Old 21st June 2013, 02:26   #21  |  Link
I have moved the trolling and related discussion to this (closed) thread:
http://forum.doom9.org/showthread.php?t=168116
Please do not troll or feed trolls in this thread because at this point any followups to it here would likely violate rules 3, 4, 11, and/or 16.
Thank you for your understanding.
Old 21st June 2013, 03:59   #22  |  Link
thebombzen
Thank you.
Anyway, how much gain can we really expect from CTUs dividing into CUs in practicality, rather than in theory? I found a good description of CTUs/CTBs/CUs/CBs on this PDF from the HHI, if it helps:
http://iphome.hhi.de/wiegand/assets/...erformance.pdf
Will 32x32 and 64x64 CTUs improve compression that much? Or will most of the gain come from the additional encoder flexibility with variable-size non-grid CUs within CTUs? Also, will the additional encoder flexibility allow for encoders which are much, much better than the bitstream format devs expected? x264 is a very good encoder for H.264, better than the H.264 devs expected, but I'm worried it's reached a point where it doesn't have any additional bitstream flexibility to allow it to improve (the x264 devs can give me an opinion on this, I'd be glad to be wrong.)
TL;DR: How much difference does the additional flexibility really make?
thebombzen is offline   Reply With Quote
Old 21st June 2013, 23:04   #23  |  Link
benwaggoner
Originally Posted by thebombzen View Post
Thank you.
Overall, there's no One Big Thing that makes HEVC so much better. It's the aggregation of lots of little things.
Those big CTUs are likely to be quite helpful for 4K/UHD resolutions.
Ben Waggoner
My Compression Book
Old 23rd June 2013, 08:00   #24  |  Link
dapperdan
When the trolling got cut out, we also lost a link to a blog comparing hevc and x264, which wasn't particularly interesting in itself but had a link to this recent paper which was:
https://ece.uwaterloo.ca/~z70wang/pu...ons/vpqm13.pdf
The basic gist is that all the standard objective frame by frame analysis methodologies (psnr, ssim etc.) may systematically, and substantially, underrepresent the improvements in HEVC over its predecessor.
dapperdan is offline   Reply With Quote
Old 23rd June 2013, 09:57   #25  |  Link
Bathrone
Curious Beta Tester
This bloke has updated his posts and says that this month he will have a new code release out:
https://code.google.com/p/x265/
Bathrone is offline   Reply With Quote
Old 26th June 2013, 16:09   #26  |  Link
jq963152
Can we please have some comments from Dark Shikari and/or akupenguin (or other appropriate x264 developers) regarding if they are already working on an open-source H.265 encoder?
jq963152 is offline   Reply With Quote
Old 26th June 2013, 20:24   #27  |  Link
benwaggoner
Do note that if one or both are doing something, it could well be under NDA, and thus they might not be able to respond one way or another.
Ben Waggoner
My Compression Book
Old 26th June 2013, 21:03   #28  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
There is something in the works, and hopefully you're hear about it soon. Keep in mind that this is going to take years to produce a good encoder if ever, just like with x264. It's not going to be ready to displace H.264 by Christmas.
I also kind of don't feel like engaging trolls, so...
Old 26th June 2013, 21:53   #29  |  Link
jq963152
Thanks for your reply.
Awesome .
Would be great.
So you can't use x264 as a base to speed up development?
Quite unfortunate .
Another question:
Have you already come up with a name? Because it can't be "x265" because that one is already in use?
Old 26th June 2013, 22:10   #30  |  Link
Dark Shikari
x264 developer
"Using x264 as a base" is not a magic silver bullet that makes developer-years of work go away. It might be called x265; last I recall the domain and trademark had been taken care of.
Old 26th June 2013, 22:33   #31  |  Link
phate89
Sure but years of experience (especially with psychovisual enhancements) with x264 is a better start point right?
