Go Back   Doom9's Forum > Announcements and Chat > General Discussion
Old 2nd March 2019, 10:03   #21  |  Link
Music Fan
By the way, you forgot to add VFR in the name for VFR files.
Music Fan is offline   Reply With Quote
Old 2nd March 2019, 17:58   #22  |  Link
manolito
manolito's Avatar
Originally Posted by Music Fan View Post
Great, thanks !
I see that you didn't put this line ;
IF NOT DEFINED height GOTO next_file
It's done for width and type but not height, I added it.
No, I did this on purpose (effective coding). If MediaInfo does not report a value for Width then the file is not a video. No reason to check the Height then, one check is all you need.
No, this was also on purpose. The FrameRate_Mode is not reported under FrameRate, it has its own parameter. I was too lazy to check it, because if you don't get a value for FrameRate then the Mode will always be VFR.
Here is a "universal" template for my needs, it also reports the AspectRatio and the FrameRate_Mode. Under the label "outname" you can easily modify the format of the output to your needs, should be easy...
https://www.sendspace.com/file/hof8bz
Cheers
manolito
Old 2nd March 2019, 20:26   #23  |  Link
Music Fan
I achieved to add VFR for VFR files, but the script also adds CFR for CFR files while I didn't specify it ; is there a way not to write anything for the FrameRate_Mode when it's CFR ?
For example ;
FOR /F %%a in ('MediaInfo.exe "--Inform=Video;%%FrameRate_Mode%%" %in%') DO SET fr_mode=%%a
IF "%fr_mode%"=="Variable" SET type=VFR
IF "%fr_mode%"=="Constant" SET type=
I also tried ;
IF "%fr_mode%"=="Constant" DO NOT SET type
but this adds CFR anyway.
Old 2nd March 2019, 21:17   #24  |  Link
manolito
manolito's Avatar
The FrameRate_Mode parameter returns CFR or VFR, not Constant or Variable. Use these lines:
SET fr_mode= %fr_mode%
IF "%fr_mode%"==" CFR" SET fr_mode=
and in the "outname" line remove the space character between %fps% and %fr_mode%. Should look like this:
%fps%%fr_mode%
If you don't do this your new file name will have an extra space before the dot for CFR files.
Old 3rd March 2019, 09:36   #25  |  Link
Music Fan
Thanks, I also had to remove 2 spaces : in front of %fr_mode% (second line) and in front of CFR (third line).
Otherwise, CFR was added anyway and a space was added in front of VFR (despite the fact that I removed the space in the "outname" line), now it's perfect
Old 9th June 2023, 13:49   #26  |  Link
Music Fan
Hi manolito,
a few years later, I'm trying to do something else based on your script : change the extension using MediaInfo because I have some video files with wrong extensions and would like to correct them.
I tried to modify your script and made this ;
@ECHO off
IF !%1==! GOTO syntax
SET Work_Drive=%~d0
SET Work_PATH=%~p0
%Work_DRIVE%
CD "%Work_PATH%"
FOR /F %%a in ('MediaInfo.exe "--Inform=General;%%Format%%" %in%') DO SET Format=%%a
IF NOT DEFINED Format GOTO next_file
FOR /F %%a in ('MediaInfo.exe "--Inform=General;%%Format profile%%" %in%') DO SET ForProf=%%a
IF "%Format%"=="MPEG-TS" SET Format=ts
IF "%Format%"=="Matroska" SET Format=mkv
IF "%Format%"=="Flash Video" SET Format=flv
IF "%Format%"=="AVI" SET Format=avi
IF "%Format%"=="MPEG-4" GOTO FormProf
:FormProf
IF "%ForProf%"=="Base Media" SET Format=mp4
IF "%ForProf%"=="QuickTime" SET Format=MOV
:outname
SET out_name=%in_name%.%Format%
RENAME %in% "%out_name%"
REM COPY /B %in% "%in_path%%out_name%" >NUL
:next_file
SHIFT
IF NOT !%1==! GOTO syntax
GOTO :EOF
:syntax
CLS
ECHO.
Echo Press a key to exit...
PAUSE >nul
I put it with a .bat extension in my MediaInfo folder but it doesn't work, it actually opens MediaInfo but nothing happens with the extension of the file I dropped on the bat.
I guess something's wrong with my code.
mp4 and mov have both the same format for MediaInfo (MPEG-4), that's why I had to redirect them to "Format profile" (with "GOTO FormProf") which helps to distinguish them.
Thanks for your help.
Old 10th June 2023, 12:59   #27  |  Link
Music Fan
By the way, if I put it in the same folder than the CLI version you gave me in 2019, I see briefly a DOS command window (as with your script) but nothing happens either on the video file.
Old 12th June 2023, 08:22   #28  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Since all the sendspace links are dead now, can you put the scripts back up here in doom9 as plain code snippets ?
That would make it possible to troubleshoot & modify, and it would be nice to have them back available again.
