Old 8th March 2014, 23:39   #19521  |  Link
Audiophile1178
Originally Posted by Shuttle99 View Post
Thanks for the info I will test it on my current problem.
Also, when you're at the Blu-ray tab you might want to make sure that "First MPLS file" says 0 as well. This will designate a number for the playlist. It seems like your player is picky so having everything at zero is probably a good idea.
FYI on tsMuxeR, if for some reason you have an issue with 2.x.xx (currently 2.6.12) try using the older one (1.10.16).
Audiophile1178 is offline   Reply With Quote
Old 8th March 2014, 23:45   #19522  |  Link
Shuttle99
@Audiophile1178 I dl tsmuxer 2.6.12 and loaded the movie that has the wrong 00023 name, I go to the blu-ray tab but I don't see anything on that page says m2ts or AVCHD radio. Do I need a different version of tsMuxer?
I dl 1.10.16 loaded 00000.mpls from the playlist directory the input shows 00000.mpls and 00023.m2ts inthe stream directory, now I go to the blu-ray tab but don't see "Blu-ray tab and make sure "First m2ts file" says 0. Then select AVCHD radio" what you want me to check? Under ouput TS muxing is default should I select M2TS muxing for the output? then after the file is created do I over write the 00023m2ts with the new 00000m2ts file and what about the files still names 00023 in stream and clip folders.
Shuttle99 is offline   Reply With Quote
Old 8th March 2014, 23:58   #19523  |  Link
Audiophile1178
@Shuttle99, I see that I was too brief with my description and will try to elaborate further.
1. Go to your BD Rebuilder AVCHD encoded folder.
2. Navigate to BDMV\PLAYLIST folder and there should be 1 file in there with a .mpls extension to it.
3. Open up tsMuxeR and drop that .mpls file into the input files window under the input tab.
4. Click on the Blu-ray tab at the top and you should see at the top right under options:
First MPLS file
First M2TS file
Start mux time
5. Make sure First MPLS file and First M2TS file are 0
6. Now, look near the bottom of tsMuxer at output section. It will say TS muxing, M2TS muxing, Blu-ray ISO, Blu-ray Folder, AVCHD folder, and Demux.
7. Click the AVCHD circle also known as a radio button.
8. Underneath that you'll see "File name:" with a browse button all the way to the right. Click on browse and select a new output destination.
9. Click "Start_muxing" at the very bottom.
10. Wait until it's finished and check the folders as mentioned prior.
If you have any further questions PM me instead as this isn't releated to BD Rebuilder.
Old 9th March 2014, 00:05   #19524  |  Link
Shuttle99
@Audiophile1178
Thanks for being patient and for the help your second directions were crystal clear. It worked perfect and I will burn a disc and test it. Thank you very much for the help.
Old 9th March 2014, 02:12   #19525  |  Link
@jdobbs This has not been a problem until this new version 46.14 something has changed because I compared setup in both and they are the same. I always backup a movie even if it is just one movie using "batch backup" because I need the output file the be renamed to 00000.m2ts if I just do a backup the output files keeps the same number as the input. I have a Panasonic BD Player if that helps, I just ran a batch backup on a single movie and and the output file now is keeping the same number name as the input which the player says unsupported dvd I reran the same movie with 46.13 and the output file renames itself to 00000.m2ts. Can you look into why this is changing now.
I'm sorry to say this -- but that's impossible. If it isn't 00000.m2ts after muxing a movie-only, something else is changing it. TSMUXER creates that file.
Are you sure you're doing movie-only -- or have you chosen Quick-Play backup?
Old 9th March 2014, 15:02   #19526  |  Link
Shuttle99
@jdobbs Sorry my fault I ripped movie only and had selected full backup in BD Rebuilder so there was only one m2ts file and since full was selected it didn't rename it. Also thanks to Audiophile1178 he showed me how to manually use txmuxer to fix this should it happen again.
Old 9th March 2014, 18:09   #19527  |  Link
Patrick
Playlist entry movie duration shortend
I just backed up Terminator Salvation (DC), where you can select the extended or theater version of the movie to watch. As a result, the movie is heavily fragmented, with different segments for either version. I found that BD rebuilder erroneously shortens the duration of at least playlist 00301 of the movie from 24 to 16 seconds, even though the converted segment itself has the correct length. As a result, the movie does not play correctly (skipping 8 seconds of the segment).
Additional information: that disc seems to be rather demanding as to its file structure - all videos seems to have (an empty) secondary video track. Maybe that is the reason for BD Rebuilder having problems? BTW: At least one other playlist ist also affected. My guess would be that running this disc would reveal all sorts of hard to uncover problems? Good stress test ;-)
Patrick is offline   Reply With Quote
Old 9th March 2014, 21:31   #19528  |  Link
Acerjen
Inserting subtitles
Does anyone know if it is possible to add a subtitle to a Bluray using BDRebuilder?
