11th July 2016, 21:08 | #24482 | Link | |
Do I have to check 05016.m2ts or the mpls file? Thank you ggtop |
11th July 2016, 22:02 | #24484 | Link |
Hi jdobbs,
I know it's already discussed to death and it's absolutely OK you are eye rolling seeing me reply once again, but I found something interesting (at least for me). If I deselect all audio streams on a multi part playlist the demuxed subtiles (no audio stream is demuxed in that case) seem to match VID_00005 just a few seconds. In case an audio stream is selected BDRB demuxes the full audio from the whole playlist (approx. 2 hrs.) including subs. And it works if no audio is selected! Maybe the AVS creation refuses to load the 9999 file just because there aren't no forced Subs including for the framecount of VID_00005 as it is only the Studio logo and a few seconds Long. Just a guess. Topic closed. I will never reply :-) ggtop |
12th July 2016, 00:50 | #24485 | Link |
For my own curiosity-killed-the-cat moment, why do you want to convert the better 576i50 video to the lower quality 480i59.94 video? All Blu-ray players can handle 576i50 video, or any other digital method for playing it.
12th July 2016, 02:44 | #24486 | Link |
Black bars
For some reason BDR is now taking a 1280x720 video and crushing it down to a 4:3 resolution then adding thick black bars on the left and right to make it 1280 again.
I've tried several 1280 MKV videos and it does this with them all during the encoding (the video was still fine in the initial pseudo conversion to m2ts). Tried checking all settings and can't seem to find any problems, anyone seen this before? Screen shot of problem attached. EDIT: Turns out the videos are just reporting 1280x720 through my video player and look right when played; but are actually only 960x720 (reported by windows). I guess BDR sees this resolution and doesn't expand it to 1280 as the player does. So it handles is as 4:3 and squeezes in the black boxes to force it to 1280. So very weird, is there any fix for these video files or should I go look for better ones? Last edited by Knightmire; 12th July 2016 at 07:33. |
12th July 2016, 04:53 | #24487 | Link | |
12th July 2016, 09:12 | #24488 | Link | |
Who am I (or who are you) to tell him to buy new equipment for it. Furthermore I was not aware that I had to state the reasons for my behavior. I was just reporting a possible bug in this report. And asking for help. I hope your curiosity is now satisfied. |
12th July 2016, 13:52 | #24489 | Link | |
12th July 2016, 13:55 | #24490 | Link |
No. MENU_VERTICAL is just another name/way of specifying MENU_TOP. I just added it for consistency in naming with MENU_HORIZONTAL. If, though, you specify both MENU_VERTICAL and MENU_TOP in your INI, the value in MENU_TOP will take precedence.
13th July 2016, 00:42 | #24491 | Link | |||
I do have a script that will convert 576i50 to 480i59,94, but it needs a program that is not part of the BD-rebuilder install (it isn't free). Here is the AVISynth portion of the script: Code:
LoadPlugin("C:\Program Files (x86)\DGAVCDecNV\DGDecodeNV.dll") dgsource("=DRIVE=\=FILENAME=") bob(height=480) lanczos4resize(720,480) convertfps(59.94) separatefields.selectevery(4,0,3) weave Does your friend have a Blu-ray player? If so, leave the video alone and author to that medium. |
13th July 2016, 00:53 | #24492 | Link | |
If the video were 1440x1080, then it could anamorphic 16:9. I do not know if the practice is still done, but many broadcasters (OTA, cable satellite) used HD-lite (1440x1080) in order to save bits. Pissed off a lot of viewers who hated the practice. |
13th July 2016, 14:15 | #24493 | Link | |
14th July 2016, 22:17 | #24496 | Link |
Speed problem
I got a curious speed problem in v 0.50.17. The reencoding speed went down to about 50 fps. In v.0.50.14 it was about 100 fps with the same settings. Any idea what have caused this? (i Hadnīt installed v. 0.50.16)
Just coppied and pasted the config file from previous version as usual... See atached files Last edited by kufo; 15th July 2016 at 10:11. |
15th July 2016, 19:12 | #24497 | Link | |
i'm loving this new rig. (atm non-overclocked) i7 6700k
16th July 2016, 15:40 | #24498 | Link |
Hello jdobbs, a long time been using the DGDenNV today returned to the DirectShow but the job is aborted as soon as it begins to encode.
I went back to 0.50.14 version using DirectShow, BD Rebuilder works normally. Edit: I again installed Avisynth, Haali in ffdshow and BDRB returned to work, go figure... Last edited by soneca; 16th July 2016 at 20:39. |
17th July 2016, 16:11 | #24499 | Link |
Using DirectShow the process is aborted at some BluRays.
Use the latest(1.13.138.14) version of Haali Media Splitter a long time, I never had problems. Returning to the 0.50.14 version everything works fine. - BD-Rebuilder v0.50.17 - Windows Version: 6.1 [7601] - Working Path Free Space: 329,72GB - AVISYNTH Version: 2.6.0.6, Ok - HAALI Splitter: Isn't recommended version - FFDSHOW: 4515, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD Remove Short Titles: Incompatible - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [11:23:41] - Failed video encode, aborted |
17th July 2016, 17:15 | #24500 | Link |
- AnyDVD Remove Short Titles: Incompatible That's likely your problem right there. Use the recommended versions and undo that setting. Bug reports can't be accepted unless you use the correct tools & settings. |
