Old 26th December 2016, 20:42   #5221  |  Link
nandoom
PAL DVD - 25fps to 24fps
Hello,
After looking up online, I came to know that PAL video is actually shot with 24fps but PAL DVDs made have 25fps with a pitched audio. I wonder a feature could be added in MeGUI to be able to encode PAL DVD video with 24fps with audio and subs sync accordingly.
nandoom is offline   Reply With Quote
Old 26th December 2016, 22:44   #5222  |  Link
You cannot generalize this for every PAL production. "PAL speedup" happens often for original cinematic "film" material. But native PAL productions do exist as well.
Matching subtitle timecodes to the inverse (PAL/Film slowdown) is quite easily possible. But converting the audio will reduce the quality once more. Some people try to mix the video with NTSC audio tracks, but that may fail if you have different cutting in each production.
Old 27th December 2016, 10:07   #5223  |  Link
Glarioo
You should certainly not expect any difference in quality.
The 64-bit CPU architecture is a bit more efficient (twice as wide and twice as many direct-access CPU registers), some encoders may work up to ~10% faster. But AviSynth used to be only available reliably in 32-bit code, and most plugins for AviSynth also existed in 32-bit code only. And you cannot call a 32-bit code DLL (like vanilla AviSynth 2.5 / 2.6) in a 64-bit code EXE. For x264 and x265, a helper application (avs4x26x) was called to pipe a stream of raw video from the AviSynth output into the encoder. If all used tools would be available in 64-bit code, making them work together would be easier and more efficient - thus faster. Now with the development of AviSynth+, chances are good that this will happen for MeGUI, as it already happened for StaxRip.
Thanks for your explanation.
About StaxRip, it seems that it is possible that Stax76 may terminate the development of StaxRip.
http://forum.doom9.org/showthread.php?t=172068&page=84
Old 27th December 2016, 13:58   #5224  |  Link
hello_hello
If it was filmed in a PAL country it could very well have been shot at 25fps.
As far as converting to 24fps though, for the video you can add AssumeFPS(24,1) to the end of the script MeGUI creates before encoding, or AssumeFPS(24000,1001) for 23.976fps, and the audio encoder configurations already have PAL/Film/NTSC conversion options (under Time Modification).
There's probably a way to change the frame rate of subtitles with some utility or another, although as I have no particular need for subtitles as a rule, if I'm changing the frame rate I don't bother with the extra work to keep them so I don't actually know. I guess any chapters would need adjusting too.
Old 27th December 2016, 15:19   #5225  |  Link
Weirdo
Process exits with error: 0xE06D7363 (-529697949). Something similar occurs with the development version (with the same source file, not all files).
[Error] Log
-[Information] Versions
--[Information] [27-Dec-16 15:11:14] MeGUI: 2624
--[Information] [27-Dec-16 15:11:14] Operating System: Windows 10 Professional x64 (10.0.0.14393)
--[Information] [27-Dec-16 15:11:14] .NET Framework: 4.0 (4.0.0.0)
--[Information] [27-Dec-16 15:11:14] .NET Framework: 4.6.x (4.6.01586)
--[Information] [27-Dec-16 15:11:14] AviSynth: 2.6.0.5 (20-02-2015)
--[Information] [27-Dec-16 15:11:14] AvisynthWrapper:  (02-01-2009)
--[Information] [27-Dec-16 15:11:14] Haali Matroska Splitter not installed properly.
--[Information] [27-Dec-16 15:11:14] Therefore DSS2() will not and certain functions of FFVideoSource() and the HD Streams Extractor may not work.
