is probably because DecodeYUVtoRGB() is expecting AVX2, however on Windows XP there's nothing after SSE4.2 In other words, you can make use of MMX, SSE, SSE2, SSSE3, SSE4.1, SSE4.2 but nothing else. It doesn't matter if the CPU supports them, XP won't use them. This is an example using a simple utility called "CPU Instruction.exe" which checks the available CPU instructions from the OS: Code:
Supported Features ================== Vendor String: GenuineIntel Brand String: Intel(R)Core(TM)i7-6700 CPU@2.60GHz Instruction Sets ---------------- MMX SSE SSE2 SSE3 SSSE3 SSE4.1 SSE4.2 Supported Special Instructions ------------------------------ Conditional Moves FXSAVE and FXSTOR XSAVE and XSTOR for processor extended state management. POPCNT RDRAND AES (Advanced Encryption Standard) Instruction Set Please, press enter to end the application ... In fact, manually calling Code:
DecodeYUVtoRGB(matrix=0, threads=1, gain=74, offset=0) If and only if DTL wants to make it XP friendly, he should check the available instructions at runtime and use the right codepath accordingly, 'cause otherwise it would fail. This isn't just an XP thing, there might be people with other Windows (like Win7, Win10 etc) with CPUs without AVX2 and it would fail there too. Anyway, as far as I'm concerned, I'm totally fine with the Avisynth YUV to RGB conversion used by AVSPmod mod by default. Ok, SD was easy, let's try something harder. Source clip is an H.264 FULL HD in yv12 23,976p, playback speed set to "normal speed": - Legacy legacy settings (video, no audio) 23,97fps - Legacy settings (video, audio) 23,97fps - Prefetch RGB Display Conversion (video, audio) 23,97fps - Prefetch RGB Display Conversion, fast YUV420 auto reset (video, audio) 23,97fps - Prefetch RGB Display Conversion, fast YUV420 display conversion using DecodeYUVtoRGB() (video, audio) - error Outstanding, but let's see if we can go one step further and dare to dream with UHD. Source clip is an H.265 UHD in 4:2:0 10bit, 23,976p, playback speed set to "normal speed": - Legacy legacy settings (video, no audio) 13,01fps - Legacy settings (video, audio) 12,44fps - Prefetch RGB Display Conversion (video, audio) - error - Prefetch RGB Display Conversion, fast YUV420 auto reset (video, audio) - error - Prefetch RGB Display Conversion, fast YUV420 display conversion using DecodeYUVtoRGB() (video, audio) - error Although the system has 64 GB of RAM available through PAE, being a 32bit system, each process cannot exceed 2 GB of RAM, therefore with the Prefetch RGB Display Conversion, you end up saturating 2GB and getting a malloc error. PAE is a clever way of extending the 32bit system to 36bit so that by having an HAL in front, the system is able to handle 64 GB of RAM, but with the same catches of a 32bit one, namely that you can't really exceed the maximum allocable memory per process of a 32bit system. Using things like MPPipeline() to split functions into different processes, allows you to have as many processes as you want, thus being able to allocate 2GB per filter (i.e per process) up to 64GB of RAM (the maximum possible RAM available in a 36bit system). Last edited by FranceBB; 9th June 2023 at 14:14. |
9th June 2023, 18:12 | #1427 | Link | |||
But as you write, the check on WinXP apparently does nothing because the CPU confirms AVX2 but XP can not use it and returns an error. Then my AVX2 test is probably useless, it tests the CPU. Quote:
Edit: Ever tested UHD with 'Resample Filter'? Should then at least run a little faster... I think. Help > Resample Filter readme Under Menu Options > 'Resample filter...' a prefetch can be added after the Spline36Resize, separated by a semicolon. Spline36Resize;Prefetch(1) If there are no problems with Prefetch(1) and it becomes faster, I can change the other prefetch too.
Live and let live Last edited by gispos; 9th June 2023 at 18:33. |
9th June 2023, 19:29 | #1428 | Link |
I currently do not know why at AVX2 CPU the targeted to AVX2 environment build of executable crash with 'illegal instruction' . As I understand operating system only route thread data to CPU core and not detect any instructions used. The only idea is to make SSE2-targeted build with AVX2 intrinsics-based SIMD program inside. May be with AVX2-targeting the VS2019 adds some not-supported by WinXP instructions at executable loading into process space ?
As a simple check - any other AVS plugin with x86-32 compilation and forcing of AVX2 with user-param also resulted in crash at 32bit WinXP with 'illegal instruction' reason ? This is SSE2-targeted x86_32 build - https://drive.google.com/file/d/1OjH...ew?usp=sharing . Do it also crashes with 'illegal instruction' reason at 32bit WinXP ? It must have only up to SSE2 instructions at all executable and run AVX2 part (main processing) only at CPUs with AVX2 detected. Asd-g made llvm build of ver 0.4.1 of the decode YUV to RGB32 plugin - https://github.com/Asd-g/AviSynth-vs...ent-1585940749 . It typically runs a bit faster. Last edited by DTL; 11th June 2023 at 04:47. |
11th June 2023, 17:08 | #1430 | Link | |
Are you using mpv.exe as an external player that is entered under the program options? If so, did it work in older AvsPmod versions? Does the avisynth script passed work in AvsPmod? I can only say that for ages nothing has been changed in the code responsible for it.
Live and let live |
11th June 2023, 17:35 | #1431 | Link | |
11th June 2023, 18:20 | #1433 | Link | |
Program Options > Paths > 'External player:' Program Options > Paths > 'External player extra args:' Program Options > Misc > 'Only allow a single instance of AvsPmod'
Live and let live |
11th June 2023, 19:45 | #1434 | Link | |
Just the default settings and the executable is there. But if it works fine for you, it must be a weird issue on my end. |
11th June 2023, 21:11 | #1435 | Link | |
Acid fr0g
Perhaps you should default it, as it's IMHO the way people could think it should work.
@turment on Telegram |
11th June 2023, 22:42 | #1436 | Link | |
Try to start another program, a media player or VDub2. Maybe the problem is the mpv.exe itself. You are right, I will do it.
Live and let live |
12th June 2023, 12:12 | #1437 | Link |
It looks in ver 2.7.4.8 something bad with monitoring conversion of YUV to control window:
With script ColorBarsHD(640, 480, pixel_type="YV24") It always convert to 'full-RGB'. Changing in Settings -> Video -> Display default YUV->RGB conversion do not change anything (after applying settings and after program restart). Also as we now have some content with 2020-matrix - may be add it too ? |
12th June 2023, 15:14 | #1438 | Link | |
- Right click into the preview picture - Display > YUV-> RGB ..... |
12th June 2023, 17:00 | #1439 | Link | ||
YV24 > RGB TV Levels rgb white = 255 PC Levels rgb white = 235 Should the selected matrix be retained even after a clip refresh: Then 'Read from source or script' must be switched off and 'Reset matrix if not found' must be switched on. 'Reset matrix if not found': At the beginning I had kept the matrix which was read at the first initialization of the clip even if after a change in the script no matrix could be read any more. The reason was that at the beginning not all filters forwarded the matrix, but I wanted to avoid a constant change of the matrix by adding or removing a filter. But some people didn't like that (the ones who like to experiment), so I added the option to re-read the matrix at each initialization. I have to think about whether I should use the reading of the matrix at each clip refresh as default. Quote:
It can only be used over 8 bit, I draw with 8bit per channel. At least the result was not usable at that time.
Live and let live |