Old 12th June 2023, 11:09   #29  |  Link
Music Fan
Yes, here is the code that still works with a 2019 CLI MediaInfo version to add resolution in name ;
@ECHO off
SET Work_Drive=%~d0
SET Work_PATH=%~p0
%Work_DRIVE%
CD "%Work_PATH%"
:loop
SET in="%~1"
SET in_path=%~dp1
SET in_name=%~n1
SET extension=%~x1
SET width=
SET height=
Set type=
SET fr_mode=
SET fps=
FOR /F %%a in ('MediaInfo.exe "--Inform=Video;%%Width%%" %in%') DO SET width=%%a
IF NOT DEFINED width GOTO next_file
FOR /F %%a in ('MediaInfo.exe "--Inform=Video;%%Height%%" %in%') DO SET height=%%a
FOR /F %%a in ('MediaInfo.exe "--Inform=Video;%%ScanType%%" %in%') DO SET type=%%a
IF NOT DEFINED type SET type=p
IF "%type%"=="Progressive" SET type=p
IF "%type%"=="Interlaced" SET type=i
IF "%type%"=="MBAFF" SET type=i
IF "%type%"=="PAFF" SET type=i
SET fr_mode=%fr_mode%
IF "%fr_mode%"=="CFR" SET fr_mode=
FOR /F %%a in ('MediaInfo.exe "--Inform=Video;%%FrameRate%%" %in%') DO SET fps=%%a
IF NOT DEFINED fps GOTO outname
:format_fps
IF %fps:~-1%==0 SET fps=%fps:~0,-1%& GOTO format_fps
IF %fps:~-1%==. SET fps=%fps:~0,-1%
:outname
SET out_name=%in_name% %width%.%height%%type%%fps%%fr_mode%
REM ____________________________________________________________________________________________________________
REM Use next command to rename the source file(s), use the command after the next one to copy the source file(s)
RENAME %in% "%out_name%%extension%"
REM COPY /B %in% "%in_path%%out_name%%extension%" >NUL
:next_file
SHIFT
IF NOT !%1==! GOTO loop
GOTO :EOF
:syntax
CLS
ECHO.
ECHO.
ECHO ERROR: No Input File Specified...
ECHO.
ECHO.
ECHO.
ECHO.
ECHO.
ECHO Syntax is: Rename_Properties.bat Input_file(s)
ECHO.
ECHO.
ECHO You can also drag and drop or copy and paste one
ECHO or multiple input file(s) on the Rename_Properties.bat file.
ECHO.
ECHO.
ECHO Hint: Create a shortcut to Rename_Properties.bat on the desktop.
ECHO Makes it easy to drop input files on the desktop icon...
ECHO.
ECHO.
ECHO.
ECHO.
PAUSE >nul
I didn't use %extension% at the RENAME and REM COPY lines in my new script (see a few posts above), that's maybe the problem but I believed my trick could work.
Old 14th June 2023, 23:41   #30  |  Link
Emulgator
Emulgator's Avatar
Many thanks, Music Fan !
Old 28th June 2023, 19:34   #31  |  Link
Music Fan
Hi Emulgator, did you try to modifiy my script (based on manolito's work) to find the problem ?
Old 28th June 2023, 22:59   #32  |  Link
Emulgator
Emulgator's Avatar
Not yet, sitting deep in repairs...
Old 26th July 2023, 18:54   #33  |  Link
Music Fan
Hi, I made some modifications and there is a little progress.
But curiously, the code only works with ts, avi and mkv but not with mp4, mov, wmv and flv for which extension is removed
Same problem with a more recent MediaInfo CLI version.
@ECHO off
SET Work_Drive=%~d0
SET Work_PATH=%~p0
%Work_DRIVE%
CD "%Work_PATH%"
:loop
SET in="%~1"
SET in_path=%~dp1
SET in_name=%~n1
SET extension=
FOR /F %%a in ('MediaInfo.exe "--Inform=General;%%Format profile%%" %in%') DO SET Format profile=%%a
IF "%Format%"=="MPEG-TS" SET extension=ts
IF "%Format%"=="Matroska" SET extension=mkv
IF "%Format%"=="Flash Video" SET extension=flv
IF "%Format%"=="AVI" SET extension=avi
:FormProf
IF "%Format profile%"=="Base Media" SET extension=mp4
IF "%Format profile%"=="Base Media / Version 2" SET extension=mp4
IF "%Format profile%"=="QuickTime" SET extension=MOV
:outname
RENAME %in% "%out_name%.%extension%"
REM COPY /B %in% "%in_path%%out_name%.%extension%" >NUL
:next_file
SHIFT
GOTO :EOF
:syntax
CLS
ECHO.
PAUSE >nul
Old 5th August 2023, 11:16   #34  |  Link
Music Fan
I still made a little modification and now the extension is not removed anymore for mp4, mov, wmv and flv files but is not corrected either, very strange
@ECHO off
SET Work_Drive=%~d0
SET Work_PATH=%~p0
%Work_DRIVE%
CD "%Work_PATH%"
:loop
SET in="%~1"
SET in_path=%~dp1
SET in_name=%~n1
SET extension=%~x1
FOR /F %%a in ('MediaInfo.exe "--Inform=General;%%Format profile%%" %in%') DO SET Formatprofile=%%a
IF "%Format%"=="MPEG-TS" SET extension=.ts
IF "%Format%"=="Matroska" SET extension=.mkv
IF "%Format%"=="Flash Video" SET extension=.flv
IF "%Format%"=="AVI" SET extension=.avi
IF "%Format%"=="Windows Media" SET extension=.wmv
:FormProf
IF "%Formatprofile%"=="Base Media" SET extension=.mp4
IF "%Formatprofile%"=="Base Media / Version 2" SET extension=.mp4
IF "%Formatprofile%"=="QuickTime" SET extension=.MOV
:outname
:next_file
SHIFT
GOTO :EOF
:syntax
:syntax
CLS
ECHO.
ECHO.
ECHO.
ECHO.
ECHO.
ECHO.
ECHO.
ECHO Syntax is: rename_extension_k.bat Input_file(s)
ECHO.
ECHO.
ECHO or multiple input file(s) on the rename_extension_k.bat file.
ECHO.
ECHO.
ECHO Hint: Create a shortcut to rename_extension_k.bat on the desktop.
ECHO.
ECHO.
ECHO.
ECHO.
PAUSE >nul
