Old 27th December 2006, 19:10   #61  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Originally Posted by akupenguin View Post
No. I am not interested in HD-DVD or any other application that adds requirements beyond the H.264 standard for no good reason.
Well it's really strange ... ???
It's like say "I am not interested in DVD or any other application that adds requirements beyond the MPEG2 standard for no good reason"
Actually all the MPEG2 encoder without DVD compliant support are completely useless. Tomorrow all the AVC encoder without HDDVD/BD compliant support will be completely useless ...
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Sagittaire is offline   Reply With Quote
Old 27th December 2006, 19:40   #62  |  Link
bond
in the end we simply need an avc stream that is hddvd compliant and analyse it in detail
i till now didnt see such a stream
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau)
I know, that I know nothing (Socrates)
MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide)
Ogg Theora | Ogg Vorbis
use WM9 today and get Micro$oft controlling the A/V market tomorrow for free
bond is offline   Reply With Quote
Old 27th December 2006, 19:41   #63  |  Link
Manao
Trying to second guess Loren : you want it, do it yourself, and he'll commit it.
Adding HDDVD support to x264 is boring, dull, and technically potentially illegal(yet) since the specifications don't seem to be public. There are much more interesting things to do in x264 than that ( for one, interlacing support ( half ironic *cough* ) ). Personnal motivation is still the principal incentive when coding for open source software.
Anyway, Loren must feel a bit lonely lately, so if somebody who was actually interested in HD DVD were to add such a fonctionnality, I think he'd be more than welcome.
DVD compliancy has nothing to do with the mpeg2 bitstream, so any encoder that respect the VBV buffer is 'DVD compliant'. Requirements put by HD DVD on the h264 bitstream are much more invasive and complicated, and are best handled in the encoder itself.
Manao is offline   Reply With Quote
Old 27th December 2006, 21:40   #64  |  Link
vsv
vsv's Avatar
Just decrypt any HD-DVD released in Japan by backupHDDVD
http://forum.doom9.org/showthread.php?t=119871
and demux streams with HD DVD Demuxer
http://dvd-logic.com/hddemuxer.htm
vsv is offline   Reply With Quote
Old 27th December 2006, 22:39   #65  |  Link
chadamir
I will post a short hd-dvd image made with an avc for all to enjoy.
The following is a sample video file and an authored disc using it.
It was encoded with mainconcept H264 encoder version 2.1 and
sonic scenarist 4. It is 1920x1080i encoded as interlaced.
http://download.yousendit.com/6F2F833F3F48859A
Only 100 downloads so don't send it around kthnx.
chadamir is offline   Reply With Quote
Old 27th December 2006, 23:36   #66  |  Link
chadamir
Using Inlet semaphore I've gotten the header. I'll now encode the same file using x264 at 4.1 profile and see how it differs
Summary
Source file : C:\Target\Untitled\0\emotion1.mpv
Width : 1920
Height : 1088
Frame rate : 59.9402 fps
FourCC :
Total frames : 0
File duration : 00:00:00:00
File bit rate : 0 bps
Video bit rate : 0 bps
Encode : CBR
Target bit rate : 8,000,000 bps
Buffer window : 2500 ms
Max key frame : 0 ms
Min quant : 0
Max quant : 0
Sequence Parameter Set
Field Value Description
profile_idc 100 High Profile
constraint_set0_flag 0
constraint_set1_flag 0
constraint_set2_flag 0
constraint_set3_flag 0
reserved_zero_4bits 0
level_idc 41 Level 4.1
seq_parameter_set_id 0
chroma_format_idc 1
bit_depth_luma_minus8 0
bit_depth_chroma_minus8 0
lossless_qpprime_y_zero_flag 0
seq_scaling_matrix_present_flag 0
