Old 7th July 2009, 16:40   #61  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
ok...
Here is a 1st attempt to create several tunings for some devices.
Any comments ?
Old 7th July 2009, 19:08   #62  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Devices should not be under --tune. There's no reason I can't use --tune film --device ipod.
Old 7th July 2009, 22:14   #63  |  Link
MatMaul
and you seem to override speed settings like --me which has nothing to do with devices compatibility.
MatMaul is offline   Reply With Quote
Old 8th July 2009, 05:50   #64  |  Link
Kurtnoise
Kurtnoise's Avatar
mmmh...right.
it's because I would like override some default settings...but you can tweak this.
Old 8th July 2009, 05:56   #65  |  Link
ACoolie
Originally Posted by Kurtnoise View Post
mmmh...right.
At most --device settings should perform like --profile. Disable certain options (like b-pyramid, cabac, etc) and limit other options like bframes and references to a certain maximum number.
ACoolie is offline   Reply With Quote
Old 8th July 2009, 06:26   #66  |  Link
Dark Shikari
x264 developer
Exactly; device settings should, like profile, guarantee a certain output by overriding all other settings.
Old 9th July 2009, 03:45   #67  |  Link
Chengbin
x264.nl finally updated.
I can't encode anymore. What was different with this build than before? I don't think a change in defaults change the format of the command line.
Chengbin is offline   Reply With Quote
Old 9th July 2009, 04:18   #68  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
the change in defaults also affected some of the command line options to take reverse forms of what they were previously...
i.e.:
--weightb (-w) replaced with --no-weightb    (default is now on)
--8x8dct  (-8) replaced with --no-8x8dct     (default is now on)
--no-psnr      replaced with --psnr          (default is now off)
--no-ssim      replaced with --ssim          (default is now off)
--mixed-refs   replaced with --no-mixed-refs (default is now on)
--progress     replaced with --no-progress   (default is now on)
so if you were using any of the options on the left, you need to remove them from your new command line
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 9th July 2009, 04:56   #69  |  Link
lcx
^^Also notice the slow-firstpass parameter.
It wasn't clear to me why my 'ref' and some other settings were being ignored in 1st pass until I check looked at x264.c changes
lcx is offline   Reply With Quote
Old 9th July 2009, 05:52   #70  |  Link
juGGaKNot
juGGaKNot's Avatar
The refs and level are now automated/resolution right ?
start "encode" /b /low /wait "%mypath%\bin\x264n.exe" --preset slower --tune animation --pass 1 --level %mylevel% --keyint %kint% --min-keyint %mint% --stats "%mypath%\%mpath%\T1\%mymovie%.stats" --bitrate %btratex264% --sar 1:1 --aud --nal-hrd --vbv-bufsize 24000 --vbv-maxrate 24000 --output NUL %myavs%
start "encode" /b /low /wait "%mypath%\bin\x264n.exe" --preset slower --tune animation --pass 2 --level %mylevel% --keyint %kint% --min-keyint %mint% --stats "%mypath%\%mpath%\T1\%mymovie%.stats" --bitrate %btratex264% --sar 1:1 --aud --nal-hrd --vbv-bufsize 24000 --vbv-maxrate 24000 --output "%mypath%\%mpath%\T1\%mymovie%.264" %myavs%
Questions :
The profile is MAIN and not high, how do i force high ?
Is --keyint and --min-keyint needed ? there rounder at fps x 10 / fps in my script
juGGaKNot is offline   Reply With Quote
Old 9th July 2009, 11:14   #71  |  Link
J_Darnley
J_Darnley's Avatar
juGGaKNot: The default settings give you a high profile video. If you don't disable the 8x8dct or set main or baseline profiles then it will remain as high profile. If you want a slow first pass then you had better set --slow-firstpass
Chengbin: If you still have problems and want help then you will have to post your command line.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 9th July 2009, 12:07   #72  |  Link
juGGaKNot
juGGaKNot's Avatar
File encoded with those settings :
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Duration : 25s 200ms
Bit rate mode : Variable
Bit rate : 4 406 Kbps
Nominal bit rate : 4 500 Kbps
Maximum bit rate : 7 507 Kbps
Width : 1 148 pixels
Height : 666 pixels
Frame rate : 30.000 fps
Writing library : x264 core 68 r1179M 96e2229
Encoding settings : cabac=1 / ref=16 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.4:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=300 / keyint_min=30 / scenecut=40 / rc=2pass / bitrate=4500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=20000 / vbv_bufsize=20000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.60
Encoding X264 First Pass :
avis [info]: 1148x666 @ 30.00 fps (756 frames)
x264 [warning]: width or height not divisible by 16 (1148x666), compression will
suffer.
