Old 1st June 2008, 19:43   #41  |  Link
MfA
Small moving objects as focal points in a scene seem pretty much worst case scenario for this method.
MfA is offline   Reply With Quote
Old 1st June 2008, 19:45   #42  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Which is somewhat odd, because the research actually shows that moving objects should be worse quality than they currently are (e.g. motion-based adaptive quantization).
Old 1st June 2008, 19:47   #43  |  Link
akupenguin
x264 developer
akupenguin's Avatar
Not if they're the focus. Then you track that one object and the rest of the frame counts as moving.
akupenguin is offline   Reply With Quote
Old 1st June 2008, 19:52   #44  |  Link
Dark Shikari
x264 developer
Hmm, true. Of course, its hard to make an algorithm that decides what is the "focus" of the scene...
Old 1st June 2008, 20:24   #45  |  Link
Dark Shikari
x264 developer
New patch. Updates:
1. Ignores chroma. This speeds things up and didn't seem to change things visually at all. Even if we used chroma, it should probably be weighted a lot lower anyways.
2. Raises B-RDO threshold.
3. Now available as a commandline option (--rdcmp).
Old 1st June 2008, 20:32   #46  |  Link
jethro
Nice discussion. The differences between what people consider to be better might be due to their displays (because i don't think our eyes differ this much). For example, in x264 encodes I don't see much ringing on my monitor but i definitely see blurring and ugly smearing of details (esp without VAQ). This new RD seems to make pictures more 'dirty' which is similar in effect to dct noise mentioned in xvid encodes. Of course, there are also preferences but I can't believe displays aren't a factor.
Originally Posted by Merlin7777 View Post
Truthfully, I rather prefer the second picture, honestly. The jaggies introduced along all of the edges are making my eyes bleed. If this can be fixed by lowering aq, then great! But frankly, I will take something over the jaggies. Sorry DS.
Yes, the jaggies come from VAQ. I noticed that default AQ 1.0 seems too strong for low resolutions as object edges get few bits. I often find myself using AQ 0.5-0.7 for something like 720x304. For HD res actually AQ 1.0 is fine and AQ 0.5 gets blocky.
EDIT: I'd like to add that I also prefer details over artifacts
jethro is offline   Reply With Quote
Old 1st June 2008, 20:54   #47  |  Link
Dark Shikari
x264 developer
Here's a really dramatic example of Psy RDO's effectiveness:
No Psy RDO
Psy RDO
Old 1st June 2008, 21:12   #48  |  Link
Screenshots from frame 600
PSY ON
PSY OFF
Old 1st June 2008, 22:23   #49  |  Link
IgorC
I think it also depends of resolution. My sample had dvd resolution while new psy rdo maybe more optimized for HD. Artifacts look different for HD and DVD. And of course it depends of display and other conditions of watching samples.
IgorC is offline   Reply With Quote
Old 1st June 2008, 22:42   #50  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Edit: Oh, another possible issue is that FGO lowers B-frame quantizers and adjusts RD thresholds, which this doesn't (yet). Thus comparisons could potentially get misleading when trying to compare just the RD metric alone.
After size analyse I think that it's simply a different complexity analysis. For really grainy picture (with really fine grain) fgo mode will use really more bit than psy mode.
vs vs
PSY vs FGO vs Elecard
31 832 vs 64 267 vs 63 751 bits (all frame are Pframe)
And here FGO produce by far the best quality ...
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Sagittaire is offline   Reply With Quote
Old 1st June 2008, 23:03   #51  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
vs vs
How about the original frame? How many bits?
Razorholt is offline   Reply With Quote
Old 1st June 2008, 23:09   #52  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
I agree. FGO does seem to come out better here.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 1st June 2008, 23:11   #53  |  Link
Dark Shikari
x264 developer
Given that its frame size is double that of psy RDO, how am I not surprised?
If its a B-frame, you can compensate for that by setting pbratio lower... that's what FGO does anyways and its probably wrong to put anything into mainline x264 that changes settings like that when the user should be in control of it.
If it isn't, maybe you didn't use the same bitrate for the two clips...?
Also, note that here, the Elecard frame isn't even the same frame of the video...
Old 1st June 2008, 23:11   #54  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Source is FFV1 master ...
Old 1st June 2008, 23:15   #55  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Yes not surprising for quality. The surprise come from decision. Here FGO seem make better choice than PSY mode. It's a really complexe frame with very fine but visible grain (grain on blue sky)
Only Pframe here.