Are you planning some in-depth analysis of the standard like you did with vp8 in your diary of x264 dev?
phate89 is offline   Reply With Quote
Old 27th June 2013, 00:56   #32  |  Link
thebombzen
My guess it is will help some but not as much as everyone would like. HEVC is not H.264 so different enhancements might still look good but some other equivalent quality enhancement will compress much better. That's what this kind of encoder research is for
Old 27th June 2013, 01:00   #33  |  Link
Dark Shikari
x264 developer
Years of experience gives some guidance in experimentation and optimization, but you still have to build the software in the first place and make it fast, clean, and efficient, and that alone is many developer-years of work. Applying smart algorithms and knowledge gleaned from x264 comes after that, and still, it's just guidance; H.265 is very different from H.264.
Old 27th June 2013, 08:46   #34  |  Link
easyfab
I agree It will take years for a good H.265 encoder ( i.e ~50% bitrate for the same H.264 quality )
But I hope the first generation of H.265 encoder will quickly at least be as good as current H.264 encoder in bitrate/speed/quality.
Old 27th June 2013, 16:27   #35  |  Link
Dark Shikari
x264 developer
Keep in mind that it took until 2007-2008 for x264 to consistently beat Xvid (the previous generation), and H.264 came out in 2003. I don't want people to get their hopes too high, or else everyone's going to be disappointed.
Old 28th June 2013, 05:14   #36  |  Link
Bathrone
Curious Beta Tester
Heres a group with a free HEVC software decoder for windows:
http://xhevc.com/en/hevc/decoder/download.jsp
Divx have a patch out for mkvtoolknix to add their divx HEVC profiles to the toolset. They also reckon they are close to releasing a HEVC decoder and their own encoder.
Old 28th June 2013, 07:11   #37  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
I think these are the guys that kierank caught using libavcodec stuff without properly dealing with it even under the LGPL. I wouldn't give these guys too much publicity here.
Also, I really didn't want to put the same stuff in a yet another thread (we already have HEVC general and Available HEVC/H.265 test encoders threads, as well as some other random ones...), but there is a libavcodec HEVC decoder by smarter that is by now in a pretty good condition. It has been forked by OpenHEVC, and is also developed there (in a somewhat chaotic form).
OpenHEVC is then used by GPAC for their Osmo4 "mp4" player. GPAC happens to have one of the 14496-15 AMD2 (HEVC File Format, aka HEVC-in-"MP4") editors on their team, so they are currently the only ones who can implement it until the last draft is published (the newest draft currently public is from May 2012, and there seem to have been plenty of changes since). Since GPAC is not historically well known for implementing things well/correctly, no-one is copying their implementation, but instead waiting for the last draft to be published to implement it.
They have a patch out for a WIP first draft of HEVC-in-Matroska. You can see the discussion related to it here. I really should have noted that they should have also added the EXPERIMENTAL flag there, since so many people want to grab the extradata format from 14496-15 AMD2, which does not have its current draft released yet. Thus one should NOT think that HEVC-in-Matroska produced with their patched binaries will be compatible with what will end up being specified as the official mapping for HEVC in Matroska. Same warning of course goes for using the GPAC implementation of 14496-15 AMD2, as that can have bugs as well as the draft in general can change with time until the final draft gets published for the final ballot.
[I'm human, no debug]
Old 28th June 2013, 09:57   #38  |  Link
iwod
Yes, sometimes i wish throwing in money would speeds things up a lot, then we could do a Kickstarter project.
iwod is offline   Reply With Quote
Old 28th June 2013, 15:46   #39  |  Link
Bathrone
Curious Beta Tester
Thanks for that. If they are abusing open source and it's a proven situation then those abusers should be named and shamed.
The topic of this thread is about HEVC decoders/encoders so its ontopic to discuss various implementations of that. I'm excited mate to hear about the libavcodec decoder and I'm a regular with ffmpeg so thats great
Old 30th June 2013, 13:43   #40  |  Link
BadFrame
Sounds interesting, there's mentioning of a commercial version, do you know if will this be like x264 where everything is open source but there is an option to purchase a proprietary licence, or will this be two versions where the commercial one is better?
Anyway, great hearing that the x264 devs have something cooking for h265, their track record speaks for itself.
BadFrame is offline   Reply With Quote
decoder, encoder, h.265, hevc, open-source