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Slow
x264 [info]: profile Main, level 4.0
x264 [info]: slice I:13 Avg QP:19.67 size: 32273
x264 [info]: slice P:293 Avg QP:22.62 size: 28497
x264 [info]: slice B:450 Avg QP:26.24 size: 15198
x264 [info]: consecutive B-frames: 4.6% 40.1% 23.8% 16.2% 8.1% 7.3%
x264 [info]: mb I I16..4: 58.9% 0.0% 41.1%
x264 [info]: mb P I16..4: 36.6% 0.0% 0.0% P16..4: 51.8% 0.0% 0.0% 0.0% 0
.0% skip:11.6%
x264 [info]: mb B I16..4: 13.1% 0.0% 0.0% B16..8: 43.0% 0.0% 0.0% direct:
17.9% skip:26.1% L0:36.8% L1:45.9% BI:17.3%
x264 [info]: final ratefactor: 22.81
x264 [info]: direct mvs spatial:99.6% temporal:0.4%
x264 [info]: coded y,uvDC,uvAC intra:56.1% 57.5% 21.8% inter:32.0% 28.1% 1.5%
x264 [info]: kb/s:4954.9
encoded 756 frames, 6.42 fps, 4955.04 kb/s
Encoding X264 Second Pass :
suffer.
x264 [warning]: DPB size (16 frames, 18579456 bytes) > level limit (10 frames, 1
2582912 bytes)
x264 [info]: profile High, level 4.0
[12.7%] 96/756 frames, 1.67 fps, 1583.70 kb/s, eta 0:06:36
So first pass is main fast, k.
What about the ref ? it did not work
For all encodes, if you don't set your own --ref option and instead use the default or a preset, x264 will automatically lower --ref if the --level you set conflicts with it. If you set --ref explicitly, it will not override what you set.
If i remove --level
suffer.
x264 [info]: profile High, level 5.0
[27.0%] 204/756 frames, 1.17 fps, 2143.48 kb/s, eta 0:07:50
LE :
--tune film works fine, animations does not
suffer.
x264 [info]: profile Main, level 3.2
x264 [info]: slice I:13 Avg QP:18.35 size: 33820
x264 [info]: slice P:310 Avg QP:22.61 size: 27635
x264 [info]: slice B:433 Avg QP:25.91 size: 14609
x264 [info]: consecutive B-frames: 5.1% 42.3% 27.9% 24.8%
x264 [info]: mb I I16..4: 55.0% 0.0% 45.0%
x264 [info]: mb P I16..4: 37.0% 0.0% 0.0% P16..4: 53.1% 0.0% 0.0% 0.0% 0
.0% skip:10.0%
x264 [info]: mb B I16..4: 14.4% 0.0% 0.0% B16..8: 42.8% 0.0% 0.0% direct:
19.1% skip:23.6% L0:35.5% L1:44.7% BI:19.9%
x264 [info]: final ratefactor: 23.09
x264 [info]: direct mvs spatial:99.5% temporal:0.5%
x264 [info]: coded y,uvDC,uvAC intra:59.9% 60.3% 23.1% inter:31.6% 28.8% 1.2%
x264 [info]: kb/s:4867.3
encoded 756 frames, 8.79 fps, 4867.43 kb/s
suffer.
x264 [info]: slice I:13 Avg QP:18.66 size: 34852
x264 [info]: slice P:310 Avg QP:23.90 size: 23569
x264 [info]: slice B:433 Avg QP:27.19 size: 14211
x264 [info]: mb I I16..4: 24.4% 70.0% 5.6%
x264 [info]: mb P I16..4: 3.7% 20.3% 1.2% P16..4: 40.4% 13.8% 6.9% 0.1% 0
.0% skip:13.6%
x264 [info]: mb B I16..4: 0.9% 3.9% 0.2% B16..8: 49.5% 2.4% 2.8% direct:
13.4% skip:26.9% L0:47.7% L1:45.8% BI: 6.5%
x264 [info]: 8x8 transform intra:78.9% inter:83.9%
x264 [info]: direct mvs spatial:99.3% temporal:0.7%
x264 [info]: coded y,uvDC,uvAC intra:69.8% 69.9% 25.4% inter:36.4% 35.3% 1.5%
x264 [info]: ref P L0 65.1% 13.7% 7.8% 4.0% 3.3% 2.9% 2.0% 1.3%
x264 [info]: ref B L0 67.1% 13.5% 7.4% 4.3% 3.1% 2.6% 1.9%
x264 [info]: kb/s:4416.8
Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=1.0:0.2 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=300 / keyint_min=30 / scenecut=40 / rc=2pass / bitrate=4500 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=20000 / vbv_bufsize=20000 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
echo Encoding X264 First Pass :
echo.
start "encode" /b /low /wait "%mypath%\bin\x264n.exe" --preset slower --tune film --pass 1 --keyint %kint% --min-keyint %mint% --stats "%mypath%\%mpath%\T1\%mymovie%.stats" --bitrate %btratex264% --sar 1:1 --aud --nal-hrd --vbv-bufsize 20000 --vbv-maxrate 20000 --output NUL %myavs%
echo.
echo Encoding X264 Second Pass :
echo.
