Old 10th October 2012, 19:58   #61  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
Update:
-Added: Support for 3gp container
-Added: Video options won't be passed if source is audio file
-Added: Some UI changes to "Logs" and "Settings" windows
-Fixed: "Canvas does not allow drawing" errors
-Fixed: Audio to audio convertion failed
-Fixed: Wrong file extension if video options were set for audio only source
-Fixed: Flickers due to excesive output from backends
-Fixed: Errors occur when Logs were created
-Updated: AlphaControls to 8.01 Beta
-Updated: FFMpeg
-Updated: MPlayer and MEncoder
-Updated: JVCL to 3.47
-Updated: MadExcept to 4.0.5
ozok is offline   Reply With Quote
Old 11th October 2012, 07:16   #62  |  Link
Uh, delicate thing, I believe there are interesting restrictions which combinations of audio and video are allowed in it, and ffmpeg may or may not obey these specs. Decide for yourself how strictly you are going to check them in your GUI before executing the command...
Old 11th October 2012, 08:42   #63  |  Link
ozok
ozok's Avatar
@LigH is there a place where i can find information about 3gp restrictions so i can check them?
Old 11th October 2012, 10:21   #64  |  Link
Official URLs:
http://www.3gpp.org/specifications
ftp://ftp.3gpp.org/specs/2012-09
External overview:
http://www.quintillion.co.jp/3GPP/3gpp_rel8.html
I did not yet read any, so I can't tell you which of them are relevant. I only remember that there was some slight trouble with some "Freeware" 3GPP converter (stealthly using a renamed ffmpeg, with some ambushing registration feature), which was able to create files some mobile players could not play, and it was a quite "usual" combination (MPEG4-ASP with MP3 or AAC-LC, I don't remember exactly...)
Old 18th October 2012, 17:17   #65  |  Link
ozok
ozok's Avatar
Update:
-Added: Option to make TEncoder delete unfinished files
-Added: Custom arguments for MEncoder and FFmpeg are seperated
-Added: Progress will be shown properly while adding folders
-Added: Preview mode for audio only sources
-Added: "Preview" window will show file's name in its title now
-Added: Preview progress will be shown in taskbar
-Added: Two new skins "WEB2" and "Subway"
-Added: File being process will be shown during adding process
-Fixed: Unnecessary warning if saving script enabled with MEncoder as encoder
-Fixed: "Abort" button was disabled in some cases
-Updated: AlphaControls to 8.02
Old 25th October 2012, 17:49   #66  |  Link
ozok
ozok's Avatar
Update:
-Added: Support for audio codec Opus
-Added: Support for .opus files
-Added: Decreased main window dimensions (will reset position info)
-Fixed: Custom arguments were not passed if codec is "Copy"
-Fixed: MEncoder "Direct Stream Copy" container problem
-Fixed: Minor UI problems
-Updated: MPlayer and MEncoder to SB41
-Updated: MediaInfo to 0.7.61
-Updated: FFmpeg to latest from ffmpeg.zeranoe.com
Old 15th November 2012, 07:27   #67  |  Link
ozok
ozok's Avatar
Update:
-Added: 64bit ffmpeg will be used when it's possible
-Added: Shutdown PC, log off or reboot post-encode options
-Added: Option to run single process when video codec is x264
-Added: CPU usage indicator
-Added: Tray icon and balloon hint
-Added: New skin "Zest"
-Fixed: Audio summary info was wrong in some cases
-Fixed: Reseting settings caused wrong skin selection
-Fixed: Speex files could not be added
-Fixed: BAT files with MEncoder as encoder could not start
-Fixed: Default output folder is program folder for portable version
-Updated: FFmpeg to 11-05-2012 from ffmpeg.zeranoe.com
-Updated: MPlayer and MEncoder to SB42
-Updated: AlphaControls to 8.03
Old 22nd November 2012, 22:03   #68  |  Link
ozok
ozok's Avatar
Update:
-Added: Turkish translation (Translators, please see "To translators.txt")
-Added: Profiles are now stored in different files under "Profiles" folder
-Added: User created Profiles will be saved in a differen directory
-Added: Custom video and audio options to profiles
-Added: Container options to profiles
-Added: Parent folder of input file will be created in the output folder
-Added: Option to use 32bit FFmpeg eventhough the OS is 64bit
-Added: New skin "Mint"
-Fixed: FFMpeg could not open AVS files (thx to goorawin)
-Fixed: Some settings were not saved
-Fixed: Preview window taskbar progress state problem
-Fixed: When a profiles was added/deleted/edited, profile lists would become empty
-Updated: AlphaControls to 8.04
-Updated: FFMpeg to 20-11-2012
-Updated: MPlayer and MEncoder to SB43
Old 2nd December 2012, 21:25   #69  |  Link
Pulp Catalyst
how do you normalize the audio conversion, having huge problems with AC3/DTS to mp3 (DRC is not being calculated)
Also, definitely will need autocrop at some point soon hopefully (it's amazing just how many don't want to mess with cropping values (actually many don't even know what cropping is!!!)