--[Information] [27-Dec-16 15:11:14] Please download and install it from http://haali.su/mkv/
--[Information] [27-Dec-16 15:11:14] Haali DSS2: not installed
--[Information] [27-Dec-16 15:11:14] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
--[Information] [27-Dec-16 15:11:14] MediaInfo: 0.7.79.0 (02-11-2015)
--[Information] [27-Dec-16 15:11:14] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [27-Dec-16 15:11:14] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
--[Information] [27-Dec-16 15:11:14] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
--[Information] [27-Dec-16 15:11:14] 7z: 9.20 (18-11-2010)
-[Information] Update detection
--[Information] [27-Dec-16 15:11:14] Using cached update config and server: http://megui.org/auto/stable/
--[Information] [27-Dec-16 15:11:14] No package requires an update
--[Information] [27-Dec-16 15:13:02] There is 1 package which can be updated: x264 10bit
--[Information] [27-Dec-16 15:13:03] updating active package x264 10bit as it is missing or outdated
-[Information] AutoEncode job generation log
--[Information] [27-Dec-16 15:12:42] Split Size : null
--[Information] Eliminating duplicate filenames
---[Information] [27-Dec-16 15:12:57] Video output file: G:\Stories.mkv.264
---[Information] [27-Dec-16 15:12:57] File already exists. New video output filename: G:\Stories.mkv_0.264
---[Information] [27-Dec-16 15:12:57] Muxed output file: G:\Films\Stories.mkv
-[Error] Log for job1 (video, Stories.mkv.avs -> Stories.mkv_0.264)
--[Information] [27-Dec-16 15:13:02] Started handling job
--[Information] [27-Dec-16 15:13:12] Preprocessing
--[Information] [27-Dec-16 15:13:12] Avisynth input script
---[NoImage] # Set DAR in encoder to 79 : 39. The following line is for automatic signalling
---[NoImage] global MeGUI_darx = 79
---[NoImage] global MeGUI_dary = 39
---[NoImage] SetMTMode(5, 4)
---[NoImage] SetMemoryMax(1000)
---[NoImage] LoadPlugin("F:\Apps\Video tools\MeGUI\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavVideoSource("G:\Stories.mkv")
---[NoImage] # ConvertToYV12()
---[NoImage] SetMTMode(2)
---[NoImage] QTGMC( Preset="Slower" )
---[NoImage] #SelectEven() # Add this line to keep original frame rate, leave out for smoother doubled frame rate
---[NoImage] crop(10, 30, -10, -30)
---[NoImage] #resize
---[NoImage] #denoise
--[Information] [27-Dec-16 15:13:16] resolution: 700x420
--[Information] [27-Dec-16 15:13:16] frame rate: 60000/1001
--[Information] [27-Dec-16 15:13:16] aspect ratio: 79:39 (2.026)
--[Information] [27-Dec-16 15:13:16] Job command line: "F:\Apps\Video tools\MeGUI\tools\x264_10b\avs4x264mod.exe"  -L "F:\Apps\Video tools\MeGUI\tools\x264_10b\x264-10b_64.exe" --preset slow --crf 18.5 --keyint 599 --no-mbtree --direct temporal --sar 79:65 --output "G:\Stories.mkv_0.264" "G:\Stories.mkv.avs"
--[Information] [27-Dec-16 15:13:16] Process started
--[Information] [27-Dec-16 15:13:16] Standard output stream
--[Information] [27-Dec-16 15:13:16] Standard error stream
---[Information] [27-Dec-16 15:13:22] raw [info]: 700x420p 79:65 @ 60000/1001 fps (cfr)
---[Information] [27-Dec-16 15:13:22] x264 [info]: using SAR=79/65
---[Information] [27-Dec-16 15:13:22] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.1 Cache64
---[Information] [27-Dec-16 15:13:22] x264 [info]: profile High 10, level 3.1, 4:2:0 10-bit
---[Information] [27-Dec-16 16:05:20] x264 [info]: frame I:74    Avg QP:27.22  size: 33980
---[Information] [27-Dec-16 16:05:20] x264 [info]: frame P:16191 Avg QP:28.95  size:  5558
---[Information] [27-Dec-16 16:05:20] x264 [info]: frame B:19396 Avg QP:30.42  size:  1026
---[Information] [27-Dec-16 16:05:20] x264 [info]: consecutive B-frames: 27.1%  0.3%  2.3% 70.3%
---[Information] [27-Dec-16 16:05:20] x264 [info]: mb I  I16..4: 12.5% 64.7% 22.8%
---[Information] [27-Dec-16 16:05:20] x264 [info]: mb P  I16..4:  0.0%  0.3%  0.1%  P16..4: 43.0% 14.2% 14.1%  0.0%  0.0%    skip:28.3%
---[Information] [27-Dec-16 16:05:20] x264 [info]: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8: 38.3%  1.9%  0.4%  direct: 0.5%  skip:58.8%  L0:34.2% L1:56.3% BI: 9.5%
---[Information] [27-Dec-16 16:05:20] x264 [info]: 8x8 transform intra:70.1% inter:77.1%
