Old 6th June 2008, 02:49   #81  |  Link
mahsah
How do you think this would work on anime? Could it be used with gradfun2db to hide DCT blocks?
mahsah is offline   Reply With Quote
Old 6th June 2008, 02:50   #82  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Yes, in my experience so far it is incredibly good at keeping the dither that gradbun2db introduces as long as you give it enough bitrate (while without, regular x264 will generally butcher banding even at absurdly high bitrates).
Old 6th June 2008, 03:13   #83  |  Link
desta
I've tried it on quite a bit of animated material now, and have got to say I'm very impressed.
Would I be right in assuming that although psy rdo is activated by default at >subme 6, it's optimised to process an image based on how grainy/noisy it is, including fine texture/detail, etc (in other words good on clean, grainy, or mixed footage)... whereas fgo by nature assumes a source is grainy/noisy, and could therefore be detrimental to a source that has both clean and grainy scenes?
desta is offline   Reply With Quote
Old 6th June 2008, 03:18   #84  |  Link
Dark Shikari
x264 developer
Both psy RDO and FGO attempt to make the output have the same <metric> as the input. But you are sort of correct, the metric used by psy RDO will generally be more friendly towards all types of complexity, not merely grain.
Old 6th June 2008, 03:23   #85  |  Link
desta
Brilliant, thanks. I know you said the object of psy rdo was to eventually replace fgo. Is that likely soon? Would you consider it to be more efficient than fgo already, or do you think they both still have their place?
Old 6th June 2008, 03:25   #86  |  Link
Dark Shikari
x264 developer
I think its more efficient, but I haven't done enough testing.
One thing I may see is if I can combine the two; Psy RD uses a 4x4 and 8x8 transform for comparison, while FGO uses a 2x2. Maybe I could combine all three transforms?
Old 6th June 2008, 04:10   #87  |  Link
gav1577
gav1577's Avatar
Wow that would be neat would love to test that one out
gav1577 is offline   Reply With Quote
Old 6th June 2008, 04:13   #88  |  Link
Yoshiyuki Blade
Novice x264 User
Yoshiyuki Blade's Avatar
With these visual improvements (VAQ and Psy RDO), I wonder if CQMs still have a large impact on image quality. I always have Sharktooth's AVC CQM on, even with animated material, but I haven't tried without it yet. Encoding a full length animated episode is incredibly slow on my lappy. You think CQMs will still remain significant at this stage (given a reasonably high bitrate/resolution)?
Yoshiyuki Blade is offline   Reply With Quote
Old 6th June 2008, 04:20   #89  |  Link
Dark Shikari
x264 developer
I've never really personally liked CQMs, for many reasons.
If you want to make comparisons, short samples should probably be sufficient.
Old 7th June 2008, 01:18   #90  |  Link
shae
Like what?
shae is offline   Reply With Quote
Old 7th June 2008, 01:27   #91  |  Link
Dark Shikari
x264 developer
Originally Posted by shae View Post
Like what?
1) When you're actually trying to keep fine detail, they butcher it.
2) They skew x264's lambda values.
3) They confuse RDO.
4) They confuse trellis even more than they confuse RDO.
5) Prestige, especially, does some really bizarre things.
Old 7th June 2008, 01:48   #92  |  Link
ToS_Maverick
x264 Tester
sry for hijacking this thread, but why is x264 so not-suited for CQMs? do other encoders work better with them?
ToS_Maverick is offline   Reply With Quote
Old 7th June 2008, 01:53   #93  |  Link
Dark Shikari
x264 developer
It isn't that x264 isn't suited for use with CQMs; nothing of the sort.
First, on the topic of RDO, you can intentionally make CQMs so that RD-wise, the inter matrix will always be favorable (for example), and so inter blocks are nearly always used when in RD mode.
However, the creator of the CQM might not have intended this; for example, the CQM might have been intended for an encoder that didn't use RDO, and therefore would not have taken into account the CQM when making its decision. I strongly suspect Prestige is this sort of CQM.
With trellis, trellis simply does not take into account CQM weights when working. I've found doing so actually reduces visual quality, unless I made a mistake in my patch--go figure.
Old 8th June 2008, 01:01   #94  |  Link
techouse
Strictly Rhythm
techouse's Avatar
Originally Posted by Razorholt View Post
Is it REALLY worth it? Maybe Wizboy or Bobor can try and compile an x264 version with the fixed me-prepass patch for us to test?
Thanks,
- Dan
Just Check out my site http://x264.tk
x264_x86_r871_techouse
Source: x264 r871 GIT (git://git.videolan.org/x264.git)
Applied patches (current versions):
x264_hrd_pulldown.04_interlace.diff
x264_me-prepass_DeathTheSheep_techouse_fix.diff
x264_progress.diff
x264_psy_rdo_0.22.diff
Please check http://forum.doom9.org/showthread.php?t=130364 and http://git.videolan.org/gitweb.cgi?p...git;a=shortlog for more info
Compiled by techouse on June 6th 2008, 03:13:38 CEST with GCC-4.3.0 on Windows Vista Ultimate SP-1 32-bit.
Commandline used: ./configure&&make fprofiled
Platform: X86
System: MINGW
avis input: yes
mp4 output: yes
pthread: yes
gtk: no
debug: no
gprof: no
PIC: no
shared: no
visualize: no
techouse is offline   Reply With Quote
Old 8th June 2008, 06:55   #95  |  Link
desta
http://forum.doom9.org/showthread.ph...86#post1146886
Old 12th June 2008, 21:18   #96  |  Link
shae
Well, doesn't that depend on the QM and is exactly what CQM are for, to allow you to fine tune what's kept and what's not?
Wouldn't that be implementation specific? It may conflict with other features currently, but in an ideal AVC encoder it should just add flexibility.
Just extreme values leading to extreme results, no?
Old 12th June 2008, 21:22   #97  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
I'd say an ideal AVC encoder wouldn't need any special CQM to workaround it's visual problems
Also I think features like VAQ, FGO and Psy RDO do exactly what people tried to achieve with CQM's before, only in a more sophisticated and more general way.
IMO it's always better to resolve the cause of the problem itself instead of fighting the symptom of the problem...
Old 13th June 2008, 01:59   #98  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
An ideal AVC encoder would vary the quant matrix per frame to completely maximize RD. That's one of those exponentially hard problems though, unless someone comes up with a good way to quickly test whether a CQM benefit outweighs its size every frame.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order.
Old 13th June 2008, 02:32   #99  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I had an idea for something similar back in the Xvid days, but it would have been very time consuming, and required a lot of user interaction. Here's how I saw it:
1) Take a movie, and split it into comp-test style chunks
2) Encode this multiple times with different CQMs
3) Show the compressionist the individual chunks, with the ability to flip between versions easily, stackhorizontal, interleave, whatever.
4) Allow the compressionist to pick a "top 3" or something for each chunk
5) Tally the votes, and pick a CQM for the movie.
I wish I could code, or I would have cobbled this together just out of curiosity.
But back on topic - I'm a huge fan of PsyRDO. It's improved almost every single thing I've thrown at it.
~MiSfit
Old 13th June 2008, 03:05   #100  |  Link
Razorholt
Cyberspace Citizen
Razorholt's Avatar
Are you using Trellis 2 ?
Razorholt is offline   Reply With Quote
psy-rd, psyrdo