log2_max_frame_num_minus4 4
pic_order_cnt_type 0
...log2_max_pic_order_cnt_lsb_minus4 4
num_ref_frames 4 Maximum number of reference frames for inter-prediction
gaps_in_frame_num_value_allowed_flag 0
pic_width_in_mbs_minus1 119 (1920)
pic_height_in_map_units_minus1 33 (544)
frame_mbs_only_flag 0 Frame or field macroblocks
...mb_adaptive_frame_field_flag 0
direct_8x8_inference_flag 1
frame_cropping_flag 1
...frame_crop_left_offset 0
...frame_crop_right_offset 0
...frame_crop_top_offset 0
...frame_crop_bottom_offset 2 (8)
vui_parameters_present_flag 1
...aspect_ratio_info_present_flag 1
.......aspect_ratio_idc 1 1:1
...overscan_info_present_flag 0
...video_signal_type_present_flag 1
.......video_format 2 NTSC
.......video_full_range_flag 0 luma/chroma range = 219/224
.......colour_description_present_flag 1
...........colour_primaries 1 ITU-R BT.709
...........transfer_characteristics 1 ITU-R BT.709
...........matrix_coefficients 1 ITU-R BT.709
...chroma_loc_info_present_flag 0
...timing_info_present_flag 1
.......num_units_in_tick 1001
.......time_scale 60000
.......fixed_frame_rate_flag 1
...nal_hrd_parameters_present_flag 1
.......cpb_cnt_minus1 0
.......bit_rate_scale 1
.......cpb_size_scale 3
.......bit_rate_value_minus1 1 62499 (8000000 bits/sec)
.......cpb_size_value_minus1 1 43399 (5555200 bits)
.......cbr_flag 1 0
.......initial_cpb_removal_delay_length_minus1 31
.......cpb_removal_delay_length_minus1 17
.......dpb_output_delay_length_minus1 17
.......time_offset_length 24
...vcl_hrd_parameters_present_flag 0
...low_delay_hrd_flag 0
...pic_struct_present_flag 1
...bitstream_restriction_flag 1
.......motion_vectors_over_pic_boundaries_flag 1 Motion vectors may exceed picture boundary
.......max_bytes_per_pic_denom 0
.......max_bits_per_mb_denom 0
.......log2_max_mv_length_horizontal 10 +/- 256
.......log2_max_mv_length_vertical 10 +/- 256
.......num_reorder_frames 1
.......max_dec_frame_buffering 4 Maximum frame decode buffers required
Edit:
The same file then demuxed from the EVO and put through semaphore
Source file : C:\0\VTS_001\Titles\t001_v001c001.m4v
Width : 1920
Height : 1088
FourCC :
Total frames : 0
Encode : CBR
Min quant : 0
Max quant : 0
chroma_format_idc 1
.......cbr_flag 1 0
Old 28th December 2006, 00:21   #67  |  Link
chadamir
--pass 2 --bitrate 8000 --stats ".stats" --level 4.1 --ref 4 --bframes 2 --no-b-adapt --direct temporal --analyse p8x8,b8x8,i4x4 --vbv-maxrate 768 --threads auto --thread-input --progress --no-psnr --no-ssim --interlaced --output "C:\Documents and Settings\Chad\Desktop\x264header2.264" "C:\Documents and Settings\Chad\Desktop\x264header.avs"
Source file : C:\Documents and Settings\Chad\Desktop\x264header2.264
Width : 1920
Height : 1088
FourCC :
Total frames : 249
File duration : 00:00:04:08
File bit rate : 31,670,915 bps
Video bit rate : 17,685,959 bps
Encode : CBR
Target bit rate : 4,000,000 bps
Min quant : 17
Max quant : 27
profile_idc 77 Main Profile
constraint_set1_flag 1 Main profile constraints (clause A.2.2)
log2_max_frame_num_minus4 5
...log2_max_pic_order_cnt_lsb_minus4 6
num_ref_frames 5 Maximum number of reference frames for inter-prediction
...mb_adaptive_frame_field_flag 1
...aspect_ratio_info_present_flag 0
...video_signal_type_present_flag 0
...nal_hrd_parameters_present_flag 0
...pic_struct_present_flag 0
.......log2_max_mv_length_horizontal 11 +/- 512
.......log2_max_mv_length_vertical 11 +/- 512
.......max_dec_frame_buffering 5 Maximum frame decode buffers required
There are some discrepancies between my settings and the header. I ended up with 5 reference frames instead of 4. And I chose high profile in megui. Also there's all the header info that's simply not there.