6900 Kbps for overall bitrate (more than 200 000 frames).
yes because it's bframe for Elecard. Anyway all the Pframe for the encoded sequence are the same size with equivalent grain complexity for picture source. So the comparison is correct here.
Old 1st June 2008, 23:16   #56  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
Thanks Sagittaire. I just wanted to find out whether PSY was actually increasing the size of the video, as FGO does.
Old 1st June 2008, 23:16   #57  |  Link
Dark Shikari
x264 developer
I'm proposing that FGO has absolutely nothing to do with the double-size frame and that there has been user error here, such as comparing B-frames with different pbratio or encoding with different bitrates. Especially since the clips you posted earlier were not even of the same video clip, I don't exactly trust that you've done everything right here...
Old 1st June 2008, 23:29   #58  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Well it's just fast size partition with mkvmerge without range selection. Anyway the overall bitrate for the complete encoding are exactly the same: 6.9 Mbps. Sample come from complete encoding (more than 200 000 frame). It's just local difference for this frame. For the Pframe 47 499 I have another size: 122 889 vs 130 734 vs 99 707, and for the 64 190 frame another size: 82 008 vs 44 114 vs 74 374.
Source is Casino Royal with really different grain level.
Old 2nd June 2008, 01:48   #59  |  Link
ToS_Maverick
x264 Tester
about the frequencies and the quantization...
that sounds like Psy RDO works somehow like a custom matrix? I understand that a matrix uses fixed values, but it goes into the same direction, be more "kind" to the lower frequencies, to avoid blocking, preserving a good "look"...
ToS_Maverick is offline   Reply With Quote
Old 2nd June 2008, 08:10   #60  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
Well I find the problem ... it's a Rate Control problem between first and second pass. With the same final bitrate crf mode produce really better result.
2 pass mode with fast first pass:
x264.exe --threads 3 --thread-input --keyint 24 --min-keyint 2 --vbv-maxrate 20000 --vbv-bufsize 30000 --mvrange 511 --level 4.1 --bframe 3 --b-pyramid --bime --weightb --ref 1 --mixed-refs --direct auto --deblock -2:-2 --bitrate 6900 --pass 1 --stats "casino.log" --ipratio 1.10 --pbratio 1.10 --partitions "all" --8x8dct --me "hex" --subme 5 --trellis 0 --aq-mode 0 --aq-strength 0.00 --aud --nal-hrd --sar 1:1 --cqmfile Sagittaire.cfg --progress -o NUL Lossless.avs
And after I use always the same casino.log stat for all the encoding.
x264.exe --threads 3 --thread-input --keyint 24 --min-keyint 1 --vbv-maxrate 20000 --vbv-bufsize 30000 --mvrange 511 --level 4.1 --bframe 3 --b-pyramid --b-rdo --bime --weightb --ref 3 --mixed-refs --direct auto --deblock -2:-2 --bitrate 6900 --pass 2 --stats "casino.log" --ipratio 1.10 --pbratio 1.10 --partitions "all" --8x8dct --me "umh" --subme 7 --trellis 2 --aq-mode 2 --aq-strength 1.00 --no-fast-pskip --no-dct-decimate --aud --nal-hrd --sar 1:1 --cqmfile Sagittaire.cfg --zone 201560,207442,b=0.33 --progress -o 1080p_3.264 Lossless.avs
Quality mode:
x264.exe --threads auto --thread-input --keyint 24 --min-keyint 1 --crf %E_BR% --vbv-maxrate %MAX_BR% --vbv-bufsize %BUF_BR% --mvrange 511 --level 4.1 --bframe 3 --b-pyramid --b-rdo --bime --weightb --ref 3 --mixed-refs --direct auto --deblock -2:-2 --ipratio 1.10 --pbratio 1.10 --partitions "all" --8x8dct --me "umh" --subme 7 --trellis 2 --no-fast-pskip --no-dct-decimate --aud --nal-hrd --sar 1:1 --cqmfile Sagittaire.cfg --aq-strength 1.00 --aq-mode 2 --zone %CRE_FR%,%END_FR%,b=0.33 --progress -o 1080p_Q1.264 %E_SRC%
With 2 pass encoding and exactly the same setting than crf mode (and same final bitrate) I have completely different Rate Control (for example 31 832 bits vs 70 926 bits for frame 20 491). VAQ + PSY seem imply major modification in RC between first and second pass. It's perhaps necessary to use VAQ and PSY in first pass too ... ???
psy-rd, psyrdo
