2nd June 2019, 07:23 | #82 | Link |
from the readme.
ThreadLevel - This parameter will set the priority level of the threads created for the processing (internal multithreading). No effect if threads=1. 1 : Idle level. 2 : Lowest level. 3 : Below level. 4 : Normal level. 5 : Above level. 6 : Highest level. 7 : Time critical level (WARNING !!! use this level at your own risk) Default : 6 |
2nd June 2019, 10:20 | #83 | Link | |
Broadcast Encoder
That's kinda nice, thank you. Tested and working on Windows XP, however, as the other previous releases, XP SSE4.2 produces a code that is not compatible with Windows XP: Link It's looking for the function libm_sse2_exp2 inside LIBMMD.DLL for whatever reason and it doesn't work. As to the SSE2 one, it works, as always: Link Thank you again anyway, Frank. Last edited by FranceBB; 2nd June 2019 at 13:57. |
8th June 2019, 17:14 | #85 | Link |
I've messed-up on resampler my files management between my VS versions, commited but not pushed, result the build was made with only some parts of the fixes (but still the output was not bad or incorrect).
If you see this post and have already downloaded the 3.1.2 version, re-download it, and sorry for the inconvenience.
My github. |
14th July 2019, 10:00 | #86 | Link |
Hello, I been trying to transition from using megui 32 bit to megui 64 bit with avisynth+ 64 bit in the hopes of seeing a speed increase during encode and slowly looking for the 64+ filters equivalents but having problems with this plugin.
My problem is the debilinear and debicubic and am I reading correct that this is essentially is an update to that plugin with multi-threading and a 64+ version as I don't see any 64 bit version plugin for this filter. As far as I am aware this is the only for that exists. http://avisynth.nl/index.php/Debilinear http://avisynth.nl/index.php/Debicubic The issue I am running into is that it doesn't have the code "bool lsb_inout" and its telling me when I use another script called DebilinearM found here. On AvsPmod 64 bit states "script error: DebilinearResizeMT does not have a named argument "lsb_inout" (path DebilinearM_v1.3.1.avsi, line 67) (New File, line 82)". As another user wrote the nnedi3_resize16 code works just fine with the lsb's for it which I use and need to make the change so I thought maybe this was an oversight. But both Debilinear and Debicubic don't seem to work and are missing the "lsb_inout" argument as I also used DeBilinearResizeMT by itself without the additional script above and it did not work with lsb_inout input. Not sure if DebilinearY and DebicubicY work, can this be confirmed? I used the one in the x64\Release_W7_AVX2 folder for this as I think I'm suppose to use this for my Ryzen 5 machine. Also, off topic is there a EdgeCleaner 64 bit version for avisynt+ same for warpsharp? I only been using http://avisynth.nl/index.php/AviSynth%2B_x64_plugins |
15th July 2019, 17:07 | #87 | Link |
The "Dexxxx" versions are included within the ResampleMT, read the doc of it, and read also here.
They are not an upgrade/update of the previous version, they do the same thing, but they are totaly rewritten from scratch, and there is no intended link between the parameters with my version and the original version. If some parameters between both version happen to have the same purpose, it's just by luck. So, yes, there is no lsb_inout parameter in my version.
My github. Last edited by jpsdr; 15th July 2019 at 17:13. |
16th July 2019, 06:20 | #88 | Link | |
Thanks for replying. I've read the documentation several times which is why I thought it was strange that the nnedi3_resize16 lsb's work as intended and thought perhaps the Debilinear and Debicubic missing these parameters were simply oversights in addition the documentation advice to work in 16 bit or float. Also, another one using IResize with success.
