Old 15th March 2015, 22:16   #961  |  Link
ultim
AVS+ Dev
ultim's Avatar
Okay, things are starting to shape up. Reported bugs have all been looked at, where appropriate fixed, and MT-functionality has also seen some necessary correctness improvements. I'm thinking about releasing 0.2 pretty soon. What is needed for that at this point is mainly testing, and maybe getting some additional content for the installer into shape. The more adventurous among you can pull the latest test binaries from avs-plus.net/builds. Starting now, binaries are built with a newer C++ runtime due to the wide availability of VS Community Edition, so if you feel like testing, don't forget to also get the vcredist stuff under the same link. In the official release, the installer will take care of setting up the runtime for you of course.
Depending on what you testers report, the r1779 binaries might be extremely similar to what 0.2 will be. I, for one have been using recent builds in my own production encodes without problems, and the (very few) independent testers I gave them to also had encouraging reports.
As for what the new caching system coupled with the rewritten filters in AviSynth+ are capable of, I'm also showing you these results, based on a real-world and pretty heavy script. And it was running only single-threaded. Now these measurements are not to be generalized, and results will surely depend on both your machine as well your script, but I certainly started smiling when I first saw this comparison. Do you like it? Are you excited for AviSynth+ 0.2?
EDIT: "Quite few" came out wrong upon reading it over. What I mean to say is very few testers, not "quite a few".
EDIT: I forgot to mention, the way how you specify the default MT mode for all filters that don't have it set explicitly has changed. For that, the first argument of SetFilterMTMode now has to be "DEFAULT_MT_MODE" instead of just "" (an empty string). I updated the MT usage notes, please consult them about how to use MT.
AviSynth+
ultim is offline
Old 15th March 2015, 22:43   #962  |  Link
ultim
AVS+ Dev
ultim's Avatar
chainik_svp,
you should also try out the latest build linked above. while i cannot stop ffdshow from leaking, this build should have improved the situation a lot. i also briefly looked at ffdshow's avisynth bridge, and i think i saw what the problem is. if you can get me someone who can build ffdshow for a test, i could submit a patch to try and see.
AviSynth+
ultim is offline
Old 15th March 2015, 23:05   #963  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
You could try to bother clsid
LoRd_MuldeR is offline
Old 15th March 2015, 23:17   #964  |  Link
chainik_svp
ultim
I'd be extremely excited IF the release will contain MT functions.
I mean make MT-enabled version the one and only version for AVS+.
I will, thanks!
yeah, clsid is the one
SVPflow motion interpolation
chainik_svp is offline
Old 15th March 2015, 23:33   #965  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by chainik_svp View Post
ultim
The build has all the MT functions. AVS+ won't have non-MT builds anymore. Due to the relatively new nature of MT in Avs+ though, MT-enabled encodes possibly don't yet have the same maturity as non-MT encodes with the same binary. This immaturity is exactly what testing should dissolve over time.
AviSynth+
ultim is offline
Old 15th March 2015, 23:36   #966  |  Link
Groucho2004
One potential problem with that build (x86):
I'm using this script to make avisynth run out of memory:
setmemorymax(3000)
n = 4800
colorbars(width = n * 2, height = n, pixel_type = "yv12").killaudio().assumefps(24000, 1001).trim(0, 999)
SelectRangeEvery(1000, 100, 200)
temporalsoften(4,4,8,15,2)
pointresize(width() - 64, height() - 64).turnleft()
pointresize(width() + 64, height() + 64).turnright()
With the "official" 2.6 I get the usual "We've run out of memory, folks" message after 9 frames.
With AVS+ r1718 I get "Could not allocate video frame. Out of memory." after 4 frames.
AVS+ r1778 does not get past the first frame but also throws "Could not allocate video frame. Out of memory.". However, it also crashes with c0000005 (access violation). Crash dump is here.
Groucho2004 is offline
Old 15th March 2015, 23:38   #967  |  Link
chainik_svp
In fact I'd LOVE to replace Avisynth with AVS+ in SVP distribution.
We're just waiting for the "official" MT build (32-bit).
And we're all looking forward for the stable 64-bit version.
ultim, if you've any other thoughts about bundling AVS+ with SVP - please contact me
good news, everyone
Old 15th March 2015, 23:51   #968  |  Link
sl1pkn07
Pajas Mentales...
please keep the non-MT version (the lastest one), for if the linux users are unable to run the MT version
sl1pkn07 is offline
Old 16th March 2015, 00:02   #969  |  Link
Groucho2004
Actually, r1778 crashes with every script. I'm on WinXPSP3.