start "encode" /b /low /wait "%mypath%\bin\x264n.exe" --preset slower --tune film --pass 2 --keyint %kint% --min-keyint %mint% --stats "%mypath%\%mpath%\T1\%mymovie%.stats" --bitrate %btratex264% --sar 1:1 --aud --nal-hrd --vbv-bufsize 20000 --vbv-maxrate 20000 --output "%mypath%\%mpath%\T1\%mymovie%.264" %myavs%
Old 9th July 2009, 12:38   #73  |  Link
nurbs
You didn't bother to post your command line so I can't say for sure, but from the Mediainfo text it looks to me as if you used your own settings and not one of the presets or defaults. Your first pass only works because the refs are automatically lowered there anyway, and of course it's main profile since 8x8dct is on of the settings that gets dropped in first pass.
nurbs is offline   Reply With Quote
Old 9th July 2009, 12:40   #74  |  Link
juGGaKNot
juGGaKNot's Avatar
i did, see 70 and 72
start "encode" /b /low /wait "%mypath%\bin\x264n.exe" --preset slower --tune animation --pass 1 --keyint %kint% --min-keyint %mint% --stats "%mypath%\%mpath%\T1\%mymovie%.stats" --bitrate %btratex264% --sar 1:1 --aud --nal-hrd --vbv-bufsize 24000 --vbv-maxrate 24000 --output NUL %myavs%
start "encode" /b /low /wait "%mypath%\bin\x264n.exe" --preset slower --tune animation --pass 2 --keyint %kint% --min-keyint %mint% --stats "%mypath%\%mpath%\T1\%mymovie%.stats" --bitrate %btratex264% --sar 1:1 --aud --nal-hrd --vbv-bufsize 24000 --vbv-maxrate 24000 --output "%mypath%\%mpath%\T1\%mymovie%.264" %myavs%
And refs are 16, x264 [warning]: DPB size (16 frames, 18579456 bytes) > level limit (10 frames, 12582912 bytes)
echo.
echo.
echo.
tune film and it is k
Old 9th July 2009, 12:51   #75  |  Link
nurbs
You shouldn't have 16 refs then because --preset slower only uses 8. Also the mediainfo of your first encode shows plenty of settings different from --preset slower and different from the command line you posted.
Old 9th July 2009, 13:40   #76  |  Link
MasterNobody
He should because --tune animation:
            else if( !strcasecmp( optarg, "animation" ) )
                param->i_frame_reference = param->i_frame_reference > 1 ? param->i_frame_reference*2 : 1;
                param->i_deblocking_filter_alphac0 = 1;
                param->i_deblocking_filter_beta = 1;
                param->analyse.f_psy_rd = 0.4;
                param->rc.f_aq_strength = 0.6;
                param->i_bframe += 2;
P.S. But it should be reduced if he doesn't specify --ref manualy.
MasterNobody is offline   Reply With Quote
Old 9th July 2009, 14:08   #77  |  Link
J_Darnley
J_Darnley's Avatar
But it isn't. I think there is a problem with the automatic ref reduction. The code block enters but doesn't run the reduction because mbs = 0 for the videos I've tried.
[EDIT] This is because the input file has not been opened yet so the width and height are 0.
[EDIT2] Quick patch: http://pastebin.com/d5259ba1a Moves the code block to after the files are opened.
Old 9th July 2009, 14:46   #78  |  Link
juGGaKNot
juGGaKNot's Avatar
From the top, new encodes :
film :
CMD :
suffer.
[51.5%] 389/756 frames, 1.75 fps, 3339.88 kb/s, eta 0:03:29
Output :
Animation :
--preset slower --tune animation --pass 1 --keyint %kint% --min-keyint %mint% --stats "%mypath%\%mpath%\T1\%mymovie%.stats" --bitrate %btratex264% --sar 1:1 --aud --nal-hrd --vbv-bufsize 20000 --vbv-maxrate 20000
--preset slower --tune animation --pass 2 --keyint %kint% --min-keyint %mint% --stats "%mypath%\%mpath%\T1\%mymovie%.stats" --bitrate %btratex264% --sar 1:1 --aud --nal-hrd --vbv-bufsize 20000 --vbv-maxrate 20000
CMD :
suffer.
[31.7%] 240/756 frames, 1.04 fps, 2234.92 kb/s, eta 0:08:15
Output :
LE :
So when i force level 4.0 it will adjust the refs auto now not to break the level limit right ?
Old 9th July 2009, 18:29   #79  |  Link
Dark Shikari
x264 developer
Ah, good point. Will fix.
Old 10th July 2009, 02:10   #80  |  Link
me7
slower:
--me umh --subme 9 --ref 8 --b-adapt 2 --direct auto --partitions all --trellis 2
placebo:
--me tesa --subme 9 --merange 24 --ref 16 --b-adapt 2 --direct auto --partitions all --no-fast-pskip --trellis 2 --bframes 16
You suggest to keep 3 B-frames up to the 'slower' setting and raise the number only for 'placebo'. Are more then 3 B-frames really that useless?
me7 is offline   Reply With Quote
development, interface, x264
