28th March 2016, 01:14 | #37221 | Link | |
28th March 2016, 01:16 | #37222 | Link |
@madshi,
Would it be possible to start a thread where test images are available for download? By that, I mean the unaltered, original image. I am new to this but have discovered the following:
Image hosting recommendations would also be beneficial to those looking for a place to host their images.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 28th March 2016 at 01:18. |
28th March 2016, 14:10 | #37224 | Link | |
The diacritic thing just seem like a madVR flaw. It just doesn't allow me to use them. I prevents me from using nine keys, so it's pretty significant. I don't see how "Ctrl+Alt+1" is relevant. That's neither "alt+[something]" nor does it include a character with a diacritic mark (like these: íöüóőúáűé) I tried Ctrl+Alt+Q/W, which works here also. But not with only Alt as a modifier. |
28th March 2016, 15:53 | #37225 | Link | |
it kind of creates on effect of double lining where anti bloat 100 was so unsharp i didn't really notice this. FHD->UHD with crisp edges 1.5 upscale refinment is already clearly highlighting this effect. and that for all anti bloat super xbr settings. even super xbr anti bloat 25 isn't as sharp as super xbr 100 and every higher anti bloat setting isn't as sharp as spline 3. so here is the main issue upscale refinement is needed with super xbr anti bloat which has issues with crisp edges. |
28th March 2016, 16:40 | #37227 | Link |
Glad to hear it. I tried out the 36x line drivers with my old config, but I went back to the 355.98: it's faster and steadier.
28th March 2016, 18:00 | #37228 | Link |
Using the latest 0.90.17 madVR I've encountered a glitch where if I keep resizing the MPC window so that the scaling changes just right, the brightness of the video becomes washed out. However, unchecking linear and sigmoidal light options in the down/upscaling menu removes the glitch.
Normal - http://i.imgur.com/4UpFebN.jpg Glitching - http://i.imgur.com/UF7I9Cx.jpg I'm watching an anamorphic DVD transfer. I couldn't quickly reproduce this glitch on 4:3 or similar content. I tried on/offing the newest options, including "scale chroma separately, if..." but only turning LL/SL off makes this glitch go away. |
28th March 2016, 19:08 | #37229 | Link |
Don't know if this has been reported, but since version 0.90.16 there is a problem with dxva deinterlacing for me. The picture is extremely pale when deinterlacing is active.
I'm using Nvidia 960 with latest driver. Last edited by krille; 28th March 2016 at 19:10. |
28th March 2016, 19:33 | #37230 | Link | |
Questions: - Why does 1080p Image Doubling works fine without drops, delays, and glitches in Exclusive FullScreen mode, but not in Windowed mode? Does it have something to do with D3D11 running only in FullScreen mode..? - Why do people say that Image Doubling (2x - always) makes the image look "different", not necessarily "better"? Its OBVIOUSLY better! All the details are finer and there is less ringing. I also have another slightly off-topic inquiry: - Only 4:4:4 mode can fully benefit from Chroma and Luma upscaling, doubling, and several other madVR image-improving settings, unlike 4:2:2 mode which cannot fully benefit from the same settings, although it does benefit from those settings partially. I have several displays - one running in 4:4:4 mode and another in 4:2:2 mode (let's not get into why). As far as I understand, SubSampling is highly related to how Chroma and Luma are used and displayed, which makes me wonder - would/does 4:2:2 mode benefit more from Chroma-related image improvement settings or Luma-related image improvement settings? I do see an obvious improvement from using Luma Image Doubling (set to Always) on my TV in 4:2:2 mode. Last edited by XMonarchY; 28th March 2016 at 19:45. |
28th March 2016, 20:00 | #37231 | Link | |||
if you see a clear improvement why even argue? Quote:
because chroma is not luma. |
28th March 2016, 20:16 | #37232 | Link | |
That's just what I observed from the image though. Last edited by AngelGraves13; 28th March 2016 at 20:19. |
28th March 2016, 20:46 | #37233 | Link |
I'm have some testing ahead of me but I hope for the new SR section AB an AR settings will help with ringing artifacts when used in combination with Enhance Details. It's disappointing to hear that they're reported as less useful for SR that other types of processing though.
28th March 2016, 20:55 | #37234 | Link | |
Are you sure enhance details is the problem? I'm not sure it touches the outside of objects, which is where the ringing would occur. See this comparison of SuperRes with anti-bloating: http://forum.doom9.org/showthread.ph...83#post1762283.
28th March 2016, 21:36 | #37235 | Link |
For hires photos SSIM downscaling w/ AR+AB100% seemed like the best compromise. I couldn't see any obvious differences between relaxed and strict AR. I vote for whatever uses the least GPU cycles.
28th March 2016, 21:45 | #37236 | Link | |
28th March 2016, 22:41 | #37237 | Link |
I think I can now retire NEDI+SR and replace it with "super-xbr, anti-bloating:75". It's almost as good as NEDI+SR at minimizing blocking and gibbs artefacts and will use much less GPU. Note: I always have enhance detail: 1.0 pre-resize.
28th March 2016, 23:03 | #37238 | Link |
Kid for Today
Antibloat appears too strong in the new sxbr doubling options.
Nope, all is well with .15 whatever SD going dark in windowed mode or 720p going dark in FSE, it's actually downscaling antibloat that triggers it in combination with NNEDI3 luma-only doubling as I just found out. |
28th March 2016, 23:19 | #37239 | Link | |
I'm trying to create a profile group under my display device and after creating the group I cannot enter text in certain text fields without focus jumping to a section in the tree above my profile group. The fields I have trouble with are the names for the profile/profile group and my profile selection rules. To elaborate, my profile group only has "display modes" in it. If I try to enter text in the fields I mentioned, the selection jumps above the profile group to "color & gamma". If I include calibration, color & gamma, and display modes in the PG, then the focus jumps up to "properties". I did the usual things like rebooting and upgrading to 0.90.17 to make sure this wasn't a bug that had been fixed. It doesn't happen when I make profile groups under scaling algorithms. Thanks.
mmm...muffins |
