Old 14th July 2012, 14:34   #15341  |  Link
Originally Posted by bikerman View Post
ok, that didn't work... 2 mins after I posted my last message I got BSod again.... (
Your system isn't stable. If you are overclocked -- you need to slow down your processor. X264 is the ultimate challange for overclocking. Also check your processor's heatsink for dust/dirt and clean if necessary. Reseat your memory modules.
Old 14th July 2012, 14:36   #15342  |  Link
Originally Posted by HiQ123 View Post
Hm, okay
Just for reference -- I've done the US version of "Pirates of the Caribbean" with no issues.
Old 14th July 2012, 14:47   #15343  |  Link
HiQ123
I will try it again...
HiQ123 is offline   Reply With Quote
Old 14th July 2012, 15:48   #15344  |  Link
Make sure you rip it again.
That error is coming from TSMUXER -- it is saying that one of the streams (usually an audio stream) has buffer requirements that aren't reasonable for something compliant with BD. That normally means a bad rip. Interestingly, in the exceptionally large number of discs I've done in testing, I don't remember ever actually seeing that error myself. It has been reported by others. I rip with AnyDVD HD.
Old 14th July 2012, 16:56   #15345  |  Link
Weirdo
BD Rebuilder (Error Condition) experienced an error 3304 [18:52:49] - CreateBDFiles() 00055 3304. If I press OK will it abort? Do you need log files? I can only see ErrLog.txt which only mentions that message.
edit: Prior to encoding, I set inspect.exe to display all ok. At the bottom: Resizing Subtitle_01 to 1280x720 PID: 4608, JAPANESE.
Weirdo is offline   Reply With Quote
Old 14th July 2012, 18:07   #15346  |  Link
AmigaFuture
AmigaFuture's Avatar
JDobbs,
Any thoughts about "The Incredibles"? I've notice with my "The Incredible Hulk (2008)" main move audio does the same thing when setting to re-render the DTS to AC3. Thanks.
Old 17th July 2012, 16:24   #15347  |  Link
bikerman
Hi
I have no problems with any other apps, and this problem only started since the latest build of bdrebuilder... I am not overclocking either...
is there any way I can go back to previous version to see if it will crash on that version? (it never did before you see)
bikerman is offline   Reply With Quote
Old 17th July 2012, 23:51   #15348  |  Link
omegaman7
omegaman7's Avatar
Hi
I've used the new version more than a dozen times without fault. Given the season(hot weather), I'd look very closely at cooling your computer better?
Old 18th July 2012, 09:00   #15349  |  Link
musiclover
Hi
You can go back by installing the old version and changing te date of your computer to the past.
Old 18th July 2012, 10:53   #15350  |  Link
bikerman
thanks will give it a go
Old 18th July 2012, 10:54   #15351  |  Link
bikerman
hey dude
the cooling is not an issue over here, the weather aint very warm at all! lol
Old 18th July 2012, 14:02   #15352  |  Link
ihmcjacky
I face error when nearly finish the muxing process, Anyone know how to solve this? (I am quite sure it is not the file's problem)
Here is the log
[07/18/12] BD Rebuilder v0.40.10 (beta)
[14:52:59] Source: MISSION_IMPOSSIBLE_(1996)
- Input BD size: 36.47 GB
- Approximate total content: [02:17:08.677]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
[14:53:03] PHASE ONE, Encoding
- [14:53:03] Processing: VID_00351 (1 of 1)
- [14:53:03] Extracting A/V streams [VID_00351]
- [15:20:28] Reencoding video [VID_00351]
- Rate/Length: 23.976fps, 177,792 frames
- Bitrate: 18,689 Kbs
- [15:20:28] Reencoding: VID_00351, Pass 1 of 1
- [19:08:04] Video Encode complete
- [19:08:04] Processing audio tracks
- [19:08:05] Multiplexing M2TS
[19:34:22]PHASE ONE complete
[19:34:22]PHASE TWO - Rebuild Started
- [19:34:22] Rebuilding BD file Structure
- [19:34:22] CopyDirStructure() 00052 1200
- [19:40:20] CopyDirStructure() 00052 1200
[19:54:02] - Aborted at user request
ihmcjacky is offline   Reply With Quote
Old 18th July 2012, 15:14   #15353  |  Link
Ch3vr0n
where's the rest of the log?
Old 18th July 2012, 18:33   #15354  |  Link
Adbear
Hi
What stop code message are you getting?
Adbear is offline   Reply With Quote
Old 19th July 2012, 12:20   #15355  |  Link
bikerman
i don't have time to write it down before is disappears..
however, after turning my clock back, and running the previous version, I did get an error stating that the h.264 (or whatever the number was) had stopped working...
clicked 'close the application' and got another BSoD...
Old 19th July 2012, 12:43   #15356  |  Link
Adbear
then you need to go into your advanced system settings and tell your system not to reboot on bluescreen
Old 19th July 2012, 14:17   #15357  |  Link
bassnut
When you get this message it is most likely do to an unstable system ..... X64 Has Stopped Working ..... Time to look at your OC or what else might be causing your sytem to be unstable.
bassnut is offline   Reply With Quote
Old 20th July 2012, 23:12   #15358  |  Link
Your system isn't stable. Whether you want to accept that doesn't really matter in the context of this thread. It isn't a bug and therefore shouldn't be posted here.
Old 20th July 2012, 23:49   #15359  |  Link
Wizzu
On one of my systems, I can't get bd rebuilder to work on any Blu-Ray with HD audio....
AFTEN errors when encoding AC3.
Here is what I get each and every time:
- [00:01:04] Processing audio tracks
- [00:01:07] Processing audio tracks
- ERROR in attempt to reencode audio (AFTEN) [AUD_00506_4352.AVS]
[00:01:08] - Failed to reencode audio, aborted
I tried everything I could think of: Re-configuring ffdshow, Uninstalling/reinstalling ffdshow, haaali and AVSynth... no joy.
Inspect results seem OK...
- Windows Version: 5.1 [2600]
- FFDSHOW: [3882], Ok
- FFDSHOW VC-1 set "disabled", WMP11, Ok
- FFDSHOW AVC set to "ffmpeg-mt": Ok
- BD Rebuilder v0.40.0.10, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
I compared the settings (ffdshow and bd rebuilder) with my other computer, they are exactly the same.
Both computers run XP SP3.
But... everything works fine on the other computer and not on this one!
I'm at a loss.
Wizzu is offline   Reply With Quote
Old 21st July 2012, 10:44   #15360  |  Link
sonate
I'm at a loss.
It may have more to do with the particular CPU's you are using and compatibility with the two versions of aften.exe BDRB incorporates.
The most ancient CPU's I've used and found workable results with current versions of BDRB are the P4-478 Northwood 3.2 and 3.0 . Maybe you should list what you are using, and if this is the problem possibly swap the CPU with one that is compatible?
sonate is offline   Reply With Quote