---[Information] [27-Dec-16 16:05:20] x264 [info]: direct mvs  spatial:32.3% temporal:67.7%
---[Information] [27-Dec-16 16:05:20] x264 [info]: coded y,uvDC,uvAC intra: 86.3% 91.2% 70.7% inter: 16.8% 24.3% 2.0%
---[Information] [27-Dec-16 16:05:20] x264 [info]: i16 v,h,dc,p: 81%  4%  6% 10%
---[Information] [27-Dec-16 16:05:20] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26%  4%  3% 10% 12% 16%  9% 13%  7%
---[Information] [27-Dec-16 16:05:20] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 39%  4%  3%  8%  9% 14%  7% 11%  5%
---[Information] [27-Dec-16 16:05:20] x264 [info]: i8c dc,h,v,p: 23% 17% 42% 18%
---[Information] [27-Dec-16 16:05:20] x264 [info]: Weighted P-Frames: Y:0.0% UV:0.0%
---[Information] [27-Dec-16 16:05:20] x264 [info]: ref P L0: 79.6% 11.1%  5.2%  2.5%  1.7%  0.0%
---[Information] [27-Dec-16 16:05:20] x264 [info]: ref B L0: 89.3%  9.0%  1.1%  0.5%
---[Information] [27-Dec-16 16:05:20] x264 [info]: ref B L1: 95.4%  4.6%
---[Information] [27-Dec-16 16:05:20] x264 [info]: kb/s:1511.37
---[Information] [27-Dec-16 16:05:20] encoded 35661 frames, 11.43 fps, 1511.37 kb/s
--[Error] [27-Dec-16 16:05:20] Process exits with error: 0xE06D7363 (-529697949)
--[Warning] [27-Dec-16 16:05:20] The 64 bit mode of x264 is enabled. Depending on the error it may help to disable it in the MeGUI settings.
--[Information] [27-Dec-16 16:05:20] Job completed
AVS:
SetMTMode(5, 4)
SetMemoryMax(1000)
LWLibavVideoSource("G:\Films\Stories.mkv")
# ConvertToYV12()
SetMTMode(2)
#resize
#denoise
MediaInfo:
General
Unique ID                                : 98275363111946528611605529657693019740 (0x49EF257E7C93264CA7BFA873EB6D9E5C)
Complete name                            : G:\Films\Stories.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 1.14 GiB
Duration                                 : 41 min 41 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 3 921 kb/s
Encoded date                             : UTC 2016-12-25 21:38:24
Writing application                      : TMPGEnc MPEG Smart Renderer 5 Version 5.0.7.9
Writing library                          : TMPGEnc MPEG Smart Renderer 5 Version 5.0.7.9
Video
Format                                   : MPEG Video
Format version                           : Version 2
Format profile                           : Main@Main
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : M=3, N=15
Format settings, picture structure       : Frame
Codec ID                                 : V_MPEG2
Codec ID/Info                            : MPEG 1 or 2 Video
Bit rate                                 : 3 651 kb/s
Maximum bit rate                         : 7 500 kb/s
Width                                    : 720 pixels
Height                                   : 480 pixels
Frame rate                               : 29.970 (30000/1001) FPS
Standard                                 : NTSC
Scan type                                : Interlaced
Scan order                               : Bottom Field First
Bits/(Pixel*Frame)                       : 0.353
Time code of first frame                 : 00:00:00:00
Time code source                         : Group of pictures header
GOP, Open/Closed                         : Closed
Stream size                              : 1.06 GiB (93%)
Color primaries                          : BT.601 NTSC
Transfer characteristics                 : BT.601
Matrix coefficients                      : BT.601
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Bit rate                                 : 192 kb/s
Channel positions                        : Front: L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 spf)
Bit depth                                : 16 bits
Stream size                              : 57.2 MiB (5%)
Win 10 Pro x64
Weirdo is offline   Reply With Quote
Old 28th December 2016, 18:43   #5226  |  Link
Pulp Catalyst
Hey,
will MeGUI ever support Vapoursynth....i know this would mean virtually a rewrite of the program, but Avisynth seems a redundant method now (multi-threading), i mean it's an obsolete and archaic system (please don't assassinate me for saying that).
