Old 7th September 2013, 10:58   #20041  |  Link
Q-the-STORM
Originally Posted by psousa View Post
i found another option where i could download this "dtsdecoderdll.dll" so can lav filter decode HD sound, but i dont know if the HD sound decode from LAV have the same quality from HD sound decode from my denon receiver.
it will be the same quality... LAV + dtsdecoderdll.dll from arcsoft decodes DTS-HD MA correctly...
Q-the-STORM is offline   Reply With Quote
Old 7th September 2013, 13:45   #20042  |  Link
Gagorian
Originally Posted by dansrfe View Post
It would be helpful if you could post close-up and distant images of the border to get a better idea of what it looks like.
https://docs.google.com/file/d/0B0gfCipWyN13MVRlUUVScS1uUXc/edit?usp=sharing
I noticed the same thing happening on my desktop with madVR, it was just harder to notice since the screen is a lot smaller, 24" vs 133". The above is a screenshot (print screen) with a portion of the lower border (resized to 500%).
Gagorian is offline   Reply With Quote
Old 7th September 2013, 14:56   #20043  |  Link
psousa
i believe in you but i like the blue log of HD sound on my denon xD
psousa is offline   Reply With Quote
Old 7th September 2013, 19:10   #20044  |  Link
psousa
Originally Posted by DragonQ View Post
I have an AVR too but it's set to pass-through the video with no changes. Is yours set up the same way? Are you sure the overscan option doesn't enable itself when you apply the custom resolution?
you are the man xDDD
you were right, when i set custom refresh rate my tv automatically oversan so after i fix the aspect rate do 16:9 no more overscan.
now playing a 24p movie madVR say my display is 23,97631 Hz. dont know if i can change it to perfect 23.97600 Hz but right now is perfect for me.
thanks a lot for the help friend
Old 7th September 2013, 19:27   #20045  |  Link
DragonQ
LAV has its own indicator (albeit harder to get to). Make sure you set tray icons to enabled, then play a file with a DTS-HD MA track. Double-click on the LAV Audio tray icon and go to the Status tab. It should say "DTS-HD MA" as the codec. Bit-streaming just causes headaches in my experience; if the software I'm using can decode everything properly, and my receiver has no issues with 7.1 LPCM, I have no reason to use bit-streaming. I think LAV decodes Dolby TrueHD without third-party plugins, plus FLAC, etc.
Nice. Out of curiosity, did you make the same change I did (+1 to total vertical pixels) to get that 23.9763x Hz?
HTPC Hardware: Intel Celeron G530; nVidia GT 430
HTPC Software: Windows 7; MediaPortal 1.19.0; Kodi DSPlayer 17.6; LAV Filters (DXVA2); MadVR
TV Setup: LG OLED55B7V; Onkyo TX-NR515; Minix U9-H
DragonQ is offline   Reply With Quote
Old 7th September 2013, 19:41   #20046  |  Link
psousa
yes, i change the total vertical pixels to 1126. with 1125 i get display rate around 23.978Hz.
Old 8th September 2013, 01:19   #20047  |  Link
psousa
but that way on my receiver the blue ligh from HD audio will not turn on right? and will not appear "dts-master" on receiver screen but something else right?
Old 8th September 2013, 03:27   #20048  |  Link
Q-the-STORM
nope... LAV is decoding DTS-HD MA to PCM, so the receiver is getting PCM... so the light won't turn on..
Old 8th September 2013, 10:07   #20049  |  Link
jkauff
The new version 19 of JRiver Media Center has a DTS output stream feature that should work for you. Check their support forum for details.
Old 9th September 2013, 16:25   #20050  |  Link
psousa
i think im go with your advice because yesterday i saw a full movie with lot of dark scenes ( MAMA was the movie name) and the dark scenes were all messed, horrible indeed, couldnt see any details on dark scenes just black.
so i stopped the movie and did some testes always with the same image and this is what i get:
1) with 24Hz (not custom refresh) i get amazing image quality from my panasonic
2) with 24 Hz custom refresh i get crap image quality especially on dark scenes, but in general colour are oversatured
3) with 24 hz custom refresh rate AND change on madvr output lvl for TV i get the same amazing image quality as on 1)
if i change for PC levels dark scene have 0 details, but on 24 Hz ( not custom refresh) if i set madvr output to PC levels i get amazing image quality and if i change to tv levels colours are all washout and is terrible.
i think custom refresh rates are messing up with madVR setting.
with custom refresh rate 24Hz and change 1 in total vertical pixels i get almost perfect 23.976Hz but that add 1 vertical pixel make something very anoying on top border of display.
im a bit tired with all this tests and tries to get perfect 24p and the blue dts-hd logo on my receiver.
i think im just go with your advice, forget the blue logo and just use LAV audio decoder + dtsdecoderdll.dll + reclock so i can get HD sound, perfect 24p experience and perfect image quality.
i will not gonna loose any quality on sound right? will just change on my screen receiver from " dts-hd master" to " PCM" and loose the blue light logo right?
so basically with LAV audio decoder + dtsdecoderdll.dll, no one really need receivers with HD decoders right?
