3rd May 2014, 20:55 | #20201 | Link | |
3rd May 2014, 22:50 | #20203 | Link | |
This has happened with other movie(can not remember the title) where the playlist was also composed of more than one stream. |
3rd May 2014, 23:45 | #20204 | Link | |
I tested encoding "Delivery Man" and I get the same anomaly, the subtitles stop right at the connection point between the first and second M2TS. It has to be something peculiar about this title (or the SUP) -- as I have lots of multipart examples that don't exhibit this issue. Last edited by jdobbs; 3rd May 2014 at 23:48. |
4th May 2014, 17:57 | #20205 | Link | |
Thanks Wally |
4th May 2014, 20:17 | #20206 | Link |
All the elements of all the playlists under "Other Movie-Only Playlist" will not be considered extras by BD-RB during making a Full Backup.
Is this statement correct? Thanks for the help in advance! Edit: Yes, it is. They are considered as main content as they should be! Great job, jdobbs! Last edited by mparade; 4th May 2014 at 20:54. |
5th May 2014, 16:10 | #20207 | Link |
Frim
Removed the encoder choice menu item. FRIM as an encoder choice for 2D causes too many issues. For those who would like to test it further, you can reenable it by adding ENCODER_MENU=1 to the config/ini file. Help, newbie here. Attempted to add "ENCODER_MENU=1" to config/ini in 0.47.06 but still does not show as an option under settings as it does in 0.47.05. Thanks |
5th May 2014, 17:46 | #20208 | Link | |
ENCODER_MENU=1 ENCODER=1 Note that ENCODER may already be in the INI, you just have to change the value. Sorry about that. |
5th May 2014, 19:54 | #20209 | Link |
BD-RB: BD5 output size varies
Hello,
This is my first post, even though I've been using the awesome BD-RB for a while now. I'm no expert, but am familiar with most options. Am sure there is a lot I must learn I'm here to ask for some help.. I have an issue that has baffled me for some time. First, let's just say I like to encode Full BDs to BD25 and BD5. For the most part, BD5 results are amazing. My preferred BD-RB SETUP settings for BD5 are as follows: ==Either v0.47.04 or v0.47.06== --------------------------------------------- Audio Language: English (only) Subtitle Language: English and Spanish (only) Video Encoding Options: Resize 1920x1080 to 1280x720 Use Deinterlacer Process 3D to 2D Audio Encoding Options: Do not convert DTS to ACS (Blu-ray only) Do not reencode AC3 (Blu-ray only) Keep HD Audio for BD25/Alternate intact Alternative Decoding Options: none (i have tried X264's internal LAVF, but have read it's ok to uncheck, since there is no difference) General Encoding Options: Strict AVCHD for BD5/9 movie only Beep at job completion --------------------------------------------- Config File: [Options] VERSION=0.47.0.6 ENCODER=0 MODE=3 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=1 MOVIEONLY_TYPE=0 ALTCRF=20 ALT_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng;spa; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=1 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=1 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 DGDECIM=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=1 DGDECNV=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23500 [Paths] --------------------------------------------- My issue has to do with output size for BD5. Typically, I'd expect approximately 4.25GB size (settings show target is 4.36GB). This is great and most BD's encode near to that number (4.16 to 4.25). Over the past year, I've noticed some BD's encode to smaller output sizes, from 4.09GB down to 3.58GB. This struck me as odd, and I've tried several methods to "work around" this issue, to no avail. I'm hoping someone can help me fix this situation. Recently, I've noticed there is a correlation with M2TS Bitrate and total Frames. The correlation is this. On a BD5 of approx 4.16 to 4.25GB, Total Bitrate x Total Frames ~ 700,000,000+. Not sure what that number represents, only know that it's very consistent. The actual range is approx. 690,000,000 to 710,000,000 (since output size varies, as mentioned above). I've never seen the bitrate too high to fit on a DVD-R. On the other hand, about 1 or 2 out of 10 BDs are encoding too small (outside the variation), due to video bitrate sizes. Below are examples of low video bitrates: Code:
AC3=640 [05/05/14] BD Rebuilder v0.47.06 (beta) [13:31:32] Source: TRANSFORMERS_00010 - Input BD size: 42.11 GB - Approximate total content: [02:23:27.307] - Target BD size: 4.36 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Resize: 1080p to 720p enabled - Auto Quality: High Quality (Default), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [13:31:39] PHASE ONE, Encoding - [13:31:39] Processing: VID_00010 (1 of 1) - [13:31:39] Extracting A/V streams [VID_00010] - [13:38:39] Reencoding video [VID_00010] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 206,369 frames - Convert: 1280x720, 23.976fps, 206,369 frames - Bitrate: 2,693 Kbs - [13:38:39] Reencoding: VID_00010, Pass 1 of 2 [13:38:55]PHASE ONE aborted by user request ---------------------- AC3=448 [05/05/14] BD Rebuilder v0.47.06 (beta) [13:45:12] Source: TRANSFORMERS_00010 - Input BD size: 42.11 GB - Approximate total content: [02:23:27.307] - Target BD size: 4.36 GB - Windows Version: 6.1 [7601] - MOVIE-ONLY mode enabled - Resize: 1080p to 720p enabled - Auto Quality: High Quality (Default), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 - Resuming from previously started job. [13:45:20] PHASE ONE, Encoding - [13:45:20] Processing: VID_00010 (1 of 1) - [13:45:23] Reencoding video [VID_00010] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 206,369 frames - Convert: 1280x720, 23.976fps, 206,369 frames - Bitrate: 2,907 Kbs - [13:45:24] Reencoding: VID_00010, Pass 1 of 2 [13:45:35]PHASE ONE aborted by user request Now, I realize this is very approximate, but I think it's relevant. I've tried searching here and on google for something relating to this issue. No luck until today. I found a post here on Doom9 which is slightly related: Link: http://forum.doom9.org/showthread.ph...d5&page=11#204 I also found a bitrate calculator which kind of confirms my theory (also via one of Doom9's threads): Link: http://tools.twanwintjes.nl/index.ph...vchdcalculator It estimated the bitrate for BD5 should be 3438 Kbps (using AC3=640) Could it be due to an internal x264 bitrate calculator that we have no control over? Is there any solution for my dilemna? Any help is much appreciated!! Thank you! -=K=- Last edited by kaminar; 5th May 2014 at 22:47. |
6th May 2014, 10:08 | #20210 | Link |
@kaminar
The video bitrate depends on: - Target size (e.g. 4.36 GB) - Duration of the movie (= number of frames/framerate) - Number of audio streams you want to keep and audio format - Number of subtitles you want to keep - Multiplexing overhead (which itself depends on the audio format) Apparently you aborted both of your examples before completion, assuming that the video bitrate is "low". Did you ever complete and burn these 2 projects to disc, and if so, how was the resulting fill factor (in %) of these discs? If it is in the order of 95% there is nothing to worry as you won't notice a visual difference compared to a 100% filled disc. Secondly, it looks like you kept the DTS audio format. Uncheck "Do not convert DTS to AC3 (Blu-ray only)" in the Settings/Setup, and you should then get a video bitrate around 3400 kbps. |
6th May 2014, 12:00 | #20211 | Link | |
Yes, I've completed them before..total output size is in the range of ~85% filled when completed, but I will try again today. TBH, the video doesn't look bad. The sound is great. It just nags at me that it could look 20%+ better (video, not total output), lol. Will chime in again later. -=K=- |
6th May 2014, 12:43 | #20212 | Link | |
I noticed the same thing as you, Kaminar; consistent undersizing relative to what I want - but in my case it is on the BD-25 target size. My solution was to simply use a custom target size. I now specify 24200 MB as a matter of course, and my disc fills are consistently 97 to 98% - can't remember the last time I had an oversize. I would suggest just taking the default BD-5 size and add 5 to 10% and see what happens. If it ends up too large then back off a bit.
You'll have people say that you are risking bad read/writes at the edge of the disc, but you are burning to a single-layer medium, like i am, so that risk would manifest itself only in the credits for a movie-only rebuild (I presume that's what you're doing). Having said that, I've never seen a problem at the end of a disc - not once. I use respectable media, of course: Verbatim. Quote:
I went back and looked at my old log files to see when I made this change. In fact, it was 2 years ago; Apr. 2012. Prior to that I had used the default setting for BD-25. But I started to notice that, at some point, my rebuilds started to seem smaller than I recalled in the past, with ImgBurn reporting fill sizes in the low 90% range, where I had been more used to the upper-mid 90% range. At this point I can't say if this was mere perception on my part - lots of water under the bridge at this point - but I do recall deciding that I had to deviate from the default setting. My custom size is only 3% larger (24200 vs 23500) so it's not a big modification. [/edit] Last edited by RobertM; 6th May 2014 at 14:02. |
6th May 2014, 14:43 | #20213 | Link |
@kaminar
Please post the log after you've modified the DTS setting. My best guess is that the DTS file is huge and is the cause of the lower bitrate. It isn't unusual for DTS sources to take up a quarter to half of a BD-25 for the audio alone. Also, most audio formats are very inefficient to mux into an M2TS file, and require 14-15% overhead -- so you have to add 14% to the size of the DTS file. In addition, as Sharc commented, I notice that you decided to keep HD audio. From that standpoint you were pretty lucky with this encode. With "Keep HD" set there are some discs in which the source might take up the entire BD-5 for DTS HD audio alone.... You pretty much always need to reencode to AC3 to backup a BD-5 disc. Last edited by jdobbs; 6th May 2014 at 14:50. |