But I've seen VapourSynth in action with Staxrip, for multi-threading, it really is incredible and very hands off for. And seems very thread safe compared to Avisynth.
Pulp Catalyst is offline   Reply With Quote
Old 29th December 2016, 21:55   #5227  |  Link
mini-moose
[Error] Log
Not sure if that helps, but isn't version 2624 really old? MeGUI is currently at 2695. Maybe there were fixes for your problem since.
mini-moose is offline   Reply With Quote
Old 29th December 2016, 22:30   #5228  |  Link
Weirdo
Actually, the latest stable version is indeed 2624 but as mentioned I've also tried the development version (currently 2679 I think).
Win 10 Pro x64
Old 3rd January 2017, 21:33   #5229  |  Link
EuropeanMan
trying to update to 2679 isn't working for me
keeps saying CORE: CANNOT CREATE A FILE WHEN THAT FILE ALREADY EXISTS
please help
EuropeanMan is offline   Reply With Quote
Old 3rd January 2017, 21:48   #5230  |  Link
Zathor
I do not have this problem, however extract this into your MeGUI directory: http://megui.org/auto/megui-core-2696-32.zip
Old 3rd January 2017, 22:15   #5231  |  Link
EuropeanMan
I somehow managed to scrounge together 2696 onto my laptop...then switched back to stable server...otherwise, it keeps trying to update 5 things which just aren't happening for whatever reason. i THINK the problem is on my laptop, which doesn't allow megui to write over the file...it's a permissions thing I guess??? and i'm not too windows 7 savvy to figure out how to fix that...heck, for the last 4 hours i've been googling on how i could save files onto my desktop...then changing permissions on folders currently encoding that small file we talked about on the other thread...almost done.
Old 3rd January 2017, 22:49   #5232  |  Link
EuropeanMan
Megui 2696 and I guess prior versions that I had from 2624 onwards
Yes, it's been more than a year and a half that I hadn't used this program. In the past, build 2525 was the last one I had used on an old laptop, whose HD is now an external HD on my current laptop which is hosting the 2696 build...and on 2525, when you encoded an XVID file, it was two passes/jobs...and it was done.
NOW I realise on both 2624, & 2696, that encoding the same takes 3 jobs??? the last being a muxing job by a process called ffmpeg. This last job I stalled/postponed. So after the first two jobs are complete, I have a file with an extension .m4v
This plays fine in VLC...no problems. In MediaINFO, it doesn't show the bitrate at all
Also, I'm unsure as to why it STILL shows the Xvid Writing Library as 67???!!!
here is that file: https://www.sendspace.com/file/84ab3e
Now, once I begin the 3rd job...the MUXING section of the encode, it gets screwed up in playback!!! I'm truly frustrated
and here's the file: https://www.sendspace.com/file/51xxue
Lastly, it shows the bitrate as 143, when it was preset to 1999!!!
Preliminary log file only. During closing of MeGUI the well formed log file will be written.