Old 16th March 2015, 00:04   #970  |  Link
chainik_svp
sl1pkn07
Why? o_O
And since AVS+ is by design Windows-only, why won't Linux users switch to native Vapoursynth?
Old 16th March 2015, 00:06   #971  |  Link
chainik_svp
Originally Posted by groucho2004 View Post
actually, r1778 crashes with every script. I'm on winxpsp3.
vc++ 2013 rt?
Old 16th March 2015, 00:07   #972  |  Link
Groucho2004
vc++ 2013 rt?
-----Yes.
Old 16th March 2015, 00:11   #973  |  Link
innocenat
innocenat's Avatar
sl1pkn07
Why? o_O
Wine C++ runtime did not support #include <thread> used by Avs+ MT iirc. But I thought it was already fixed?
AviSynth+
innocenat is offline
Old 16th March 2015, 00:12   #974  |  Link
chainik_svp
may be binaries was built with v120 instead of v120_xp?
so this's the question to WineHQ, right?
and last time I checked, I was able to install any VC runtime i needed
VC runtime isn't provided by Wine o_O
Old 16th March 2015, 00:18   #975  |  Link
Groucho2004
Then it should not run at all (I think).
Old 16th March 2015, 00:33   #976  |  Link
sl1pkn07
Pajas Mentales...
sl1pkn07
Why? o_O
i mean, maintain the both version, the last one non-MT and the MT version
yes, i use a VS, but for some projects needs maintain AVS system
greetings
sl1pkn07 is offline
Old 16th March 2015, 02:04   #977  |  Link
innocenat
innocenat's Avatar
A year ago (that was when this wine and thread thing was discussed here, and I dont follow wine development much) the situation is that some api arent available so even if you install vcredist it wont run thread at all. And that bug was assigned WontFix in wine bug tracker.
So if that bug is still present, user kinda require ST version.
AviSynth+
Old 16th March 2015, 07:37   #978  |  Link
qyot27
qyot27's Avatar
The issues with Wine are gone so long as you're using the latest Wine 1.7, although the native Wine dlls for msvc[p|r]120 are still insufficient, so you need the MS ones (since 1.7 is the -devel branch, this could very well change before 1.8). My various personal builds of AviSynth+ from r1718 onwards seem to work fine - I get similar speeds as I was with 2.6 MT (might be mostly due to getting bottlenecked in HCenc). And I was using Prefetch(4) and setting the filter mode with the .avsi, so the MT should be active.
The only problem is that the MSVC 2012 and 2013 runtime installers error out. The DLLs work, the installers don't. So trying to use the redist bundled in AviSynth+'s installer won't work on Wine. You have to extract the dlls from the MS redists and copy them into Wine's system32 directory, and then add overrides for those DLLs in winecfg. This was true on both OSX 10.10 with Homebrew and Ubuntu 14.10 with the ubuntu-wine PPA. Really, winetricks is the place to handle that part, and it should be only a matter of time before vcrun2012/vcrun2013/etc. options get added to it (if they haven't been already).
Classic AviSynth has that limitation; there is work being done to resolve that issue in AviSynth+ (it's just taking a while).
qyot27 is offline
Old 16th March 2015, 10:33   #979  |  Link
ultim
AVS+ Dev
ultim's Avatar
setmemorymax(3000)
n = 4800
Yeah this script runs out of memory. I'll try to adapt some things to shrink the caches more aggressively under extreme memory pressure.
As for XP-compatibility, all things are compiled with the xp-toolset, so at least from that aspect, it should be fine. I wonder if there was some other oversight on my part (e.g. using an unsupported API or dunno what), I admit I haven't tested on XP at all. Will look into it.
AviSynth+
ultim is offline
Old 16th March 2015, 10:41   #980  |  Link
Boulder
Pig on the wing
Boulder's Avatar
It's been a year since I said "I'm going to hop on from Avisynth MT (SEt's latest v2.6 build) to Avisynth+ just for some testing." and now it seems that it is the time if you feel that the multithreading issues should be gone. Do you have anything specific you wish to have tested? Should the output of Avisynth 2.6 MT and Avisynth+ be identical? And the most important question: is MT enabled automatically or does it need to be set to achieve maximum performance?
Boulder is offline