Old 28th December 2006, 15:35   #68  |  Link
chadamir
HD-DVD profile from megui
Old 28th December 2006, 16:39   #69  |  Link
chadamir
Ok thanks to bond we got the header to this point
chroma_format_idc 1
log2_max_frame_num_minus4 1
...log2_max_pic_order_cnt_lsb_minus4 2
pic_height_in_map_units_minus1 67 (1088)
frame_mbs_only_flag 1 Frame macroblocks only (no field)
...frame_crop_bottom_offset 4 (8)
But no NAL HRD.
Old 28th December 2006, 18:41   #70  |  Link
Inventive Software
Turkey Machine
Location: Lowestoft, UK (but visit lots of places with bribes [beer])
Originally Posted by check View Post
You can get something like that if you enable verbose mode.
Tried that, didn't give what I wanted. Essentially, a better progress indicator is what I'd like, if that's not too much to ask. I'd do it myself, but my coding's non-existant (practically).
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 28th December 2006, 19:33   #71  |  Link
akupenguin
x264 developer
akupenguin's Avatar
Exactly. If I were writing an MPEG2 encoding library, I wouldn't put anything DVD-specific in it. Of course, profile/level/VBV/GOP/etc are all configurable, but it's up to the application or user to configure them appropriately.
So: If you determine that HDDVD needs some H.264 feature like maybe a specific SEI message or one of the optional fields in the SPS, then feel free to implement it and send a patch. But I will reject any application-specific kludges, just like I rejected magiK's PSP-mode patch.
x264's --ref selects the number of L0 references used by P-frames, not necessarily the DPB size. (Maybe someday I'll add a mode to optimize for max quality per DBP size instead of per encoding time/complexity.)
x264 signals the lowest profile that allows all your enabled features. You can't select high profile without enabling some feature that needs high profile.
akupenguin is offline   Reply With Quote
Old 29th December 2006, 05:00   #72  |  Link
hpn
For those who like patches I just got around to adding something small I've always thought was missing while encoding - total time on the progress indicator: patch
Originally Posted by Inventive Software View Post
The progress indicator only updates every (total frames / 1000), thus for a 100000 frame movie, it updates every 100 frames. This is a little slow with some resolutions
Also in the patch - up to 10'000 times per input file seems more enjoyable with negligible speed penalty (a second/hour or something).
hpn is offline   Reply With Quote
Old 29th December 2006, 05:39   #73  |  Link
Malow
In bytes we trust
Malow's Avatar
if someone need another hd-dvd compilant h.264 ES, go here:
http://forum.doom9.org/showthread.ph...921#post919921
Malow is offline   Reply With Quote
Old 1st January 2007, 02:41   #74  |  Link
pyrates
came across this strange error, here's the output:
C:\>x264.exe --pass 2 --bitrate 4665 --stats "L:\movie\108
0i.stats" --ref 16 --mixed-refs --no-fast-pskip --bframes 3 --b-pyramid --b-rdo
--bime --weightb --direct auto --direct-8x8 -1 --filter -2,-1 --subme 7 --trelli
s 1 --analyse all --8x8dct --vbv-maxrate 25000 --me umh --threads 6 --non-determ
inistic --cqmfile "E:\eqm_avc_hr.cfg" --progress -
-no-psnr --output "L:\movie\1080i.264" "L:\movie\1080i.a
vs"
avis [info]: 1920x1080 @ 23.98 fps (172975 frames)
x264 [warning]: width or height not divisible by 16 (1920x1080), compression wil
l suffer.
x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2 3DNow!
x264 [warning]: VBV maxrate specified, but no bufsize.