--[Information] [03-Jan-17 1:31:33 PM] MeGUI: 2696
--[Information] [03-Jan-17 1:31:33 PM] Operating System: Windows 7 Premium Edition x64 SP1 (6.1.65536.7601)
--[Information] [03-Jan-17 1:31:33 PM] .NET Framework: 4.0 (4.0.0.0)
--[Information] [03-Jan-17 1:31:33 PM] .NET Framework: 4.5.x (4.5.51209)
--[Information] [03-Jan-17 1:31:34 PM] Using cached update config and server: http://megui.org/auto/
--[Information] [03-Jan-17 1:31:34 PM] AviSynth+: 2.6.0.5 (03-01-2014) (active)
--[Information] [03-Jan-17 1:31:34 PM] AviSynth portable: 2.6.0.6 (21-09-2015) (inactive)
--[Information] [03-Jan-17 1:31:34 PM] AvisynthWrapper:  (02-01-2009)
--[Information] [03-Jan-17 1:31:34 PM] Haali Media Splitter: 1.13.138.14 (14-04-2013)
--[Information] [03-Jan-17 1:31:34 PM] Haali DSS2:  (14-04-2013)
--[Information] [03-Jan-17 1:31:34 PM] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
--[Information] [03-Jan-17 1:31:34 PM] MediaInfo: 0.7.91.0 (01-12-2016)
--[Information] [03-Jan-17 1:31:34 PM] MediaInfoWrapper: 0.7.61.0 (06-01-2013)
--[Information] [03-Jan-17 1:31:34 PM] There is 1 package which can be updated: MeGUI
--[Information] [03-Jan-17 1:31:34 PM] MessageBoxExLib: 1.0.2218.28317 (19-12-2008)
--[Information] [03-Jan-17 1:31:34 PM] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
--[Information] [03-Jan-17 1:31:34 PM] 7z: 9.20 (18-11-2010)
--[Information] [03-Jan-17 1:31:37 PM] There is 1 package which can be updated: MeGUI
-[Information] Log for job1 (video, Master script.avs -> )
--[Information] [03-Jan-17 1:33:57 PM] Started handling job
--[Information] [03-Jan-17 1:33:57 PM] Preprocessing
-[NoImage] avisource("h:\\test.avi")
-[NoImage] #trim(4029,226032)
-[NoImage] trim(6000,7000)
-[NoImage] spline36resize(720,300)
-[NoImage] addborders(0,2,0,2)
-[NoImage] spline36resize(720,304)
-[NoImage] ConvertToYV12()
--[Information] [03-Jan-17 1:33:57 PM] Avisynth input script
--[Information] [03-Jan-17 1:33:58 PM] resolution: 720x304
--[Information] [03-Jan-17 1:33:58 PM] frame rate: 5000000/208333
--[Information] [03-Jan-17 1:33:58 PM] aspect ratio: 45:19 (2.368)
--[Information] [03-Jan-17 1:33:58 PM] Job command line: "C:\Users\Angel\Desktop\one\tools\xvid_encraw\xvid_encraw.exe" -i "C:\Users\Angel\Desktop\Master script.avs" -pass1 "C:\Users\Angel\Desktop\Master script.stats" -bitrate 1999 -turbo -qtype 1 -imin 1 -bmin 1 -pmin 1 -par 1
--[Information] [03-Jan-17 1:33:58 PM] Process started
--[Information] [03-Jan-17 1:33:58 PM] Standard output stream
--[Information] [03-Jan-17 1:33:59 PM] Standard error stream
---[Information] [03-Jan-17 1:34:12 PM] xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert
---[Information] [03-Jan-17 1:36:39 PM] Tot: enctime(ms) =11353.00,               length(bytes) = 13723529
---[Information] [03-Jan-17 1:36:39 PM] Trying to retrieve width and height from input header
---[Information] [03-Jan-17 1:36:39 PM] Avg: enctime(ms) =  11.34, fps =  88.17, length(bytes) =   13709
---[Information] [03-Jan-17 1:36:39 PM] xvidcore build version: xvid-1.3.4
---[Information] [03-Jan-17 1:36:39 PM] I frames:     12 frames, size =   41637/ 499644, quants =  2 / 2.00 /  2
---[Information] [03-Jan-17 1:36:39 PM] Bitstream version: 1.3.4
---[Information] [03-Jan-17 1:36:39 PM] P frames:    433 frames, size =   25228/10923946, quants =  2 / 2.00 /  2
---[Information] [03-Jan-17 1:36:39 PM] Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 3DNOW 3DNOWEXT TSC
---[Information] [03-Jan-17 1:36:39 PM] B frames:    556 frames, size =    4136/2299939, quants =  4 / 4.00 /  4
---[Information] [03-Jan-17 1:36:39 PM] Detected 2 cpus, using 2 threads.
