Old 19th April 2014, 21:19   #20041  |  Link
raul124
raul124's Avatar
Would Intel processor (i7 4770k) be faster?
raul124 is offline   Reply With Quote
Old 19th April 2014, 21:25   #20042  |  Link
Ch3vr0n
that one does support intel quicksync, so yes it would be (alot) faster
Old 19th April 2014, 22:15   #20043  |  Link
emilio99
Hmm, I don't find Information if my Intel Processor supports quicksync?
http://ark.intel.com/de/products/657...Cache-3_30-GHz
Here is a log from Bold 3D, i cancelt after 6 hours when it startrt encoding the next file...
[04.19.14] BD Rebuilder v0.47.04 (beta)
[17:15:15] Source:  BOLT_00001
  - Input BD size: 32,03 GB
  - Approximate total content: [01:36:21.775]
  - Target BD size: 22,95 GB
  - Windows Version: 6.1 [7601]
  - MOVIE-ONLY mode enabled
  - Quality: Highest (Very Slow), ABR
  - MVC 3D Output Mode enabled
  - Decoding/Frame serving: FRIMDecode
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
  - Audio [2] set to default.
- Resuming from previously started job.
[17:15:19] PHASE ONE, Encoding
 - [17:15:19] Processing: VID_00002 (1 of 2)
 - [17:15:20] Reencoding video [VID_00002]
   - Rate/Length: 23,976fps, 71.283 frames
   - Bitrate: 29.994 Kbs
   - Using FRIMEncoder for MVC encoding
 - [17:15:20] Reencoding: VID_00002, Pass 1 of 1
 - [22:47:27] Video Encode complete
 - [22:47:27] Processing audio tracks
   - Track 4353 (deu): Reencoding audio to AC3...
 - [22:52:02] Processing: VID_00003 (2 of 2)
 - [22:52:02] Extracting A/V streams [VID_00003]
 - [22:57:44] Reencoding video [VID_00003]
   - Rate/Length: 23,976fps, 67.341 frames
   - Bitrate: 29.866 Kbs
 - [22:57:44] Reencoding: VID_00003, Pass 1 of 1
emilio99 is offline   Reply With Quote
Old 19th April 2014, 22:47   #20044  |  Link
In order to take advantage of the Quick-Sync you'd have to first make sure the video processor is enabled, and then add FRIM_SW_DECODE=0 and/or FRIM_SW_ENCODE=0 to your INI file. Software decoding/encoding is the default.
jdobbs.softworks@gmail.com
Old 20th April 2014, 05:04   #20045  |  Link
HWK
HWK's Avatar
@ emilio99, jdobbs advice does not apply to you. Your processor is based on xeon and these processor are workstation based with no gpu or quicksync tech.
Old 20th April 2014, 09:53   #20046  |  Link
emilio99
Damn That's sound not good.... but there are so many possible speedups like CUDA or Hyper-Threading??
I actually tried a new recode with the two FRIM-Parameters but with no effect:
Speed: 0,19x ETA: 04:08:15 FPS: 4,53
Old 20th April 2014, 12:19   #20047  |  Link
Hajnal
good fast
Hajnal is offline   Reply With Quote
Old 20th April 2014, 16:55   #20048  |  Link
sparkyar
I have an i7 2600, anyone noticed quality differences between "Software" and "Quick Sync enabled" FRIMencoder? thx
sparkyar is offline   Reply With Quote
Old 20th April 2014, 17:31   #20049  |  Link
@Hajnal
That's pretty impressive. I'm usually hanging around 10fps -- and you're using a higher quality mode than I normally do.
Old 20th April 2014, 19:56   #20050  |  Link
DMagic1
DMagic1's Avatar
Man these 70+ fps guys are killing me. It takes me 10-12 hours for most films. I know I need an upgraded but dang.
DMagic1 is offline   Reply With Quote
Old 20th April 2014, 23:32   #20051  |  Link
I can get those kinds of speeds on 2D encodes with X264 and DGDecodeNV -- but never when using FRIMEncode.
Old 21st April 2014, 11:33   #20052  |  Link
Hajnal
(2D) - Decoding/Frame serving: X264/LAVF - Quality: Ultra High Quality (Extremely Slow) 4-6fps
(2D) - Decoding/Frame serving: FRIMSource - X264/LAVF Quality: Ultra High Quality (Extremely Slow) ~3fps
(3D) - Decoding/Frame serving: FRIMSource - 70-80fps (u=2; u= 1:quality - 7:speed)
Old 21st April 2014, 13:57   #20053  |  Link
Ughh... I get a lot higher rates than that with 2D and X264! But it's been a long time since I tested "Ultra High Quality" mode.
Are those speeds using ABR with X264 (like FRIM), or are they pass-2 speeds from a 2 pass encode?
JMHO, but ultrahigh quality is almost always overkill. That's why it is "hidden" from the menu. It might be more closely related to u=1 in FRIM. But since I couldn't see a difference between 2 and 1 for the increased time, I didn't enable u=1 in BD-RB.
[Edit]
I just tested X264/LAVF with "Ultra High Quality" in one pass ABR mode on a 1920x1080 source, and I'm getting about ~11-14fps. I get slightly higher with DGDecNV. I'm not sure if 2x speed increase would qualify as "a lot". With "High Quality" mode, which is as high as I ever use, I get 28fps on the same source (using LAVF).
Based on your results, I may want to consider adding an option to allow FRIM to be used as the encoder on 2D sources (for use by those with Quick-Sync capabilities).
Old 21st April 2014, 14:28   #20054  |  Link
DK
DK's Avatar
once again:
thanx for all your hard work and effort
donation was done
Old 21st April 2014, 14:49   #20055  |  Link
Originally Posted by DK View Post
once again:
donation was done
My sincere thanks to you for the support.
Old 21st April 2014, 18:32   #20056  |  Link
emilio99
Another question:
I always set default language to another language than english,
but when I play the movie, its always set to english???
Old 21st April 2014, 19:11   #20057  |  Link
I'm confused by the second 2D setting. You can't have FRIMSource set and LAVF at the same time. I'd be interested to know what speed you get with X264 and FRIMSource in HW mode.
Old 21st April 2014, 19:16   #20058  |  Link
Another question:
I'd need more information. If it is a full backup, then the language is going to default to that set in the original authoring. I'll do a check to make sure movie-only "set default" language is working properly.
Old 21st April 2014, 20:22   #20059  |  Link
Hajnal
good quality (bd50/25 conversion) = Extremely x264 settings
Old 21st April 2014, 21:36   #20060  |  Link
emilio99
It's Movie Only Mode.
Thx