Pulp Catalyst is offline   Reply With Quote
Old 3rd December 2012, 14:55   #70  |  Link
ozok
ozok's Avatar
IIRC there was a filter named "pan" for FFMpeg but i don't know about Mencoder. I'll look into it. But i remember it being fairly complex.
Unfortunetly, it is not easy to implement auto-croping in TEncoder, every file must be examined first which is not how TEncoder works. Maybe you could try feeding a simple avs script that just does auto-croping?
Old 3rd December 2012, 18:03   #71  |  Link
Pulp Catalyst
that's a good idea, although finding those values, then creating the script, then feeding that into this encoder (gui)......
that's the thing about autocrop, it really does save so much time and gets rid of superfluous steps (like creating avs scripts with values that need to be found out such as correct crop values)
i really do hope though that you can solve the DRC, BIG problem, having to adjust volume on TV because the voices can't be heard yet the special effect sounds are so loud there's smoke coming out the speakers LOL
Old 3rd December 2012, 21:27   #72  |  Link
ozok
ozok's Avatar
That is probably the most annoying thing ever . I was already planning to add audio filters.
Old 27th January 2013, 17:53   #73  |  Link
GMJCZP
GMJCZP's Avatar
Thank you for this program.
As is well known the Mencoder presents problems when encoding at low bitrates, at least in my case with Mpge2. That is, not distributed properly bitrate in motion or static scenes, Mencoder that's fantastic away. I muffled this problem by defining an equation, but in later versions of mencoder not allow me to continue using it.
I wonder if there is a profile that optimizes finally bitrate distribution in Mpeg2 codification. Thank you.
GMJCZP is offline   Reply With Quote
Old 27th January 2013, 18:35   #74  |  Link
ozok
ozok's Avatar
@GMJCZP, unfortunately I do not know anything about these equations or profiles.
Old 28th January 2013, 00:23   #75  |  Link
GMJCZP
GMJCZP's Avatar
Ozok, thanks for your quick reply.
About getting a profile to optimize coding at low bitrates is an old issue that I personally see if I return.
One suggestion: you could put an option or tool in the program is making a direct muxing of audio tracks with the video, as does the YAMB, TMPGEnc, the VirtualDubMod, etc.
Old 29th January 2013, 05:15   #76  |  Link
GMJCZP
GMJCZP's Avatar
What do you think of adding to the program the ability to mux tracks (multiplexing maybe) of audio and video without encoding?
Old 29th January 2013, 08:09   #77  |  Link
I got two reports via phone which I could not yet verify:
a) Trying to convert a FLV (or some other sources) to AVC + AAC, the result doesn't contain any audio stream. Certainly to be investigated further with more details; either the audio stream cannot be decoded from the source, or the used encoder does not support AAC?
b) Minimizing the main window with empty queue quits the program surprisingly. I hope he did not miss it vanishing into the hidden tray icon container... this user is not used to Windows 7 auto-hiding many tray icons.
Old 29th January 2013, 14:26   #78  |  Link
ozok
ozok's Avatar
@GMJCZP It's a bit out of scope of TEncoder but, I added it to my to-do list.
@LigH
a) Some FLV videos downloaded from youtube can cause that problem. TEncoder, Tx264 and TAC (changed with latest version) use same code piece to identify audio track ID in the file and MediaInfo and FFMpeg sometimes report different ID for same audio track. I cannot confirm that for MEncoder.
b) That is really strange. Can he reproduce that with skinning disabled? TEncoder uses tray icon only for informative purpose not minimizing.
Old 29th January 2013, 16:41   #79  |  Link
b) During a conversion, the main form disappears, and you can minimize the converter form. After the conversion finished, the converter form closes, the main form appears again. Now if you minimize the main form, it disappears from the task bar; there is a tray icon left which disappears when clicked. You can use the ProcessExplorer to bring the window back to front, though.
Old 29th January 2013, 16:49   #80  |  Link
ozok
ozok's Avatar
You are right Ligh. Now I can reproduce the problem. I've also located and fixed the problem.
ffmpeg, gui, mencoder, multithreaded, subtitle
