28th November 2015, 22:24 | #1 | Link |
MeGUI (fps cannot be determined)
Hi everyone, first of all english is not my native language so I'm sorry if you see some mistakes in my writing.
My problem is very simple, I have some mkv files (with audio and video) that I want to encode with MeGUI, mainly to reduce their size, the thing is that when I drag any file to the program and I queue it and then I click "start" I get this error: The program cannot determine the frame rate of the file. When I check the properties of the file WHILE I'm playing it with MEDIA PLAYER CLASSIC, it clearly tells me that the frame rate is 30fps: BUT when I go to the MediaInfo tab, it tells me the frame rate is VARIABLE: How can I fix this problem? Is there a way to correct this or I have to manually change the fps when I encode it later? Thanks! |
29th November 2015, 09:55 | #2 | Link |
The frame rate variable (VFR) is a common problem, mainly with anime video.
To solve the problem you need mkvtoolnix installed in your system and: 1) Extract the timecodes of video track from your source mkv file: "...megui\tools\mkvmerge\mkvextract.exe" timecodes_v2 "source.mkv" 0:"timecodes.txt" Or use some GUI for mkvextract, for instance with UsEac3to: - Load your source.mkv - Click over Auxiliary Tools -> 'MkvExtract/Mux' - Select 'Extract Timecodes of Track' - Select the video Track and 'Run' You obtain a "source.mkv_0.txt" file at same folder than "source.mkv" 2) Recode your source.mkv with MeGUI to output.mkv 3) Open output.mkv in MkvToolnix-gui. - Select the video track - Load the timecodes.txt in Properties -> Timecode file - Start muxing
1st December 2015, 21:59 | #3 | Link |
Sometimes MediaInfo gets it wrong though, and MeGUI uses MediaInfo to obtain the frame rate. And MeGUI adds frame rate conversion to the script when indexing with ffms2 or opening a video via DirectShow, in which case the timecodes trick won't work because MeGUI will be converting to a constant frame rate by adding or dropping frames. I'm not 100% sure if MeGUI always offers up that warning no matter how the video is being opened.
If it was me I'd first try to get MeGUI to output the "correct" constant frame rate. I'm not sure how doomleox999 is opening the video but if it's via the Script Creator and after indexing with ffmsindex, MeGUI should open the video with frame rate conversion in the script something like this: LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("E:\test.mkv", cachefile="D:\test.mkv.ffindex", fpsnum=24000, fpsden=1001, threads=1) Manually changing the frame rate added to the script will often fix the problem. If it's 30fps like this: LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("E:\test.mkv", cachefile="D:\test.mkv.ffindex", fpsnum=30, fpsden=1, threads=1) If it's 29.970fps, like this: LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("E:\test.mkv", cachefile="D:\test.mkv.ffindex", fpsnum=30000, fpsden=1001, threads=1) I've come across the occasional video that was no doubt originally constant frame rate, but re-encoded as variable frame rate (probably via a GUI such as Handbrake) so repeated frames are only encoded once.... that sort of thing.... in which case converting back to a constant frame rate using the above method tends to work quite well. If it doesn't, generally because the source really is variable frame rate, then using the timescodes as tebasuna51 would be the better way to do it, but index with L-Smash rather than ffmsindex as currently MeGUI doesn't add frame rate conversion to the script when L-Smash is used. Or use Handbrake/Vidcoder instead. They handle variable frame rate video quite well and can output variable frame rate without a need to mess with timecodes. Last edited by hello_hello; 1st December 2015 at 22:21. |
2nd December 2015, 12:12 | #4 | Link |
Like hello_hello say, the encode can't include changes in number of output frames.
Use the timecodes is only allowed when the output frames is the same than input frames. Then it's not allowed: - Changes in decoder like FFVideoSource(..., fpsnum=30000, fpsden=1001,...) and/or DirectShowSource - AviSynth functions like: Changefps(), Convertfps(), Trim(), decimates, etc. @doomleox999 Can you upload a sample of your VFR source? Maybe Zathor can include functions to MeGUI to extract and mux timecodes.
error, fps, fps cannot be determined, megui, mkv |
