Old 13th November 2009, 23:06   #21  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by CpT View Post
Testing that now.
Edit: just tested, same results with --nf + weighted p
Upload it somewhere...
Old 13th November 2009, 23:19   #22  |  Link
CpT
Here's a test page
http://vizmu.com/player/flash/test.html
Direct link,
http://vizmu.com/player/2012-yellostone.mp4
CpT is offline   Reply With Quote
Old 13th November 2009, 23:34   #23  |  Link
Chengbin
Originally Posted by Dark Shikari View Post
What the heck are you on about?
We've tested dozens of software and hardware decoders. There are a grand total of two that fail: CoreAVC and the Apple TV. Basically everything else works.
Make that 5.
All Archos PMPs do not handle weightp properly.
Chengbin is offline   Reply With Quote
Old 13th November 2009, 23:37   #24  |  Link
Dark Shikari
x264 developer
Originally Posted by Chengbin View Post
Make that 5.
Are they broken with weightp, or with dupes? In other words, do they work with --weightp 2 --ref 1?
Old 13th November 2009, 23:45   #25  |  Link
Dark Shikari
x264 developer
More things to test:
--weightp 2 --nf --direct temporal
--weightp 2 --nf --direct none
--weightp 2 --nf --bframes 0
--weightp 2 --direct temporal
--weightp 2 --direct none
--weightp 2 --bframes 0
Which ones of those work?
I have a hunch that Flash's direct calculation is broken.
Old 13th November 2009, 23:55   #26  |  Link
CpT
Just tried --weightp 2 --ref 1 and it works
see below, scrub to 50 seconds
direct download -sorry for speed cap.
http://vizmu.com/player/2012-yellostone2.mp4
Old 13th November 2009, 23:56   #27  |  Link
Chengbin
Anything other than ref 1 will not work.
Old 14th November 2009, 00:02   #28  |  Link
Dark Shikari
x264 developer
Which means it's broken with dupes, not with weightp.
Old 14th November 2009, 00:05   #29  |  Link
Chengbin
I thought 64bit wasn't broken.
Also, they play fine with ffmpeg-mt.
Is it still duped?
Old 14th November 2009, 00:27   #30  |  Link
CpT
LOL,
I enabled mbtree and it works with 3 ref's + mixed ref's and weighted p @ 2.
So weighted p requires mbtree for flash usage?
Old 14th November 2009, 00:31   #31  |  Link
Dark Shikari
x264 developer
LOL,
I find that extraordinarily dubious... MB-tree doesn't change anything with regards to the features used on a bitstream level.
Old 14th November 2009, 00:59   #32  |  Link
unschuldsengel
I have mbtree always on and with weightedp=2 the problem occurs. also with 3 refs.
unschuldsengel is offline   Reply With Quote
Old 14th November 2009, 01:05   #33  |  Link
CpT
Are you talking about in flash or elseware.
I'm also running a longer test atm to see if I can reproduce it.
Edit: if I am able to reproduce it. mbtree on = no issue,
But mbtree off + same exact settings the issue occurs.
I'm done testing for for now.
Old 14th November 2009, 01:12   #34  |  Link
unschuldsengel
Just Flash, the videos worke fine in VLC etc.
Old 14th November 2009, 01:43   #35  |  Link
prOnorama
lol, Where do u live? We only allow viewing from a few countries.
403 Forbidden here also (Netherlands)
Maybe not use your site (wtf vizmu? lol it sounds like a rodent) but a site that's internationally accessible. Really Germany and The Netherlands aren't the bush-bush geographically or interwebz-wise also *cough* x264.nl should give a hint
prOnorama is offline   Reply With Quote
Old 14th November 2009, 02:05   #36  |  Link
CpT
This coming from a guy named prOnoram.
You should have access now btw, So should you Lord Mulder.
Old 14th November 2009, 02:11   #37  |  Link
CruNcher
CruNcher's Avatar
The Same black blocks on TIs Decoder (Archos 5IT Omap 3440) @ the 5th second like in Chengbins sample
It is about Time
Old 14th November 2009, 02:21   #38  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
It can be seen here http://vizmu.com/movie-trailers/724/129861/
Scrub to 50 seconds, it's shortly after that.
Yes, it works now. Thanks. But I'm unable to spot the distortions around 0:50 in that sample
Old 14th November 2009, 02:26   #39  |  Link
CpT
I uploaded a working version to the actual site. Then updated the links in my first post about it.
It can be seen here http://vizmu.com/player/flash/test2.html
Scrub to 50 seconds, it's shortly after that @ 56-59
working version - scrub to 50 seconds.
Old 14th November 2009, 02:28   #40  |  Link
LoRd_MuldeR
Software Developer
Oh, yes. Now I can reproduce the distortions in the "explosion" scene
artifacts, coreavc, corruption, weightp