Old 9th September 2013, 17:17   #20051  |  Link
DragonQ
As I understand it, the way Reclock works is that it resamples the audio to match the video. So if the video is playing back at 23.978 Hz instead of 23.976 Hz, then the video and audio will just be played back slightly quicker than normal so you won't get dropped/repeated frames. As long as you choose the best resampling algorithm I highly doubt you would be able to tell the difference between the original audio and the resampled audio. Aside from this, letting LAV Audio decode Dolby TrueHD or DTS-HD MA will result in the same PCM stream as letting your AVR do it, it just gets done a step earlier. It is possible that some receivers have different settings available for different input types though, so this is something to check.
Also note that the reason your custom 24 Hz refresh rate makes the colours over-saturated is because it's forced to 0-255 output. Your normal refresh rates were presumably using 16-235. You can fix this by changing the MadVR output, as you did. I need to use EVR on my HTPC so the only fix for me is to use YCbCr output instead of RGB. However, if you're getting a dodgy row of pixels then I guess this method isn't an option for your particular TV.
Old 9th September 2013, 21:17   #20052  |  Link
psousa
today im go see a movie ( the great gatsby ), hope finally i get 0 frame drops with reclock xD
Old 10th September 2013, 08:27   #20053  |  Link
Qaq
AV heretic
Normal? Movies are filmed in 24.
Qaq is offline   Reply With Quote
Old 10th September 2013, 09:00   #20054  |  Link
AngelGraves13
You should tick the passthrough options in LAV Audio decoder.
AngelGraves13 is offline   Reply With Quote
Old 10th September 2013, 10:50   #20055  |  Link
DragonQ
Indeed, but BDs are mastered at 23.976 fps normally. Kinda bizarre considering, AFAIK, HDTVs that support 23.976p support 24p anyway and a few BDs are indeed 24p.
Also shows that playing the film back 0.002 Hz faster than default isn't a problem in and of itself - the problem is just dropped/repeated frames due to the display refresh rate not matching.
Old 10th September 2013, 10:54   #20056  |  Link
DragonQ
That's not the point, he wanted to use it with Reclock but that's not possible.
Old 10th September 2013, 18:13   #20057  |  Link
leeperry
Kid for Today
Originally Posted by leeperry View Post
Hi madshi, I was wondering if you could please be of any assistance regarding my problems with a GTX660 on XPSP3
Hi again, OK nevermind about my e-drama as it would appear that even HR gives tearing and only overlay manages to provide smoothish playback(interframe jitter isn't stable and scaling is horrid). I wonder how Q3 manages to work so well with such broken drivers.
And lo and behold as I just bought a W8 licence, let's see how the 21st century feels like
Old 11th September 2013, 01:14   #20058  |  Link
moffy
I am looking at using the SubRenderIntf.h interface. I ran across it while browsing the LAVVideo source code, and have a project using subtitlles that I believe could benefit from it. You have extensive comments in the file, but being somewhat inexperienced with Directshow are there any more examples or documentation available? From reading, to use the interface you have to have a ISubRenderConsumer. How does one filter interrogate all the other filters of the graph looking for this interface? Thanks.
moffy is offline   Reply With Quote
Old 11th September 2013, 06:53   #20059  |  Link
Just to make sure, the interface used in LAVVideo is slightly outdated, you should grab the latest one from madVR itself, otherwise it might not be compatible (LAV only uses it internally with itself, not with the outside)
Old 12th September 2013, 00:50   #20060  |  Link
moffy
Thanks nevcairiel. I have also looked at the code from xy_subfilter_consumer. I managed to insert some code into LAVVideo e.g.
HRESULT CLAVVideo::Pause()
  CComPtr<IEnumFilters> pEF;
  HRESULT hr;
  ULONG merit;
  if((m_pGraph) && !(m_pSubConsumer))
	  if(SUCCEEDED(m_pGraph->EnumFilters(&pEF)))
		  for(CComPtr<IBaseFilter> pBF; pEF->Next(1, &pBF, 0) == S_OK; pBF = NULL)
			  CComQIPtr<ISubRenderConsumer> pNSC(pBF);
			  if((pBF != (IBaseFilter *) this) && pNSC)
				  merit = 0;
				  hr = pNSC->GetMerit(&merit);
				  if(SUCCEEDED(hr) && (merit > m_consumermerit))
					  m_consumermerit  = merit;
					  if(m_pSubConsumer != NULL)
						  m_pSubConsumer->Release();
					  m_pSubConsumer   = pNSC;
					  m_pSubConsumer->AddRef();
	return __super::Pause();
after much trial and error. When I had the xy_subfilter_consumer.dll loaded, it was able to discover the interface. If there are any mistakes in the above code please let me know.