--[Information] [03-Jan-17 1:36:39 PM] Postprocessing
---[Information] [03-Jan-17 1:36:39 PM] Deleting intermediate files
--[Information] [03-Jan-17 1:36:39 PM] Job completed
-[Information] Log for job2 (video, Master script.avs -> Master script.m4v)
--[Information] [03-Jan-17 1:36:40 PM] Started handling job
--[Information] [03-Jan-17 1:36:40 PM] Preprocessing
--[Information] [03-Jan-17 1:36:40 PM] Avisynth input script
--[Information] [03-Jan-17 1:36:42 PM] resolution: 720x304
--[Information] [03-Jan-17 1:36:42 PM] frame rate: 5000000/208333
--[Information] [03-Jan-17 1:36:42 PM] aspect ratio: 45:19 (2.368)
--[Information] [03-Jan-17 1:36:42 PM] Job command line: "C:\Users\Angel\Desktop\one\tools\xvid_encraw\xvid_encraw.exe" -i "C:\Users\Angel\Desktop\Master script.avs" -o "C:\Users\Angel\Desktop\Master script.m4v" -pass2 "C:\Users\Angel\Desktop\Master script.stats" -bitrate 1999 -turbo -qtype 1 -imin 1 -bmin 1 -pmin 1 -par 1
--[Information] [03-Jan-17 1:36:42 PM] Process started
--[Information] [03-Jan-17 1:36:42 PM] Standard output stream
--[Information] [03-Jan-17 1:36:42 PM] Standard error stream
---[Information] [03-Jan-17 1:36:54 PM] xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert
---[Information] [03-Jan-17 1:39:02 PM] Trying to retrieve width and height from input header
---[Information] [03-Jan-17 1:39:02 PM] Tot: enctime(ms) =14496.00,               length(bytes) = 10406474
---[Information] [03-Jan-17 1:39:02 PM] xvidcore build version: xvid-1.3.4
---[Information] [03-Jan-17 1:39:02 PM] Avg: enctime(ms) =  14.48, fps =  69.05, length(bytes) =   10396
---[Information] [03-Jan-17 1:39:02 PM] Bitstream version: 1.3.4
---[Information] [03-Jan-17 1:39:02 PM] I frames:     12 frames, size =   37180/ 446166, quants =  2 / 2.33 /  3
---[Information] [03-Jan-17 1:39:02 PM] Detected CPU flags: ASM MMX MMXEXT SSE SSE2 SSE3 3DNOW 3DNOWEXT TSC
---[Information] [03-Jan-17 1:39:02 PM] P frames:    433 frames, size =   18376/7957130, quants =  2 / 2.58 /  3
---[Information] [03-Jan-17 1:39:02 PM] Detected 2 cpus, using 2 threads.
---[Information] [03-Jan-17 1:39:02 PM] B frames:    556 frames, size =    3602/2003178, quants =  4 / 4.34 /  5
--[Information] [03-Jan-17 1:39:09 PM] Final statistics
---[Information] [03-Jan-17 1:39:09 PM] Video Bitrate Desired: 1999 kbit/s
---[Information] [03-Jan-17 1:39:09 PM] Video Bitrate Obtained (approximate): 1996 kbit/s
--[Information] [03-Jan-17 1:39:09 PM] MediaInfo
---[Information] [03-Jan-17 1:39:09 PM] File: C:\Users\Angel\Desktop\Master script.m4v
-[Information] Format: MPEG-4 Visual
-[Information] FormatString: MPEG-4 Visual
-[Information] FileSize: 10406474
-[Information] PlayTime:
---[Information] General
-[Information] ID:
-[Information] StreamOrder:
-[Information] Width: 720
-[Information] Height: 304
-[Information] FrameCount:
-[Information] FrameRate: 24.000
-[Information] FrameRateOriginal:
-[Information] FrameRateMode:
-[Information] ScanType: Progressive
-[Information] Codec: MPEG-4V
-[Information] CodecString: MPEG-4 Visual
-[Information] Bits Depth: 8
-[Information] AspectRatio: 2.368
-[Information] AspectRatioString: 2.35:1
-[Information] Delay:
-[Information] Title:
-[Information] Language:
-[Information] LanguageString:
-[Information] Default:
-[Information] DefaultString:
-[Information] Forced:
-[Information] ForcedString:
---[Information] Video
--[Information] [03-Jan-17 1:39:11 PM] Postprocessing
