#104 | Link | |
#105 | Link | |
![]() I just started using your program so i'm not quite sure when you need IE, but if its just to open a web link, you can just run a command line argument "start http://www.cnn.com" for instance. It will launch the system default browser. |
#106 | Link |
Biiiill !!! This guy is badmouthing IE !!! (haha, just a bad joke)
![]() Anyways, the EI portion is just for when you open About box. The links in there open with IE by default. I will have to change that since, as it was pointed out earlier, in Windows 7 it is possible to get rid of IE completely. The GUI itself does not use IE or any element of it. |
#108 | Link |
Well, I can't compare MMG to MKVcleaver in that aspect. There is a lot that can go wrong in MMG, that's why they have that message. However, with MKVcleaver it either extracted ok or not ok, that's it. Since mkvextract has only 3 exit codes.
I suppose, users would like to know if all the files extracted fine. I will look at implementing checking for errors from mkvextract. Maybe even add "Finished" message, if it's not too hard, 'cause I'm lazy. ![]() |
#110 | Link |
@sheck
Forgive me if I've overlooked something in the posts to this thread but, in addition to extracting streams, does MKVCleaver have the ability to actually delete the original versions of those same streams from the original source material (after, of course, extracted copies have been saved)? |
#112 | Link |
For example, I have "Title1.MKV", comprised of "VideoA.avc", "AudioA.ac3", and "SubtitleA.pgs", "SubtitleB.pgs", "SubtitleC.pgs", :
1) I load "Title1.MKV" into MKVCleaver 2) I expand the tree in the left window and select "SubtitleA.pgs" to be extracted - and MKVCleaver extracts and saves "SubtitleA.sup" After steps 1 and 2, can MKVCleaver DELETE "SubtitleA.pgs" from my original "Title1.MKV" - so that it would be comprised of only "VideoA.avc", "AudioA.ac3", and "SubtitleB.pgs", "SubtitleC.pgs" (NO "SubtitleA.pgs")? |
#114 | Link | |
#117 | Link | |
Example: If you have mkvfile.mkv and you want to extract it folder A then MKVcleaver would create another folder in folder A - so something like C:\A\mkvfile\attachment1. If that's ok, I could add it to the next release. Everybody else, I would appreciate your opinions on this as well. |
batch extract, extractor, matroska, mkv, mkv batch, mkv decoder, mkvextract |