Maybe I'm just misunderstanding. I'm trying to understand. Quote:
Perhaps give an example if you don't mind on how to apply this 16 bit as I am not seeing it. Essentially, I'm trying to get this to work in a 16 bit field using the DebilinearM script as mentioned in my previous post. Since you mention that you don't have the original code asking if this function could be implemented maybe asking too much. Therefore, I have to ask if you are aware of any other Debilinear plugins available for avisynth+? Maybe I am not looking hard enough but I just do not see them. I might have to give VaporSynth a look if there is none. Last edited by dREV; 16th July 2019 at 07:28. Reason: more details |
16th July 2019, 15:30 | #89 | Link |
have a look here http://avisynth.nl/index.php/AviSynth%2B#Deep_color
See My Avisynth Stuff |
16th July 2019, 17:38 | #90 | Link |
It's possible that this :
#For exemple, if the source file is a 1280x720 8 bits video : Spline36ResizeMT(1920,1080,src_left=-0.2) # or Spline36Resize(1920,1080,src_left=-0.2) # To revert : ConvertBits(16) # or ConvertBits(32) DeSpline36ResizeMT(1280,720,src_left=-0.2) ConvertBits(8) # If you want to revert back to 8 bits video Code:
#For exemple, if the source file is a 1280x720 8 bits video : Spline36ResizeMT(1920,1080,src_left=-0.2) # or Spline36Resize(1920,1080,src_left=-0.2) # To revert : DeSpline36ResizeMT(1280,720,src_left=-0.2)
My github. Last edited by jpsdr; 16th July 2019 at 17:44. |
17th July 2019, 09:35 | #91 | Link | |||
The issue I ran into while it did work by itself given the code above I can't do anything about the sharpness of the source. I cannot soften that parameter so it doesn't look like jagged edges (this is with using anti-aliasing filter) and this is where DebilinearM comes into play. Found at the very bottom of http://avisynth.nl/index.php/Debilinear in the mediafire link. Using the thr parameter I can soften the amount of descaling sharpness thing it does on the very same source used in the testing for DebilinearResizeMT. Code:
/* DebilinearM v1.3.1 DebilinearM is a wrapper function for the Debilinear and Debicubic plugins that masks parts of the frame that aren't upscaled, such as text overlays, and uses a regular ResizeX kernel to downscale those areas. It works by downscaling the input clip to the target resolution with Debilinear or Debicubic, upscaling it again, comparing it to the original clip, and masking pixels that have a difference greater than the specified threshold. ##### Requirements ##### Plugins: Debicubic Debilinear Dither MaskTools2 Scripts: ResizeX Color formats: YV12 */ function DebilinearM(clip input, int target_width, int target_height, int "thr", int "expand", int "inflate", \ string "kernel", int "taps", float "a1", float "a2", bool "cubic", float "b", float "c", \ bool "chroma", bool "lsb_inout", int "showmask") { # Default settings and other variable assignment thr = Default(thr, 10) expand = Default(expand, 1) inflate = Default(inflate, 2) kernel = Default(kernel, "Spline36") cubic = Default(cubic, false) chroma = Default(chroma, true) lsb_inout = Default(lsb_inout, false) showmask = Default(showmask, 0) Assert(target_width > 0, "DebilinearM: target width must be greater than 0") Assert(target_height > 0, "DebilinearM: target height must be greater than 0") Assert(thr >= 0 && thr <= 255, "DebilinearM: thr must be in the range 0 to 255") Assert(showmask > -1 && showmask < 3, "DebilinearM: showmask must be 0, 1, or 2") w = input.Width() h = lsb_inout ? input.Height()/2 : input.Height() uvint = chroma ? 3 \ : 1 # Resizing input_8bit = lsb_inout ? input.DitherPost(mode=-1) : input cubic ? \ Eval(""" dbi = chroma ? input.Debicubic(target_width,target_height, b=b, c=c, lsb_inout=lsb_inout) \ : input.DebicubicY(target_width,target_height, b=b, c=c, lsb_inout=lsb_inout) dbi_8bit = chroma ? input_8bit.Debicubic(target_width,target_height, b=b, c=c) \ : input_8bit.DebicubicY(target_width,target_height, b=b, c=c) dbi2 = lsb_inout ? dbi_8bit.ResizeX(w,h, kernel="Bicubic", a1=b, a2=c, chroma=chroma) \ : dbi.ResizeX(w,h, kernel="Bicubic", a1=b, a2=c, chroma=chroma) """) \ : Eval(""" dbi = chroma ? input.Debilinear(target_width,target_height, lsb_inout=lsb_inout) \ : input.DebilinearY(target_width,target_height, lsb_inout=lsb_inout) dbi_8bit = chroma ? input_8bit.Debilinear(target_width,target_height) \ : input_8bit.DebilinearY(target_width,target_height) dbi2 = lsb_inout ? dbi_8bit.ResizeX(w,h, kernel="Bilinear", chroma=chroma) \ : dbi.ResizeX(w,h, kernel="Bilinear", chroma=chroma) """) rs = input.ResizeX(target_width,target_height, kernel=kernel, taps=taps, a1=a1, a2=a2, chroma=chroma, lsb_in=lsb_inout, lsb=lsb_inout) # Masking diffmask = mt_lutxy(input_8bit,dbi2, "x y - abs", U=uvint, V=uvint).mt_binarize(threshold=thr, U=uvint, V=uvint) diffmask = showmask == 2 ? diffmask.DebilinearM_expand(expand=expand, U=uvint, V=uvint) \ .DebilinearM_inflate(inflate=inflate, U=uvint, V=uvint) \ : diffmask.ResizeX(target_width,target_height, kernel="Bilinear", chroma=chroma) \ .mt_binarize(threshold=3, U=uvint, V=uvint) \ .DebilinearM_expand(expand=expand, U=uvint, V=uvint) \ .DebilinearM_inflate(inflate=inflate, U=uvint, V=uvint) merged = lsb_inout ? Dither_merge16_8(dbi,rs,diffmask, u=uvint, v=uvint) \ : mt_merge(dbi,rs,diffmask, U=uvint, V=uvint) return showmask > 0 ? diffmask \ : merged } # DebicubicM alias function DebicubicM(clip input, int target_width, int target_height, int "thr", int "expand", int "inflate", \ string "kernel", int "taps", float "a1", float "a2", float "b", float "c", \ bool "chroma", bool "lsb_inout", int "showmask") { return DebilinearM(input,target_width,target_height,thr,expand,inflate,kernel,taps,a1,a2,true,b,c,chroma,lsb_inout,showmask) } # Helper functions function DebilinearM_expand(clip input, int "expand", int "U", int "V") { return expand > 0 ? DebilinearM_expand(input.mt_expand(mode="both", U=U, V=V), expand-1) \ : input } function DebilinearM_inflate(clip input, int "inflate", int "U", int "V") { return inflate > 0 ? DebilinearM_inflate(input.mt_inflate(U=U, V=V), inflate-1) \ : input } My script involves the implementations of what's in image 02: Code:
Image 01 (left)(by itself) via AviSynth+ 64 bit ConvertBits(32) DeBilinearResizeMT(1280,720,accuracy=2) Image 02 (right) via Avisynth+ 32 bit dither_convert_8_to_16() ly = DebilinearM(1280,720,thr=01,lsb_inout=true) # Debilinear lc = nnedi3_resize16(1280*2, 720*2,lsb_in=true,lsb=true,kernel_d="Spline64",kernel_u="Spline64",src_top=0.0,src_left=0.50) # lu = lc.UtoY() lv = lc.VtoY() YtoUV(lu,lv,ly) Dither_out() The above script (at least from what I read from others) allows upscaling the chroma, I don't understand it myself but results on the quality of both the image and colors are better then simply by itself. I've also recently found another script that's even greater that requires both DebilinearM and Debilinear.dll with even more depth to detail, colors, and debanding. Also, I don't understand why your code had src_left=-0.2 when I used it it did not match the source I had when taking screenshot. The image 02 doesn't do this as if it does it won't match my 1080p source and when I downsize it via avspmod and photoshop (where I do my comparisons from). I had read here on Doom9 that for chroma it's src_left=0.50. Would it be possible to do the above with this plugin as is? From what I'm perceiving it may not be so. Sorry for having to repeat myself and sorry for the long post. If not I'll give VaporSynth a look as I don't want to waste your time anymore with my questions. Last edited by dREV; 19th July 2019 at 18:48. Reason: forgot to add something, typos and grammar |
17th July 2019, 17:05 | #92 | Link |
The code was just an exemple of what Dexxxx parameters must be, linked to the xxxx parameters.
Don't see any specific sense in the value themselve. I used src_left in the exemple, but it could has been any other src_xxx. I'll update my post, as it seems it can lead to misunderstanding.
My github. Last edited by jpsdr; 17th July 2019 at 17:19. |
17th July 2019, 18:55 | #93 | Link |
here an update for DebilinearM https://pastebin.com/bS8s4Chn
ColorBars(width=1280, height=720, pixel_type="yv12") BilinearResize(1920,1080) dither_convert_8_to_16() ly = DebilinearM(1280,720,thr=01,lsb_inout=true, DeResizeMT=true) # Debilinear lc = nnedi3_resize16(1280*2, 720*2,lsb_in=true,lsb=true,kernel_d="Spline64",kernel_u="Spline64",src_top=0.0,src_left=0.50) # lu = lc.UtoY() lv = lc.VtoY() YtoUV(lu,lv,ly) Dither_out() you need update ResizeX https://forum.doom9.org/showthread.p...61#post1837361
See My Avisynth Stuff Last edited by real.finder; 21st July 2019 at 03:33. |
19th July 2019, 18:39 | #94 | Link | ||
I also read all of the posts after the ResizeX link you gave above and I wanted to ask some questions to clarify if I understood it correct. But I think I should ask it over at your thread instead of here so I don't go off topic. I also have another script that I briefly mentioned above that maybe you can help me understand why it adds artifact (not sure if that's the term for it) and another issue added with it that requires another color profile that may or may not conflict with one another with the "YV12" I see in your example script. If you don't mind that is once I play around with the filter. Last edited by dREV; 19th July 2019 at 18:43. Reason: stuff |
21st July 2019, 02:44 | #95 | Link |
new update for speed (in HBD only, will not see speed up in lsb)
21st July 2019, 07:10 | #96 | Link |
Thanks. Made a post on your thread. https://forum.doom9.org/showthread.p...64#post1879764