-[Information] [03-Jan-17 1:39:11 PM] Successfully deleted C:\Users\Angel\Desktop\Master script.stats
---[Information] [03-Jan-17 1:39:11 PM] Deleting intermediate files
--[Information] [03-Jan-17 1:39:11 PM] Job completed
-[Information] Log for job3 (mux, Master script.m4v -> Master script.avi)
--[Information] [03-Jan-17 1:45:58 PM] Started handling job
--[Information] [03-Jan-17 1:46:03 PM] Preprocessing
--[Information] [03-Jan-17 1:46:03 PM] MediaInfo
---[Information] [03-Jan-17 1:46:03 PM] File: C:\Users\Angel\Desktop\Master script.m4v
-[Information] ID:
--[Information] [03-Jan-17 1:46:04 PM] Job command line: "C:\Users\Angel\Desktop\one\tools\ffmpeg\ffmpeg.exe" -y -i "C:\Users\Angel\Desktop\Master script.m4v" -vcodec copy -vtag XVID -r 24 "C:\Users\Angel\Desktop\Master script.avi"
--[Information] [03-Jan-17 1:46:06 PM] Process started
--[Information] [03-Jan-17 1:46:06 PM] Standard output stream
--[Information] [03-Jan-17 1:46:06 PM] Standard error stream
---[Information] [03-Jan-17 1:46:06 PM] ffmpeg version 3.2.2 Copyright (c) 2000-2016 the FFmpeg developers
---[Information] [03-Jan-17 1:46:06 PM]   built with gcc 5.4.0 (GCC)
---[Information] [03-Jan-17 1:46:06 PM]   configuration: --enable-gpl --enable-version3 --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib
---[Information] [03-Jan-17 1:46:06 PM]   libavutil      55. 34.100 / 55. 34.100
---[Information] [03-Jan-17 1:46:06 PM]   libavcodec     57. 64.101 / 57. 64.101
---[Information] [03-Jan-17 1:46:06 PM]   libavformat    57. 56.100 / 57. 56.100
---[Information] [03-Jan-17 1:46:06 PM]   libavdevice    57.  1.100 / 57.  1.100
---[Information] [03-Jan-17 1:46:06 PM]   libavfilter     6. 65.100 /  6. 65.100
---[Information] [03-Jan-17 1:46:06 PM]   libswscale      4.  2.100 /  4.  2.100
---[Information] [03-Jan-17 1:46:06 PM]   libswresample   2.  3.100 /  2.  3.100
---[Information] [03-Jan-17 1:46:06 PM]   libpostproc    54.  1.100 / 54.  1.100
---[Information] [03-Jan-17 1:46:07 PM] Input #0, m4v, from 'C:\Users\Angel\Desktop\Master script.m4v':
---[Information] [03-Jan-17 1:46:07 PM]   Duration: N/A, start: 0.000000, bitrate: N/A
---[Information] [03-Jan-17 1:46:07 PM]     Stream #0:0: Video: mpeg4 (Advanced Simple Profile), yuv420p, 720x304 [SAR 1:1 DAR 45:19], 24.01 tbr, 1200k tbn, 24.01 tbc
---[Information] [03-Jan-17 1:46:07 PM] Output #0, avi, to 'C:\Users\Angel\Desktop\Master script.avi':
---[Information] [03-Jan-17 1:46:07 PM]   Metadata:
---[Information] [03-Jan-17 1:46:07 PM]     ISFT            : Lavf57.56.100
---[Information] [03-Jan-17 1:46:07 PM]     Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 720x304 [SAR 1:1 DAR 45:19], q=2-31, 24.01 tbr, 24 tbn, 24 tbc
---[Information] [03-Jan-17 1:46:07 PM] Stream mapping:
---[Information] [03-Jan-17 1:46:07 PM]   Stream #0:0 -> #0:0 (copy)
---[Information] [03-Jan-17 1:46:07 PM] Press [q] to stop, [?] for help
---[Information] [03-Jan-17 1:46:07 PM] video:10163kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 3.286147%
--[Information] [03-Jan-17 1:46:07 PM] MediaInfo
---[Information] [03-Jan-17 1:46:07 PM] File: C:\Users\Angel\Desktop\Master script.avi
-[Information] Format: AVI
-[Information] FormatString: AVI
-[Information] FileSize: 10748446
-[Information] PlayTime: 00:09:42.708
-[Information] ID: 0
-[Information] StreamOrder: 0
-[Information] FrameCount: 13985
-[Information] Codec: XVID
-[Information] CodecString: XviD
