2nd January 2020, 13:00 | #18161 | Link | |
The issue with the Client shutdown hangs ripbot has been fixed in this or the previous version, but it could be nice to know when it happend! I will have a look at MDegrain when I get home. Atak: Thanks for fixing and hope you had a good new year. |
2nd January 2020, 16:42 | #18162 | Link | |
ByteShare
Catching up on things...
I see RipBot264 v1.25.0 Core 2020.01.01 as the most uptodate, did the stalling/timeouts get resolved by this version? Still need help with this? I posted something about this when trying to help Ryushin: https://forum.doom9.org/showthread.p...63#post1892063 Quote:
3rd January 2020, 00:24 | #18163 | Link | |
Grumpy Old Man.
Haven't heard from you since last year, lol, your last post was #17979. This version seems to be pretty good, there's only one question I have about it, and that hasn't been addressed yet. (see https://forum.doom9.org/showpost.php...ostcount=18160). No thanks, I got the filters figured out (with some help).
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 3rd January 2020 at 03:25. |
4th January 2020, 05:14 | #18164 | Link |
Grumpy Old Man.
Some weird problems with DE (latest build)
Hey guys,
So my first use of this build (in anger), and I could NOT get any Servers to connect to the Client...as soon as you choose what Server you want from the Client screen, it creates and error log in TCP Com's, and it looks like it's looking for the wrong port. I have several screen shots that I hope will show what's going on..I don't know whether it's just me, or the HOT weather today, it's a baking 46° Celsius !!!!! Anyway, here's the link:- https://www.mediafire.com/file/7ihak..._Error.7z/file
4th January 2020, 11:48 | #18165 | Link | |
1) stop saying that EmcodingClient is listening at wrong ports. Everything is fine. Tcpservers on client use ports from 1001 to 1016. On other hand servers use 1000 to 16000 to avoid conflicts.
2) server can not Access that cmd file using network Path. Enter that Path in Explorer to see If shared folder is acessible. Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 4th January 2020 at 12:25. |
4th January 2020, 12:27 | #18166 | Link | |
Grumpy Old Man.
I wasn't aware it uses differing ports, in normal operation...one doesn't notice that, when everything is working OK. I don't understand why I got this error today, when the last time I used RB (2 days ago) everything was running well. The only difference being the latest update. So I will double check the sharing, next time I using.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 5th January 2020 at 10:26. |
4th January 2020, 12:30 | #18167 | Link | |
Grumpy Old Man.
Australia is suffering the worst drought & bush fire's, in our short history
4th January 2020, 12:43 | #18168 | Link |
Personally I have been noticing global warming since 90s. We used to have always so called white christmas almost every year. Now IT is just a history. Every year winter is milder and shorter. Instead of winter we just have cold autum at the moment. Spring is also very short. Last year we had Rapid change from 10C to 20C+ in first week of april. In other words IT was sudden jump to summer season.
4th January 2020, 17:48 | #18169 | Link | |
bug reports
1) Adding new audio profiles currently has no effect on the 2-Pass KBPS calculations with Lock Size on. To reproduce, add two new AC3 profiles to Audio.txt: Code:
5.1 FFMPEG AC3 512 kbps [cbr] 5.1 FFMPEG AC3 576 kbps [cbr] Note: this may only affect some 5.1 AC3 profiles because I don't recall noticing this with "2.0 FFMPEG AC3 384 kbps [cbr]". I've only done a handful of jobs with the new profiles, so it obviously needs more testing. I'll let you know if I discover new details. 2) The program still has a problem with Unicode characters. This is a longstanding issue, but I just retested it on 1.25. To reproduce, rename a test file to "Tést.mkv". Add as a new job. The audio track list will be empty ([NO AUDIO]). Related note: as I recall from long ago, having Unicode characters in the output's file name would cause another error during the muxing process. I'm can't test it now, unfortunately, but the steps to reproduce would be: have a regular input "Test.mkv", set the output name as "Tést.mkv", start the job, wait for an error on the final stage. 3) The program also has two slight problems with intentional periods in output names: Everything after the last period gets trimmed. To test, try renaming output to "BAD.NAME" (without .MKV). It will save as BAD.MKV. To avoid the problem, the .MKV extension part should be added to the file's name: entering "BAD.NAME.MKV" won't trim the name but will show as "BAD NAME.MKV" in the job's window. This is also a problem for titles that should contain periods ("Dr. Dolittle", "Mr. Robot", etc.). I love that the program auto-removes periods from input names on demuxing ("test.file.S01E01.pilot.episode" becomes "test file S01E01 pilot episode"), but ideally, once you edit it manually, it should allow and keep the changes you make. I found these naming issues a long time ago, so now I just routinely remove Unicode and periods from names and rename afterward, but I thought I'd mention them nevertheless. Hope it helps. |
4th January 2020, 17:50 | #18170 | Link | |
1) Go to ...\RipBot264\Tools\AviSynth plugins\Scripts\Custom\ 2) Create a custom script, name it something like like AddSideBorders_2x2.avs. Edit it in a text editor to include this: Code:
#AddSideBorders video=AddBorders(video,2,0,2,0) 3) In the AviSynth tab of the job, go to the second screen and select your script from the CUSTOM SCRIPT dropdown menu. Preview. That's it. If you just want to add black bars based on the aspect ratio, the custom scripts folder already has AddBorders16by9.avs for 16:9. Copy it and adjust its values for whatever aspect ratio you desire. |
4th January 2020, 23:01 | #18172 | Link |
4th January 2020, 23:11 | #18174 | Link |
Encoding speed in fps
5th January 2020, 00:35 | #18175 | Link | |
Grumpy Old Man.
It's certainly not going to get better, any time soon (if at all), and I really pity the current & future generations growing up, and coming into this world
5th January 2020, 00:44 | #18176 | Link |
Grumpy Old Man.
MDegrain options.....
So enough of that doom & gloom.
Could you please give an explanation for this :- https://forum.doom9.org/showpost.php...ostcount=18160 Mainly the MDegrain situation....
5th January 2020, 00:48 | #18177 | Link |
There is nothing to explain.
5th January 2020, 00:55 | #18178 | Link |
Grumpy Old Man.
OK, but there's a reference to MDegrain 1 2 & 3 in the .ini file.
There's exceptions for them in the MT section. But where are they, to use / enable....they're not in the Denoise drop down, or in the Custom drop down.
5th January 2020, 10:47 | #18179 | Link | |
Grumpy Old Man.
Windows Networks & Sharing sux !!! One thing that really bugs me is when you can connect to another pc, from a pc, but if you try to connect the other way, from the 2nd pc, it won't "talk" to the 1st pc, even with ALL the settings identical. Not sure if that makes much sense, but then neither does this behaviour. I now know why RB & DE can have so many problems, with situations like this, and also poor cables & plugs, doesn't help. I've just updated all the connections on my small encoding "farmlet", I'm now using "Teaming" on all connections, which should greatly decrease the possibility of disconnections & dropouts (hopefully). 2 out of the 6 servers I have in this "farmlet", have this bizarre network connection problem that I mentioned above, they just won't "talk" to the client. But at least I got nearly half way thru my next long encode, so it wasn't all bad.