I ask because I recently got a foreign Bluray not realizing there wasn't english subs on it. I found some english subs on the internet, but need them to enjoy the movie. I know I can probably mux it in with tsMuxer, but would like to keep the menu, chapters, extras,etc. intact.
My last option might be to use the import option in BDRebuilder, but was hoping to keep the original menus intact.
Any ideals. Thanks in advance for any help. Much appreciated.
Later,
Acerjen
Acerjen is offline   Reply With Quote
Old 9th March 2014, 22:06   #19529  |  Link
DoctorM
@Averjen - You can add subtitles with multiAVCHD (in reauthor mode). From there you can let BD-RB re-encode the disc if you need to.
Old 10th March 2014, 05:25   #19530  |  Link
Dream-Cypher
Quick-Play menus not working on PS3
Hello,
I am having an issue where BD-R's with Quick-Play menus will not play on my PS3. I searched here, but was unable to find if this was a known issue.
The discs are built and burned successfully, and work fine on TMT5 and my Standalone Sony player. When I use them in the PS3, I get a black screen with no menus, and cannot do anything other than exit to the PS3 system menu.
If I press the "display" button, it shows me no time codes or title information. Attempting to hit the menu button tells me "This operation is not available here"
One of the discs was a standard BD backup, and the other was a disc created by importing several DVDs in Quick-Author mode. There are no errors in the BD-Rebuilder.log file, and as mentioned, the discs work fine in the other players I've tried. I have tried them in both a fat and slim PS3.
The DVD compilation was created in version .46.14 while the Movie backup was created in .46.11 a while ago. (I had not tried it in the PS3 previously, so I just found out that there was an issue.)
Thanks,
Dream-Cypher
Dream-Cypher is offline   Reply With Quote
Old 10th March 2014, 07:59   #19531  |  Link
Ch3vr0n
jdobbs i think i've found a rather big issue with DTS-Express
I just recoded "Riddick_G51", the original has 2 VC-1, 480p, 23.976fps pip streams. the streams get demuxed, recoded but the video does NOT get muxed back in while the audio does. Pdvd 11 plays the pipstream of the original perfectly video/audio while of the backup it only plays the audio. The pip stream video simply isn't there. i don't know if its due to the removal of the DTSX_Enable=1 string but i thought that one wasn't needed anymore or due to DGdecNV, ill run a new job using LAVF
log below
[03/10/14] BD Rebuilder v0.46.14 (beta)
[04:37:01] Source:  RIDDICK_G51
  - Input BD size: 30,45 GB
  - Approximate total content: [03:50:31.550]
  - Target BD size: 22,95 GB
  - Windows Version: 6.0 [6002]
  - Output folder: C:\BDRB Rebuilds\
  - Decoding/Frame serving: DGDecNV [2-way]
[04:37:01] PHASE ONE, Encoding
 - [04:37:01] Processing: VID_00037 (1 of 10)
 - [04:37:01] Extracting A/V streams [VID_00037]
 - [05:06:59] Reencoding video [VID_00037]
 - [05:06:59] Reencoding secondary video [TRK_02]
 - [05:22:55] Reencoding secondary video [TRK_03]
   - Rate/Length: 23,976fps, 192.912 frames
   - Bitrate: 12.699 Kbs
 - [05:38:45] Reencoding: VID_00037, Pass 1 of 1
 - [06:41:09] Video Encode complete
 - [06:41:09] Processing audio tracks
   - Track 4357 (eng): Keeping original audio
   - Track 6656 (eng): Keeping original audio
   - Track 6657 (eng): Keeping original audio
 - [06:41:09] Multiplexing M2TS
 - [06:54:13] Processing: VID_00146 (2 of 10)
 - [06:54:13] Extracting A/V streams [VID_00146]