--[Information] [03-Jan-17 1:46:08 PM] Postprocessing
-[Information] [03-Jan-17 1:46:08 PM] Successfully deleted C:\Users\Angel\Desktop\Master script.m4v
---[Information] [03-Jan-17 1:46:08 PM] Deleting intermediate files
--[Information] [03-Jan-17 1:46:08 PM] Job completed
PLEASE HELP ME THANKS in advance
Old 3rd January 2017, 23:17   #5233  |  Link
EuropeanMan
Since I've figured out on my 64bit Win7 laptop, that the culprit is INDEED the latest ffmpeg tool, I replaced it with the one from my 2525 build, and now the result is perfect.
Can someone please explain WHY this works? Please note, and I don't know if the current ffmpeg is written for a 64bit computer, that the 32bit ffmpeg from the 2525 build works!!!
here is that build: https://www.sendspace.com/file/qyadpm
the version that did NOT work for me: ffmpeg-3.2.2-64.7z
I also still don't know why it states in MediaINFO that the writing library for XviD is still 67
Old 4th January 2017, 03:23   #5234  |  Link
hello_hello
https://forum.doom9.org/showthread.p...60#post1791860
Old 4th January 2017, 08:23   #5235  |  Link
bxyhxyh
I do rgb encodes with x264. Now I can't do it with megui because of this change and avs4x26x doesn't support rgb.
2681 [x264]                 removed option to select 32bit x264 on a 64bit OS and merged the 8- and 10-bit packages
Can you restore x264 32bit support back?
Is changelog working with 2696 btw?
bxyhxyh is offline   Reply With Quote
Old 4th January 2017, 08:28   #5236  |  Link
What is an "RGB encode"? Do you create an AviSynth script which outputs RGB24, so that x264 has to convert it to YUV internally to be able to encode it at all?
Old 4th January 2017, 08:33   #5237  |  Link
bxyhxyh
Do you create an Avisynth script which outputs RGB24
Yes.
And with --input-csp rgb --output-csp rgb options, it works without converting it.
But avs4x26x doesn't support it, so it converts it to YUV, makes end result wrong.
With older versions, I just unchecked x64 support. It feeds to x264 32bit directly.
Old 4th January 2017, 10:35   #5238  |  Link
mini-moose
pgcdemux
With the current versions, it's only possible to create .d2v using pgcdemux to extract files from a DVD first (when an ifo is present).
I usually extract the vobs myself before (to vob+ifo with only what I needed from the VTS).
I'ts not possible anymore to load the vob I pre-extracted and d2v it. Megui load the ifo and tries to extract a new vobs set even if I selected the vob and not the ifo. That fails with my old routine as the ifo contains all the VTS info but not all its parts.
Old 4th January 2017, 17:46   #5239  |  Link
Zathor
Small update:
2699 [VobSubber]            added option to extract forced subtitles in dedicated file(s)
     [OneClick]             fixed wrong assignment of automatically detected forced IDX/SUB subtitles (regression of 2686)
2696                        runtime files will always be copied
Old 4th January 2017, 17:50   #5240  |  Link
Zathor
No, pgcdemux will only be used when either a multi-pgc or multi-angle structure is found in the IFO of the corresponding VOB files. This is necessary to avoid a/v/s sync issues or unwanted content.
How do you do that? If you tool also adjusts the IFO file everything is fine, if it is a 1:1 copy (waht I assume based on your description below), it must of course fail.
Remove/rename the IFO, then the PGC/Angle (and also language) information is not available anymore - or adjust your ripping process
