Old 6th August 2016, 22:06   #1  |  Link
StainlessS
StainlessS's Avatar
qCombed() v1.03 - 31 Mar 2019.
qCombed() v1.03, mod of IsCombed (c)Donald Graft.
qCombed(),  by StainlessS @ Doom9.org.  http://forum.doom9.org/showthread.php?p=1776495#post1776495
Runtime function to establish combing status of video frames, or to write a frames file of combed frames [Intent for ClipClop() use].
ColorSpace, Planar and YUY2. (v2.5 dll but as only examines the luma channel can also function with v2.6 colorspaces).
qCombed() is a mod of IsCombed from DeComb plugin for Avisynth, (c) Donald Graft. [can be found here:- http://rationalqm.us/mine.html].
qCombed has two modes of operation, can use in conditional filter eg Scriptclip() or ConditionFilter() [just like IsCombed()],
and also has complete clip scan and frames file writing capability builtin.
    qCombed(clip c,int "Threshold"=20,String "FileName"="",int "ClipIndex"=1,Bool "Range"=False,String "RngSep"="",int "n"=current_frame,Bool "Debug"=true)
    Args:-
        Threshold, default 20.      Threshold used to establish combed-ness, 0 <= Th <= 255. [same as for IsCombed(Threshold)].
        FileName, default "".       When filename is default "", qCombed will behave the same as IsCombed() and all other args with exception
                                    of Threshold (and additional 'n') are totally ignored.
                                        When in this mode it uses current_frame as set at each frame by runtime script functions eg Scriptclip()
                                        and WriteFileIf() or ConditionalFilter(). In addition, you can use it within at compile time eg in a GScript
                                        script and interogate frames by setting the n arg to the desired frame number. In this mode the function returns
                                        a Bool status, True = Combed.
                                    If you set FileName to eg "ClipClop_Cmd.txt", it will switch modes from default IsCombed() style
                                        function, to a function which scans entire clip and writes a frames command file. In this mode, all other
                                        args (with exception of 'n', which is ignored) are also valid. Will take time to scan entire clip but
                                        output file will exist on return, and qCombed() will return the number of combed frames in clip as Int.
        ClipIndex, default 1.       Ignored unless FileName != "", ie in File Writing mode. By Default writes a ClipClop() style frame command file
                                    where commands may look like:
                                        1 100        # Clip index 1, frame 100.  (where arg Range=False, or single frame range).
                                        1 200,210    # Clip index 1, frames 200 -> 210 (where arg Range=true).
                                    The clip index (1 as above) is a requirement in ClipClop which supports up to 256 clips, and so needs a clip index.
                                    A ClipIndex of -1, will omit the clip index and just write the frames or ranges.
                                    Valid range -1 -> 255 although 1 is probably the only sensible setting for ClipClop (clip 0 being the unaltered source clip).
        Range, Default false.       If False (default), writes all frame numbers on individual lines, else if true, then concatenates adjacent
                                    frames into ranges (single frame range will write only a single frame number).
        RngSep, Default "".         RangSep of "" will be converted to ',' COMMA and used only if Range is True, as shown above in "1 200,210".
                                    Can set RngSep to any character Chr(32) SPACE to Chr(126), only the first character in string is used.
        n,                          n defaults to current_frame when FileName is default "", ie Conditional filter mode, but can be given explicitly as
                                    arg in eg GScript script. When FileName != "", n has no function.
        Debug,                      default True, show debug info.
        Example 1:
            Below single pass script deinterlaces as clip is played.
            EVEN=False                                                          # Odd frames wanted from double rate deinterlaced clip.
            SHOW=True                                                           # Show status on frame
            COMBEDTHRESH=20                                                     # Default Threshold
            Avisource(...)
            AssumeTFF                                                           # For Deinterlacer [NNedi3(Field=-2) ie Double rate, internal parity].
            UNLACED=NNedi3(Field=-2, nns=2)                                     # Or whatever you use to deinterlace.
            UNLACED=(EVEN)?UNLACED.SelectEven:UNLACED.SelectOdd
            UNLACED=(SHOW)?UNLACED.Subtitle("COMBED",align=5,size=48):UNLACED
            SSS=RT_String("qCombed(Threshold=%d)",COMBEDTHRESH)                 # Make runtime condition script string with embedded threshold.
            ORG=Last                                                            # Remember Original clip
            ConditionalFilter(Last,UNLACED,Last,SSS,"=","true")
            Return (SHOW)?StackVertical(ORG,Last):Last
        Example 2:
            Below two pass example allows fast access (via ClipClop) to non-deinterlaced frames where multiple pass processing and/or avoiding
            intermediate writing of lossless AVI's before additional processing can be carried out.
            RANGE=True                                                          # We Want Ranges, not frames.
            RNGSEP=" "                                                          # SPACE separator instead of COMMA (Also allowed in ClipClop).
            FN="ClipClop_Cmd.Txt"
            Avisource(...)
            StartT=RT_TimerHP
            nCombedFrames = qCombed(Last,Threshold=COMBEDTHRESH,FileName=FN,Range=RANGE,RngSep=RNGSEP)  # Returns only after complete clip scan.
            Tim = RT_TimerHP - StartT
            RT_DebugF("Result=%d Time = %.3fsecs (%.3fmins) FPS=%.3f",nCombedFrames,Tim,Tim/60.0,Framecount/Tim)
            ClipClop(ORG,UNLACED,cmd=FN,Show=Show)                              # Replace combed frames/ranges with deinterlaced ones.
ssS
dll and source (52KB) @ MediaFire or SendSpace below in my sig.
EDIT: Avs 2.5, and v2.60, x86, x64 versions.
I sometimes post sober.
Old 6th August 2016, 23:02   #2  |  Link
GMJCZP
GMJCZP's Avatar
Tin man, this plugin is an early edition (2016/08/16) ?
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 6th August 2016, 23:10   #3  |  Link
StainlessS
StainlessS's Avatar
You are such a stickler for the niceties
Thanx, corrected.
Old 15th December 2020, 01:26   #4  |  Link
kedautinh12
can you compile with x64 ver??
Old 15th December 2020, 16:30   #5  |  Link
StainlessS
StainlessS's Avatar
OOps, v1.3 with x64 compiled Mar 2019, forgot to upload to MediaFire and SendSpace,
DONE!
EDIT: It should work , I hope, not tested. [I dont usually re-version/re-date folder unless ready for posting]
Old 15th December 2020, 18:57   #6  |  Link
kedautinh12
combing, deinterlace, iscombed