 - [06:54:38] Reencoding video [VID_00146]
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29,970fps, 17.875 frames
   - Bitrate: 3.478 Kbs
 - [06:54:38] Reencoding: VID_00146, Pass 1 of 1
 - [06:56:01] Video Encode complete
 - [06:56:01] Processing audio tracks
 - [06:56:01] Multiplexing M2TS
 - [06:56:09] Processing: VID_00147 (3 of 10)
 - [06:56:09] Extracting A/V streams [VID_00147]
 - [06:56:24] Reencoding video [VID_00147]
   - Rate/Length: 29,970fps, 10.823 frames
   - Bitrate: 3.430 Kbs
 - [06:56:24] Reencoding: VID_00147, Pass 1 of 1
 - [06:57:20] Video Encode complete
 - [06:57:20] Processing audio tracks
 - [06:57:20] Multiplexing M2TS
 - [06:57:25] Processing: VID_00148 (4 of 10)
 - [06:57:25] Extracting A/V streams [VID_00148]
 - [06:57:42] Reencoding video [VID_00148]
   - Rate/Length: 29,970fps, 14.470 frames
   - Bitrate: 3.096 Kbs
 - [06:57:42] Reencoding: VID_00148, Pass 1 of 1
 - [06:58:55] Video Encode complete
 - [06:58:55] Processing audio tracks
   - Track 4353 (eng): Keeping original audio
 - [06:58:55] Multiplexing M2TS
 - [06:59:05] Processing: VID_00149 (5 of 10)
 - [06:59:05] Extracting A/V streams [VID_00149]
 - [06:59:34] Reencoding video [VID_00149]
   - Rate/Length: 29,970fps, 20.148 frames
   - Bitrate: 5.297 Kbs
 - [06:59:34] Reencoding: VID_00149, Pass 1 of 1
 - [07:01:28] Video Encode complete
 - [07:01:28] Processing audio tracks
 - [07:01:28] Multiplexing M2TS
 - [07:01:48] Processing: VID_00150 (6 of 10)
 - [07:01:48] Extracting A/V streams [VID_00150]
 - [07:02:27] Reencoding video [VID_00150]
   - Rate/Length: 29,970fps, 24.178 frames
   - Bitrate: 5.451 Kbs
 - [07:02:27] Reencoding: VID_00150, Pass 1 of 1
 - [07:04:49] Video Encode complete
 - [07:04:49] Processing audio tracks
 - [07:04:49] Multiplexing M2TS
 - [07:05:17] Processing: VID_00151 (7 of 10)
 - [07:05:17] Extracting A/V streams [VID_00151]
 - [07:05:27] Reencoding video [VID_00151]
   - Rate/Length: 29,970fps, 5.735 frames
   - Bitrate: 3.157 Kbs
 - [07:05:27] Reencoding: VID_00151, Pass 1 of 1
 - [07:05:59] Video Encode complete
 - [07:05:59] Processing audio tracks
 - [07:05:59] Multiplexing M2TS
 - [07:06:03] Processing: VID_00152 (8 of 10)
 - [07:06:03] Extracting A/V streams [VID_00152]
 - [07:06:52] Reencoding video [VID_00152]
   - Rate/Length: 29,970fps, 31.473 frames
   - Bitrate: 5.277 Kbs
 - [07:06:52] Reencoding: VID_00152, Pass 1 of 1
 - [07:10:02] Video Encode complete
 - [07:10:02] Processing audio tracks
 - [07:10:02] Multiplexing M2TS
 - [07:10:37] Processing: VID_00166 (9 of 10)
 - [07:10:37] Extracting A/V streams [VID_00166]
 - [07:10:49] Reencoding video [VID_00166]
   - Rate/Length: 23,976fps, 1.465 frames
   - Bitrate: 5.820 Kbs
 - [07:10:49] Reencoding: VID_00166, Pass 1 of 1
 - [07:11:16] Video Encode complete
 - [07:11:16] Processing audio tracks
 - [07:11:16] Multiplexing M2TS
 - [07:11:24] Processing: VID_00169 (10 of 10)
 - [07:11:24] Extracting A/V streams [VID_00169]
 - [07:11:37] Reencoding video [VID_00169]
   - Rate/Length: 23,976fps, 7.200 frames
   - Bitrate: 3.961 Kbs
 - [07:11:37] Reencoding: VID_00169, Pass 1 of 1
 - [07:13:06] Video Encode complete
 - [07:13:06] Processing audio tracks
 - [07:13:06] Multiplexing M2TS
[07:13:13]PHASE ONE complete
[07:13:13]PHASE TWO - Rebuild Started
 - [07:13:13] Rebuilding BD file Structure
[07:13:58] - Encode and Rebuild complete
[07:13:58] Writing BD structure to ISO file
 - ImgBurn completed successfully
 - RIDDICK_G51 folder removed.
 - WORKFILES folder removed.
[07:26:00] JOB: RIDDICK_G51 finished.