mb type: 7 mes: 10552/172975 (6.1%), 0.50 fps, eta 89:44:29
mv: l1r0 (115,407)
limit: 352
mb_xy: 1,11
completed: 264
Assertion failed: 0, file encoder/analyse.c, line 2714
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
I am using the MT plugin for avisynth 2.5.6a with the following avisynth script:
SetMTMode(6,0)
# Modify the path so that it finds your decomb dll file #
LoadPlugin("E:\DeComb\decomb521.dll")
# Modify the path so that it finds your MPEG2DEC dll file #
LoadPlugin("E:\DGMPGDec\DGDecode.dll")
LoadPlugin("E:\MKVMagic\exe\filter\Convolution3D.dll")
LoadPlugin("E:\MKVMagic\exe\filter\deen.dll")
LoadPlugin("E:\MKVMagic\exe\filter\MSharpen.dll")
LoadPlugin("E:\MKVMagic\exe\filter\tdeint.dll")
LoadPlugin("E:\MKVMagic\exe\filter\UnFilter.dll")
LoadPlugin("E:\MKVMagic\exe\filter\undot.dll")
import("E:\MvBob\mvbob.avs")
import("E:\AVS Scripts\convert60ito24p.avsi")
Import("E:\MKVMagic\exe\filter\HybridFuPP.avsi")
# Modify the path so that it finds the d2v file you created using dvd2avi #
MPEG2Source("L:\movie\movie.d2v")
#audio=wavSource("E:\24.1.wav")
#audiodub(video,audio)
#Crop(left, top, -right, -bottom)
Crop(0, 0, -0, -0)
# Assume Top Field
#AssumeTFF().SeparateFields()
#Telecide(order=1)
# Assume Bottom Field
#AssumeBFF().SeparateFields()
Telecide(order=0)
# Reduce down to 23.976 fps
Decimate()
Undot()
Convolution3d(preset="movieHQ")
HybridFuPP(preset="High")
#assumefps(23976,1000)
assumefps(24000,1001)
I'm using build 614 of x264. The error occurs quite randomly I find but it is always the same error referencing the same line. Anyone know what it means?
pyrates is offline   Reply With Quote
Old 1st January 2007, 05:15   #75  |  Link
akupenguin
x264 developer
akupenguin's Avatar
It means that somehow the motion estimation failed to limit itself to the available range, and ended up using pixels that might not yet have been encoded by another thread.
Old 1st January 2007, 09:43   #76  |  Link
bkman
Akupenguin, are you aware of the problem with direct B-frame modes and AQ or certain custom matrices? They can currently cause artifacts in some scenes unless the direct mode is set to "none".
Hopefully you can fix it, as disabling the direct B-frame modes wastes bitrate.
bkman is offline   Reply With Quote
Old 1st January 2007, 10:25   #77  |  Link
pyrates
So does this mean it is a bug and can be fixed?
Old 1st January 2007, 16:35   #78  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
AQ is an unsupported patch. As for custom matirces........any examples?
ChronoCross is offline   Reply With Quote
Old 1st January 2007, 17:37   #79  |  Link
bkman
*.mp4 guy mentions that the problem occurs with some of his matrices in his Custom Matrix topic.
Old 1st January 2007, 18:16   #80  |  Link
akupenguin
x264 developer
akupenguin's Avatar
No, I am not aware of any such. I have heard some people suggest disabling B-direct as a last-ditch attempt to remove some artifacts, but I don't recall any cases where it actually worked. I always figured it was similar to people not using B-frames in XviD: a mistaken assumption that anything that improves compression ratio shouldn't be used if you want very high quality.
Artifacts related to cqm (assuming they're not a direct consequence of the matrix's frequency distribution) are probably due to the cqm deviating too far from the bitrate-per-qp values of the flat matrix. x264 makes some assumptions about the quality level of a given qp, and I'm not likely to work very hard at generalizing them for all cqms when you can always scale a cqm to match the flat matrix. (That and I'm not convinced that cqms are useful in the first place.)
coding, development, x264 dev
