26th December 2008, 15:31 | #41 | Link | |
HDConvertToX author
update the linux build (again), just some gui glitch (and fixed the Donate button ... )
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
28th December 2008, 13:53 | #42 | Link |
HDConvertToX author
fixed muxing on No audio (both for linux and windows build)
BHH
29th December 2008, 08:30 | #43 | Link |
@buzzqw: did you find a workaround for http://forum.doom9.org/showthread.php?t=140261 ? (strange connection between sample rate and bitrate when encoding to aac audio)
29th December 2008, 17:30 | #44 | Link |
HDConvertToX author
well.. i don't pass sample rate to mencoder , i let mencoder select it (or can be selected by user) (and i use only mencoder, not ffmpeg)
can you use sox as a prefilter for sampling ? BHH
29th December 2008, 19:46 | #46 | Link |
HDConvertToX author
autox264 can handle input file with multiple audio tracks (change pid in audio options) , BUT can output only one audio track at time
BHH
29th December 2008, 21:21 | #47 | Link | |
say you got a stereo source with 380kBit/s@48kHz and you want a 60kBit/s@48kHz stereo aac file with you end up with 96+kBit/s instead of 60kBit/s. So the problem is that the output bitrate strongly depends on the output sample rate if you just take the sampel rate of the input (48kHz) you can't get a bitrate around 60kBit/s you always end somewhere between 80kBit/s-160kBit/s and as far as I could test it then there's no way of knowing what the output size will be. All in all it isn't really a problem if it doesn't bother you if you get a 60kBit/s or a 132kBit/s audio output. (doesn't kill you for normal dvd encodes aiming for 1CD+ but it's really a pain if you want some low bitrate encodes for the net; that's what I needed when I stumbled over this problem. ) Haven't found a workaround for it myself and for low datarates I now use neroaacenc, just wanted to know if you were aware of the problem and may be knew a way to fix it. Cu Selur |
29th December 2008, 22:10 | #48 | Link |
HDConvertToX author
understud, that a pita
i will encode some sample files at different audio bitrate with autox264... just to look at audio bitrate thanks for the input BHH
31st December 2008, 08:45 | #49 | Link |
HDConvertToX author
update windows build
now autox264 propose the same input folder as output folder when saving with extension "mkv" autox264 set automatically mux to mkv BHH
2nd January 2009, 13:16 | #50 | Link |
HDConvertToX author
update the windows build (later for linux)
added support for multi audio BHH
4th January 2009, 23:29 | #51 | Link | |
Hi , thanks for this prog..
Question : How would I go about a non-cropped , Anamorphic encode to an mkv - encode at original res then use mkvmerge to set DAR ? Problem - Have noted that even when I set the cropping to all zero , clicking anywhere on the cropping tag re-enters values into the crop fields. (and conversely - when changing the crop fields to zero it changes the output resolution away from what was previously set) Another problem I got is that when trying to encode - audio is processed but then everything just stops - does not get to trying to encode video , just halts after the audio.(the terminal window closes and nothing else happens) I pasted the encode line directly into a terminal window and got the following : Quote:
5th January 2009, 09:07 | #52 | Link | |
HDConvertToX author
you are using a very old mencoder build
":b_adapt=2" , set the b adapt to 1 "me=tesa" , set to a lower value (or update the mencoder build...) BHH
5th January 2009, 17:01 | #53 | Link |
HDConvertToX author
update both builds (win and linux)
better ffmpeg encoding better ffmpeg path detection added support for NO video encoding (will encode only audio) BHH
9th January 2009, 15:20 | #55 | Link |
HDConvertToX author
i can't compile for PPC sorry
but autox264 is FOOS, so if you have a license of purebasic you can compile BHH
10th January 2009, 10:36 | #56 | Link |
HDConvertToX author
update to 0.13
update both builds, windows and linux added support for encoding with x264 (via avisynth) added support for decoding with avisynth (and encoding with x264) , using dgavcdec, ffmpegsource, directshowsource added support for copy audio/copy video/no audio/no video better encoding with ffmpeg now autox264 is a multi encoder (x264/ffmpeg/mencoder) for h264 codec!
14th January 2009, 09:49 | #58 | Link | |
HDConvertToX author
if you download autox264 AND applications pack (first post) when you start the application, it will find automatically the new decoding/encoding capabilities in case of use avisynth (dgavcdec or ffmpegsource or dss) mencoder is used only for audio encoding, while autox264 will build a minimal avisynth script (crop/resize/denoise/filtering as requested, and of course decoding with dg/ff/dss) and will encode with x264 it works for linux (under wine) too BHH
14th January 2009, 14:12 | #60 | Link | |
HDConvertToX author
what's source file ? could you provide a sample ? and last dumb question: have you hit "Analyze with..." ? BHH
gui, linux, mencoder, windows, x264 |