[Options]
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
AUDIO_TO_KEEP=dut;eng;nld;und;
SUBS_TO_KEEP=dut;eng;nld;und;
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
FULL_AVCHD=0
REMOVE_WORKFILES=1
REMOVE_OUTPUT=1
REMOVE_IMPORT=1
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23450
PRIORITY_CLASS=1
TARGET_SIZE=23500
AUTO_BURN=2
QUICK_EXTRAS=0
MINIMIZE_TO_TRAY=1
OPEN_GOP=0
MOVIE_ONLY_LOOP=1
USE_FILTERS=0
USE_LAVF=0
DGDECNV=1
VERBOSE_STATUS=1
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=1
SD_TO_1080=0
CONVERT_WIDE=1
AUTO_BLANK=0
UNMASK_CHAPTER=1
ENABLE_TEST=1
ENABLE_BLANKING=0
BLANK_THRESHOLD=60
MULTIPROCESS=1
VERSION=0.46.0.14
COMPLETION_BEEP=1
BEEP_SOUNDFILE=C:\Program Files (x86)\ImgBurn\Sounds\Success.wav
MOVIEONLY_TYPE=0
ALTCRF=20
ALT_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
WIDE_PERCENT=40
WIDE_OFFSET=.85
RESIZE_1440=0
RESIZE_720=0
OUTPUT_3D=1
NEROAAC=1
SD_PROGRESSIVE=1
MKV_CHAPTERS=1
SUPTITLE=0
IMPORT_FOLDER=D:\TEMP
OUTPUT_SBS=0
MENU_BACKGROUND=C:\Program Files (x86)\BD_Rebuilder\misc\menuback.jpg
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=1
MENU_PLAY_SEQUENTIAL=1
MENU_START_WITH_MENU=1
OUTPUT_FOLDER=C:\BDRB Rebuilds
IGNORE_3D=1
[Paths]
WORKING_PATH=C:\TEMP\
SOURCE_PATH=I:\
DGIndexNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\DGIndexNV.exe
DGDecNV=C:\Program Files (x86)\BD_Rebuilder\Tools\dgdecnv\DGDecodeNV.dll
DirectShowMVCSource=C:\Program Files (x86)\BD_Rebuilder\Tools\MVCtoAVI.exe\DirectShowMVCSource.dll
NeroAACPath=C:\Program Files (x86)\BD_Rebuilder\Tools\neroaacenc1.5.1\win32\neroAacEnc.exe
[03/10/14] Checking System Settings
  - BD-Rebuilder v0.46.14 (beta)
  - Working Path Free Space: 629,36GB
  - FFDSHOW: 4504, Ok
  - FFDSHOW MPEG2 set to "libmpeg2":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
  - FRIMEncode:  Ok
  - FRIMDecode:  Ok
[03/10/14] Systems Settings Check complete
** edit ** just played the LAVF rebuild and BDRB does detect the pip streams in that mounted iso and the pip stream works as expected. So the problem seems related between the new code and DGdecNV
the total difference in size between the 2 iso's is 21.8GB for the dgdecNV build (non-working pip) and 21.2GB for the LAVF build (working pip)
Old 10th March 2014, 12:52   #19532  |  Link
If you download and use an old version of TSMUXER, just be aware that I will not accept bug reports. There are sections of code in BD-RB that rely on the newere version.
Old 10th March 2014, 19:21   #19533  |  Link
Sharc
@jdobbs
Just wondering: Could there be a relation between Ch3vr0n's report and my Quick-Play Backup problem?
It seems that the Quick-Play issue exists only for discs with Secondary Video and DTS Express.
@Ch3vr0n: Is the secondary video stream actually missing in the multiplexed .m2ts, or is it only missing in DB-RB's GUI (your 2nd picture)?
Old 10th March 2014, 21:17   #19534  |  Link
Ch3vr0n
Its completely missing in the dgdecnv rebuild. The audio is there but the video isn't. Using x264s lavf the internal frameserver it all works normally. Video and audio present and working.
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Old 10th March 2014, 21:57   #19535  |  Link
Have you tried it more than once with DGDecNV? Is it also missing in the working folder?
Old 10th March 2014, 22:14   #19536  |  Link
Ch3vr0n
I'll run a second job, but the pip steams were demuxed there were 3 .vc1 streams. 1 For the main movie and 2 of arround 400mb for the pip streams
** edit ** 2nd dgdecnv job is running now
Old 10th March 2014, 22:36   #19537  |  Link
Sharc
In my case, MediaInfo reports the secondary video stream included as Video#2 in the encoded .m2ts. However, when I try to watch it with MPC-HC all I get is the secondary audio (2-channel), but no video.
Old 10th March 2014, 23:26   #19538  |  Link
Have you tried it on a standalone?
Old 10th March 2014, 23:37   #19539  |  Link
Sharc
Yes, but as I wrote the Quick-Play Backup feature does not start from the Quick-Menu (black TV Screen only, and "no video" message on TV after some time). The IMPORT backup -- my workaround -- works as expected, but IMPORT removes the secondary video. Chicken and egg .....
My standalone is rather old BDP-S360.
Old 11th March 2014, 15:19   #19540  |  Link
Ch3vr0n
so i let the job run overnight and just got back to it. Mounted, BDRB scanned, same thing. DTS-E audio streams are present, pip video streams arent with the DGdecNV rebuild. After demuxing the 3 vid_00037.vc1 streams exist, it's just that the 2 for the pip streams don't get muxed back in. movie is "Chronicles of Riddick". Volume name "Riddick_G51"
